Technical FAQ
[hide]- 1 How do I get started?
- 2 Do you have antennas to match your daughterboards?
- 3 What operating systems are supported?
- 4 Are design files available with the boards that may aid in further prototyping?
- 5 Are there any license requirement for the transmit or transceive daughterboards?
- 6 Will the power supply work in country X? Is it approved in country X? What are the power requirements?
- 7 What USRP models are compatible with the GPSDO kit?
- 8 Are all daughterboards compatible with all USRP motherboards?
For the UHD Getting Started documentation please refer to: UHD Manual.
For the GNU Radio Getting Started documentation please refer to: http://gnuradio.org/redmine/projects/gnuradio/wiki.
Yes, we have antennas for nearly every daughterboard which we sell. Please see the ordering page for pictures and specifications.
The UHD (USRP Hardware Driver) supports all Ettus Research hardware on the following operating systems:
- Linux (any distribution should work, but primarily Ubuntu 14.04, 16.04, Fedora 24, Fedora 25, CentOS 7)
- Mac OS X 10.10, 10.11, 10.12
- Microsoft Windows 7, 8 ,10
Primary development for UHD is done on Linux.
Yes. Schematics for select USRP devices and daughterboards are available. You can find them here:
http://files.ettus.com/schematics
The USRP hardware is sold as test equipment. If you choose to use your USRP hardware and daughterboards to transmit using an antenna, it is your responsibility to make sure you are in compliance with all laws for the country, frequency and power levels in which the device is used. Additionally, some countries regulate reception in certain frequency bands. Again, it is the responsibility of the user to maintain compliance with all local laws and regulations.
All current USRP software defined radios require 6V at 3A. The USRP power supply shipped with all USRP software defined radios has the following specifications:
- Input: 90-264 Vac at 50 to 60Hz
- Output: 6Vdc at 3A
- Interchangeable input plugs provided: NA, EU, UK, AU
- Safety Approvals: UL/cUL, GS, CE, FCC, RCM
- EMC/EMI: FCC class B, CE, VCCI class II
The DC plug is a 2.1mm center conductor, 9.5mm barrel, 5.5mm outer diameter standard plug.
The USRP power supplies accept 90-264Vac at 50 or 60Hz, and come with interchangeable plugs that allow use in most parts of the world.
The GPSDO kit is compatible with a specific set of USRP models and revisions. Compatibility is determined by hardware characteristics, and therefore incompatible models cannot be upgraded to be made compatible. Before purchasing a GPSDO kit please verify whether it will be compatible with the USRP device you intend to use with it. The compatible models and revisions are:
USRP N200/N210
- USRP N200 Rev 2.0
- USRP N200 Rev 3.0
- USRP N200 Rev 4.0
- USRP N210 Rev 2.0
- USRP N210 Rev 3.0
- USRP N210 Rev 4.0
USRP E100/E110
- USRP E100 Rev 4.0
- USRP E110 Rev 4.0
Please note the USRP hardware revision is on the label on the back of the unit.
The GPSDO kit is not compatible with the USRP1, USRP2, USRP B100 and any revision of the USRP N200/210 and E100/110 series not listed above.
All daughterboards are compatible with all USRP models except for the first 500 USRP1 software defined radios manufactured in 2005. At that time all daughterboards had an onboard local oscillator so the USRP1 did not provide a clock signal required by most of the current daughterboards. The only daughterboards currently compatible with the first 500 USRP1 are the BasicRX, BasicTX, LFRX and LFTX as they do not require a clock signal.
To identify if you have one of the first 500 USRP1 devices, please refer to the serial number as it will be between 1 and 500.
Although unsupported, a workaround exists and can be accessed on the following page: USRP Serial Below 500 on GNU Radio.
