BasicTX/BasicRX
Revision as of 18:49, 3 January 2017 by Ettus (Talk | contribs) (Certifications)
The BasicRX/BasicTX daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRX/BasicTX is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
  • 1-250 MHz coverage
  • Real or Complex sampling
Daughterboard Specifications
Frontends
BasicRX
The BasicRX has 4 frontends:
  • Frontend A: real signal on antenna RXA
  • Frontend B: real signal on antenna RXB
  • Frontend AB: quadrature frontend using both antennas (IQ)
  • Frontend BA: quadrature frontend using both antennas (QI)
BasicTX
The BasicTX has 4 frontends:
  • Frontend A: real signal on antenna TXA
  • Frontend B: real signal on antenna TXB
Gains
BasicRX
  • The BasicRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
BasicTX
  • The BasicTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
BasicRX
  • For Real-Mode (A or B frontend): 250 MHz
  • For Complex (AB or BA frontend): 500 MHz
BasicTX
Hardware Specifications
BasicRX
  • Minimum version of UHD required: 3.8.0
BasicTX
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Basic RX
Basic RX Schematics
Basic TX
Basic TX Schematics
Key Component Datasheets
24LC025B EEPROM U1 (1); U52 (1)
ADT1−1WT RF Transformer T1 (1); T2 (1); T50 (1); T51 (1)
Mechanical Information
Drawings
RF Connectors
  • The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
China RoHS
Chinese Customers National Instruments is in compliance with the Chinese policy on the Restriction of Hazardous Substances (RoHS) used in Electronic Information Products. For more information about the National Instruments China RoHS compliance, visit ni.com/environment/rohs_china.
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
