Getting Started with UHD and C++
Revision as of 11:54, 10 August 2017 by Ettus (Talk | contribs) (→‎CMake)
AN-204
Date Author Details
2016-05-01 Neel Pandeya
Nate Temple
Initial creation
This AN explains how to write and build C++ programs that use the UHD API.
This Application Note will walk through building a basic C++ program with UHD. This program will initialize, configure the USRP device, set the sample rate, frequency, gain, bandwidth, and select the antenna.
UHD Manual
The UHD Manual is hosted at http://files.ettus.com/manual/index.html and provides information on how to use the USRP devices and how to use the UHD API to connect to them through your own software. The manual is split into two parts: The device manual, and the UHD/API manual. The first part describes details of Ettus Research devices, motherboards and daughterboards, as well as aspects of using UHD. The second is meant for developers writing UHD-based applications, and includes descriptions of the API, sorted by namespaces, classes, and files.
Including Header Files
    #include <uhd/utils/thread_priority.hpp>
    #include <uhd/utils/safe_main.hpp>
    #include <boost/program_options.hpp>
    #include <boost/format.hpp>
    #include <boost/thread.hpp>
    #include <iostream>
UHD_SAFE_MAIN()
Defines a safe wrapper that places a catch-all around main. If an exception is thrown, it prints to stderr and returns.
    int UHD_SAFE_MAIN(int argc, char *argv[]) {
set_thread_priority_safe()
Set the scheduling priority on the current thread. Same as set_thread_priority but does not throw on failure.
    uhd::set_thread_priority_safe();
Create Variables
    std::string device_args("addr=192.168.10.2");
    std::string subdev("A:0");
    std::string ant("TX/RX");
    std::string ref("internal");
    double rate(1e6);
    double freq(915e6);
    double gain(10);
    double bw(1e6);
Creating a USRP Object
    uhd::usrp::multi_usrp::sptr usrp = uhd::usrp::multi_usrp::make(device_args);
Setting the Motherboard Clocks
Set the clock source for the usrp device. This sets the source for a 10 MHz reference clock. Typical options for source: internal, external, MIMO.
    usrp->set_clock_source(ref)
Selecting the Sub Device
Set the RX frontend specification. The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards. For more details on selecting the Sub Device, see the Specifying the Subdevice section of the UHD Manual.
    usrp->set_rx_subdev_spec(subdev)
Getting the selected Sub Device
    usrp->get_pp_string()
Setting the Sample Rate
Set the RX sample rate. The rate is in Samples Per Second.
    usrp->set_rx_rate(rate)
Getting the Sample Rate
Gets the RX sample rate. Returns the rate is in Samples Per Second.
    usrp->get_rx_rate()
Setting Center Frequency
Create a tune request, with the RF frequency in Hz. Set the RX center frequency.
    uhd::tune_request_t tune_request(freq)
    usrp->set_rx_freq(tune_request)
Getting the Center Frequency
Get the RX center frequency. Returns the frequency in Hz.
    usrp->get_rx_freq()
Setting the RF Gain
Set the RX gain value for the specified gain element. For an empty name, distribute across all gain elements. Sets the gain in dB.
    usrp->set_rx_gain(gain)
Reading the RF Gain
Get the RX gain value for the specified gain element. For an empty name, sum across all gain elements. Returns the gain in dB.
    usrp->get_rx_gain()
Setting the IF Filter Bandwidth
Set the RX bandwidth on the frontend. Sets the bandwidth in Hz.
    usrp->set_rx_bandwidth(bw)
Getting the IF Filter Bandwidth
Get the RX bandwidth on the frontend. Returns the bandwidth in Hz.
    usrp->get_rx_bandwidth()
Selecting the Antenna
Select the RX antenna on the frontend.
    usrp->set_rx_antenna(ant)
Getting the Antenna
Get the selected RX antenna on the frontend. Returns the antenna name.
    usrp->get_rx_antenna()
Exiting
    return EXIT_SUCCESS;
Full Example
#include <iostream>
    double rate(1e6);
    double freq(915e6);
    double gain(10);
    double bw(1e6);
    //create a usrp device
    std::cout << std::endl;
    std::cout << boost::format("Creating the usrp device with: %s...") % device_args << std::endl;
    // Lock mboard clocks
    std::cout << boost::format("Lock mboard clocks: %f") % ref << std::endl;
    usrp->set_clock_source(ref);
    //always select the subdevice first, the channel mapping affects the other settings
    std::cout << boost::format("subdev set to: %f") % subdev << std::endl;
    usrp->set_rx_subdev_spec(subdev);
    std::cout << boost::format("Using Device: %s") % usrp->get_pp_string() << std::endl;
    //set the sample rate
    if (rate <= 0.0) {
        std::cerr << "Please specify a valid sample rate" << std::endl;
        return ~0;
    // set sample rate
    std::cout << boost::format("Setting RX Rate: %f Msps...") % (rate / 1e6) << std::endl;
    usrp->set_rx_rate(rate);
    std::cout << boost::format("Actual RX Rate: %f Msps...") % (usrp->get_rx_rate() / 1e6) << std::endl << std::endl;
    // set freq
    std::cout << boost::format("Setting RX Freq: %f MHz...") % (freq / 1e6) << std::endl;
    uhd::tune_request_t tune_request(freq);
    usrp->set_rx_freq(tune_request);
    std::cout << boost::format("Actual RX Freq: %f MHz...") % (usrp->get_rx_freq() / 1e6) << std::endl << std::endl;
    // set the rf gain
    std::cout << boost::format("Setting RX Gain: %f dB...") % gain << std::endl;
    usrp->set_rx_gain(gain);
    std::cout << boost::format("Actual RX Gain: %f dB...") % usrp->get_rx_gain() << std::endl << std::endl;
    // set the IF filter bandwidth
    std::cout << boost::format("Setting RX Bandwidth: %f MHz...") % (bw / 1e6) << std::endl;
    usrp->set_rx_bandwidth(bw);
    std::cout << boost::format("Actual RX Bandwidth: %f MHz...") % (usrp->get_rx_bandwidth() / 1e6) << std::endl << std::endl;
    // set the antenna
    std::cout << boost::format("Setting RX Antenna: %s") % ant << std::endl;
    usrp->set_rx_antenna(ant);
    std::cout << boost::format("Actual RX Antenna: %s") % usrp->get_rx_antenna() << std::endl << std::endl;
CMake
Use the uhd/host/examples/init_usrp/CMakeLists.txt file as template
  • Add the names of your C++ source files to the add_executable(...) section
  • Put both modified CMakeLists.txt file and C++ file into an empty folder
Compile and Install
  • Create a “build” folder and invoke CMake the usual way:
   mkdir build
   cd build
   cmake ../
   make
Running the Application
$ ./usrp_basic
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-202-g9e0861e1
Creating the usrp device with: addr=192.168.10.2...
-- Opening a USRP2/N-Series device...
-- Current recv frame size: 1472 bytes
-- Current send frame size: 1472 bytes
Lock mboard clocks: internal
subdev set to: A:0
Using Device: Single USRP:
  Device: USRP2 / N-Series Device
  Mboard 0: N210r4
  RX Channel: 0
    RX DSP: 0
    RX Dboard: A
    RX Subdev: WBXv2 RX+GDB
  TX Channel: 0
    TX DSP: 0
    TX Dboard: A
    TX Subdev: WBXv2 TX+GDB
Setting RX Rate: 1.000000 Msps...
Actual RX Rate: 1.000000 Msps...
Setting RX Freq: 915.000000 MHz...
Actual RX Freq: 915.000000 MHz...
Setting RX Gain: 10.000000 dB...
Actual RX Gain: 10.000000 dB...
Setting RX Bandwidth: 1.000000 MHz...
Actual RX Bandwidth: 1.000000 MHz...
Setting RX Antenna: TX/RX
Actual RX Antenna: TX/RX
Additional Example Programs
Additional C++ example programs using the UHD API are provided within the Ettus Research Github Repository, located in the host/examples/ directory. These examples are installed with UHD and will be located at $prefix/lib/uhd/examples directory of your system.
