UBX
Revision as of 18:57, 3 January 2017 by Ettus (Talk | contribs) (China RoHS)
The UBX daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 6 GHz. Coherent and phase-aligned operation across multiple UBX daughterboards on USRP X Series motherboards enables users to explore MIMO and direction finding applications. The UBX daughterboard works interchangeably with other USRP daughterboards and is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The UBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications, on the X Series. Additionally this capability is only available on the X Series devices.
  • Frequency Range: 10 MHz - 6 GHz
  • Versions: 40MHz / 160MHz
  • RF shielding
  • Full duplex operation with independent TX and RX frequencies
  • Synthesizer synchronization for applications requiring coherent or
    phase-aligned operation, supported on USRP X Series motherboards only
Daughterboard Specifications
Features
  • 2 quadrature frontends (1 transmit, 1 receive)
    • Defaults to direct conversion
    • Can be used in low IF mode through lo_offset with uhd::tune_request_t
  • Independent receive and transmit LO's and synthesizers
    • Allows for full-duplex operation on different transmit and receive frequencies
    • Can be set to use Integer-N tuning for better spur performance with uhd::tune_request_t
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
  • Frontend 0: Complex baseband signal for selected antenna
  • Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a UBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
  • Transmit Gains: PGA0, Range: 0-31.5dB
  • Receive Gains: PGA0, Range: 0-31.5dB
Bandwidths
  • UBX: 40 MHz, RX & TX
  • UBX-160: 160 MHz, RX & TX
Sensors
  • lo_locked: boolean for LO lock state
LEDs
  • LOCK: Synthesizer Lock Detect
  • TX/RX TXD: Transmitting on TX/RX antenna port
  • TX/RX RXD: Receiving on TX/RX antenna port
  • RX2 RXD: Receiving on RX2 antenna port
Freq Range
  • 10MHz - 6GHz
Noise Figure
  • 10 MHz - 500 MHz: 3 - 4 dB
  • 500 MHz - 1.5 GHz: 2 - 3 dB
  • 1.5GHz - 6GHz: 4 - 10 dB
RX IIP3 (Max)
  • 10 MHz - 6 GHz: 8 - 9 dBm
RX IQ Imbalance
  • 10 MHz - 6 GHz: < -30dBc
TX Power (Max)
  • 10 MHz - 3 GHz: 20 dBm
  • 3 - 6 GHz: 8 - 20 dBm
TX OIP3
  • 10 - 500 MHz: 41 dBm
  • 0.5 - 3 GHz: 36 dBm
  • 3 - 6 GHz: 26 dBm - 36 dBm
TX IQ Imbalance
  • 10 MHz - 6 GHz: < -30 dBc
Note: The UBX 160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Hardware Specifications
UBX-40
  • Minimum version of UHD required: 3.8.2
UBX-160
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
UBX-40
  • N or X Series
UBX-160
  • X Series only
Phase Synchronization
The UBX daughterboard is capable of phase-synchronous operation, and is recommended for phase-coherent applications. The SBX and TwinRX daughterboards are also recommended for phase-coherent applications.
UBX
UBX Schematics
Key Component Datasheets
MAX2871 Fractional/Integer-N Synthesizer/VCO U3 (3); U9 (5); U19 (7); U23 (9)
ADL5375-05 Quadrature Modulator U22 (8)
LFCN-2250+ Low Pass Filter F1 (3); F24 (7); F34, F35 (10)
LTC5510 Active Mixer U15 (6)
LFCN-490+ Low Pass Filter F12 (5); F15 (6); F26 (7); F31 (9); F33, F36 (10)
HMC624LP4E ATTENUATOR U16 (6)
NBB-400 Amplifier U13 (6); U30 (11)
PHA-1+ Amplifier U31 (11)
ADA4927-2 Differential ADC Driver U6 (4)
ADL5380 Quadrature Demodulator U8 (4)
MGA-62563 Low Noise Amplifier U36 (11)
LFCN-1700+ Low Pass Filter F41 (11)
VMMK-3603 Low Noise Amplifier U34 (11)
LFCN-2600+ Low Pass Filter F14, F17 (6)
855916 SAW Filter F16 (6)
LTC5510 Active Mixer U15 (6); U28 (10)
LFCN-2600+ Low Pass Filter F14, F17 (10)
TCM1-63AX+ RF Transformer T1 (3); T2, T3 (4); T7 (8)
AD8591 Operational Amplifiers U7 (4)
ZXTC2062E6 TRANSISTORS Q1 (6)
HMC624ALP4E ATTENUATOR U16 (6); U29 (10)
LFCN-800+ Low Pass Filter F2 (3); F25 (7)
ADP7104-3.3 CMOS LDO U4, U5 (3); U10, U11 (5); U20, U21 (7); U24, U25 (9); U48 (13)
LTC5510 Active Mixer U28 (10)
24LC024 EEPROM U38, U39 (12)
ADP7104-5.0 CMOS LDO U41, U42, U43, U44, U45, U46, U47 (13)
ZXTC2062E6 TRANSISTORS Q2, Q3, Q4, Q5 (13)
Mechanical Information
Drawings
RF Connectors
  • The UBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
Certificate of Volatility
UBX-40/UBX-160
Important Notes
  • A larger 24W (6V, 4A) power supply is required when using a UBX-40 daughterboard and integrated GPS Disciplined Oscillator accessory together in a USRP2, USRP N200, or USRP N210 device.
  • The UBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
RF Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
