CBX
Revision as of 12:48, 10 August 2017 by Ettus (Talk | contribs) (RF Specifications)
The CBX is a full-duplex, wideband transceiver that covers a frequency band from 1.2 GHz to 6 GHz with a instantaneous bandwidth of 40 MHz or 120 MHz. The CBX can serve a wide variety of application areas, including WiFi research, cellular base stations, cognitive radio research, and RADAR.
The CBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
  • Frequency Range: 1.2GHz - 6GHz
  • Versions: 40MHz / 120MHz
Daughterboard Specifications
Features
  • 2 quadrature frontends (1 transmit, 1 receive)
    • Defaults to direct conversion
    • Can be used in low IF mode through lo_offset with uhd::tune_request_t
  • Independent receive and transmit LO's and synthesizers
    • Allows for full-duplex operation on different transmit and receive frequencies
    • Can be set to use Integer-N tuning for better spur performance with uhd::tune_request_t
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
  • Frontend 0: Complex baseband signal for selected antenna
  • Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a CBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
  • Transmit Gains: PGA0, Range: 0-31.5dB
  • Receive Gains: PGA0, Range: 0-31.5dB
Bandwidths
  • CBX: 40 MHz, RX & TX
  • CBX-120: 120 MHz, RX & TX
Sensors
  • lo_locked: boolean for LO lock state
LEDs
  • All LEDs flash when daughterboard control is initialized
  • TX LD: Transmit Synthesizer Lock Detect
  • TX/RX: Receiver on TX/RX antenna port (No TX)
  • RX LD: Receive Synthesizer Lock Detect
  • RX1/RX2: Receiver on RX2 antenna port
Freq Range
  • 1.2GHz - 6GHz
Noise Figure
  • 5 - 7.5 dB @ (1.2GHz ~ 5GHz)
  • 7.5dB - 10 dB (5GHz ~ 6GHz)
RX IIP3 (Max)
  • 8 - 10 dBm
RX IQ Imbalance
  • -20 dBc
TX Power (Max)
  • 22 dBm @ (1.2GHz ~ 3GHz)
  • 12 ~ 22 dBm @ (3GHz ~ 6GHz)
TX OIP3
  • 30 - 32 dBm @ (1.2GHz ~ 5GHz)
  • 26 ~ 30 dBm @ (5GHz ~ 6GHz)
TX IQ Imbalance
  • -20 dBc
Input/Output Impedance
  • All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
The maximum input power for the CBX is -15 dBm.
Hardware Specifications
CBX
  • Minimum version of UHD required: 3.8.0
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
CBX-40
  • N or X Series
CBX-120
  • X Series only
Phase Synchronization
The CBX daughterboard is not capable of phase-synchronous operation. The SBX, UBX, TwinRX daughterboards are recommended for phase-coherent applications.
CBX
CBX Schematics
Key Component Datasheets
VMMK-3603 Low Noise Amplifier U1, U5 (1)
AS225-313LF SPDT Switch U3, U6 (1)
HMC624LP4E ATTENUATOR U7, U2 (1)
MGA82563 Amplifier U4 (1)
GVA-84+ Amplifier U9 (1)
PHA-1+ Amplifier U8 (1)
ADL5380ACPZ Quadrature Demodulator U11 (2)
ADA4927-2YCPZ Differential ADC Driver U10 (2)
AD8591ARTZ-REEL Amplifiers U31 (2)
NC7WZ04P6X Dual Inverter U26 (3); U15, U16 (4); U21 (5); U27 (6)
MAX2870ETJ+ Fractional/Integer-N Synthesizer U23 (3); U24 (6)
SKY13267-321 Diversity Switch U12 (3); U25 (6)
LFCN-2000+ Low Pass Filter FL13 (3); FL12 (6)
LP3878MR-ADJ Voltage Regulator U13, U14 (4); U19, U20 (5)
24LC024 EEPROM U17 (4); U22 (5)
ADL5375-05 Quadrature Modulator U18 (5)
Drawings
RF Connectors
  • The CBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
Certificate of Volatility
CBX-40/CBX-120
RF Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
