Revision as of 12:44, 9 May 2017 by Ettus (Talk | contribs) (Gains)
B200
B210
B200mini
B200mini-i
B205mini-i
Frontend Specifications
Tuning
The RF frontend has individually tunable receive and transmit chains. On the B200 and B200 mini, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is tunable between 50 MHz and 6 GHz.
Gains
Bandwidths
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
  • Maximum Input Power: 0 dBm
RF Performance Data
B200mini / B205mini
B200 / B210
Hardware Specifications
B200
  • Current Hardware Revision: 6
  • Minimum version of UHD required: 3.8.4
  • B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
  • Current Hardware Revision: 5
  • Minimum version of UHD required: 3.6.0
B200mini
  • Current Hardware Revision: 2
  • Minimum version of UHD required: 3.9.0
B200mini-i
B205mini-i
  • Minimum version of UHD required: 3.9.2
Physical Specifications
Dimensions
Environmental Specifications
  • B200mini / B200 / B210 0-40 °C
  • B200mini-i / B205mini-i 0-45 °C
Operating Humidity Range
  • 10% to 90% non-condensing
B200mini/B200mini-i/B205mini-i
B200mini/B200mini-i/B205mini-i Schematics
B200/B210
B200/B210 Schematics
Key Component Datasheets
Analog Devices AD9364 RF Transceiver U1 (2)
Analog Devices AD9361 RF Transceiver U2 (2,8)
AD9361/AD9364 Product Page RF Transceiver -
Xilinx Spartan-6 Product Page FPGA U1 (2,3,4,6); PG1 (6); U18B, U18C (7); U18D (8); U18E, U18F (9); U18G, U18H (10)
XC6SLX75 / XC6SLX150 FPGA
ADF4001 Frequency Synthesizer U101 (1)
CYUSB3014 FX3: SuperSpeed USB Controller U3 (5,6); U13 (5)
EZ-USB FX3™ Product Page
SKY13317 Antenna Switch U801, U810 (8)
BD3150L50100A00 Balun U802, U808, U809, U815 (8)
PGA−102+ Amplifier U804, U817 (8)
B200mini VXTCXO VXTCXO (B200mini only) -
M9107 Optional GPSDO (B200/B210 only) U100 (1)
Mechanical Information
Weight
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
B200mini
B200
B210
Enclosures
USRP B200/B210 Enclosure
  • Full Steel Enclosure
FPGA
  • Utilization statistics are subject to change between UHD releases. This information is current as of UHD 3.9.4 and was taken directly from Xilinx Vivado 2014.4.
B200
Device utilization summary:
Slice Logic Utilization:
Slice Logic Distribution:
IO Utilization:
Specific Feature Utilization:
B210
IO Utilization:
B200mini
IO Utilization:
B205mini
IO Utilization:
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
GPIO
Power on state
Output Current
The GPIOs are configured as LVCMOS33 outputs with pull-ups on the B2xx. The strength for LVCMOS and LVTTL on Spartan 6 is 12 mA if not otherwise specified.
Timing Reference Input
  • 1-PPS or 10 MHz input
1-PPS
  • Maximum: -5V / +5V
  • Minimum: 0V / +2.5V
10 MHz
  • Maximum: 0V / +5V
  • Minimum: 0V / +1.8V
OR
  • +10dBm ~ +27dBm
B200/B210
1-PPS
  • Maximum: 5V
10 MHz
  • Maximum: 15dBm (3.5V into 50 ohms)
China RoHS
Chinese Customers
Certificate of Volatility
B200/B210
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
FAQ
The performance and throughput of USB 3.0 can vary between host controllers. Ettus Research recommends using the Intel Series 7, 8, and 9 USB controllers. In Linux, the command lspci will show the USB controller on the system.
1 RX 1.92 2.112 2.184 2.508
2 RX 2.148 2.436 2.508 2.64
1 TX 2.184 2.34 2.352 2.22
2 TX 2.76 2.88 2.904 2.64
