Software Development on the E3xx USRP - Building RFNoC UHD / GNU Radio / gr-ettus from Source
AN-315
Date | Author | Details |
2017-09-28 | Nate Temple | Initial creation |
This application note is one of a multi-part series which will cover the software development process on the USRP E310, E312 and E313. It will cover building the rfnoc-devel branch of UHD, GNU Radio and gr-ettus from source for the host machine, and cross-compiling the rfnoc-devel branch of UHD, GNU Radio and gr-ettus for the E3xx USRP.
Note: Linux only. The application note has been tested using Ubuntu 16.04.3.
This application note has three sections:
1. Building rfnoc-devel UHD / GNU Radio / gr-ettus for the Host machine
2. Cross-compiling rfnoc-devel UHD / GNU Radio / gr-ettus for the E3xx USRP
3. Running an example application, RFNoC Fosphor
Installing rfnoc-devel UHD / GNU Radio / gr-ettus on the Host
This step is required in order to run the RFNoC Fosphor example. It is possible to operate the E3xx USRP with a RFNoC flowgraph without connecting it to a host machine. All of the processing is performed on the E3xx FPGA, the host is only used to display the FFT/Waterfall.
A more detailed guide to installing UHD / GNU Radio on Linux can be found at the following application note, which can be helpful for reference. https://kb.ettus.com/Building_and_Installing_the_USRP_Open-Source_Toolchain_(UHD_and_GNU_Radio)_on_Linux
This application note is using a vanilla Ubuntu 16.04.3 installation for the host operating system. If you are using another operating system, please refer to the above application note for specifics on dependency requirements. If you already have UHD and GNU Radio installed, you should first remove them before proceeding with this application note.
System Update
$ sudo apt-get update $ sudo apt-get upgrade
Reconfigure Default Shell
Switch your default shell on the host computer from Dash
to Bash
. In some Linux distributions (e.g. Ubuntu) Dash
is set as default shell, which may cause some issues. It is recommended to set the shell to Bash
by running the following commands in the terminal. Choose No
when prompted by the first command and the second command will validate the that Bash
will be used.
$ sudo dpkg-reconfigure dash
Verify Bash is the default shell.
$ ll /bin/sh
Expected Output:
lrwxrwxrwx 1 root root 4 Apr 2 22:00 /bin/sh -> bash*
Install Dependencies
$ sudo apt-get -y install git swig cmake doxygen build-essential libboost-all-dev libtool libusb-1.0-0 libusb-1.0-0-dev libudev-dev libncurses5-dev libfftw3-bin libfftw3-dev libfftw3-doc libcppunit-1.13-0v5 libcppunit-dev libcppunit-doc ncurses-bin cpufrequtils python-numpy python-numpy-doc python-numpy-dbg python-scipy python-docutils qt4-bin-dbg qt4-default qt4-doc libqt4-dev libqt4-dev-bin python-qt4 python-qt4-dbg python-qt4-dev python-qt4-doc python-qt4-doc libqwt6abi1 libfftw3-bin libfftw3-dev libfftw3-doc ncurses-bin libncurses5 libncurses5-dev libncurses5-dbg libfontconfig1-dev libxrender-dev libpulse-dev swig g++ automake autoconf libtool python-dev libfftw3-dev libcppunit-dev libboost-all-dev libusb-dev libusb-1.0-0-dev fort77 libsdl1.2-dev python-wxgtk3.0 git-core libqt4-dev python-numpy ccache python-opengl libgsl-dev python-cheetah python-mako python-lxml doxygen qt4-default qt4-dev-tools libusb-1.0-0-dev libqwt5-qt4-dev libqwtplot3d-qt4-dev pyqt4-dev-tools python-qwt5-qt4 cmake git-core wget libxi-dev gtk2-engines-pixbuf r-base-dev python-tk liborc-0.4-0 liborc-0.4-dev libasound2-dev python-gtk2 libzmq-dev libzmq1 python-requests python-sphinx libcomedi-dev python-zmq
Create Working Directory
This location will be used for building UHD / GNU Radio / gr-ettus for the Host installation.
$ mkdir -p ~/rfnoc $ cd ~/rfnoc
$ git clone https://github.com/EttusResearch/uhd $ cd uhd $ git checkout rfnoc-devel $ mkdir build $ cd build $ cmake -DENABLE_E300=ON .. $ make -j4 $ sudo make install $ sudo ldconfig
Download UHD FPGA Images
$ sudo uhd_images_downloader
Building GNU Radio
$ cd ~/rfnoc $ git clone --recursive https://github.com/gnuradio/gnuradio $ cd gnuradio/ $ git checkout v3.7.10.2 $ mkdir build $ cd build $ cmake .. $ make -j4 $ sudo make install $ sudo ldconfig
Building gr-ettus
$ cd ~/rfnoc $ git clone https://github.com/EttusResearch/gr-ettus.git $ cd gr-ettus $ mkdir build $ cd build $ cmake .. $ make -j4 $ sudo make install $ sudo ldconfig
Verify Installation
Run the following command to verify the rfnoc-devel
branch of UHD was installed properly.
$ uhd_usrp_probe --version
Expected Output:
4.0.0.rfnoc-devel-xxx-xxxxxxxxx
Cross-Compiling rfnoc-devel UHD / GNU Radio / gr-ettus for the E3xx USRP
Working Directory
Make a working directory on host computer for the cross-compiling sources. This is where we will clone, download, cross-compile and install all files.
$ mkdir -p ~/e300
Make a src/
directory within the working directory.
$ mkdir -p ~/e300/src
SDK Setup
Download the OE SDK for the E31x release into the src/
directory:
$ cd ~/e300/src $ wget http://files.ettus.com/e3xx_images/e3xx-release-4/oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
Next, install the SDK to the ~/e300
directory. Enter ~/e300
for the installation directory when prompted.
$ bash oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
Expected Output:
Enter target directory for SDK (default: /usr/local/oecore-x86_64): ~/e300 You are about to install the SDK to "/home/user/e300". Proceed[Y/n]?y Extracting SDK...done Setting it up...done SDK has been successfully set up and is ready to be used.
Your ~/e300
directory should have a structure such as below:
$ ls ~/e300 environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi src version-armv7ahf-vfp-neon-oe-linux-gnueabi site-config-armv7ahf-vfp-neon-oe-linux-gnueabi sysroots
Source the environment setup file:
$ cd ~/e300 $ source ./environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi
Verify the environment has been setup correctly.
$ echo $CC
Expected Output:
arm-oe-linux-gnueabi-gcc -march=armv7-a -mfloat-abi=hard -mfpu=neon --sysroot=/home/user/e300/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi
- Note: If you open a new terminal at any point, you will need to re-run the source command above to initialize the environment. The compiling environment setup is only needed for terminals that are cross-compiling the sources. The terminals used later in this application note which are using SSH to connect to other devices do not need to have the compiling environment initialized.
Next, download the rfnoc-devel
branch of UHD, v3.7.10.2 GNU Radio, and master branch of gr-ettus:
$ cd ~/e300/src $ git clone -b rfnoc-devel https://github.com/EttusResearch/uhd.git
Next, we will cross-compile the rfnoc-devel
branch of UHD.
$ cd uhd/host $ mkdir build $ cd build $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr -DENABLE_E300=ON .. $ make -j4 $ make install DESTDIR=~/e300 $ make install DESTDIR=~/e300/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
Next, we will create an environment setup file that will set the correct system variables to point to our new installation when ran on the E31x.
$ cd ~/e300 $ touch setup_env.sh $ nano setup_env.sh
Add the following lines to setup_env.sh
LOCALPREFIX=~/newinstall/usr export PATH=$LOCALPREFIX/bin:$PATH export LD_LOAD_LIBRARY=$LOCALPREFIX/lib:$LD_LOAD_LIBRARY export LD_LIBRARY_PATH=$LOCALPREFIX/lib:$LD_LIBRARY_PATH export PYTHONPATH=$LOCALPREFIX/lib/python2.7/site-packages:$PYTHONPATH export PKG_CONFIG_PATH=$LOCALPREFIX/lib/pkgconfig:$PKG_CONFIG_PATH export GRC_BLOCKS_PATH=$LOCALPREFIX/share/gnuradio/grc/blocks:$GRC_BLOCKS_PATH export UHD_RFNOC_DIR=$LOCALPREFIX/share/uhd/rfnoc/ export UHD_IMAGES_DIR=$LOCALPREFIX/share/uhd/images
Next, we will need to SSH into the E31x and will mount the ~/e300
folder using SSHFS in order to test our new installation.
- Note: This tutorial assumes you're using the default IP address of
192.168.10.2
for your E31x device, and that your host has the IP address of192.168.10.1
. If you're using different IP addresses, the commands below will need to be updated to reflect the correct IPs.
Open a new terminal and verify that you can ping the E31x:
$ ping 192.168.10.2
Next, SSH into the E31x.
$ ssh root@192.168.10.2
For this next step, your host computer will need to have OpenSSH Server installed.
Open a third terminal window on the host and run:
$ sudo apt-get install openssh-server
Returning to the terminal which you're connected to the E31x via SSH, mount the ~/e300
folder onto the E31x.
First create a directory to mount the remote folder to with (running these commands on the E31x):
$ mkdir -p ~/newinstall $ sshfs username@192.168.10.1:e300 newinstall/
- Note: The "username" in the above command needs to be updated to reflect your user on the host machine.
When prompted, enter the password of your user to complete the mounting of the remote file system.
Verify the mount was successful, your directory structure should match ~/e300
$ ls ~/newinstall/
Expected output:
environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi setup_env.sh site-config-armv7ahf-vfp-neon-oe-linux-gnueabi src sysroots usr version-armv7ahf-vfp-neon-oe-linux-gnueabi
Next, we will need to setup the system environment on the E31x to use the newly compiled version of UHD.
We will first verify that the E31x is using the existing UHD installation, using the which
command:
$ which uhd_usrp_probe
Expected output:
/usr/bin/uhd_usrp_probe
Next, source the setup_env.sh file:
$ cd ~/newinstall $ source ./setup_env.sh
Now we will verify that the newly compiled UHD is being used, again using the which
command:
Expected output:
/home/root/newinstall/usr/bin/uhd_usrp_probe
Next, we must download the correct FPGA images for the new installation. Run the utility uhd_images_downloader
, since the E3xx is not connected to the internet, this will throw an error:
$ uhd_images_downloader
Expected output:
UHD_IMAGES_DIR environment variable is set. Default install location: /home/root/newinstall/usr/share/uhd/images Images destination: /home/root/newinstall/usr/share/uhd/images Downloading images from: http://files.ettus.com/binaries/images/uhd-images_4.0.0.rfnoc-devel-xxx-xxxxxxxxx.zip Downloading images to: /tmp/tmpS1uIFt/4.0.0.rfnoc-devel-xxx-xxxxxxxxx.zip Downloader raised an unhandled exception: ('Connection aborted.', gaierror(-2, 'Name or service not known')) You can run this again with the '--verbose' flag to see more information If the problem persists, please email the output to: support@ettus.com
Note the URL to the FPGA images package which is trying to access. Copy this URL and return to a terminal that is on your host machine and download it into the ~/e300/src
folder.
On the host machine run:
$ cd ~/e300/src $ wget http://files.ettus.com/binaries/images/uhd-images_4.0.0.rfnoc-devel-xxx-xxxxxxxxx.zip
- Note, This FPGA image package will vary depending upon the current version of UHD you are using. You must use the URL that is shown in the above output when trying to run
Next, decompress this file:
$ unzip uhd-images_4.0.0.rfnoc-devel-xxx-xxxxxxxxx.zip
Note, the URL/paths may be slightly different than what is shown above due to different versions, however the process is the same.
Next we must create the folder for the FPGA images.
Navigate to the folder on your host machine:
$ mkdir -p ~/e300/usr/share/uhd/images $ cd ~/e300/usr/share/uhd/images
Verify your directory with the pwd command:
$ pwd
Expected output:
/home/user/e300/usr/share/uhd/images
Now, copy the FPGA images from the decompressed FPGA ZIP package:
$ cp -R ~/e300/src/uhd-images_4.0.0.rfnoc-devel-xxx-xxxxxxxxx/share/uhd/images/* .
Verify the copy was successful:
$ ls
Expected Output:
$ ls 4.0.0.rfnoc-devel.tag usrp_b200_fpga.bin usrp_n200_fw.bin usrp_x300_fpga_RFNOC_XG.bit bit usrp_b200_fw.hex usrp_n200_r2_fpga.bin usrp_x300_fpga_RFNOC_XG.lvbitx LICENSE usrp_b200mini_fpga.bin usrp_n200_r3_fpga.bin usrp_x300_fpga_XG.bit octoclock_bootloader.hex usrp_b205mini_fpga.bin usrp_n200_r4_fpga.bin usrp_x300_fpga_XG.lvbitx octoclock_r4_fw.hex usrp_b210_fpga.bin usrp_n210_fw.bin usrp_x310_fpga_HG.bit usrp1_fpga_4rx.rbf usrp_e100_fpga_v2.bin usrp_n210_r2_fpga.bin usrp_x310_fpga_HG.lvbitx usrp1_fpga.rbf usrp_e110_fpga.bin usrp_n210_r3_fpga.bin usrp_x310_fpga_RFNOC_HG.bit usrp1_fw.ihx usrp_e310_fpga.bit usrp_n210_r4_fpga.bin usrp_x310_fpga_RFNOC_HG.lvbitx usrp2_fpga.bin usrp_e310_fpga_RFNOC.bit usrp_n230_fpga.bit usrp_x310_fpga_RFNOC_XG.bit usrp2_fw.bin usrp_e310_fpga_RFNOC_sg3.bit usrp_x300_fpga_HG.bit usrp_x310_fpga_RFNOC_XG.lvbitx usrp_b100_fpga_2rx.bin usrp_e310_fpga_sg3.bit usrp_x300_fpga_HG.lvbitx usrp_x310_fpga_XG.bit usrp_b100_fpga.bin usrp_e3xx_fpga_idle.bit usrp_x300_fpga_RFNOC_HG.bit usrp_x310_fpga_XG.lvbitx usrp_b100_fw.ihx usrp_e3xx_fpga_idle_sg3.bit usrp_x300_fpga_RFNOC_HG.lvbitx winusb_driver
Next, in order to save space on the E31x when we transfer this build to the E31x, delete all non-E31x FPGA images.
$ rm -v usrp1_f* $ rm -v usrp2_f* $ rm -v usrp_b* $ rm -v usrp_n2* $ rm -v usrp_x3* $ rm -v usrp_e1* $ rm -v octoclock_* $ rm -vrf winusb_driver/ $ rm -vrf bit/
Verify the folder structure:
$ ls
Expected Output:
4.0.0.rfnoc-devel.tag usrp_e310_fpga.bit usrp_e310_fpga_RFNOC_sg3.bit usrp_e3xx_fpga_idle.bit LICENSE usrp_e310_fpga_RFNOC.bit usrp_e310_fpga_sg3.bit usrp_e3xx_fpga_idle_sg3.bit
Next, return to the terminal which is connected via SSH to the E31x and run uhd_usrp_probe
$ uhd_usrp_probe
Expect output:
[INFO] [UHDlinux; GNU C++ version 4.9.2; Boost_105700; UHD_4.0.0.rfnoc-devel-xxx-xxxxxxxxx] [INFO] [E300] Loading FPGA image: /home/root/newinstall/usr/share/uhd/images/usrp_e310_fpga_sg3.bit... [INFO] [E300] FPGA image loaded [INFO] [E300] Initializing core control (global registers)... [INFO] [E300] Performing register loopback test... [INFO] [E300] Register loopback test passed [INFO] [RFNOC RADIO] Register loopback test passed [INFO] [RFNOC RADIO] Register loopback test passed [WARNING] [RFNOC] [0/fosphor_0] defines 2 input buffer sizes, but 1 input ports [INFO] [AD936X] Performing CODEC loopback test... [INFO] [AD936X] CODEC loopback test passed [INFO] [AD936X] Performing CODEC loopback test... [INFO] [AD936X] CODEC loopback test passed [INFO] [CORES] Performing timer loopback test... [INFO] [CORES] Timer loopback test passed _____________________________________________________ / | Device: E-Series Device | _____________________________________________________ | / | | Mboard: E3XX | | product: 30675 | | revision: 6 | | serial: xxxxxxx | | mac-addr: 00:00:00:00:00:00 | | FPGA Version: 255.0 | | FPGA git hash: f764326-dirty | | RFNoC capable: Yes | | | | Time sources: none, internal, external | | Clock sources: internal | | Sensors: temp, ref_locked | | _____________________________________________________ | | / | | | RX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxx | | | _____________________________________________________ | | | / | | | | RX Frontend: A | | | | Name: FE-RX2 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: B | | | | Name: FE-RX1 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: E3x0 RX dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxx | | | _____________________________________________________ | | | / | | | | TX Frontend: A | | | | Name: FE-TX2 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: B | | | | Name: FE-TX1 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: E3x0 TX dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * Radio_0 | | | * FIFO_0 | | | * Window_0 | | | * FFT_0 | | | * fosphor_0 | | | * FIFO_1 | | | * FIR_0
At this point, it's possible to run the included UHD example programs with the newly compiled UHD.
$ cd ~/newinstall/usr/lib/uhd/examples/ $ ./rx_samples_to_file --freq 100e6 --gain 0 --ant TX/RX --rate 1e6 --null
Press CTRL+C
to exit the program.
Cross-Compiling GNU Radio
On the host computer, navigate to the ~/e300/src
directory, clone and cross-compile GNU Radio:
$ cd ~/e300/src $ git clone -b v3.7.10.2 --recursive https://github.com/gnuradio/gnuradio.git $ cd gnuradio/ $ mkdir build $ cd build $ cmake -Wno-dev -DCMAKE_TOOLCHAIN_FILE=../cmake/Toolchains/oe-sdk_cross.cmake -DENABLE_GR_WXGUI=OFF -DENABLE_GR_VOCODER=OFF -DENABLE_GR_DTV=OFF -DENABLE_GR_ATSC=OFF -DENABLE_DOXYGEN=OFF -DCMAKE_INSTALL_PREFIX=/usr ../ $ make -j4 $ make install DESTDIR=~/e300/ $ make install DESTDIR=~/e300/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
Next, verify your GNU Radio installation was successful. On the E31x terminal, run the command:
$ gnuradio-config-info --version
Expected output:
3.7.10.2
Cross-Compiling gr-ettus
Next, we will clone and cross-compile gr-ettus
. On the host machine, navigate to ~/e300/src
$ cd ~/e300/src $ git clone -b master https://github.com/EttusResearch/gr-ettus.git $ cd gr-ettus/ $ mkdir build $ cd build $ cmake -DCMAKE_TOOLCHAIN_FILE=~/e300/src/gnuradio/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. $ make -j4 $ make install DESTDIR=~/e300/ $ make install DESTDIR=~/e300/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
At this point you should have a fully functional UHD RFNoC, GNU Radio and gr-ettus installation. However being that the compiled sources are not located on the E31x we will need to transfer the files to the E31x.
On the host machine navigate to your home directory:
Next, create a folder on the E31x, localinstall
$ mkdir -p ~/localinstall
Next, copy the etc/
, setup_env.sh
and usr/
folder to this new local folder:
$ cd ~/localinstall
$ cp -Rv ~/newinstall/setup_env.sh . $ cp -Rv ~/newinstall/etc . $ cp -Rv ~/newinstall/usr .
Verify the folder contents:
$ ls ~/localinstall
Expected Output:
etc/ setup_env.sh usr/
Next, we will need to update the setup_env.sh
file that is located within the ~/localinstall/
folder.
Verify your directory location with the pwd
command:
$ pwd
Expected Output:
/home/root/localinstall
Edit the setup_env.sh
file to update the PATH
variable to point to your new installation location (/home/root/localinstall
$ sed -i 's/newinstall/localinstall/g' setup_env.sh
Verify your edit was successful with the command cat
$ cat setup_env.sh
Expected Output:
LOCALPREFIX=~/localinstall/usr export PATH=$LOCALPREFIX/bin:$PATH export LD_LOAD_LIBRARY=$LOCALPREFIX/lib:$LD_LOAD_LIBRARY export LD_LIBRARY_PATH=$LOCALPREFIX/lib:$LD_LIBRARY_PATH export PYTHONPATH=$LOCALPREFIX/lib/python2.7/site-packages:$PYTHONPATH export PKG_CONFIG_PATH=$LOCALPREFIX/lib/pkgconfig:$PKG_CONFIG_PATH export GRC_BLOCKS_PATH=$LOCALPREFIX/share/gnuradio/grc/blocks:$GRC_BLOCKS_PATH export UHD_RFNOC_DIR=$LOCALPREFIX/share/uhd/rfnoc/ export UHD_IMAGES_DIR=$LOCALPREFIX/share/uhd/images
Note, the LOCALPREFIX
variable has been updated to the new location.
This setup_env.sh
file needs to be source in order to utilize the new ~/localinstall
location.
Verify that the environment is setup correctly:
Expected Output:
/home/root/localinstall/usr/bin/uhd_usrp_probe
We can now dismount the remotely connected SSHFS folder. On the E31x, run the command:
$ umount ~/newinstall
Running RFNoC Fosphor
In order to run RFNoC Fosphor, we will first need to generate the Python file to be ran on the E3xx USRP.
On the Host machine, open GNU Radio:
$ gnuradio-companion
Within GNU Radio, open the following files:
/home/user/rfnoc/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_host.grc /home/user/rfnoc/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_usrp.grc
Select the rfnoc_fosphor_network_usrp.grc
flowgraph.
Modify the Variable ip_addr
and set the value to match the E3xx USRP's address: 192.168.10.1
Next, click the Generate the flow graph
button. Note the file path in the console where it is generating the rfnoc_fosphor_network_usrp.py
is created.
Copy the generated Python file, rfnoc_fosphor_network_usrp.py
to the E3xx using the scp
utility.
$ scp /home/user/rfnoc/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_usrp.py root@192.168.10.2:~/.
You will now need to SSH to the USRP E3xx.
Verify that the rfnoc_fosphor_network_usrp.py
file was copied to your E3xx.
# ls -al rfnoc_fosphor_network_usrp.py
Expected Output:
root@ettus-e3xx-sg3:~# ls -al rfnoc_fosphor_network_usrp.py -rwxr-xr-- 1 root root 8980 Jan 15 04:43 rfnoc_fosphor_network_usrp.py
Source the Environment Setup file, setup_env.sh
# source ./localinstall/setup_env.sh
Next, run rfnoc_fosphor_network_usrp.py
. Leave this window open in the background.
# python rfnoc_fosphor_network_usrp.py
Return to gnuradio-companion
, select the rfnoc_fosphor_network_host.grc
flowgraph, and click the Execute the flow graph
button.
Maximize the GUI window that has started. RFNoC Fosphor should be running now on the E3xx and be displayed on your host computer. Adjust the Frequency to a strong set of signals, and adjust the Gain slider as needed to produce the best signal to noise ratio for your RF environment.
