Revision as of 02:49, 16 January 2017 by Ettus (Talk | contribs) (Testing the default FPGA image and building from existing blocks)
AN-823
Date Author Details
2016-07-12 Martin Braun
Nicolas Cuervo
Initial creation
2017-01-10 Team Added “Digital Gain” example
This application note guides a user through basic information on the RFNoC architecture, installing necessary software to develop custom RFNoC blocks, also called Computation Engines (CE), and walks through the steps of creating a custom RFNoC block using an example.
Licensing
The RFNoC code base is open source, including code that executes on the host, as well as code targeted to the USRP hardware (FPGA and microcontroller firmware). As dual-licensed software, RFNoC is available under the open-source GNU Public License version 3 (GPLv3), as well as an alternative, less-restrictive license offered only by Ettus Research. For more information on our licensing policy, please contact [email protected].
Prerequisites
  • Ubuntu 14.04 or 16.04(preferred): Currently PyBOMBs (which can be used to install the Software build tools), is only supported in Ubuntu. Also, a majority of the scripts used during the build process are Linux (Ubuntu) specific. A PC with multiple cores and 8GB+ of RAM is recommended.
  • Xilinx Vivado tools (ver. 2015.4): The specific version depends on the branch and state of the FPGA code. The default install location is /opt/Xilinx/Vivado. Once all of the Software build tools are installed the specific version for the downloaded code can be found in the setupenv.sh file located in the {USER_PREFIX}/src/uhd-fpga/usrp3/top/{DEVICE} directory. Further information can be found here.
  • Software build tools: If UHD can be or has been compiled from source on the development PC then all the necessary software build components are present (PyBOMBS can be used to set all this up and instructions on how to do so are given in a following step).
  • X3xx series or E3xx series device or any future USRP
NOTE:
  • The edition of Xilinx Vivado that is required will depend on the USRP device.
    • X3xx series devices: Design or System editions.
    • E3xx series devices: Design, System or the free WebPack edition.
  • Other operating systems can be used, but the exact steps on how to proceed are not given in this Application Note.
  • In some Linux distributions (e.g. Ubuntu) dash is set as default shell, which may cause some issues. It is recommended to set the shell to bash by running the following commands in the terminal. Choose <No> when prompted by the first command and the second command will validate the that bash will be used.
   $ sudo dpkg-reconfigure dash
   $ ll /bin/sh
  • UHD
  • GNU Radio
  • gr-ettus
   $ sudo apt-get install git
   $ sudo apt-get install python-setuptools python-dev build-essential
   $ sudo easy_install pip
  • Install Git
  • Install pip
  • Install the latest PyBOMBS from its Git repository
  • Add the gr-recipes recipes which are used to install GNU Radio specific software
  • Add the ettus recipes which are used to install Ettus Research specific software
This will do the following:
  • Create a directory in the user’s home directory called rfnoc (any valid directory name will work)
  • Give the prefix an alias of rfnoc ( [-a alias], e.g. –a rfnoc ), which would be the name given to this path. This name will be used in further steps that use PyBOMBS. When creating the first prefix and omitting the alias, the prefix will be setup as the default.
  • Use the rfnoc prefix recipe ( as opposed to a package recipe like gqrx ) to clone UHD, FPGA, GNU Radio, and gr-ettus sources into the ~/rfnoc directory as well as compile and install all the software
NOTE: A user can specify how many cores are used during compile time by specifying the --config makewidth=X argument, where “X” is an integer number. The default is set to 4. If the user only has 4 cores it is recommend to use this argument in the pybombs command to limit the number of cores to <4 (e.g. 3) so that the computer stays responsive. Following are 2 examples, one using less cores and the other using more cores:
   $ pybombs --config makewidth=3 prefix init ~/rfnoc -R rfnoc -a rfnoc
   $ pybombs --config makewidth=7 prefix init ~/rfnoc -R rfnoc -a rfnoc
   $ cd ~/rfnoc
   $ source ./setup_env.sh
Create development environment manually
   $ git clone --recursive -b rfnoc-devel https://github.com/EttusResearch/uhd.git
   $ git clone --recursive -b maint https://github.com/gnuradio/gnuradio.git # master branch is also fine instead of maint
   $ git clone -b master https://github.com/EttusResearch/gr-ettus.git
   $ git clone -b rfnoc-devel https://github.com/EttusResearch/fpga.git
Verify Environment
Running the command “uhd_usrp_probe” with the “--version” flag will verify that the installation has been completed successfully.
   $ uhd_usrp_probe --version
   linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-161- g83150fdd
   4.0.0.rfnoc-devel-161-g83150fdd
   $ uhd_images_downloader
Image Name Included Blocks
usrp_x300_fpga_HG.bit
usrp_x300_fpga_XG.bit
usrp_x310_fpga_HG.bit
usrp_x310_fpga_XG.bit
2x DDC, 2x DUC
usrp_x300_fpga_RFNOC_HG.bit
usrp_x300_fpga_RFNOC_XG.bit
usrp_x310_fpga_RFNOC_HG.bit
usrp_x310_fpga_RFNOC_XG.bit
usrp_e310_fpga.bit
usrp_e310_fpga_sg3.bit
1x DDC, 1x DUC
usrp_e310_fpga_RFNOC_sg3.bit
  • UHD/RFNoC code downloaded and installed
  • FPGA code available
  • A valid RFNoC image on your X3xx or E3xx series device
Inspect default images
   $ uhd_usrp_probe
   |   |     _____________________________________________________
   |   |   |   * DmaFIFO_0
   |   |   |   * Radio_0
   |   |   |   * Radio_1
   |   |   |   * DDC_0
   |   |   |   * DDC_1
   |   |   |   * DUC_0
   |   |   |   * DUC_1
   |   |   |   * DmaFIFO_0
   |   |   |   * Radio_0
   |   |   |   * Radio_1
   |   |   |   * DDC_0
   |   |   |   * DUC_0
   |   |   |   * FFT_0
   |   |   |   * Window_0
   |   |   |   * FIR_0
   |   |   |   * SigGen_0
   |   |   |   * KeepOneInN_0
   |   |   |   * fosphor_0
   |   |   |   * FIFO_0
   |   |   |   * FIFO_1
Build custom image with pre-built RFNoC blocks
A more detailed discussion of this script is given in an upcoming section. For now, compiling an FPGA image that has 2 RFNoC blocks (window and fft<c/ode>) and some <code>FIFOs, is done by running the script with the following arguments.
Example for an X310 USRP:
   $ uhd_image_loader --args “type=x300,addr={IP_ADDRESS}” --fpga-path {USER_PREFIX}/src/uhd-fpga/usrp3/top/x300/build/usrp_x310_fpga_RFNOC_HG.bit
   $ uhd_usrp_probe
   |   |   |   * DmaFIFO_0
   |   |   |   * Radio_0
   |   |   |   * Radio_1
   |   |   |   * Window_0
   |   |   |   * FFT_0
   |   |   |   * FIFO_0
   |   |   |   * FIFO_1
   |   |   |   * FIFO_2
   rfnoc_rx_to_file.cpp
   rfnoc_nullsource_ce_rx.cpp
Getting started with GNU Radio + RFNoC
A good way of getting started with RFNoC in a more tangible fashion is to use GNU Radio. The gr-ettus out-of-tree module (OOT) allows a user to use RFNoC blocks in their local GNU Radio / GNU Radio Companion (GRC) installation. This GNU Radio OOT contains blocks that allow you to configure your FPGA through GRC.
Examples can be run from gr-ettus/examples/rfnoc, provided that the appropriate RFNoC blocks and compiled into the FPGA image currently running on the USRP.
A couple of rules for building GNU Radio flowgraphs:
  • You always need a Device3 object in your flow graph (it does not get connected, see screenshot below).
  • You should have at least two RFNoC blocks connected together, going GNU Radio Block -> RFNoC Block -> GNU Radio Block is not recommended (it will work, but with suboptimal performance).
NOTE: Copy Block: In the RFNoC domain, streams of data can not be split as easily as they are in the GNU Radio domain. The “copy” block depicted in the screenshot above serves the function as a stream splitter . It’s main purpose, when “enabled”, is to copy the samples it is getting at its input and putting then into the output, but here it is also serving as a boundary between a RFNoC-domain and a GNURadio-domain. In the flowgraph above. after this boundary is passed, the data stream can easily be split into the two sinks to have them run simultaneously (standard GNU Radio functionality). It is possible to connect the GNU Radio blocks directly to RFNoC blocks without a “copy” block, but only one would work at a time (the other ones would have to be disabled). Another way to split data streams from the RFNoC- domain is to use the ”RFNoC: split stream” block, which would split the streams in the RFNoC domain, but this is not very useful here as we are, in any case, moving into the GNURadio-domain.
Starting a custom RFNoC block using RFNoC Modtool
RFNoC Modtool Utilization
   $ rfnocmodtool help
   linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-162-g335a1317
   Usage:
   List of possible commands:
Creating an RFNoC OOT Module
   $ rfnocmodtool newmod tutorial
   Creating out-of-tree module in ./rfnoc-tutorial... Done.
   $ ls rfnoc-tutorial/
   apps  cmake  CMakeLists.txt  docs  examples  grc  include  lib  MANIFEST.md  python  README.md  rfnoc  swig
In order to add blocks to your module, navigate to the folder just created and use the add command of rfnocmodtool. Continuing with the example above, run the following:
   $ cd rfnoc-tutorial
   $ rfnocmodtool add [NAME OF THE BLOCK]
   $ rfnocmodtool add gain
   RFNoC module name identified: tutorial
   Block/code identifier: gain
   Add Python QA code? [Y/n] Y
   Add C++ QA code? [y/N] N
   Block NoC ID (Hexadecimal): 1111222233334444
   Skip Block Controllers Generation? [UHD block ctrl files] [y/N] N
   Skip Block interface files Generation? [GRC block ctrl files] [y/N] N
  • Add Python QA code: Not used.
  • Add C++ QA code: Not used.
  • NoC ID: This ID is a Hexadecimal number which serves as identification between the hardware part and the software part of the design. It can be as long as 16 0-9 A-F digits. If a NoC ID is not provided, it will be set to a random number.
  • Block Controllers Generation: The block controllers are the C++ control that the user can apply to the UHD-part of the design. In these files, the user can add more control over this layer of the design. Depending on the complexity of the block it may be possible to add all necessary control using NoCScript (more details on NoCScript can be found in the section labeled UHD Integration). In this case the cpp/hpp block control files generation are not needed. Default is to generate as their existence will be ignored if not edited.
  • Block Interface: Add more design specific functionality to the design at the GNU Radio interface by generating these block-interface files and adding necessary logic. Depending on the complexity of the block it may be possible to add all necessary control using NoC-Script. In this case the block-interface files are not needed. Default is to generate as their existence will be ignored if not edited.
   Adding file 'lib/gain_impl.h'...
   Adding file 'lib/gain_impl.cc'...
   Adding file 'include/tutorial/gain.h'...
   Adding file 'include/tutorial/gain_block_ctrl.hpp'...
   Adding file 'lib/gain_block_ctrl_impl.cpp'...
   Editing swig/tutorial_swig.i...
   Adding file 'python/qa_gain.py'...
   Adding file 'grc/tutorial_gain.xml'...
   Adding file 'rfnoc/blocks/gain.xml'...
   Adding file 'rfnoc/fpga-src/noc_block_gain.v'...
   rfnoc/testbenches/noc_block_gain_tb folder created
   Adding file 'rfnoc/testbenches/noc_block_gain_tb/noc_block_gain_tb.sv'...
   Adding file 'rfnoc/testbenches/noc_block_gain_tb/Makefile'...
   Adding file 'rfnoc/testbenches/noc_block_gain_tb/CMakeLists.txt'...
Creating FPGA portion of custom RFNoC Block
AXI Stream signals:
  • m_axis_data_tdata: Input sample data packets
    • Data coming from host or another CE
  • s_axis_data_tdata: Output sample data packets
    • Data going to another CE or host
  • m_axis_data_tready: Input signal to CE
    • Used to notify CE that downstream CE is ready for data
  • s_axis_data_tready: Output signal to CE
    • Used to notify upstream CE that CE is ready for data
  • m_axis_data_tvalid: Input signal to CE
    • Used to indicate upstream CE has valid data
  • s_axis_data_tvalid: Output signal to CE
    • Used to indicate to downstream CE that CE has valid data
  • m_axis_data_tlast: Input signal to CE
    • Used to delimit packets from upstream CE
  • s_axis_data_tlast: Output signal to CE
    • Used to delimit packets to downstream CE
Settings Bus signals:
  • set_stb: Assert to write set_data to register at set_address
  • set_addr: Register address to set
  • set_data: Data to set
  • rb_data: Data to read back
  • rb_strobe: Assert to read rb_data from register at set_address
For the gain example block the following architecture is desired (the blue signal has both “I” and “Q” data):
Open the file rfnoc-tutorial/rfnoc/fpga-src/noc_block_gain.v that contains the RFNoC block skeleton code that was created when the $ rfnocmodtool add gain command was run and modify the following sections.
For the setting register that will hold the constant value as well as the read back register:
   wire [15:0] gain;
   setting_reg #(
   sr_gain (
     .clk(ce_clk), .rst(ce_rst),
       case(rb_addr)
         8'd0 : rb_data <= {48'd0, gain};
         8'd1 : rb_data <= {32'd0, test_reg_1};
         default : rb_data <= 64'h0BADC0DE0BADC0DE;
       endcase
    end
And for the processing section:
   assign m_axis_data_tready = s_axis_data_tready;
   assign s_axis_data_tvalid = m_axis_data_tvalid;
   assign s_axis_data_tlast = m_axis_data_tlast;
   wire [15:0] i = m_axis_data_tdata[31:16];
   wire [15:0] q = m_axis_data_tdata[15:0];
   assign s_axis_data_tdata = {i_mult_gain[15:0], q_mult_gain[15:0]};
NOTE: Because the multiplication process can occur in the same clock cycle there is no need for handshaking with the AXI tready, tvalid and tlast signals and therefore they are simply passed through the gain RFNoC block.
Creating and running HDL testbenches
In order to make the coding iteration process more efficient, it is recommended to create testbenches for all RFNoC blocks before compiling them into the FPGA image. This allows for flaw and/or bug detection early in the design. RFNoC Modtool provides the structure and files ( e.g. noc_block_{USER_BLOCK_NAME}_tb ) for the testbenches of each of the OOT blocks that are added with the $ rfnocmodtool add command.
Below is a figure that shows the structure of the testbench created by the RFNoC Modtool.
  • noc_block_gain_tb.sv: this is a System Verilog file, in which user custom tests are to be located.
This is the only file that needs modified.
  • Makefile: This file determines the directives that run the simulation.
   initial begin : tb_main
     string s;
     logic [31:0] random_word;
     logic [63:0] readback;
     logic [15:0] gain;
   random_word = $random();
   $sformat(s, "User register 0 incorrect readback! Expected: %0d, Actual %0d", readback[15:0], random_word[15:0]);
   gain = 100;
   tb_streamer.write_user_reg(sid_noc_block_gain, noc_block_gain.SR_GAIN, gain);
     fork
       begin
       expected_value = i*gain;
Create a build directory, verify directory location is rfnoc-tutorial and run:
   $ mkdir build && cd build/
If PyBOMBS used, run:
   $ cmake ../
If PyBOMBS not used, run:
   -- Configuring done
   -- Generating done
   -- Build files have been written to: /home/widow/rfnoc/src/rfnoc-tutorial/build
   $ make test_tb
   Scanning dependencies of target test_tb
   Built target test_tb
   $ make noc_block_gain_tb
   [TEST CASE   1] (t=000000000) BEGIN: Wait for Reset...
   [TEST CASE   1] (t=000001002) DONE... Passed
   [TEST CASE   2] (t=000001002) BEGIN: Check NoC ID...
   [TEST CASE   2] (t=000001238) DONE... Passed
   [TEST CASE   3] (t=000001238) BEGIN: Connect RFNoC blocks...
   [TEST CASE   3] (t=000005457) DONE... Passed
   [TEST CASE   4] (t=000005457) BEGIN: Write / readback user registers...
   [TEST CASE   4] (t=000006888) DONE... Passed
   [TEST CASE   5] (t=000006888) BEGIN: Test sequence...
   [TEST CASE   5] (t=000007633) DONE... Passed
    - Time elapsed:   7700 ns
    - Tests Expected: 5
    - Tests Run:      5
    - Tests Passed:   5
   Result: PASSED
   $finish called at time : 7700 ns : File "/home/widow/rfnoc/src/rfnoc-tutorial/rfnoc/testbenches/noc_block_gain_tb/noc_block_gain_tb.sv" Line 10
   launch_simulation: Time (s): cpu = 00:00:10 ; elapsed = 00:00:12 . Memory (MB): peak = 966.387 ; gain = 54.848 ; free physical = 3080 ; free virtual = 29888
   #     puts "BUILDER: Closing project"
   #     close_project
   # } else {
   #     puts "BUILDER: In GUI mode. Leaving project open."
   $ uhd_image_builder.py --help
RFNoC target names follow the pattern {DEVICE}_RFNoC_{BUILD_TYPE} with the following build types:
  • HG: 1GigE on SFP+ Port0, 10Gig on SFP+ Port
  • XG: 10GigE on both SFP+ ports
  • HLS: Vivado High Level Synthesis enabled
  • sgX: Speed grade for E300 devices (1 or 3)
Some examples are:
  • X310_RFNOC_HG
  • X300_RFNOC_HG
  • X310_RFNOC_XG
  • X300_RFNOC_XG
  • X310_RFNOC_HLS_HG
  • X300_RFNOC_HLS_HG
  • E310_RFNOC (this is for the speed grade 1 FPGA version of E310, append _sg3 for speed grade 3)
NOTE: E310, E312 and E313 are all have the same FPGA hardware and therefore will use the E310_RFNOC_{BUILD_TYPE} target. USRP E3xx devices have either sg1 or sg3 hardware, please visit here to find out how to differentiate.
Image building using the command line
                               [blocks [blocks ...]]
   positional arguments:
   optional arguments:
                           10, for e300: 6)
     -o OUTFILE, --outfile OUTFILE
                           won't build your IP
     -d DEVICE, --device DEVICE
     -t TARGET, --target TARGET
     -g, --GUI             Open Vivado GUI during the FPGA building process
     -c, --clean-all       Cleans the IP before a new build
   noc_block_{NAME}.v
Incorrect method:
Correct method:
  • axi_fifo_loopback
  • axi_dma_fifo
  • fir_filter
  • fft
  • null_source_sink
  • schmidl_cox
  • packet_resizer
  • split_stream
  • vector_iir
  • addsub
  • window
  • keep_one_in_n
  • pfb
  • export_io
  • conv_encoder_qpsk
  • siggen
  • logpwr
  • fosphor
  • moving_avg
  • ddc
  • duc
-I INCLUDE_DIR: The -I directive provides the path to the users rfnoc/fpga-src directory which contains the custom blocks. This path is needed by the Xilinx Vivado tool. Inside the fpga-src directory there is a file called Makefile.srcs that contains the path of the OOT module and a list of all the custom OOT blocks. This is an auto generated file, which is amended every time a new block is added to the OOT module. Manually modifying this file is not recommended. If there are multiple OOT modules with various custom blocks that reside in different directories the way to include them all is by separating the different paths by a space (e.g. -I /first/OOT/path/ /second/OOT/path/)
   $ ./uhd_image_builder.py gain ddc fft -I {USER_PREFIX}/src/rfnoc-tutorial/rfnoc/fpga-src/ -d x310 -t X310_RFNOC_HG -m 6 --fill-with-fifos
NOTE:
  • The FPGA image building process may take over an hour.
  • FPGA images are specific to the USRP device NOT the USRP series. For example, a USRP X300 FPGA image will NOT work on a USRP X310 and vice versa. Loading an image that does not correspond to a USRP device will likely brick the device. Additional instructions on flashing a custom image to a device can be found here for X3xx series and here for E3xx series.
  • [Environment setup] - The uhd_image_builder.py script will also set up the Xilinx Vivado environment by automatically running the setupenv.sh script located in the {USER_PREFIX}/src/uhd-fpga/usrp3/top/{device} directory. The setupenv.sh script assumes that Xilinx Vivado is installed in the default location of /opt/Xilinx/Vivado. If the installation is in a different directory the setupenv_base.sh script will need to be modified. The script is located at: {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts/setupenv_base.sh
Once the newly compiled image is loaded onto a USRP X310 running the following command will show what RFNoC blocks are available on the FPGA:
   $ uhd_usrp_probe
 |   |   |   * DmaFIFO_0
 |   |   |   * Radio_0
 |   |   |   * Radio_1
 |   |   |   * Block_0
 |   |   |   * DDC_0
 |   |   |   * FFT_0
 |   |   |   * FIFO_0
 |   |   |   * FIFO_1
 |   |   |   * FIFO_2
Using a graphical interface
   $ ./uhd_image_builder_gui
  • HG: 1GigE on SFP+ Port0, 10Gig on SFP+ Port1
3. Blocks in current design: This panel will be populated by adding elements from the available blocks. All the blocks listed in here will be compiled into the FPGA custom image. There is a maximum number of blocks that can be added for each device. See the section in this App Note labeled Discussion on number of blocks in an FPGA image for more information.
4. Add button (>>): Manually add the blocks from the central panel into your design.
5. Remove button (<<): Remove blocks from the current design (far-left panel)
6. Fill with FIFOs: By checking this box, the design will fill any available/unspecified block slots with FIFOs. The number of FIFO blocks that will be instantiated is based on the rules of amount of blocks explained at #3. When less than the max amount of blocks are needed for certain implementation, many users choose to fill their design with FIFO blocks.
7. Open Vivado GUI: Open Vivado GUI during the FPGA building process. This allows the user to save a Vivado project with all IP and work within the Vivado GUI for development.
8. Clean IP: Cleans the IP before a new build (recompiles all IP).
9. Add OOT blocks: Manually add RFNoC Modtool-generated OOT modules by pointing the application to the Makefile.srcs file, which is located in the {USER_PREFIX}/src/{USER-OOT-moddir}/rfnoc/fpga-srcs/ directory. After adding this file, blocks will appear under “OOT blocks for XXXX devices
10. Import from GRC: If the user has a GNU Radio flowgraph with RFNoC blocks already in it, this application can read what RFNoC blocks are in the flowgraph and populate the Blocks in current design section of the application with the necessary RFNoC blocks. NOTE: All RFNoC blocks pulled from a .grc file must be in the of List of blocks available before beginning the build.
12. Generate .bit file: Start the build by clicking this button.
Creating Software/Host portion of custom RFNoC Block
UHD integration
  • Block name and Noc-ID
  • Registers
  • Inputs and outputs (including types)
   <?xml version="1.0"?>
   <!--Default XML file-->
   <nocblock>
     <name>gain</name>
     <blockname>gain</blockname>
     <ids>
     </ids>
     <!-- Registers -->
     <registers>
       <setreg>
         <name>GAIN</name>
         <address>128</address>
       </setreg>
     </registers>
     <!-- Args -->
     <args>
       <arg>
         <name>gain</name>
         <type>double</type>
         <value>1.0</value>
         <action>
         </action>
       </arg>
     </args>
     <ports>
       <sink>
         <name>in0</name>
         <type>sc16</type>
       </sink>
       <source>
         <name>out0</name>
         <type>sc16</type>
       </source>
     </ports>
   </nocblock>
GNU Radio Integration
Since most RFNoC blocks behave very similar to one another from GNU Radio’s perspective, it is generally not required to write C++ code for another block. Rather, a default block provided by RFNoC can be used with appropriate configuration. However, in some cases it may be desirable or even necessary to write a custom GNU Radio block for more specific controlling of the underlying RFNoC block. GNU Radio allows writing blocks in either C++ or Python, but since UHD and RFNoC do not have a Python API, a custom wrapper for an RFNoC block needs to be written in C++. RFNoC Modtool will create skeleton files for these purpose.
GNU Radio Block Code
  • C++ or Python, although RFNoC blocks need to be written in C++ (if at all)
  • How does GNU Radio interface to RFNoC?
    • via C++ infrastructure code in gr-ettus
    • gr-ettus provides a base RFNoC block class
    • Users extend base class for their RFNoC blocks
    • Many blocks can use base class “as is”
    • No C++ or Python code!
  • rfnoc-tutorial/lib/gain_impl.cc
    • The gain block does not need anything additional
GNU Radio Companion Bindings
   <block>
     <name>RFNoC: gain</name>
     <key>tutorial_gain</key>
     <category>tutorial</category>
     <make>tutorial.gain(
       self.device3,
           cpu_format="fc32",
           otw_format="sc16",
           cpu_format="fc32",
           otw_format="sc16",
       $block_index, $device_index,
     </make>
           Sub-nodes:
           * name
           * type -->
       <option>
         <name>Byte</name>
         <key>u8</key>
       </option>
     </param>
     <param>
       <name>Gain</name>
       <key>gain</key>
       <value>1.0</value>
       <type>real</type>
     </param>
           * type
           * vlen
     <sink>
       <name>in</name>
       <type>complex</type>
       <vlen>$grvlen</vlen>
       <domain>rfnoc</domain>
     </sink>
           * type
           * vlen
     <source>
       <name>out</name>
     </source>
   </block>
Compile, Install and Verify
   $ make install
   $ uhd_usrp_probe
   |   |   |   * DmaFIFO_0
   |   |   |   * Radio_0
   |   |   |   * Radio_1
   |   |   |   * gain_0
   |   |   |   * DDC_0
   |   |   |   * FFT_0
   |   |   |   * FIFO_0
   |   |   |   * FIFO_1
   |   |   |   * FIFO_2
Testing out the custom block
Troubleshooting
Xilinx Vivado
Compile issues
Synthesis is failing
Environment Setup
Links and Additional Resources
RFNoC additional resources
GNU Radio resources
UHD resources
Other resources
