N300/N310 Getting Started Guides
Revision as of 20:54, 23 April 2018 by Ettus (Talk | contribs) (Turning the Device Off/On)
Kit Contents
N310
  • USRP N300/N310
  • DC Power Supply (12V, 7A)
  • 1 RJ45 – SFP+ Adapter
  • 1 Gigabit Ethernet Cat-5e Cable (3m)
  • Getting Started Guide
  • Ettus Research Sticker
You Will Need
  • For Network Mode: A host computer with an available 1 or 10 Gigabit Ethernet interface for sample streaming.
  • For Stand-Alone Embedded Mode: A host computer with an available 1 Gigabit Ethernet port or a USB 2.0 port to remotely access the embedded Linux operating system running on ARM CPU.
Proper Care and Handling
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. See the Hardware Specifications section of the USRP N300 Series Hardware Resources page for additional details on which version of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
The USRP N300/N310 requires UHD version 3.11.0.0 or later. Ettus recommends using the latest stable version of UHD. Please consult the UHD Manual at ​[1] for more details on device-specific software features.
Connecting the Device
Powering on for the First Time
You can connect the device to your host computer in the following ways:
  • Using the on-board serial-to-USB connector.
  • Using the RJ-45 Ethernet port and an SSH client on your host computer.
To power on the device for the first time, connect the host computer to the device using the USB cable. This setup allows you to review and modify the network configuration of the device and interact with the bootloader in case of problems during the boot process.
Setting up a Serial Connection
It is possible to gain root access to the device using a serial terminal emulator. Most Linux, OSX, or other Unix flavours have a tool called screen which can be used for this purpose, by running the following command:
In this command, we prepend sudo to elevate user privileges (by default, accessing serial ports is not available to regular users), we specify the device node, in this case, /dev/ttyUSB2, and the baud rate 115200.
   $ ls /dev/serial/by-id
   usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0
   usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to Linux, whereas the second connects to the STM32 microcontroller. If you have multiple N3XX devices connect, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
Boot messages will appear and update rapidly after you power on the device. Once the boot process successfully completes, a login prompt like the following should appear:
   ni-3xx-<motherboard serial #>:
Enter the username ​root​ and leave the password field blank.
   root@ni-n3xx-<motherboard serial #>:~#
   $ sudo screen /dev/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0 115200
Configuring an SSH Connection
The device relies on the DHCP protocol to automatically obtain an IP address when connected over the RJ45 1 Gigabit Ethernet port. If your network setup does not include a DHCP server, refer to the ​Serial Connection​ section above or configure a DHCP server on the network to provide an IP address to the device.
After the device has obtained an IP address, you can remotely log into it from a Linux or macOS system with SSH, as shown below:
   $ ssh [email protected]
On Microsoft Windows, the connection can be established using ​Putty​. Enter the IP address of the device and the username ​root. The password field should be left blank.
You should be presented with a shell like the following:
Find more details on network configuration here: https://files.ettus.com/manual/page_usrp_n3xx.html#n3xx_network_configuration
The device supports multiple, high-speed, low-latency interfaces on the SFP+ ports for streaming samples to the host computer. Complete the steps below to set up a streaming connection over the 1 Gigabit Ethernet interface on the SFP+ port.
1. Configure your Host's Ethernet adapter as shown below:
   IP Address: 192.168.10.1
   Subnet Mask: 255.255.255.0
   Gateway: 0.0.0.0
2. Insert the ​ RJ45 – SFP+ adapter ​into​ SFP Port 0​ .
3. Connect the adapter to a host computer using the Ethernet cable.
The ​ Green LED​ above ​SFP Port 0​ should illuminate.
   $ ping 192.168.10.2
For more details on Network Setup and Configuration, please see the “Interfaces and Connectivity” section on the N300/N310 hardware resources page located within the Ettus Research Knowledge Base at ​https://kb.ettus.com/N300/N310​ .
Verifying Device Operation
Once the UHD driver is installed on the host computer, verify the correct operation of the device by running the various utility programs included in the driver. Refer to the Application Note Verifying the Operation of the USRP Using UHD and GNU Radio.
Upgrading to 10 Gigabit Ethernet
The device also supports dual 10 Gigabit Ethernet connections. To use these interfaces, we recommend our 10 Gigabit Ethernet Connectivity kit. For more information on this accessory, visit https://www.ettus.com/product/details/10GIGE-KIT​. For more information on using the 10 Gigabit Ethernet interface, refer to N300/N310 Hardware Resources Page.
Updating the Filesystem
Before doing any major work with a newly acquired USRP N300/N310, it is recommended to update the file system. Updating the filesystem can be accomplished directly on the N300/N310 by using Mender or externally by manually writing an image onto a micro SD card and inserting it. While manual updating is faster, Mender requires no direct physical access to the device. For details on using Mender, see Section Mender: Remote update capability.
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg, where UHD_INSTALL_DIR is the UHD installation directory.
The <YOUR_IMAGE> is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_n3xx_fs.sdimg).
The <YOUR_SD_CARD> device node depends on your operating system and which other devices are plugged in. Typical values are sdb or mmcblk0. CAUTION: Operating on the wrong device can cause damage to that device.
   shutdown ­-h now
Enable Auto Booting
Auto booting of the N310 when power is applied can be configured by enabling the flag on the device's EEPROM with the following command:
   eeprom-set-flags 0x1
Network Connectivity
By default, the N310 USRP will be configured as a DHCP client on the 1 Gigabit Ethernet port. Assuming your network resolves hostnames (depends on your routers / switches), if you connect the device to your network, you should see it appear with the hostname ni-n3xx-<motherboard serial #>.​ You can then access the device over SSH.
If the hostname does not resolve, you can discover the IP address by logging into the device over the serial connection, or checking your network’s DHCP tables.
Once you have logged in to the device, you can reconfigure the network settings (e.g., you could configure it for a static IP address, if you wish).
Logging In
When you first log in to the device, the user is ‘root’ and the password is empty (no password).
Example Programs
The UHD driver includes several example programs, which may serve as test programs or the basis for your application program. These example programs are already installed on the N300/N310 USRP, and the source code can be obtained from the UHD repository on GitHub at: https://github.com/EttusResearch/uhd/tree/master/host/examples
Test and Verify the Operation of the USRP
You can quickly verify the operation of your USRP N300/N310 by running the rx_ascii_art_dft UHD example program. The rx_ascii_art_dft utility is a simple console ­based, real­time FFT display tool. It is not graphical in nature, so it can be easily run over an SSH connection within a terminal window, and does not need any graphical capability, such as X Windows, to be installed. It can also be run over a serial console connection, although this is not recommended, as the formatting may not render correctly.
You can run a simple test of the N300/N310 USRP by connecting an antenna and observing the spectrum of a commercial FM radio station in real­time. Please follow the steps listed below.
1. Attach an antenna to the RX2­ antenna port of the N310.
2. Log into the N310 from an external host computer over Ethernet using an SSH client.
3. At a terminal prompt running on the N310, run:
   /usr/lib/uhd/examples/rx_ascii_art_dft ­­--freq 88.1e6 ­­--rate 400e3 ­­--gain 30 ­­--ref­-lvl ­-30
4. Modify the command­line argument freq ​above to specify a tuning frequency for a strong local FM radio station.
5. You should see a real­time FFT display of 400 KHz of spectrum, centered at the specified tuning frequency.
6. Type "Q" or Ctrl­-C to stop the program and to return to the Linux command line.
7. You can adjust the size of your terminal window and then re­run the command to enlarge or shrink the FFT display.
8. You can run with the "​­­help"​option to see a description of all available command­line options.
Additional information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
