Using the RFNoC Replay Block
TBD
| Date | Author | Details |
| 2018-10-05 | Wade Fife | Initial creation |
This application note guides a user through basic use of the RFNoC Replay block and explains how to run the UHD Replay example. This example covers use on the X300/X310 and N310 products.
The Replay block is an RFNoC block that allows recording and playback of arbitrary data using DRAM on the USRP hardware as a buffer. To use the Replay block, it must be instantiated in the design and connected to the DRAM interface. It can take the place of the DMA FIFO(s) or be used concert with the DMA FIFO(s). In this note we will be replacing the DMA FIFO block with the Replay block and running a UHD example that records data to DRAM from a file then plays it back over the radio continuously.
Prerequisites
Cloning the Repository
Your system must be configured for RFNoC development to compile and use the RFNoC examples. Here we briefly explain how to setup a system to build and run the RFNoC Replay example.
Note: Refer to Application Note AN-823 Getting Started with RFNoC Development for a more detailed overview of RFNoC development.
To begin, use the following git clone commands to download the needed UHD and FPGA repositories.
Note: At the time of writing, the UHD example is not in a current release so for this application note we will use the master branches.
$ git clone https://github.com/EttusResearch/uhd.git $ git clone https://github.com/EttusResearch/fpga.git
If UHD and/or FPGA are already installed, then it would be sufficient to checkout the branches mentioned and update them (git pull) then rebuild UHD.
Building and Installing UHD
If you have not already done so, follow the steps in Application Note AN-445 under the heading Update and Install dependencies.
Note: Refer to Application Note AN-445 for detailed instructions on building and installing UHD from the source code. However, RFNoC must be enabled when running CMake in order to run the RFNoC examples. The instructions below summarize the basic steps required to build and install UHD so that you can run the Replay example.
To build and install UHD, begin by opening a terminal in the UHD repository that you cloned, then create a build folder within the host host folder of the repository.
$ cd uhd/host $ mkdir build $ cd build
Run CMake with RFNoC enabled to create the Makefiles.
$ cmake -DENABLE_RFNOC=ON ../
Run Make to build UHD with RFNoC support.
$ make
Install UHD, using the default install prefix, which will install UHD under the /usr/local/lib folder. You need to run this as root due to the permissions on that folder.
$ sudo make install
Update the system's shared library cache.
$ sudo ldconfig
Make sure that the LD_LIBRARY_PATH environment variable is defined and includes the folder under which UHD was installed. Most commonly, you can add the line below to the end of your $HOME/.bashrc file.
Note: the LD_LIBRARY_PATH location may vary depending on your Linux distribution.
$ export LD_LIBRARY_PATH=/usr/local/lib
Installing the FPGA Tools
In order to build the FPGA image for the intended USRP product, you will need to have the Xilinx development tools installed. The specific version required depends on the branch and state of the FPGA code. The UHD-3.13 branches require Vivado 17.4. Refer to the installation instructions for Vivado in order to install these tools. It is recommended that you use the default install location of /opt/Xilinx/Vivado to ensure compatibility with the FPGA build flow.
Building the FPGA
In order to use the Replay block, it must be built into the FPGA image for the USRP you plan to use. This is currently a manual step. The instructions below are for the X310, but similar instructions apply to the N310.
First, we must modify the Verilog code to include the Replay Block. To do this, modify the file fpga/top/x300/x300_core.v and change localparam USE_REPLAY from 0 to 1. This causes the FPGA code to instantiate noc_block_replay instead of noc_block_axi_dma_fifo. Note that the DMA FIFO will not be included in this example and therefore cannot be used.
Note: If using the N310, modify the file fpga/top/n3xx/n3xx_core.v and make the same change. Other products that support RFNoC can also use the replay block. However, in other products, the noc_block_replay instance would need to be manually instantiated in the code following the examples given in the x300_core.v and n3xx_core.v files.
After making the required code change, you are ready to rebuild the FPGA image. Begin by setting up the environment to use the FPGA build tools.
$ cd fpga/usrp3/top/x300 $ source ./setup.sh
Run make to build the desired FPGA image. For example, to build the X310 HG image, use the following command:
$ make X310_HG
Once compilation is complete, download the image to your USRP product. For example, if the X310 HG image were connected to SFP port 0 (1 Gigabit Ethernet) using the default IP address, then you would run the following command.
$ uhd_image_loader --args="type=x300,addr=192.168.10.2" --fpga-path=./build-X310_HG/x300.bit
After the download has completed, power cycle the X310 to load the new bitstream. Confirm that the Replay block appears in the system by running uhd_usrp_probe.
$ uhd_usrp_probe --args="addr=192.168.10.2"
You should see the Replay block listed among the RFNoC blocks on the device.
| | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * Replay_0 | | | * Radio_0 | | | * Radio_1 | | | * DDC_0 | | | * DDC_1 | | | * DUC_0 | | | * DUC_1
Building the Replay Example
In this section we will compile the replay_from_file UHD example. Begin by creating a CMake file for the Replay example using uhd/host/examples/init_usrp/CMakeLists.txt as an example.
$ cd uhd/host/examples $ mkdir replay_samples_from_file $ cd replay_samples_from_file $ cp ../init_usrp/CMakeLists.txt ./
Edit CMakeLists.txt and change the init_usrp references to replay_samples_from_file and init_usrp.cpp to ../replay_samples_from_file.cpp.
You can now invoke CMake and run Make to build the example.
$ mkdir build $ cd build $ cmake ../ $ make
Running the Example
The replay_samples_from_file example assumes that you have a file containing the samples you wish to replay. This could be generated in advance or recorded using rx_samples_to_file or another method.
Note: The replay_samples_from_file example does not perform rate conversion, so the rate specified must match the native sample rate of your device (i.e., 200 Msps for the X300/X310 or 125 Msps for the N310). The samples file should contains sc16 (16-bit signed complex) data samples and should be a multiple of 2 samples (8 bytes) in size, since the Replay block records and plays back in multiples of 8 bytes.
To run the example, enter the following command.
$ ./replay_samples_from_file --freq 915e6 --gain 10 --file usrp_samples.dat
This will replay the data from the file continuously. Press Ctrl+C to stop transmitting.
