X300/X310
Revision as of 15:05, 16 December 2016 by Ettus (Talk | contribs) (Key Component Datasheets)
The Ettus Research USRP X310 is a high-performance, scalable software defined radio (SDR) platform for designing and deploying next generation wireless communications systems. The hardware architecture combines two extended-bandwidth daughterboard slots covering DC – 6 GHz with up to 160 MHz of baseband bandwidth, multiple high-speed interface options (PCIe, dual 10 GigE, dual 1 GigE), and a large user-programmable Kintex-7 FPGA in a convenient desktop or rack-mountable half-wide 1U form factor.
X300
  • Xilinx Kintex-7 XC7K325T FPGA
  • 14 bit 200 MS/s ADC
  • 16 bit 800 MS/s DAC
  • Frequency range: DC - 6 GHz with suitable daughterboard
  • Up 160MHz bandwidth per channel
  • Two wide-bandwidth RF daughterboard slots
  • Optional GPSDO
  • Multiple high-speed interfaces (Dual 10G, PCIe Express, ExpressCard, Dual 1G)
X310
  • Xilinx Kintex-7 XC7K410T FPGA
  • Optional GPSDO
Compatible Daughterboards
  • WBX-120 / WBX-40
  • SBX-120 / SBX-40
  • CBX-120 / CBX-40
  • UBX-160 / UBX-40
  • BasicTX / BasicRX
  • LFRX / LFTX
  • TwinRX
RF Performance Data (with SBX-120)
  • Power Output >10dBm
  • IIP3 (@ typ NF) 0dBm
  • Typical Noise Figure 8dB
Hardware Specifications
X300
  • Current Hardware Revision: 8
  • Minimum version of UHD required: 3.9.0
X310
Physical Specifications
Dimensions
27.7 x 21.8 x 3.9 cm
Environmental Specifications
  • X300/X310 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
X300/X310
X300/X310 Schematics
XC7K325T / XC7K410T FPGA U23 (3,5,8,9,10,18)
AD9146 Dual Channel, 16-Bit, 1230 MSPS DAC U12, U36 (7)
ADS62P48 Dual Channel, 14-Bit 210 MSPS ADC U11, U35 (6)
FIN1002 High Speed Differential Receiver U3, U5, U31, U32 (4)
24LC256T EEPROM U530 (11)
LMK04816BISQ/NOPB_1/3 Jitter Cleaner With Dual Loop PLLs U531 (11)
SY89547LMGTR Multiplexer U506 (12)
SN74AUP1T17 Single Schmitt-Trigger Buffer Gate U6, U519 (12)
TPS54620RGYT Synchronous Step Down SWIFT™ Converter U515 (21); U516 (26)
LT1764EQ-3.3 Voltage Regulator U27 (21); U516 (26)
TPS7A47 Voltage Regulator U28, U532 (21)
LTC3603EUF_TRPBF Monolithic Synchronous Step-Down Regulator U517 (23); U500 (25); U514, U513 (27)
TPS77625_SM Low-Dropout Voltage Regulators U30 (23)
TPS79318_SM Low-Dropout Voltage Regulators U510 (27)
GPSDO
Sensors
Mechanical Information
Weight
With 2x SBX-120: 1.7kg
Drawings
FPGA
  • Utilization statistics are subject to change between UHD releases. This information is current as of UHD 3.9.4 and was taken directly from Xilinx Vivado 2014.4.
X300
1. Slice Logic
|          Site Type         |  Used | Available | Util% |
| Slice LUTs                 | 61622 |    203800 | 30.23 |
|   LUT as Logic             | 52887 |    203800 | 25.95 |
|   LUT as Memory            |  8735 |     64000 | 13.64 |
|     LUT as Distributed RAM |  1878 |           |       |
|     LUT as Shift Register  |  6857 |           |       |
| Slice Registers            | 62961 |    407600 | 15.44 |
|   Register as Flip Flop    | 62961 |    407600 | 15.44 |
|   Register as Latch        |     0 |    407600 |  0.00 |
| F7 Muxes                   |  1209 |    101900 |  1.18 |
| F8 Muxes                   |   150 |     50950 |  0.29 |
3. Memory
| Block RAM Tile    |  409 |       445 | 91.91 |
|   RAMB36/FIFO*    |  398 |       445 | 89.43 |
|     RAMB36E1 only |  398 |           |       |
|   RAMB18          |   22 |       890 |  2.47 |
|     RAMB18E1 only |   22 |           |       |
* Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1
4. DSP
| DSPs           |  123 |       840 | 14.64 |
|   DSP48E1 only |  123 |           |       |
X310
1. Slice Logic
| Slice LUTs                 | 61616 |    254200 | 24.23 |
|   LUT as Logic             | 52885 |    254200 | 20.80 |
|   LUT as Memory            |  8731 |     90600 |  9.63 |
|     LUT as Shift Register  |  6853 |           |       |
| Slice Registers            | 62958 |    508400 | 12.38 |
|   Register as Flip Flop    | 62958 |    508400 | 12.38 |
|   Register as Latch        |     0 |    508400 |  0.00 |
| F7 Muxes                   |  1209 |    127100 |  0.95 |
| F8 Muxes                   |   150 |     63550 |  0.23 |
3. Memory
| Block RAM Tile    |  409 |       795 | 51.44 |
|   RAMB36/FIFO*    |  398 |       795 | 50.06 |
|   RAMB18          |   22 |      1590 |  1.38 |
4. DSP
| DSPs           |  123 |      1540 |  7.98 |
Interfaces and Connectivity
Front Panel
  • JTAG: USB connector for the on-board USB-JTAG programmer
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on daughterboard A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on daughterboard A
  • REF: Indicates that the external Reference Clock is locked
  • PPS: Indicates a valid PPS signal by pulsing once per second
  • AUX I/O: Front panel GPIO connector.
  • GPS: Indicates that GPS reference is locked
  • LINK: Indicates that the host computer is communicating with the device (Activity)
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on daughterboard B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on daughterboard B
  • PWR: Power switch
Rear Panel
  • PWR: Connector for the USRP-X Series power supply
  • 1G/10G ETH: SFP+ ports for Ethernet interfaces
  • REF OUT: Output port for the exported reference clock
  • PCIe x4: Connector for Cabled PCI Express link
  • PPS/TRIG OUT: Output port for the PPS signal
Ref Clock - 10 MHz
Using an external 10 MHz reference clock, a square wave will offer the best phase noise performance, but a sinusoid is acceptable. The power level of the reference clock cannot exceed +15 dBm.
PPS - Pulse Per Second
Front Panel GPIO
Power on state
The hardware power on state and UHD initial state for the front-panel GPIOs is high-Z. For the X3xx, there are no external pull-ups/pull-downs for the GPIO pins, but the FPGAs do have them and they are configured as follows: X3xx: pull-down.
Pin Mapping
  • Pin 1: +3.3V
  • Pin 2: Data[0]
  • Pin 3: Data[1]
  • Pin 4: Data[2]
  • Pin 5: Data[3]
  • Pin 6: Data[4]
  • Pin 7: Data[5]
  • Pin 8: Data[6]
  • Pin 9: Data[7]
  • Pin 10: Data[8]
  • Pin 11: Data[9]
  • Pin 12: Data[10]
  • Pin 13: Data[11]
  • Pin 14: 0V
  • Pin 15: 0V
Note: Please see the E3x0/X3x0 GPIO API for information on configuring and using the GPIO bus.
On-Board LEDs
LED Detail Description
DS1 1.2V power
DS2 TXRX1 Red: TX, Green: RX
DS3 RX1 Green: RX
DS4 REF reference lock
DS5 PPS flashes on edge
DS6 GPS GPS lock
DS7 SFP0 link
DS8 SFP0 link activity
DS10 TXRX2 Red: TX Green: RX
DS11 RX2 Green: RX
DS12 6V daughterboard power
DS13 3.8V power
DS14 3.3V management power
DS15 3.3V auxiliary management power
DS16 1.8V FPGA power
DS16 3.3V FPGA power
DS19 SFP1 link
DS20 SFP1 link active
DS21 LINK link activity
Certificate of Volatility
X300/X310
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
Choosing USRP X310 vs USRP X300
In terms of host bandwidth, interface options, and all other hardware features the USRP X300 and USRP 310 are identical. However, the USRP X310 provides a larger FPGA, a Xilinx XC7K410T, as opposed to XC7K325T. While both options provide a significant amount of free resources for custom FPGA development, the XC7K410T provides additional design margin, which translates to ease of development and future expandability. Most users choose the USRP X310 for their development.
USRP X300 and X310 FPGA Resource Summary
Resource Type USRP X300 (XC7K325T) USRP X310 (XC7K410T)
Count Count
DSP48 Blocks 840 1540
Block Rams (18kB) 890 1590
Logic Cells 326,080 406,720
Slices (logic) 50,950 63,550
For up-to-date information on FPGA resource utilization in the stock FPGA design, please see "USRP 300/X310 FPGA Resources" in the Ettus Research knowledge base (https://kb.ettus.com).
Choosing an RF Daughterboard
With the increased sample rates used by the USRP X300 and USRP X310, these new device can support extended-bandwidth daughterboards. The WBX-120, SBX-120, and CBX-120 are recommended to take advantage of the full bandwidth capability of the USRP X300 and X310. The WBX-120, SBX-120, and CBX-120 have been upgraded from their predecessors (40 MHz) to use 120 MHz baseband filters. You can select your daughterboard based on the center frequency of your primary application.
Daughterboard Frequency Range Bandwidth
WBX-120 50 MHz - 2200 MHz 120 MHz
SBX-120 400 MHz - 4400 MHz 120 MHz
CBX-120 1200 MHz - 6000 MHz 120 MHz
UBX-160 10 MHz - 6000 MHz 160 MHz
TwinRX 10 MHz - 6000 MHz 80 MHz per channel, 160 MHz total
If your application is in the HF frequency range, the LFRX and LFTX are recommended for up to 30 MHz of bandwidth per channel. The BasicRX and BasicTX are ideal for configurations that use an external frontend for tuning and filtering with either an IF or baseband interface.
The USRP X300 and X310 are backward compatible with legacy daughterboards except for the RFX Series and XCVR2450. Please note, while there are two daughterboard slots, the USRP X300/X310 can only support a single TVRX2.
If you plan to transmit or receive over the air, you should also purchase an antenna.
Choosing a Host Interface
The USRP X300/X310 provide three interface options – 1 Gigabit Ethernet (1 GigE), 10 Gigabit Ethernet (10 GigE), and PCI-Express (PCIe). Generally, Ettus Research recommends using 10 GigE to achieve the maximum throughput available from the USRP X300/X310. PCIe is recommended for applications that require the lowest possible latency, which is a desirable characteristic for PHY/MAC research. If your application does not require the full bandwidth of the USRP ™ X300 and X310, the 1 GigE interface serves as a cost-effective fall-back option. Ettus Research provides a complete interface kit for each of these options, which is also shown in Table 3.
Table 3 - Interface Performance Summary
Interface Throughput (MS/s @ 16-bit) Target Recommended Kit
1 Gigabit 25 MS/s Desktop/Laptop Components provided with USRP X300/X310 kit.
For additional connections, purchase the following: SFP Adapter + GigE Cable
10 Gigabit 200 MS/s Desktop 10 GigE Interface Kit
PCI-Express
(PCIe, 4 lane)
200 MS/S Desktop PCI-Express Desktop Kit
Express Card
(PCIe, 1 lane)
50 MS/s Laptop ExpressCard Kit
Figure 2 - Host Interface Options
International Power Supply Options
The power supply provided with the USRP X300/X310 kit is packaged with a power cord that is compatible with power outlets in the US/Japan. If you are not using the USRP X300/X310 in the US/Japan, we recommend purchasing the International USRP X300/X310 Power Cord set.
Option: GPS Disciplined, Oven-Controlled Oscillator (GPSDO)
The USRP X300 and USRP X310 provide the option to integrate a high-accuracy GPS-disciplined oscillator (GPSDO). The GPSDO improves the accuracy of the internal frequency reference to 20 ppb, or 0.1 ppb if the GPS is synchronized to the GPS constellation. When synchronized to the GPS constellation, all USRP ™ devices will also be synchronized in time within 50 ns.
Internal TCXO GPS-Disciplined Clock
Frequency Reference TCXO OCXO
Frequency Accuracy ± 2.5ppm
± 2,500 Hz @ 1 GHz
± 20 ppb
± 20 Hz @ 1 GHz
Frequency Accuracy ± 0.01ppb
(GPS-Disciplined) ~ ± 0.01 Hz @ 1 GHz
GPS Time Sync Accuracy ±50ns to UTC Time**
10 MHz Reference Phase Drift with GPS Sync <±20ns After 1 Hour**
Option: Antenna Kit for GPSDO
The GPSDO Mini Kit will improve the accuracy of the USRP reference clock, even if it does not receive signals from the GPS Constellation. However, to achieve the best accuracy possible, and to achieve global timing alignment across multiple USRPs, Ettus Research recommends the GPSDO Mini Antenna Kit.
Option: General Purpose Input/Output (GPIO) Kit
The USRP X300 and X310 include a DB15 connector on the front panel that provides convenient access to GPIO signals. Each pin can be configured as an input or output, uses 3.3V-level logic, and is protected with basic anti-static circuitry. These pins can be used to control external devices like RF switches and amplifiers, trigger software events on the host, or even provide basic debugging functionality. The USRP GPIO Kit is an affordable option that provides access to these signals with a DB15 cable and a breakout board. The breakout board allows the user to connect external devices through a terminal block. The user can also solder wires and components into the dedicated prototyping area.
Option: Cables for MIMO Expansion
Multiple USRP X300/X310s can be synchronized for coherent operation by sharing a common 10 MHz and 1 PPS signal. We recommend using a star-distribution topology with an OctoClock or OctoClock-G, as seen in Figure 4. This requires matched length cables to be used for both 10 MHz and 1 PPS.
For more information about MIMO operation, please see the MIMO and Synchronization Application Note.
Figure 4 - Star-Distribution of 10 MHz/PPS Signals with OctoClock
Option: USRP X300/X310 Rackmount
The USRP X300/X310 was designed to use a convenient half-wide 1U rack-mount form factor. This allows developers to build high-density MIMO systems in a neat and well organized setup. If the user will be developing in a lab environment, or building a high-channel count system, the 1U Rackmount Assembly is recommended. However, if the user plans to work with the USRP X300/X310 on a desk, the rackmount is not required. Rubber standoffs are mounted on the USRP X300/X310 to avoid direct contact and surface scratching.
Guidance on SFP+ Adapters for Fiber Connectivity on USRP X300/X310
Ettus Research currently offers direct-connect, copper cabling accessories for the USRP X300 and USRP X310. However, it is also possible to use multi-mode fiber instead of copper connections for these devices. In this document, we will provide general guidance on the types of fiber adapters and cables that can be used with these products. General Guidance on SFP+ Adapters
The USRP X Series is compatible with most brands of SFP+ fiber adapters. In some cases, other equipment in the systems such as 1/10 Gigabith Ethernet switches are only compatible with specific brands of SFP+ adapters and cables. As a general rule, we recommend checking compatibility with the switches and network cards in your system before purchasing an adapter.
Ettus Research does test the USRP X Series devices with our 10 Gigabit Ethernet Connectivity Kit and a Blade Networks G8124 1/10 GigE switch. Here are is a list of known-good cables and adapters.
Known-Good Adapters
Known-Good Cables
FAQ
  • What is the bandwidth of the USRP X300/X310
  • How can I program the USRP X300/X310
Like all other USRP models, the USRP X300 and X310 are compatible with the USRP Hardware Driver™ (UHD) architecture. The UHD architecture is a common driver that allows users to develop and execute applications on a host-PC. UHD provides a direct C++ API to control and stream to/from the USRP X300/X310. It also provides compatibility with a variety of third-party software frameworks including GNU Radio, LabVIEW, and Matlab. You may also customize the FPGA image provided with UHD to integrate your own signal processing. For more information about UHD, and supported software frameworks, please see:
  • How do I update the FPGA images and firmware with the latest from UHD
  • How can I modify the FPGA of the USRP X300/X310
The source code (Verilog) for the USRP X300/X310 is available in the UHD repository. The USRP X300/X310 requires ISE 14.4 or newer. The build process leverages the existing CMAKE build system used to compile the host-side driver. A Linux-based setup will provide the best results.
  • How much free space is available in the USRP X300/X310 FPGA
  • What type of PC setup is recommended for use with the USRP X300/X310
  • What frequency range does the USRP X300/X310 cover
  • What components do I need to purchase for a complete USRP X300/X310 system
  • What is the difference between the USRP X300/X310
