N300/N310 Getting Started Guides
Revision as of 14:53, 4 June 2018 by NeelPandeya (Talk | contribs) (Example Sample Rates)
Kit Contents
N310
  • USRP N300/N310
  • DC Power Supply (12V, 7A)
  • 1 RJ45 – SFP+ Adapter
  • 1 Gigabit Ethernet Cat-5e Cable (3m)
  • Getting Started Guide
  • Ettus Research Sticker
You Will Need
  • microSD Card Writer
  • For Network Mode: A host computer with an available 1 or 10 Gigabit Ethernet interface for sample streaming. In addition to the Ethernet interface used for sampling streaming, your host computer will require a separate 1 Gigabit Ethernet interface for command and control streaming.
  • For Stand-Alone Embedded Mode: A host computer with an available 1 Gigabit Ethernet port or a USB 2.0 port to remotely access the embedded Linux operating system running on ARM CPU.
Proper Care and Handling
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes.
The USRP N300/N310 requires UHD version 3.11.0.0 or later. It is strongly​ recommended to use the latest stable version of UHD.
To find the latest release of UHD, see the Changelog at: https://github.com/EttusResearch/uhd/blob/master/CHANGELOG
Updating the File-system
Before operating the device, it is​ ​strongly​ recommended to re-image the microSD card with the latest version of the Embedded Linux file-system. The image should match the version of UHD installed on the host computer.
   $ sudo uhd_images_downloader -t sdimg -v
Example Output:
   845962 kB / 845962 kB (100%) n3xx_common_sdimg_default-v3.11.1.0.zip
Example Output:
   Install prefix: /usr/local
Example Output:
   /usr/local/share/uhd/images/usrp_n3xx_fs.sdimg
   dmesg | tail
   [21265.575488] usb-storage 1-2:1.0: USB Mass Storage device detected
   [21266.586983] scsi 0:0:0:0: Direct-Access     Generic  Mass-Storage     1.11 PQ: 0 ANSI: 2
   [21266.588024] sd 0:0:0:0: Attached scsi generic sg0 type 0
   [21267.299812] sd 0:0:0:0: [sdb] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
   [21267.302687]  sdb: sdb1 sdb2 sdb3 sdb4
Example Output:
   $ lsblk
   NAME           MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
   sdb              8:0    1  14.9G  0 disk
   ├─sdb4           8:4    1   128M  0 part  /media/user/data
   ├─sdb2           8:2    1   7.3G  0 part  /media/user/primary
   ├─sdb3           8:3    1   7.3G  0 part  /media/user/secondary
   └─sdb1           8:1    1    16M  0 part  /media/user/boot
   $ sudo umount /media/user/data
   $ sudo umount /media/user/primary
   $ sudo umount /media/user/secondary
   $ sudo umount /media/user/boot
Example Output:
   $ lsblk
   └─sdb1           8:1    d1    16M  0 part
Writing the SD Card Image
NOTE: You must use a 16GB or larger SD card.
The ​<SD_CARD_DEV_NAME>​ device node depends on your operating system and which other devices are plugged in. Typical values are ​sdb​ or mmcblk0​.
In the examples above:
   <IMAGE>=/usr/local/share/uhd/images/usrp_n3xx_fs.sdimg
   <SD_CARD_DEV_NAME>=/dev/sdb
The step of writing the disk image to the SD card can take a while to complete.
Example Output:
   $ sudo dd if=/usr/local/share/uhd/images/usrp_n3xx_fs.sdimg of=/dev/sdb bs=1M
   15160+0 records in
   15160+0 records out
   15896412160 bytes (16 GB, 15 GiB) copied, 1160.93 s, 13.7 MB/s
   $ sync
You can now remove the microSD card from your Host computer and insert it into the USRP N310.
For more information on updating the file-system, refer to the UHD Manual at ​http://uhd.ettus.com.
Connecting the Device
Listed below are the interfaces to connect to the USRP N300/N310. Each interface has specific functionality, limitations and purpose.
Serial Console
The Serial Console provides a low level interface to the device typically used for debugging.
1 Gigabit RJ45 Connection
The 1 Gigabit RJ45 Connection interfaces with the on-board ARM CPU. When operated in "Host mode", this interface is used for UHD management traffic. Regardless of the operation mode (Host vs Embedded) this interface can be used to connect to the ARM via SSH. By default, the 1Gb RJ45 connection is configured to use a DHCP assigned IP address.
Dual SFP+ Connections
The Dual SFP+ Connections support multiple configurations for streaming high-speed, low-latency data, depending upon the FPGA image which is loaded.
It is possible to gain shell access to the device using a serial terminal emulator via the Serial Console port. Most Linux, OSX, or other Unix based operating systems have a tool called screen which can be used for this purpose.
If you do not have screen installed, it can be installed via your package manager. For Ubuntu/Debian based operating systems it can be installed with apt such as:
   sudo apt install screen
   $ ls /dev/serial/by-id
   usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0
   usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to the ARM CPU, whereas the second connects to the STM32 Microcontroller.
If you have multiple N3XX Serial Consoles connected to a single host, you may have to empirically test nodes.
Upon starting the USRP N300/N310, boot messages will appear and rapidly update. Once the boot process successfully completes, a login prompt like the following should appear:
   OpenEmbedded test ni-n3xx-313ABDA ttyPS0
   ni-n3xx-313ABDA login:
Enter the username: ​root
   root@ni-n3xx-<motherboard serial #>:~#
Example Output:
   root@ni-n3xx-313ABDA:~# passwd
   Changing password for root
   Enter the new password (minimum of 5 characters)
   Please use a combination of upper and lower case letters and numbers.
   New password:
   Re-enter new password:
   passwd: password changed.
Using the default configuration, the serial console will show all kernel log messages (which are not available when using SSH), and give access to the boot loader (U-boot prompt). This can be used to debug kernel or boot-loader issues more efficiently than when logged in via SSH.
Using the Serial Console interface, it is possible to connect to the STM32 microcontroller with the command below. The STM32 controls the power sequencing and several other low level device operations.
Connecting to the ARM via SSH
By default, the RJ45 1Gb management interface is configured to be assigned a DHCP IP address.
If you have access to a network which provides a DHCP server (such as a common router's LAN), attach the RJ45 1Gb port to this network. Details vary by vendor, however, most router management interfaces will provide a list of attached devices to the LAN including their IP address.
Example Output:
# ip a
4: sfp1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 8000 qdisc pfifo_fast qlen 1000
   $ sudo dnsmasq -i <ETHERNET_ADAPTER_NAME> --dhcp-range=192.168.1.151,192.168.1.254 --except-interface=lo --bind-dynamic --no-daemon
After the device has obtained an IP address, you can remotely log into it from a Linux or macOS system with SSH, as shown below:
   $ ssh [email protected]
NOTE: The root password will be empty/blank, unless you have updated it as detailed above.
On Microsoft Windows, the SSH connection can be established using the third-party program ​Putty​.
After logging in, you should be presented with a shell like the following:
The USRP N300/N310 systemd network configuration files are located at: /etc/systemd/network/
   # ls /etc/systemd/network/
   eth0.network  sfp0.network  sfp1.network
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=8000
sfp1 (static):
    [Match]
    Name=sfp1
    [Network]
    Address=192.168.20.2/24
    [Link]
    MTUBytes=8000
For addition details on network configuration here: https://files.ettus.com/manual/page_usrp_n3xx.html#n3xx_network_configuration
Updating the FPGA Image
Host Mode FPGA Image Update
The FPGA image should match the version of UHD installed on the host computer, when operated in Host mode. Connect the device to the host computer using either the RJ45 or SFP+ port, refer to the section above for detailed instructions.
To obtain all the FPGA images for a specific version of UHD, run the following command on the host computer with internet access:
   $ sudo uhd_images_downloader -v
Example Output:
   00006 kB / 00006 kB (100%) usrp1_b100_fw_default-g6bea23d.zip
   11698 kB / 11698 kB (100%) n3xx_n310_fpga_default-g61cdf981.zip
   02757 kB / 02757 kB (100%) usrp2_n210_fpga_default-g6bea23d.zip
   02076 kB / 02076 kB (100%) n230_n230_fpga_default-g61cdf981.zip
   00522 kB / 00522 kB (100%) usrp1_b100_fpga_default-g6bea23d.zip
   00465 kB / 00465 kB (100%) b2xx_b200_fpga_default-g1c568e6.zip
   02415 kB / 02415 kB (100%) usrp2_n200_fpga_default-g6bea23d.zip
   29462 kB / 29462 kB (100%) x3xx_x310_fpga_default-g61cdf981.zip
   00517 kB / 00517 kB (100%) b2xx_b205mini_fpga_default-g1c568e6.zip
   28343 kB / 28343 kB (100%) x3xx_x300_fpga_default-g61cdf981.zip
   00017 kB / 00017 kB (100%) octoclock_octoclock_fw_default-g14000041.zip
   04839 kB / 04839 kB (100%) usb_common_windrv_default-g14000041.zip
   00007 kB / 00007 kB (100%) usrp2_usrp2_fw_default-g6bea23d.zip
   00009 kB / 00009 kB (100%) usrp2_n200_fw_default-g6bea23d.zip
   00450 kB / 00450 kB (100%) usrp2_usrp2_fpga_default-g6bea23d.zip
   00144 kB / 00144 kB (100%) b2xx_common_fw_default-g14000041.zip
   00473 kB / 00473 kB (100%) b2xx_b200mini_fpga_default-g1c568e6.zip
   00319 kB / 00319 kB (100%) usrp1_usrp1_fpga_default-g6bea23d.zip
   00009 kB / 00009 kB (100%) usrp2_n210_fw_default-g6bea23d.zip
   08058 kB / 08058 kB (100%) n3xx_n300_fpga_default-g61cdf981.zip
   04442 kB / 04442 kB (100%) e3xx_e310_fpga_default-g61cdf981.zip
   00859 kB / 00859 kB (100%) b2xx_b210_fpga_default-g1c568e6.zip
NOTE: In the above example output, the Images Destination folder is printed:
To list the N310 FPGA images with a full path, run the command:
   $ ls -w 1 /usr/local/share/uhd/images/usrp_n31*.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_HG.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_XG.bit
To update the default HG variant of FPGA image, run the command:
   $ uhd_image_loader --args "type=n3xx,addr=<N310_IP_ADDR>,fpga=HG"
Example Output:
   uhd_image_loader --args "type=n3xx,addr=192.168.1.151,fpga=HG"
   [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.11.1.HEAD-0-gad6b0935
   [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1
   [INFO] [MPM.main] Launching USRP/MPM, version: 3.11.1.0-gunknown
   [INFO] [MPM.main] Spawning RPC process...
   [INFO] [MPM.PeriphManager] Device serial number: 313ABDA
   [INFO] [MPM.PeriphManager] Found 2 daughterboard(s).
   [INFO] [MPM.RPCServer] RPC server ready!
   [INFO] [MPM.RPCServer] Spawning watchdog task...
To load a different default FPGA image (i.e. XG, WG), modify the device argument fpga= to a value of fpga=XG or fpga=WG.
   $ uhd_image_loader --args "type=n3xx,addr=<N310_IP_ADDR>" --fpga-path=/path/to/custom/fpga.bit
The Verilog code for the FPGA in the USRP N300/N310 is open-source, and users are free to modify and customize it for their needs. However, certain modifications may result in either bricking the device, or even in physical damage to the unit. Please note that modifications to the FPGA are made at the risk of the user, and may not be covered by the warranty of the device.
It is possible to update the FPGA image when operated in Embedded mode. Connect to the ARM CPU via Serial Console or SSH as detailed in the section above.
NOTE: The 1 GB RJ45 management interface will require Internet access for the next step.
# uhd_images_downloader
NOTE: The default UHD FPGA Images destination within the N300/N310's file-system is /usr/share/uhd/images. The default UHD FPGA Images destination on a typical host installation is /usr/local/share/uhd/images.
Updating the FPGA image from the ARM CPU is the same as detailed above for a Host mode update:
root@ni-n3xx-313ABDA:~# uhd_image_loader --args "type=n3xx,fpga=HG"
[INFO] [UHD] linux; GNU C++ version 7.2.0; Boost_106400; UHD_3.11.1.0-0-unknown
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=127.0.0.1,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1
For more information on updating the FPGA image, refer to the UHD Manual at http://uhd.ettus.com .
The device supports multiple, high-speed, low-latency interfaces on the SFP+ ports for streaming samples to the host computer.
1Gb Streaming SFP Port 0
Complete the steps below to set up a streaming connection over the 1 Gigabit Ethernet interface on SFP Port 0.
When streaming via SFP Port 0 at 1 Gb speeds, it is important that the connection is direct between the Host and USRP. Placing a switch or other network gear between the Host and USRP can reduce throughput of the transport link. It is also generally recommended to avoid using USB to Ethernet Adapters for the high speed streaming interface, as they may limit performance or cause periodic flow control errors.
NOTE: The HG FPGA image must be loaded for SFP Port 0 to operate at 1Gb speeds. If the XG image is loaded, the port will be unresponsive at 1Gb speeds.
1. Configure your Host's Ethernet adapter as shown below. This interface should be separate from the 1Gb NIC/network which is connected to the 1Gb RJ45 management interface.
   IP Address: 192.168.10.1
   Subnet Mask: 255.255.255.0
   Gateway: 0.0.0.0
   MTU: 8000
NOTE: When operating SFP Port 0 at 1Gb speeds, it is important to set a MTU of 8000 and not a value of automatic.
2. Insert the ​ RJ45 – SFP+ adapter ​into​ SFP Port 0​ .
3. Connect the adapter to a host computer using the Ethernet cable to SFP0.
The ​ Green LED​ above ​SFP Port 0​ should illuminate.
   $ ping 192.168.10.2
   ^C
Proceed to the next section "Verifying Device Operation".
10Gb Streaming SFP Port 1
Complete the steps below to set up a streaming connection over the 10 Gigabit Ethernet interface on SFP Port 1.
NOTE: Both the HG and XG FPGA images support 10Gb speeds over SFP Port 1.
1. Configure your Host's 10Gb Ethernet adapter as shown below.
   IP Address: 192.168.20.1
   Gateway: 0.0.0.0
   MTU: 8000
NOTE: When operating at 10Gb speeds, it is important to set a MTU of 8000 and not a value of automatic.
2. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cable to SFP Port 1.
The ​ Green LED​ above ​SFP Port 1​ should illuminate.
3. To test the connection,​ ​ping​ the device at address 192.168.20.2​ from the host, as shown below:
   $ ping 192.168.20.2
Dual 10Gb Streaming SFP Ports 0/1
Complete the steps below to set up a streaming connections over the Dual 10 Gigabit Ethernet interface on SFP Ports 0/1.
NOTE: The XG FPGA image must be loaded for SFP Port 0 to operate at 10 Gb speeds. If the HG image is loaded, the port will be unresponsive at 10 Gb speeds.
1. Configure your Host's #1 10Gb Ethernet adapter as shown below.
   Gateway: 0.0.0.0
   MTU: 8000
2. Configure your Host's #2 10Gb Ethernet adapter as shown below.
   Gateway: 0.0.0.0
   MTU: 8000
3. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cables to SFP Ports 0/1.
The ​Green LEDs​ above ​SFP Ports 0/1​ should illuminate.
4. To test the SFP Port 0 connection,​ ​ping​ the device at address 192.168.10.2​ from the host, as shown below:
   $ ping 192.168.10.2
5. To test the SFP Port 1 connection,​ ​ping​ the device at address 192.168.20.2​ from the host, as shown below:
   $ ping 192.168.20.2
For more details on Network Setup and Configuration, please see the “Interfaces and Connectivity” section on the N300/N310 hardware resources page located within the Ettus Research Knowledge Base at ​https://kb.ettus.com/N300/N310​ .
Probe the USRP N300/N310
$ uhd_usrp_probe
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,addr=192.168.10.2
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.1.151,product=n310'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1323 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1331 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1339 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1330 MB/s)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_2] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_3] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_2] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_3] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_2] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_3] Initializing block control (NOC ID: 0xD0C0000000000000)
|       Device: N300-Series Device
|   |       Mboard: ni-n3xx-313ABDA
|   |   eeprom_version: 1
|   |   pid: 16962
|   |   product: n310
|   |   rev: 3
|   |   serial: 313ABDA
|   |   type: n3xx
|   |   MPM Version: 1.2
|   |   FPGA Version: 5.2
|   |   RFNoC capable: Yes
|   |   Sensors: gps_time, gps_tpv, fan, gps_locked, gps_sky, temp, ref_locked
|   |   |       RX Dboard: A
|   |   |   |   Antennas: TX/RX, RX2, CAL, LOCAL
|   |   |   |   Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked
|   |   |   |   Freq range: 1.000 to 6000.000 MHz
|   |   |   |   Gain range all: 0.0 to 75.0 step 0.5 dB
|   |   |   |   Gain range rfic: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Gain range dsa: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Gain range amp: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz
|   |   |   |   Name: AD9371 Dual ADC
|   |   |       RX Dboard: B
|   |   |       RX Dboard: C
|   |   |   |       RX Codec: C
|   |   |       RX Dboard: D
|   |   |   |       RX Codec: D
|   |   |       TX Dboard: A
|   |   |   |   Gain range all: 0.0 to 65.0 step 0.5 dB
|   |   |   |   Name: AD9371 Dual DAC
|   |   |       TX Dboard: B
|   |   |       TX Dboard: C
|   |   |   |       TX Codec: C
|   |   |       TX Dboard: D
|   |   |   |       TX Codec: D
|   |   |   * DmaFIFO_0
|   |   |   * Radio_0
|   |   |   * Radio_1
|   |   |   * Radio_2
|   |   |   * Radio_3
|   |   |   * DDC_0
|   |   |   * DDC_1
|   |   |   * DDC_2
|   |   |   * DDC_3
|   |   |   * DUC_0
|   |   |   * DUC_1
|   |   |   * DUC_2
|   |   |   * DUC_3
If you see warnings such as:
   [WARNING] [UDP] The recv buffer could not be resized sufficiently.
You need to resize the socket buffers for your network interface card:
   sudo sysctl -w net.core.rmem_max=288000
   sudo sysctl -w net.core.wmem_max=288000
The USRP N310 contains 4 channels, each represented on the front panel as RF0-3. Below is the subdev mapping of RF Ports.
N310
  • RF0 = A:0
  • RF1 = B:0
  • RF2 = C:0
  • RF3 = D:0
Supported Sample Rates
The USRP N300/N310 supports the three fixed Master Clock Rates listed below.
  • 122.88 MHz
  • 125.00 MHz
  • 153.60 MHz
Listed below are common sample rates for the given master clock rates. This is not a complete listing of the supported sample rates.
Master Clock Rate Decimation / Interpolation Rate
Host Sample Rate [Msps]
1 2 4 6 8 10 12 14 16 18 20 30 32 64 100 128 256 512 1024
122.88e6 61.44e6 30.72e6 20.48e6 15.36e6 12.288e6 10.24e6 8.7771e6 7.68e6 6.8267e6 6.144e6 4.096e6 3.84e6 1.92e6 1.2288e6 960e3 614.4e3 480e3 240e3 120e3
125e6 62.5e6 31.25e6 20.833e6 15.625e6 12.5e6 10.417e6 8.9286e6 7.8125e6 6.9444e6 6.25e6 4.1667e6 3.90625e6 1.953125e6 1.25e6 976.5625e3 625e6 488.28125e3 244.14e6 122.07e6
153.6e6 76.8e6 38.4e6 25.6e6 19.2e6 15.36e6 12.8e6 10.971e6 9.6e6 8.5333e6 7.68e6 5.12e6 4.8e6 2.4e6 1.536e6 1.2e6 768e3 600e3 300e3 150e3
ASCII Art Example
You can quickly verify the operation of your USRP N300/N310 by running the rx_ascii_art_dft UHD example program.
You can run a simple test of the N300/N310 USRP by connecting an antenna and observing the spectrum of a commercial FM radio station in real-time, following the steps below:
1. Attach an antenna to the Ch0/RX2­ antenna port of the N310.
$ /usr/local/lib/uhd/examples/rx_ascii_art_dft --args "master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2" --freq 98.5e6 --rate 2.5e6 --gain 50 --ref-lvl="-50" --dyn-rng 90 --ant "RX2" --subdev "A:0"
NOTE: Modify the command­ line argument freq ​above to specify a tuning frequency for a strong local FM radio station. You will also need to update the IP Address to match your device IP.
3. You should see a real-time FFT display of 2.5 MHz of spectrum, centered at the specified tuning frequency.
4. Type "Q" or Ctrl­-C to stop the program and to return to the Linux command line.
Example Output:
Creating the usrp device with: master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2...
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,master_clock_rate=125e6,addr=192.168.10.2
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.1.151,product=n310,master_clock_rate=125e6'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1336 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1338 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1346 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1350 MB/s)
Using Device: Single USRP:
  Mboard 0: ni-n3xx-313ABDA
  RX Channel: 0
    RX DSP: 0
    RX Dboard: A
    RX Subdev: Magnesium
  TX Channel: 0
    TX DSP: 0
    TX Dboard: A
    TX Subdev: Magnesium
  TX Channel: 1
    TX DSP: 0
    TX Dboard: B
  TX Channel: 2
    TX DSP: 0
    TX Dboard: C
  TX Channel: 3
    TX DSP: 0
    TX Dboard: D
Setting RX Rate: 2.500000 Msps...
Actual RX Rate: 2.500000 Msps...
Setting RX Gain: 50.000000 dB...
Actual RX Gain: 50.000000 dB...
Done!
Benchmarking your system
1 Gb Interface
NOTE: This example requires the HG FPGA image to be loaded.
This example will test one full-duplex stream using "RF0/A:0", at a rate of 3.84 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=122.88e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 3.84e6 \
   --rx_subdev "A:0" \
   --tx_rate 3.84e6 \
   --tx_subdev "A:0"
This example will test four full-duplex streams at 1.25 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=125e6" \
   --duration 60 \
   --channels "0,1,2,3" \
   --rx_rate 1.25e6 \
   --rx_subdev "A:0 B:0 C:0 D:0" \
   --tx_rate 1.25e6 \
   --tx_subdev "A:0 B:0 C:0 D:0"
10 Gb Interface SFP 1
NOTE: This example will work with either the HG or XG FPGA image.
This example will test one full-duplex stream using "RF0/A:0", at a rate of 31.25 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=125e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 31.25e6 \
   --rx_subdev "A:0" \
   --tx_rate 31.25e6 \
   --tx_subdev "A:0"
This example will test four full-duplex streams at 30.72 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=122.88e6" \
   --duration 60 \
   --rx_rate 30.72e6 \
   --tx_rate 30.72e6 \
Dual 10 Gb Interface
NOTE: This example requires the XG FPGA image to be loaded.
This example will test four full-duplex streams at 62.5 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,second_addr=192.168.20.2,master_clock_rate=125e6" \
   --duration 60 \
   --rx_rate 62.5e6 \
   --tx_rate 62.5e6 \
USRP N300/N310 Device Specific Operations
White Rabbit Ethernet-Based Synchronization
Turning the Device Off/On
   shutdown ­-h now
Enable Auto Booting
Auto booting of the N310 when power is applied can be configured by enabling the flag on the device's EEPROM with the following command:
   eeprom-set-flags 0x1
Default Password
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
