Technical FAQ
Revision as of 14:09, 28 April 2017 by Ettus (Talk | contribs) (→‎Are all daughterboards compatible with all USRP motherboards?)
How do I get started?
For the UHD Getting Started documentation please refer to: UHD Manual.
For the GNU Radio Getting Started documentation please refer to: http://gnuradio.org/redmine/projects/gnuradio/wiki.
Do you have antennas to match your daughterboards?
Yes, we have antennas for nearly every daughterboard which we sell. Please see the ordering page for pictures and specifications at the following links:
What operating systems are supported?
The UHD (USRP Hardware Driver) supports all Ettus Research hardware on the following operating systems:
  • Linux (any distribution should work, but primarily Ubuntu 14.04, 16.04, Fedora 24, Fedora 25, CentOS 7)
  • Mac OS X 10.10, 10.11, 10.12
  • Microsoft Windows 7, 8 ,10
Primary development for UHD is done on Linux.
Are design files available with the boards that may aid in further prototyping?
Yes. Schematics for select USRP devices and daughterboards are available. You can find them here:
http://files.ettus.com/schematics
Are there any license requirement for the transmit or transceive daughterboards?
The USRP hardware is sold as test equipment. If you choose to use your USRP hardware and daughterboards to transmit using an antenna, it is your responsibility to make sure you are in compliance with all laws for the country, frequency and power levels in which the device is used. Additionally, some countries regulate reception in certain frequency bands. Again, it is the responsibility of the user to maintain compliance with all local laws and regulations.
