N200/N210
[hide]- 1 Device Overview
- 2 Key Features
- 3 Compatible Daughterboards
- 4 RF Specifications
- 5 Hardware Specifications
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Mechanical Information
- 11 FPGA
- 13 Certifications
- 15 Recovering the N200/N210
- 16 Downloads
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
N210
- SBX-40
- UBX-40
- WBX-40
- CBX-40
- LFRX / LFTX
- BasicRX / BasicTX
- TVRX2
- DBSRX2
RF Performance Data (with WBX)
- Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
- Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
- Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
- Power Output 15 dBm
- IIP3 (@ typ NF) 0 dBm
- Typical Noise Figure 5 dB
N200
- Current Hardware Revision: 4
N210
Dimensions
22 x 16 x 5 cm
- N200/N210 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
N200/N210
AD9777 | Dual Channel, 16-Bit DAC | U3 (1) |
ADS62P4X | Dual Channel, 14-Bit ADC | U2 (1) |
XC3SD3400AFG676 | FPGA | U1 (2,8,9,10,11,12) |
AD9510 | Clock Distribution IC | U9 (4) |
ET1011C2 | Gigabit Ethernet Transceiver | U12 (6) |
CY7C1354C | Pipelined SRAM | U19 (7) |
MAX232 | Drivers/Receiver | U25 (10) |
Weight
1.2 kg
Drawings
FPGA
N200
Device utilization summary: --------------------------- Selected Device : 3sd1800afg676-5 Number of Slices: 18356 out of 16640 110% (*) Number of Slice Flip Flops: 20466 out of 33280 61% Number of 4 input LUTs: 32968 out of 33280 99% Number used as logic: 28511 Number used as Shift registers: 3945 Number used as RAMs: 512 Number of IOs: 338 Number of bonded IOBs: 331 out of 519 63% IOB Flip Flops: 342 Number of BRAMs: 41 out of 84 48% Number of GCLKs: 6 out of 24 25% Number of DCMs: 1 out of 8 12% Number of DSP48s: 31 out of 84 36%
N210
Device utilization summary: --------------------------- Selected Device : 3sd3400afg676-5 Number of Slices: 18349 out of 23872 76% Number of Slice Flip Flops: 20475 out of 47744 42% Number of 4 input LUTs: 32986 out of 47744 69% Number used as logic: 28529 Number used as Shift registers: 3945 Number used as RAMs: 512 Number of IOs: 338 Number of bonded IOBs: 331 out of 469 70% IOB Flip Flops: 342 Number of BRAMs: 41 out of 126 32% Number of GCLKs: 6 out of 24 25% Number of DCMs: 1 out of 8 12% Number of DSP48s: 31 out of 126 24%
N200/N210
- Gigabit Ethernet
China RoHS
Chinese Customers
N200/N210
For a detailed guide to recovering the N200/N210, please see the N200/N210 Device Recovery application note.
