B200/B210/B200mini/B205mini
[hide]- 1 Device Overview
- 2 Key Features
- 3 Frontend Specifications
- 4 RF Specifications
- 5 Hardware Specifications
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Mechanical Information
- 11 Enclosures
- 12 FPGA
- 13 Interfaces and Connectivity
- 14 Certifications
- 15 Certificate of Volatility
- 16 Downloads
- 17 FAQ
B200
B210
B200mini
B200mini-i
B205mini-i
Tuning
The RF frontend has individually tunable receive and transmit chains. On the B200 and B200 mini, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is tunable between 50 MHz and 6 GHz.
Gains
All frontends have individual analog gain controls. The receive frontends have 73 dB of available gain; and the transmit frontends have 89.5 dB of available gain. Gain settings are application specific, but it is recommended that users consider using at least half of the available gain to get reasonable dynamic range.
Bandwidths
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
- Maximum Input Power: 0 dBm
RF Performance Data
B200mini / B205mini
B200 / B210
B200
- Current Hardware Revision: 6
- Minimum version of UHD required: 3.8.4
- B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
- Current Hardware Revision: 5
- Minimum version of UHD required: 3.6.0
B200mini
- Current Hardware Revision: 2
- Minimum version of UHD required: 3.9.0
B200mini-i
B205mini-i
- Minimum version of UHD required: 3.9.2
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
- B200mini / B200 / B210 0-40 °C
- B200mini-i / B205mini-i 0-45 °C
Operating Humidity Range
- 10% to 90% non-condensing
B200mini/B200mini-i/B205mini-i
B200mini/B200mini-i/B205mini-i Schematics
B200/B210
Analog Devices AD9364 | RF Transceiver | U1 (2) |
Analog Devices AD9361 | RF Transceiver | U2 (2,8) |
AD9361/AD9364 Product Page | RF Transceiver | - |
Xilinx Spartan-6 Product Page | FPGA | U1 (2,3,4,6); PG1 (6); U18B, U18C (7); U18D (8); U18E, U18F (9); U18G, U18H (10) |
XC6SLX75 / XC6SLX150 | FPGA | |
ADF4001 | Frequency Synthesizer | U101 (1) |
CYUSB3014 | FX3: SuperSpeed USB Controller | U3 (5,6); U13 (5) |
EZ-USB FX3™ Product Page | ||
SKY13317 | Antenna Switch | U801, U810 (8) |
BD3150L50100A00 | Balun | U802, U808, U809, U815 (8) |
PGA−102+ | Amplifier | U804, U817 (8) |
B200mini VXTCXO | VXTCXO (B200mini only) | - |
M9107 | Optional GPSDO (B200/B210 only) | U100 (1) |
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
B200mini
B200
B210
Enclosures
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
B200
Device utilization summary: --------------------------- Selected Device : 6slx75fgg484-3 Slice Logic Utilization: Number of Slice Registers: 15781 out of 93296 16% Number of Slice LUTs: 19987 out of 46648 42% Number used as Logic: 15983 out of 46648 34% Number used as Memory: 4004 out of 11072 36% Number used as RAM: 972 Number used as SRL: 3032 Slice Logic Distribution: Number of LUT Flip Flop pairs used: 24062 Number with an unused Flip Flop: 8281 out of 24062 34% Number with an unused LUT: 4075 out of 24062 16% Number of fully used LUT-FF pairs: 11706 out of 24062 48% Number of unique control sets: 434 IO Utilization: Number of IOs: 172 Number of bonded IOBs: 155 out of 280 55% IOB Flip Flops/Latches: 124 Specific Feature Utilization: Number of Block RAM/FIFO: 144 out of 172 83% Number using Block RAM only: 144 Number of BUFG/BUFGCTRLs: 4 out of 16 25% Number of DSP48A1s: 76 out of 132 57%
B210
Device utilization summary: --------------------------- Selected Device : 6slx150fgg484-3 Slice Logic Utilization: Number of Slice Registers: 29310 out of 184304 15% Number of Slice LUTs: 36486 out of 92152 39% Number used as Logic: 29279 out of 92152 31% Number used as Memory: 7207 out of 21680 33% Number used as RAM: 1752 Number used as SRL: 5455 Slice Logic Distribution: Number of LUT Flip Flop pairs used: 43635 Number with an unused Flip Flop: 14325 out of 43635 32% Number with an unused LUT: 7149 out of 43635 16% Number of fully used LUT-FF pairs: 22161 out of 43635 50% Number of unique control sets: 723 IO Utilization: Number of IOs: 180 Number of bonded IOBs: 163 out of 338 48% IOB Flip Flops/Latches: 148 Specific Feature Utilization: Number of Block RAM/FIFO: 186 out of 268 69% Number using Block RAM only: 186 Number of BUFG/BUFGCTRLs: 4 out of 16 25% Number of DSP48A1s: 152 out of 180 84%
B200mini
Device utilization summary: --------------------------- Selected Device : 6slx75csg484-3 Slice Logic Utilization: Number of Slice Registers: 15949 out of 93296 17% Number of Slice LUTs: 19963 out of 46648 42% Number used as Logic: 16140 out of 46648 34% Number used as Memory: 3823 out of 11072 34% Number used as RAM: 972 Number used as SRL: 2851 Slice Logic Distribution: Number of LUT Flip Flop pairs used: 23859 Number with an unused Flip Flop: 7910 out of 23859 33% Number with an unused LUT: 3896 out of 23859 16% Number of fully used LUT-FF pairs: 12053 out of 23859 50% Number of unique control sets: 429 IO Utilization: Number of IOs: 123 Number of bonded IOBs: 114 out of 328 34% IOB Flip Flops/Latches: 147 Specific Feature Utilization: Number of Block RAM/FIFO: 110 out of 172 63% Number using Block RAM only: 110 Number of BUFG/BUFGCTRLs: 6 out of 16 37% Number of DSP48A1s: 76 out of 132 57% Number of PLL_ADVs: 1 out of 6 16%
B205mini
Device utilization summary: --------------------------- Selected Device : 6slx150csg484-3 Slice Logic Utilization: Number of Slice Registers: 15949 out of 184304 8% Number of Slice LUTs: 19963 out of 92152 21% Number used as Logic: 16140 out of 92152 17% Number used as Memory: 3823 out of 21680 17% Number used as RAM: 972 Number used as SRL: 2851 Slice Logic Distribution: Number of LUT Flip Flop pairs used: 23859 Number with an unused Flip Flop: 7910 out of 23859 33% Number with an unused LUT: 3896 out of 23859 16% Number of fully used LUT-FF pairs: 12053 out of 23859 50% Number of unique control sets: 429 IO Utilization: Number of IOs: 123 Number of bonded IOBs: 114 out of 338 33% IOB Flip Flops/Latches: 147 Specific Feature Utilization: Number of Block RAM/FIFO: 110 out of 268 41% Number using Block RAM only: 110 Number of BUFG/BUFGCTRLs: 6 out of 16 37% Number of DSP48A1s: 76 out of 180 42% Number of PLL_ADVs: 1 out of 6 16%
B200/B210/B200mini - USB 3.0
GPIO
Power on state
Timing Reference Input
- 1-PPS or 10 MHz input
1-PPS
- Maximum: -5V / +5V
- Minimum: 0V / +2.5V
10 MHz
- Maximum: 0V / +5V
- Minimum: 0V / +1.8V
OR
- +10dBm ~ +27dBm
B200/B210
1-PPS
- Maximum: 5V
10 MHz
- Maximum: 15dBm (3.5V into 50 ohms)
China RoHS
Chinese Customers National Instruments is in compliance with the Chinese policy on the Restriction of Hazardous Substances (RoHS) used in Electronic Information Products. For more information about the National Instruments China RoHS compliance, visit ni.com/environment/rohs_china.
B200/B210
Downloads
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - info@ettus.com.
5 Msps | 15.36 Msps | 30.72 Msps | 56 Msps | 61.44 Msps | |
1 RX | 1.92 | 2.112 | 2.184 | 2.508 | |
2 RX | 2.148 | 2.436 | 2.508 | 2.64 | |
1 TX | 2.184 | 2.34 | 2.352 | 2.22 | |
2 TX | 2.76 | 2.88 | 2.904 | 2.64 | |
Full Duplex (1x1) | 2.508 | 2.736 | 2.796 | 3.168 | |
2x2 MIMO | 3.252 | 3.588 | 3.672 | 4.11 | 4.092 |
