[hide]- 1 Application Note Number
- 2 Revision History
- 3 Abstract
- 4 Overview
- 5 Licensing
- 6 Prerequisites
- 7 Creating a development environment
- 8 Starting a custom RFNoC block using RFNoC Modtool
- 9 Creating FPGA portion of custom RFNoC Block
- 10 Creating Software/Host portion of custom RFNoC Block
- 11 Testing out the custom block
- 12 Troubleshooting
- 13 Links and Additional Resources
AN-823
Date | Author | Details |
2016-07-12 | Martin Braun Nicolas Cuervo |
Initial creation
2017-01-10 | Team | Added “Digital Gain” example |
This application note guides a user through basic information on the RFNoC architecture, installing necessary software to develop custom RFNoC blocks, also called Computation Engines (CE), and walks through the steps of creating a custom RFNoC block using an example.
Licensing
The RFNoC code base is open source, including code that executes on the host, as well as code targeted to the USRP hardware (FPGA and microcontroller firmware). As dual-licensed software, RFNoC is available under the open-source GNU Public License version 3 (GPLv3), as well as an alternative, less-restrictive license offered only by Ettus Research. For more information on our licensing policy, please contact info@ettus.com.
Prerequisites
- Ubuntu 14.04 or 16.04(preferred): Currently PyBOMBS (which can be used to install the Software build tools), works most reliably in Ubuntu, and thus, we recommend using this distribution. Also, a majority of the scripts used during the build process are Linux (Ubuntu) specific. A PC with multiple cores and 8GB+ of RAM is recommended.
- Xilinx Vivado tools (ver. 2015.4): The specific version depends on the branch and state of the FPGA code. The default install location is
/opt/Xilinx/Vivado
. Once all of the Software build tools are installed the specific version for the downloaded code can be found in thesetupenv.sh
file located in the{USER_PREFIX}/src/uhd-fpga/usrp3/top/{DEVICE}
directory. Further information can be found here.
- Software build tools: If UHD can be or has been compiled from source on the development PC then all the necessary software build components are present (PyBOMBS can be used to set all this up and instructions on how to do so are given in a following step).
- X3xx series or E3xx series device or any future USRP
NOTE:
- The edition of Xilinx Vivado that is required will depend on the USRP device.
- X3xx series devices: Design or System editions.
- E3xx series devices: Design, System or the free WebPack edition.
- Other operating systems can be used, but the exact steps on how to proceed are not given in this Application Note.
- In some Linux distributions (e.g. Ubuntu)
dash
is set as default shell, which may cause some issues. It is recommended to set the shell tobash
by running the following commands in the terminal. Choose<No>
when prompted by the first command and the second command will validate the that bash will be used.
$ sudo dpkg-reconfigure dash $ ll /bin/sh
- UHD
- GNU Radio
- gr-ettus
$ sudo apt-get install git $ sudo apt-get install python-setuptools python-dev python-pip build-essential $ sudo pip install git+https://github.com/gnuradio/pybombs.git $ pybombs recipes add gr-recipes git+https://github.com/gnuradio/gr-recipes.git $ pybombs recipes add ettus git+https://github.com/EttusResearch/ettus-pybombs.git
- Install
Git
- Install
pip
and other Python dependencies - Install the latest
PyBOMBS
from its Git repository - Add the
gr-recipes
recipes which are used to install GNU Radio specific software - Add the
ettus
recipes which are used to install Ettus Research specific software
This will do the following:
- Create a directory in the user’s home directory called
rfnoc
(any valid directory name will work)
- Give the prefix an alias of
rfnoc
([-a alias]
, e.g.–a rfnoc
), which would be the name given to this path. This name will be used in further steps that use PyBOMBS. When creating the first prefix and omitting the alias, the prefix will be setup as the default.
- Use the
rfnoc
prefix recipe ( as opposed to a package recipe likegqrx
) to clone UHD, FPGA, GNU Radio, and gr-ettus sources into the~/rfnoc
directory as well as compile and install all the software
NOTE: A user can specify how many cores are used by builds when using PyBOMBS. The default is set to 4. For example, this will set the number of cores used to 3:
$ pybombs config makewidth 3
The value will be written into a configuration file and then applied to subsequent PyBOMBS commands. This value can temporarily be overridden for a specific build by specifying the --config makewidth=X
argument, where “X
” is an integer number. If the user only has 4 cores it is recommend to use this argument in the pybombs command to limit the number of cores to <4 (e.g. 3) so that the computer stays responsive. Following are 2 examples, one using less cores and the other using more cores:
$ pybombs --config makewidth=3 prefix init ~/rfnoc -R rfnoc -a rfnoc $ pybombs --config makewidth=7 prefix init ~/rfnoc -R rfnoc -a rfnoc
$ cd ~/rfnoc $ source ./setup_env.sh
NOTE: Throughout the rest of this document the term {USER_PREFIX}
will used at the beginning of different directories. For example, {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts
is a directory that contains useful scripts for compiling. The term {USER_PREFIX}
is used to denote the folders that precede the /src
directory. Examples of what {USER_PREFIX}
could be: /home/user/rfnoc
or /home/user/myDevfolder/
. On many Linux environments using ~/
at the beginning of the target directory path is equivalent to the user’s home directory.( i.e ~/
is equal to /home/user/
). So {USER_PREFIX}
could also look like ~/rfnoc
or ~/myDevfolder/
Create the development environment manually
To manually download the software, use these git clone
commands, which will select the correct branches:
$ git clone --recursive -b rfnoc-devel https://github.com/EttusResearch/uhd.git $ git clone --recursive -b maint https://github.com/gnuradio/gnuradio.git # master branch is also fine instead of maint $ git clone -b master https://github.com/EttusResearch/gr-ettus.git $ git clone -b rfnoc-devel https://github.com/EttusResearch/fpga.git
If UHD, GNU Radio and/or gr-ettus are already installed, it would be sufficient to checkout the branches mentioned and update them them (git pull
). Thereafter, rebuild each of the repositories (rebuild order: UHD, GNU Radio, gr-ettus).
Verify Environment
Running the command “uhd_config_info
” with the “--version
” flag will verify that the installation has been completed successfully.
$ uhd_config_info --version linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-161- g83150fdd 4.0.0.rfnoc-devel-161-g83150fdd
$ uhd_images_downloader
Ettus Research will be updating the default image(s) occasionally, and uhd_images_downloader
can be run anytime after running git pull
and re-installing to pull the most current images. Images are stored in the {USER_PREFIX}/share/uhd/images
directory.
Image Name | Included Blocks |
usrp_x300_fpga_HG.bit
2x DDC, 2x DUC
usrp_x300_fpga_RFNOC_HG.bit
usrp_x310_fpga_RFNOC_HG.bit
usrp_e310_fpga.bit
1x DDC, 1x DUC
- UHD/RFNoC code downloaded and installed
- FPGA code available
- A valid RFNoC image on your X3xx or E3xx series device
Inspect default images
$ uhd_usrp_probe
If an RFNoC image was successfully loaded onto the USRP, there will be a lot of output text (RFNoC code is currently very verbose). The final lines of the output should be similar to the following for an USRP X310 ( e.g. usrp_x310_fpga_HG
| | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * DDC_0 | | | * DDC_1 | | | * DUC_0 | | | * DUC_1
Final output for usrp_x310_fpga_RFNOC_HG.bit
image:
| | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * DDC_0 | | | * DUC_0 | | | * FFT_0 | | | * Window_0 | | | * FIR_0 | | | * SigGen_0 | | | * KeepOneInN_0 | | | * fosphor_0 | | | * FIFO_0 | | | * FIFO_1
NOTE: The actual names and number of blocks can differ. The list of blocks should start with the DmaFIFO_x
and Radio_x
, and then a couple more lines of block IDs should follow.
Build custom image with pre-built RFNoC blocks
The script to initiate a compile is called uhd_image_builder.py
, and is located in the {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts
directory. Run the help menu by typing:
$ cd {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts $ ./uhd_image_builder.py --help
A more detailed discussion of this script is given in an upcoming section. For now, compiling an FPGA image that has 2 RFNoC blocks (window
and fft
) and some FIFOs
, is done by running the script with the following arguments.
Example for an X310 USRP:
At the end of a successful compilation process, write the new image to a USRP. If the image was compiled for a USRP X310, the following command will load the new image. Update the {IP_Address}
of the USRP and {USER_PREFIX}
to the appropriate values for your configuration before running the command.
$ uhd_image_loader --args “type=x300,addr={IP_ADDRESS}” --fpga-path {USER_PREFIX}/src/uhd-fpga/usrp3/top/x300/build/usrp_x310_fpga_RFNOC_HG.bit
After the image has been successfully written to the USRP, power-cycle it and run the “uhd_usrp_probe
” utility to view the newly compiled blocks.
$ uhd_usrp_probe
| | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * Window_0 | | | * FFT_0 | | | * FIFO_0 | | | * FIFO_1 | | | * FIFO_2
The following new examples included within the rfnoc-devel
branch of UHD, are a good reference on how to use RFNoC from UHD.
The following example is based off of rx_samples_to_file.cpp
. The example can be configured to place an RFNoC block in between the radio and host.
rfnoc_rx_to_file.cpp
rfnoc_nullsource_ce_rx.cpp
Getting started with GNU Radio + RFNoC
A good way of getting started with RFNoC in a more tangible fashion is to use GNU Radio. The gr-ettus
out-of-tree module (OOT) allows a user to use RFNoC blocks in their local GNU Radio / GNU Radio Companion (GRC) installation. This GNU Radio OOT contains blocks that allow you to configure your FPGA through GRC.
NOTE: As blocks in the gr-ettus
OOT mature, they will be upstreamed to gr-uhd
. Also, gr-ettus
is a container used by Ettus Research to disseminate experimental or under-development features for gr-uhd
. It is not a replacement for gr-uhd
(in fact, the latter is a requirement for gr-ettus
Examples can be run from gr-ettus/examples/rfnoc
, provided that the appropriate RFNoC blocks and compiled into the FPGA image currently running on the USRP.
A couple of rules for building GNU Radio flowgraphs:
- You always need a
Device3
object in your flow graph (it does not get connected, see screenshot below). - You should have at least two RFNoC blocks connected together, going
GNU Radio Block
->RFNoC Block
->GNU Radio Block
is not recommended (it will work, but with suboptimal performance).
The GNU Radio flowgraph rfnoc_ddc.grc
is an example that can be run using the default RFNoC image. Below are screenshots of the flowgraph and what it produces.
NOTE: Copy Block: In the RFNoC domain, streams of data can not be split as easily as they are in the GNU Radio domain. The “copy” block depicted in the screenshot above serves the function as a stream splitter . It’s main purpose, when “enabled”, is to copy the samples it is getting at its input and putting then into the output, but here it is also serving as a boundary between a RFNoC-domain and a GNURadio-domain. In the flowgraph above. after this boundary is passed, the data stream can easily be split into the two sinks to have them run simultaneously (standard GNU Radio functionality). It is possible to connect the GNU Radio blocks directly to RFNoC blocks without a “copy” block, but only one would work at a time (the other ones would have to be disabled). Another way to split data streams from the RFNoC- domain is to use the ”RFNoC: split stream” block, which would split the streams in the RFNoC domain, but this is not very useful here as we are, in any case, moving into the GNURadio-domain.
The figure below shows the basic structure of the RFNoC Stack. Corresponding code is needed in each of the three sections in order to build a custom RFNoC block with GNU Radio integration. A tool called RFNoC Modtool was created in order to minimize the effort needed to implement a new RFNoC block. RFNoC Modtool creates a custom GNU Radio OOT module with the basic structure and the necessary files for each of these sections. RFNoC Modtool is currently a part of the GNU Radio OOT module gr-ettus
RFNoC Modtool Utilization
Because the RFNoC Modtool has similar functionality to the gr_modtool
[ gr_modtool ] provided by GNU Radio, those that have worked with gr_modtool
in the past will find the RFNoC Modtool familiar.
$ rfnocmodtool help linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-162-g335a1317 Usage: rfnocmodtool <command> [options] -- Run <command> with the given options. rfnocmodtool help -- Show a list of commands. rfnocmodtool help <command> -- Shows the help for a given command. List of possible commands: Name Aliases Description ===================================================================== disable dis Disable block (comments out CMake entries for files) info getinfo,inf Return information about a given module remove rm,del Remove block (delete files and remove Makefile entries) makexml mx Make XML file for GRC block bindings add insert Add block to the out-of-tree module. newmod nm,create Create a new out-of-tree module rename mv Rename a block in the out-of-tree module.
Creating an RFNoC OOT Module
To start generating an RFNoC OOT module navigate to the source location ( i.e. cd ~/{USER_PREFIX}/src
) and type:
Where [NAME OF THE MODULE]
is a name the user gives the new module. In the following, a module is created with the name “tutorial
”. If the user does not write the name of the module following the newmod
command the tool will ask for it interactively. Running this command will create a folder containing the basic folders that you may need for a functional module.
$ rfnocmodtool newmod tutorial linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-162-g335a1317 Creating out-of-tree module in ./rfnoc-tutorial... Done. Use 'rfnocmodtool add' to add a new block to this currently empty module.
$ ls rfnoc-tutorial/ apps cmake CMakeLists.txt docs examples grc include lib MANIFEST.md python README.md rfnoc swig
In contrast with gr_modtool
, this includes a folder called rfnoc
, which is where the UHD/FPGA files are located.
In order to add blocks to your module, navigate to the folder just created and use the add
command of rfnocmodtool
. Continuing with the example above, run the following:
$ cd rfnoc-tutorial $ rfnocmodtool add [NAME OF THE BLOCK]
For demonstrative purposes, a block named gain
will be created. The gain
block will multiply samples that pass through it by a constant. As before, if the name is not given, the tool will ask the user for the name. There are several arguments that can be passed to the tool, but running the tool without any of these arguments will give the following interactive parsing output:
$ rfnocmodtool add gain linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_4.0.0.rfnoc-devel-162-g335a1317 RFNoC module name identified: tutorial Block/code identifier: gain Enter valid argument list, including default arguments: Add Python QA code? [Y/n] N Add C++ QA code? [y/N] N Block NoC ID (Hexadecimal): 1111222233334444 Skip Block Controllers Generation? [UHD block ctrl files] [y/N] N Skip Block interface files Generation? [GRC block ctrl files] [y/N] N
Hitting enter
on each one of the options will take the default values.
- Add Python QA code: Not used.
- Add C++ QA code: Not used.
- NoC ID: This ID is a Hexadecimal number which serves as identification between the hardware part and the software part of the design. It can be as long as 16 0-9 A-F digits. If a NoC ID is not provided, it will be set to a random number.
- Block Controllers Generation: The block controllers are the C++ control that the user can apply to the UHD-part of the design. In these files, the user can add more control over this layer of the design. Depending on the complexity of the block it may be possible to add all necessary control using NoCScript (more details on NoCScript can be found in the section labeled UHD Integration). In this case the cpp/hpp block control files generation are not needed. Default is to generate as their existence will be ignored if not edited.
- Block Interface: Add more design specific functionality to the design at the GNU Radio interface by generating these block-interface files and adding necessary logic. Depending on the complexity of the block it may be possible to add all necessary control using NoC-Script. In this case the block-interface files are not needed. Default is to generate as their existence will be ignored if not edited.
Adding file 'lib/gain_impl.h'... Adding file 'lib/gain_impl.cc'... Adding file 'include/tutorial/gain.h'... Adding file 'include/tutorial/gain_block_ctrl.hpp'... Adding file 'lib/gain_block_ctrl_impl.cpp'... Editing swig/tutorial_swig.i... Adding file 'python/qa_gain.py'... Editing python/CMakeLists.txt... Adding file 'grc/tutorial_gain.xml'... Adding file 'rfnoc/blocks/gain.xml'... Adding file 'rfnoc/fpga-src/noc_block_gain.v'... rfnoc/testbenches/noc_block_gain_tb folder created Adding file 'rfnoc/testbenches/noc_block_gain_tb/noc_block_gain_tb.sv'... Adding file 'rfnoc/testbenches/noc_block_gain_tb/Makefile'... Adding file 'rfnoc/testbenches/noc_block_gain_tb/CMakeLists.txt'...
Many designs will want to use an AXI Stream interface with only sample data. However, as stated earlier, the NoC Shell block expects CHDR packets. To ease interfacing user code, the AXI Wrapper block provides the necessary logic to strip and insert the CHDR header, effectively converting packetized sample data into streaming sample data and vice versa. The example RFNoC blocks noc_block_fft.v
and noc_block_fir.v
show how AXI Wrapper is used to implement existing Xilinx AXI Stream based IP within a computation engine.
The primary user interface consists of four AXI stream interfaces ( tready, tvalid, tlast, tdata
) and a settings register bus ( 8-bit, valid user register addresses: 128-255
AXI Stream signals:
Settings Bus signals:
For the gain
example block the following architecture is desired (the blue signal has both “I” and “Q” data):
Open the file rfnoc-tutorial/rfnoc/fpga-src/noc_block_gain.v
that contains the RFNoC block skeleton code that was created when the $ rfnocmodtool add gain
command was run and modify the following sections.
For the setting register that will hold the constant value as well as the read back register:
localparam [7:0] SR_GAIN = SR_USER_REG_BASE; localparam [7:0] SR_TEST_REG_1 = SR_USER_REG_BASE + 8'd1; wire [15:0] gain; setting_reg #( .my_addr(SR_GAIN), .awidth(8), .width(16)) sr_gain ( .clk(ce_clk), .rst(ce_rst), .strobe(set_stb), .addr(set_addr), .in(set_data), .out(gain), .changed()); always @(posedge ce_clk) begin case(rb_addr) 8'd0 : rb_data <= {48'd0, gain}; 8'd1 : rb_data <= {32'd0, test_reg_1}; default : rb_data <= 64'h0BADC0DE0BADC0DE; endcase end
And for the processing section:
assign m_axis_data_tready = s_axis_data_tready; assign s_axis_data_tvalid = m_axis_data_tvalid; assign s_axis_data_tlast = m_axis_data_tlast; wire [15:0] i = m_axis_data_tdata[31:16]; wire [15:0] q = m_axis_data_tdata[15:0]; wire [31:0] i_mult_gain = i*gain; wire [31:0] q_mult_gain = q*gain; assign s_axis_data_tdata = {i_mult_gain[15:0], q_mult_gain[15:0]};
NOTE: Because the multiplication process can occur in the same clock cycle there is no need for handshaking with the AXI tready, tvalid and tlast
signals and therefore they are simply passed through the gain
RFNoC block.
Creating and running HDL testbenches
In order to make the coding iteration process more efficient, it is recommended to create testbenches for all RFNoC blocks before compiling them into the FPGA image. This allows for flaw and/or bug detection early in the design. RFNoC Modtool provides the structure and files ( e.g. noc_block_{USER_BLOCK_NAME}_tb
) for the testbenches of each of the OOT blocks that are added with the $ rfnocmodtool add
command.
Below is a figure that shows the structure of the testbench created by the RFNoC Modtool.
From the Adding custom blocks to OOT Module section where the gain
block was initially created, the last files generated were:
The noc_block_gain_tb
is a folder generated to contain all the files related to the test bench of the gain
block. Each time a new OOT block is created, a new folder will be generated as well.
CMakeLists.txt:
this is an empty file used, so far, only to increase the scope of the compilers. -
noc_block_gain_tb.sv:
this is a System Verilog file, in which user custom tests are to be located. This is the only file that needs to be modified. -
Makefile:
This file determines the directives that run the simulation.
Open the file rfnoc-tutorial/rfnoc/testbenches/noc_block_gain_tb/noc_block_gain_tb.sv
and modify the following lines:
initial begin : tb_main string s; logic [31:0] random_word; logic [63:0] readback; logic [15:0] gain; `TEST_CASE_START("Write / readback user registers"); random_word = $random(); tb_streamer.write_user_reg(sid_noc_block_gain, noc_block_gain.SR_GAIN, random_word[15:0]); tb_streamer.read_user_reg(sid_noc_block_gain, 0, readback); $sformat(s, "User register 0 incorrect readback! Expected: %0d, Actual %0d", readback[15:0], random_word[15:0]); `ASSERT_ERROR(readback[15:0] == random_word[15:0], s); `TEST_CASE_START("Test sequence"); gain = 100; tb_streamer.write_user_reg(sid_noc_block_gain, noc_block_gain.SR_GAIN, gain); fork begin tb_streamer.recv(recv_payload,md); for (int i = 0; i < SPP/2; i++) begin expected_value = i*gain;
Create a build
directory, verify directory location is rfnoc-tutorial
and run:
$ mkdir build && cd build/
The next step is to run cmake
. If PyBOMBS was used to create the development sandbox, cmake
will automatically detect the location of the fpga
repository. If PyBOMBS was not used, the user must provide the location of where the fpga
repository is installed.
If PyBOMBS used, run:
$ cmake ../
If PyBOMBS not used, run:
Final output from the $ cmake ../
command:
-- Configuring done -- Generating done -- Build files have been written to: /home/widow/rfnoc/src/rfnoc-tutorial/build
$ make test_tb Scanning dependencies of target test_tb Built target test_tb
$ make noc_block_gain_tb
======================================================== TESTBENCH STARTED: noc_block_gain ======================================================== [TEST CASE 1] (t=000000000) BEGIN: Wait for Reset... [TEST CASE 1] (t=000001002) DONE... Passed [TEST CASE 2] (t=000001002) BEGIN: Check NoC ID... Read GAIN NOC ID: 1111222233334444 [TEST CASE 2] (t=000001238) DONE... Passed [TEST CASE 3] (t=000001238) BEGIN: Connect RFNoC blocks... Connecting noc_block_tb (SID: 1:0) to noc_block_gain (SID: 0:0) Connecting noc_block_gain (SID: 0:0) to noc_block_tb (SID: 1:0) [TEST CASE 3] (t=000005457) DONE... Passed [TEST CASE 4] (t=000005457) BEGIN: Write / readback user registers... [TEST CASE 4] (t=000006888) DONE... Passed [TEST CASE 5] (t=000006888) BEGIN: Test sequence... [TEST CASE 5] (t=000007633) DONE... Passed ======================================================== TESTBENCH FINISHED: noc_block_gain - Time elapsed: 7700 ns - Tests Expected: 5 - Tests Run: 5 - Tests Passed: 5 Result: PASSED ======================================================== $finish called at time : 7700 ns : File "/home/widow/rfnoc/src/rfnoc-tutorial/rfnoc/testbenches/noc_block_gain_tb/noc_block_gain_tb.sv" Line 10 INFO: [USF-XSim-96] XSim completed. Design snapshot 'noc_block_gain_tb_behav' loaded. INFO: [USF-XSim-97] XSim simulation ran for 1000000000us launch_simulation: Time (s): cpu = 00:00:10 ; elapsed = 00:00:12 . Memory (MB): peak = 966.387 ; gain = 54.848 ; free physical = 3080 ; free virtual = 29888 # if [string equal $vivado_mode "batch"] { # puts "BUILDER: Closing project" # close_project # } else { # puts "BUILDER: In GUI mode. Leaving project open." # } BUILDER: Closing project ****** Webtalk v2015.4 (64-bit) **** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015 **** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015 ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved. source /home/widow/rfnoc/src/rfnoc-tutorial/rfnoc/testbenches/noc_block_gain_tb/xsim_proj/xsim_proj.hw/webtalk/labtool_webtalk.tcl -notrace INFO: [Common 17-206] Exiting Webtalk at Tue Jan 10 23:26:20 2017... INFO: [Common 17-206] Exiting Vivado at Tue Jan 10 23:26:22 2017... Built target noc_block_gain_tb
With every custom block created, a make
directive will be available to run the simulation from the build
directory.
Verify the current maximum values by running the uhd_images_builder.py
utility from the scripts directory.
$ cd {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts $ uhd_image_builder.py --help
RFNoC target names follow the pattern {DEVICE}_RFNoC_{BUILD_TYPE}
with the following build types:
HG:
1GigE on SFP+ Port0, 10Gig on SFP+ Port -
XG:
10GigE on both SFP+ ports -
HLS:
Vivado High Level Synthesis enabled -
sgX:
Speed grade for E300 devices (1 or 3)
Some examples are:
X310_RFNOC_HG
X300_RFNOC_HG
X310_RFNOC_XG
X300_RFNOC_XG
X310_RFNOC_HLS_HG
X300_RFNOC_HLS_HG
E310_RFNOC
(this is for the speed grade 1 FPGA version of E310, append_sg3
for speed grade 3)
NOTE: E310, E312 and E313 all have the same FPGA hardware and therefore will use the E310_RFNOC_{BUILD_TYPE}
target. USRP E3xx devices have either sg1
or sg3
hardware, please visit here to find out how to differentiate.
Image building using the command line
The script uhd_image_builder.py
is used to generate the NoC block instantiation file and build the FPGA image. Run the help menu by typing:
$ cd {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts $ ./uhd_image_builder.py --help usage: uhd_image_builder.py [-h] [-I INCLUDE_DIR [INCLUDE_DIR ...]] [-m MAX_NUM_BLOCKS] [--fill-with-fifos] [-o OUTFILE] [-d DEVICE] [-t TARGET] [-g] [-c] [blocks [blocks ...]] Generate the NoC block instantiation file positional arguments: blocks List block names to instantiate. optional arguments: -h, --help show this help message and exit -I INCLUDE_DIR [INCLUDE_DIR ...], --include-dir INCLUDE_DIR [INCLUDE_DIR ...] Path directory of the RFNoC Out-of-Tree module -m MAX_NUM_BLOCKS, --max-num-blocks MAX_NUM_BLOCKS Maximum number of blocks (Max. Allowed for x310|x300: 10, for e300: 6) --fill-with-fifos If the number of blocks provided was smaller than the max number, fill the rest with FIFOs -o OUTFILE, --outfile OUTFILE Output /path/filename - By running this directive, you won't build your IP -d DEVICE, --device DEVICE Device to be programmed [x300, x310, e310] -t TARGET, --target TARGET Build target - image type [X3X0_RFNOC_HG, X3X0_RFNOC_XG, E310_RFNOC_sg3...] -g, --GUI Open Vivado GUI during the FPGA building process -c, --clean-all Cleans the IP before a new build
Blocks: The first arguments are the names of RFNoC blocks that the user wants to have compiled into the new image which are separated by a space. They can be custom blocks from the user’s OOT module or from the ones that are provided from Ettus, or a combination. Blocks provided by Ettus Research are listed (among other sources necessary for the FPGA build) in the {USER_PREFIX}/src/uhd-fpga/usrp3/lib/rfnoc/Makefile.srcs
file.
noc_block_{NAME}.v
However, as all the RFNoC blocks have the same noc_block_
prefix, for simplicity this prefix is omitted when listing the blocks in the uhd_image_builder.py
utility. As an example of the incorrect and correct way of adding blocks, consider the following examples when adding the noc_block_null_source_sink
and noc_block_siggen
blocks:
Incorrect method:
Correct method:
axi_fifo_loopback
axi_dma_fifo
fir_filter
fft
null_source_sink
schmidl_cox
packet_resizer
split_stream
vector_iir
addsub
window
keep_one_in_n
pfb
export_io
conv_encoder_qpsk
siggen
logpwr
fosphor
moving_avg
ddc
duc
RFNoC related blocks generally reside in fpga/usrp3/lib/rfnoc/
Block | Filename | Description |
FIFO | noc_block_axi_fifo_loopback.v | Simple FIFO loopback / passthrough block. |
FFT | noc_block_fft.v | Xilinx coregen based Fast Fourier Transform up to length 4096. |
FIR | noc_block_fir_filter.v | Xilinx coregen based Finite Impulse Response Filter, 41 taps, reconfigurable tap coefficients. |
Window | noc_block_window.v | Windowing block for use with FFT block. |
Vector IIR | noc_block_vector_iir.v | Single pole IIR with configurable coefficients that filters data along vectors (i.e. parallel streams of samples). Useful with FFT output. |
Keep One in N | noc_block_keep_one_in_n.v | Keeps one packet every N packets. |
AddSub | noc_block_addsub.v | Example of using multiple block ports in a single RFNoC block to add and subtract streams. |
Null Source Sink | noc_block_null_source_sink.v | Generates dummy packets and can consume packets at a configurable rate. Useful for testing. |
Packet Resizer | noc_block_packet_resizer.v | Resizes input packets to a configurable size (larger or smaller than source packets). |
Split Stream | noc_block_split_stream.v | Replicates an input stream to a configurable number of output streams. |
-I INCLUDE_DIR:
The -I
directive provides the path to the users rfnoc/fpga-src
directory which contains the custom blocks. This path is needed by the Xilinx Vivado tool. Inside the fpga-src
directory there is a file called Makefile.srcs
that contains the path of the OOT module and a list of all the custom OOT blocks. This is an auto generated file, which is amended every time a new block is added to the OOT module. Manually modifying this file is not recommended. If there are multiple OOT modules with various custom blocks that reside in different directories the way to include them all is by separating the different paths by a space (e.g. -I /first/OOT/path/ /second/OOT/path/
-d DEVICE:
The -d
directive directs the script on which USRP device the build is for. If no –d
is included the default is –d x310
. Generation-3 USRPs and above all support RFNoC.
-t TARGET:
The –t
directive directs the script on which type of image to build for the chosen device. With each USRP device there are several build options to choose from. Detailed information about the build targets can be found at the build instructions for USRP3, found here. If -t
is not included, a default target will be chosen for the given device. For example, the default X310_RFNOC_HG
target builds for the –d x310
device. More details on targets can be found in the section of this Application Note labeled Discussion on FPGA image targets.
-m MAX_NUM_BLOCKS:
The –m
directive specifies the max number of RFNoC blocks to build on the FPGA image. An RFNoC image does not need to fill all available slots with RFNoC blocks.
--fill-with-fifos:
The --fill-with-fifos
directive will fill the empty RFNoC block slots with FIFOS. As an example, if a user indicates three RFNoC blocks by name and also specifies –m 5
then the other two slots will be filed with FIFOs.
-o OUTFILE:
With the -o
directive, the RFNoC blocks instantiation file is generated and saved at the desired path with the given name for the user to inspect. The FPGA image will NOT build if this directive is provided. The purpose of the uhd_image_builder.py
script is to auto generate an instantiation file and populate the source files needed for the Xilinx Vivado tool to build the FPGA image, however, it may be desirable to only see the effect of adding a custom OOT module in the fpga/
directory, or for inspecting the instantiation file. When the directive is not provided the rfnoc_ce_auto_inst_x3x0.v
file is overwritten and the FPGA image build process will start automatically (standard use).
-g, --GUI:
-c, --clean-all:
Here is how to create an X310 FPGA image incorporating the gain
block that was created earlier in this Application Note:
$ cd {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts $ ./uhd_image_builder.py gain ddc fft -I {USER_PREFIX}/src/rfnoc-tutorial/rfnoc/fpga-src/ -d x310 -t X310_RFNOC_HG -m 6 --fill-with-fifos
At the end of a successful compilation process, write the new image to a USRP. The following command will load the new image. Update the {IP_Address}
NOTE:
- The FPGA image building process may take over an hour.
- FPGA images are specific to the USRP device NOT the USRP series. For example, a USRP X300 FPGA image will NOT work on a USRP X310 and vice versa. Loading an image that does not correspond to a USRP device will likely brick the device. Additional instructions on flashing a custom image to a device can be found here for X3xx series and here for E3xx series.
- [Environment setup] - The
script will also set up the Xilinx Vivado environment by automatically running thesetupenv.sh
script located in the{USER_PREFIX}/src/uhd-fpga/usrp3/top/{device}
directory. Thesetupenv.sh
script assumes that Xilinx Vivado is installed in the default location of/opt/Xilinx/Vivado
. If the installation is in a different directory thesetupenv_base.sh
script will need to be modified. The script is located at:{USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts/setupenv_base.sh
Besides the custom gain
block, a DDC
and FFT
block are also being added along with three FIFOs
. The DDC
, FFT
and FIFO
blocks are already in the script's path and therefore do not need their path specified (they ship with the Ettus Research FPGA code). The reason three FIFOs are added is because the max number of blocks was specified to be 6 ( -m 6
) and since only 3 blocks were specifically named the other three slots are filled with FIFOs.
Once the newly compiled image is loaded onto a USRP X3xx running the following command will show what RFNoC blocks are available on the FPGA:
$ uhd_usrp_probe | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * Block_0 | | | * DDC_0 | | | * FFT_0 | | | * FIFO_0 | | | * FIFO_1 | | | * FIFO_2
NOTE: The reason the custom block is called Block_0
and not gain_0
is because there is still host side software/files that need updated in order for this block to populate it’s proper name. A following section (UHD Integration) will step through the process of updating those host side files.
Using a graphical interface
A graphical user interface for FPGA generation and building is shipped along with the uhd_image_builder.py
script. This intuitive application aids in setting up a custom FPGA build.
This utility is located in the same scripts
directory as uhd_image_builder.py
$ cd {USER_PREFIX}/src/uhd-fpga/usrp3/tools/scripts/ $ ./uhd_image_builder_gui
HG:
1GigE on SFP+ Port0, 10Gig on SFP+ Port1 -
XG:
HLS:
sgX:
2. List of blocks available: In this panel the available blocks are listed that can be included into a custom design. This list separates the RFNoC blocks provided by Ettus Research and the OOT modules and corresponding blocks that the user adds. Given the hardware differences between the X3xx and E3xx devices, this list will dynamically change when a different device is selected from the panel on the left. This implies that it is necessary to add the OOT modules for each device independently. This is accomplished by using the Add OOT Blocks
feature of the application, details of which are explained at #7 (Add OOT Blocks
3. Blocks in current design: This panel will be populated by adding elements from the available blocks. All the blocks listed in here will be compiled into the FPGA custom image. There is a maximum number of blocks that can be added for each device. See the section in this App Note labeled Discussion on number of blocks in an FPGA image for more information.
4. Add button (>>): Manually add the blocks from the central panel into your design.
5. Remove button (<<): Remove blocks from the current design (far-left panel)
6. Fill with FIFOs: By checking this box, the design will fill any available/unspecified block slots with FIFOs. The number of FIFO blocks that will be instantiated is based on the rules of amount of blocks explained at #3. When less than the max amount of blocks are needed for certain implementation, many users choose to fill their design with FIFO blocks.
7. Open Vivado GUI: Open Vivado GUI during the FPGA building process. This allows the user to save a Vivado project with all IP and work within the Vivado GUI for development.
8. Clean IP: Cleans the IP before a new build (recompiles all IP).
9. Add OOT blocks: Manually add RFNoC Modtool-generated OOT modules by pointing the application to the Makefile.srcs
file, which is located in the {USER_PREFIX}/src/{USER-OOT-moddir}/rfnoc/fpga-srcs/
directory. After adding this file, blocks will appear under “OOT blocks for XXXX devices
10. Import from GRC: If the user has a GNU Radio flowgraph with RFNoC blocks already in it, this application can read what RFNoC blocks are in the flowgraph and populate the Blocks in current design
section of the application with the necessary RFNoC blocks. NOTE: All RFNoC blocks pulled from a .grc
file must be in the of List of blocks available
before beginning the build.
12. Generate .bit file: Start the build by clicking this button.
UHD integration
Despite the data processing happening on the FPGA, the host software still has a lot of responsibilities in order for an RFNoC application to function. For example, it needs to know which settings registers are available within an RFNoC block, or what kind of input and output a block has. All of this information goes into the Block Declaration
, which is an XML file that is readable by UHD. Often, some simple logic needs to be embedded in the XML file, which we can do by using a simple scripting language called Noc-Script. Changes to the block declaration file are immediately imported into UHD every time an application is executed, and therefore, no software development toolchain needs to be set up.
- Block name and Noc-ID
- Registers
- Inputs and outputs (including types)
In some cases, additional C++ code is required to properly control a block from software. In this case, a Block Controller
file is required as well as the declaration file. In most cases, the default block controller provided by UHD is sufficient, so no C++ code needs to be written. Writing custom block controllers requires more effort, and means having to set up a programming toolchain. A common reason to write custom C++ block controllers is if setting a register requires a lot of computation, which is not feasible to do within a block declaration file (e.g., using Noc-Script).
Because the gain
block does not require anything other than simply reading and writing to a single register the default block controller will suffice for this example. However, we will need to add information about the register.
Open the gain.xml
file located in the /rfnoc-tutorial/rfnoc/blocks
directory and add the following:
<?xml version="1.0"?> <!--Default XML file--> <nocblock> <name>gain</name> <blockname>gain</blockname> <ids> <id revision="0">1111222233334444</id> </ids> <!-- Registers --> <registers> <setreg> <name>GAIN</name> <address>128</address> </setreg> </registers> <!-- Args --> <args> <arg> <name>gain</name> <type>double</type> <value>1.0</value> <check>GE($gain, 0.0) AND LE($gain, 32767.0)</check> <check_message>Invalid gain.</check_message> <action> SR_WRITE("GAIN", IROUND($gain)) </action> </arg> </args> <!--One input, one output. If this is used, better have all the info the C++ file.--> <ports> <sink> <name>in0</name> <type>sc16</type> </sink> <source> <name>out0</name> <type>sc16</type> </source> </ports> </nocblock>
GNU Radio Integration
Since most RFNoC blocks behave very similar to one another from GNU Radio’s perspective, it is generally not required to write C++ code for another block. Rather, a default block provided by RFNoC can be used with appropriate configuration. However, in some cases it may be desirable or even necessary to write a custom GNU Radio block for more specific controlling of the underlying RFNoC block. GNU Radio allows writing blocks in either C++ or Python, but since UHD and RFNoC do not have a Python API, a custom wrapper for an RFNoC block needs to be written in C++. RFNoC Modtool will create skeleton files for these purpose.
GNU Radio Block Code
- C++ or Python, although RFNoC blocks need to be written in C++ (if at all)
- How does GNU Radio interface to RFNoC?
- via C++ infrastructure code in
gr-ettus
gr-ettus
provides a base RFNoC block class - Users extend base class for their RFNoC blocks
- Many blocks can use base class “as is”
- No C++ or Python code!
rfnoc-tutorial/lib/gain_impl.cc
- The gain block does not need anything additional
GNU Radio Companion Bindings
- XML
- Describes GNU Radio blocks to GRC
- No recompilation
- Requirement of GNU Radio Companion
- Not strictly necessary for GNU Radio
- Tutorial on how to write them:
- Skeleton file generated by RFNoC Modtool
Open the tutorial-gain.xml
file located in the rfnoc-tutorial/grc
directory and edit as follows:
<?xml version="1.0"?> <block> <name>RFNoC: gain</name> <key>tutorial_gain</key> <category>tutorial</category> <import>import tutorial</import> <make>tutorial.gain( self.device3, uhd.stream_args( \# TX Stream Args cpu_format="fc32", otw_format="sc16", args="gr_vlen={0},{1}".format(${grvlen}, "" if $grvlen == 1 else "spp={0}".format($grvlen)), ), uhd.stream_args( \# RX Stream Args cpu_format="fc32", otw_format="sc16", args="gr_vlen={0},{1}".format(${grvlen}, "" if $grvlen == 1 else "spp={0}".format($grvlen)), ), $block_index, $device_index, ) self.$(id).set_arg("gain", $gain) </make> <callback>set_arg("gain", $gain)</callback> <!-- Make one 'param' node for every Parameter you want settable from the GUI. Sub-nodes: * name * key (makes the value accessible as $keyname, e.g. in the make node) * type --> . . . <option> <name>Byte</name> <key>u8</key> </option> </param> <param> <name>Gain</name> <key>gain</key> <value>1.0</value> <type>real</type> </param> <!-- Make one 'sink' node per input. Sub-nodes: * name (an identifier for the GUI) * type * vlen * optional (set to 1 for optional inputs) --> <sink> <name>in</name> <type>complex</type> <vlen>$grvlen</vlen> <domain>rfnoc</domain> </sink> <!-- Make one 'source' node per output. Sub-nodes: * name (an identifier for the GUI) * type * vlen * optional (set to 1 for optional inputs) --> <source> <name>out</name> <type>complex</type> <vlen>$grvlen</vlen> <domain>rfnoc</domain> </source> </block>
NOTE: Indentation spacing is important in the <make>
section.
Compile, Install and Verify
$ cd {USER_PREFIX}/src/rfnoc-tutorial/build $ make install $ uhd_usrp_probe | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * gain_0 | | | * DDC_0 | | | * FFT_0 | | | * FIFO_0 | | | * FIFO_1 | | | * FIFO_2
NOTE: In the case where the gain_0
does not appear but Block_0
does: Most likely, the XML block declaration file (see UHD Integration section) for the block contains a NoC-ID that does not match with any NoC-ID defined in the hardware part of the design. The user has to be certain that the description files are up-to-date and that the NoC-ID matches in the SW and HW side. See the UHD Integration section to update those host side files.
At this point the custom gain
RFNoc Block (Computation Engine) can be used within a GNU Radio flowgraph. Below is an example GRC flowgraph using our new block as well as the output application it produces.
Troubleshooting
Xilinx Vivado
Compile issues
Synthesis is failing
- https://forums.xilinx.com/t5/Synthesis/Synthesis-failed-without-reporting-any-error/td-p/686000
- https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-on-Linux-synthesis-fails-with-no-error-message/td-p/732143
Environment Setup
The uhd_image_builder.py
script will also set up the Xilinx Vivado environment by automatically running the setupenv.sh
located in the {USER_PREFIX}/src/uhd-fpga/usrp3/top/{device}
directory. The setupenv.sh
script assumes that Xilinx Vivado is installed in the default location of /opt/Xilinx/Vivado
. If the installation is in a different directory, then the setupenv_base.sh
script will need to be modified. The script is located at: {USER_PREFIX}/src/uhd-fpga/usrp3_rfnoc/tools/scripts/setupenv_base.sh
RFNoC additional resources
- RFNoC Primary Application Note
- RFNoC Introduction
- RFNoC Deep Dive: FPGA
- RFNoC Deep Dive: Host side
- Video: RFNoC presented at Wireless @ Virginia Tech, 2015
- Explaining the slides of Intro, FPGA and Host presentations above (in that order).
