LFTX/LFRX
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz.
Daughterboard Specifications
Frontends
LFRX
The LFRX has 4 frontends:
- Frontend A: real signal on antenna RXA
- Frontend B: real signal on antenna RXB
- Frontend AB: quadrature frontend using both antennas (IQ)
- Frontend BA: quadrature frontend using both antennas (QI)
LFTX
The LFTX has 4 frontends:
- Frontend A: real signal on antenna TXA
- Frontend B: real signal on antenna TXB
Gains
LFRX
- The LFRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
LFTX
- The LFTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
LFRX
- For Real-Mode (A or B frontend): 33 MHz
- For Complex (AB or BA frontend): 66 MHz
LFTX
Hardware Specifications
LFRX
LFTX
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
LFRX
- N or X Series
LFTX
- N or X Series
LFRX
LFTX
Key Component Datasheets
| AD813x | Differential ADC Driver | U2, U3 (1) |
| LT3462 | DC/DC Converter | U3 (1) |
| 24LC025B | EEPROM | U1 (1) |
RF Connectors
- The LFTX / LFRX daughterboard features female SMA connectors for both the TX and RX connectors.
China RoHS
Chinese Customers National Instruments is in compliance with the Chinese policy on the Restriction of Hazardous Substances (RoHS) used in Electronic Information Products. For more information about the National Instruments China RoHS compliance, visit ni.com/environment/rohs_china.
