E320 Getting Started Guide
- 1 Kit Contents
- 3 You Will Need
- 4 Proper Care and Handling
- 6 Connecting the Device
- 7 Updating the Linux File System
- 8 Updating the Network Configurations
- 9 Updating the FPGA Image
- 10 Setting Up a Streaming Connection
- 11 Verifying Device Operation
- 12 USRP E320 Device Specific Operations
- 13 Technical Support and Community Knowledge Base
- 14 Legal Considerations
- 15 Sales and Ordering Support
- 16 Terms and Conditions of Sale
Kit Contents
E320 Board-only
E320 Full Enclosure
Ensure that your kit contains all the items listed above. If any items are missing, please contact [email protected] immediately.
You Will Need
- For Network Mode: A host computer with an 1 or 10 Gigabit Ethernet interface. Optionally a second 1 Gb Ethernet interface can be used to connect to the onboard ARM CPU. If operating with the 10Gb Ethernet interface, the "XG" FPGA image must be loaded before the SFP+ port will operate at 10Gb speeds.
- For Embedded Mode: A host computer is only required for initial device configuration, remote control and management, or data visualization. The host computer can connect to the RJ45 1 Gb port or Serial Console port to remotely access the Open Embedded Linux operating system running on the ARM CPU. Once configured, the USRP E320 can operate as a stand-alone device without a connection to a remote host computer.
- For Board-only Version: A 12V/7A power supply, which requires assembly to the power connector included in the kit. An assembled power supply can be purchased here: https://www.ettus.com/product/details/12V-PWR
- Never allow anything especially metal objects to touch the board while it is powered on.
- Never allow any water or condensing moisture to come into contact with the device.
- Never touch the circuit board or heatsink while the device is powered on.
- All connections should be made/removed while is device is powered off.
| Never apply more than -15 dBm of power into any RF input. | |
To use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes.
It is strongly recommended to use the latest stable version of UHD. It is generally recommended to use the maintenance branch latest stable version, for example UHD-3.13.
To find the latest release of UHD, see the UHD repository at https://github.com/ettusresearch/uhd.
The USRP E320 requires UHD version 3.13.0.2 or later. It is recommended to use the UHD-3.13 maintenance branch at the time of this writing.
NOTE: Before operating the device, it is strongly recommended to update to the latest version of the Embedded Linux file system. If you are operating the device in Network Mode, the version of UHD running on the host machine and E320 USRP must match.
Interfaces Overview
Listed below are the interfaces to connect to the USRP E320. Each interface has specific functionality, limitations and purpose.
Serial Console
The Serial Console provides a low-level interface to the device, typically used for debugging.
1 Gigabit RJ45 Connection
The 1 Gigabit RJ45 Connection interfaces with the on-board ARM CPU. When operated in "Host mode", this interface is used for UHD management traffic. Regardless of the operation mode (Host vs Embedded) this interface can be used to connect to the ARM via SSH. By default, the 1Gb RJ45 connection is configured to use a DHCP assigned IP address.
SFP+ Connection
The SFP+ Connection supports multiple configurations for streaming high-speed, low-latency data, depending upon which FPGA image is loaded.
It is possible to gain shell access to the device using a serial terminal emulator via the Serial Console port. Most Linux, OS X, or other Unix based operating systems have a utility called screen which can be used for this purpose.
If you do not have screen installed, it can be installed via your distribution's package manager. For Ubuntu/Debian based operating systems it can be installed with the package manager apt such as:
sudo apt install screen
$ ls /dev/serial/by-id usb-FTDI_Dual_RS232-HS-if00-port0 usb-FTDI_Dual_RS232-HS-if01-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A69-if00-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A69-if01-port0
Every E320 series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to the STM32 Microcontroller, whereas the second connects to the ARM CPU.
If you have multiple E320 Serial Consoles connected to a single host, you may have to empirically test nodes.
$ sudo screen /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A69-if01-port0 115200
Upon starting the USRP E320, boot messages will appear and rapidly update. Once the boot process successfully completes, a login prompt like the following should appear:
Alchemy 2018.04 ni-e320-serial ttyPS0 ni-e320-serial login:
Enter the username: root
root@ni-e320-<motherboard serial #>:~#
Using the default configuration, the serial console will show all kernel log messages (which are not available when using SSH) and give access to the boot loader (U-boot prompt). This can be used to debug kernel or boot-loader issues more efficiently than when logged in via SSH.
Using the Serial Console interface, it is possible to connect to the STM32 microcontroller with the command below. The STM32 controls the power sequencing and several other low-level device operations.
$ sudo screen /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A69-if00-port0 115200
Connecting to the ARM via SSH
By default, the RJ45 1 Gb management interface is configured to be assigned a DHCP IP address.
If you have access to a network which provides a DHCP server (such as a common router's LAN), attach the RJ45 1 Gb port to this network. Details vary by vendor, however, most router management interfaces will provide a list of attached devices to the LAN including their IP address.
Example Output:
# ip a
$ sudo dnsmasq -i <ETHERNET_ADAPTER_NAME> --dhcp-range=192.168.1.50,192.168.1.100 --except-interface=lo --bind-dynamic --no-daemon
After the device has obtained an IP address, you can remotely log into it from a Linux or macOS systems with SSH, as shown below:
$ ssh [email protected]
NOTE: The root password will be empty/blank, unless you have updated it as detailed above.
On Microsoft Windows, the SSH connection can be established using the third-party program, such as PuTTY.
After logging in, you should be presented with a shell prompt like the following:
There is two ways to update the file system for the E320 USRP:
1. Mender
File System Partition Layout
The SD Card is divided into four partitions. There is two root file system partitions, a boot partition and a data partition.
Any data you would like to preserve through Mender updates should be saved to the data partition, which is mounted at /data.
Updating the file system with Mender
Mender is third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website https://mender.io). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Mender servers can be self-hosted or hosted by Mender.io (see mender.io for pricing and availability).
Mender Update Process
$ sudo uhd_images_downloader -t mender -t e320
Example Output:
[INFO] Images destination: /usr/local/share/uhd/images 395769 kB / 395769 kB (100%) e3xx_e320_mender_default-v3.13.1.0.zip [INFO] Images download complete.
Next, you will need to copy this Mender file system image to the USRP E320. This can be done with the Linux utility scp.
$ scp /usr/local/share/uhd/images/usrp_e320_fs.mender [email protected]:~/.
Note: The path and IP may different for your configuration, the command above assumes you're using the default installation path of /usr/local and that the E320's IP is 192.168.1.51.
After copying the Mender file system image to the E320, connect to the E320 using either the Serial Console, or via SSH to gain shell access.
On the E320, run mender -rootfs /path/to/latest.mender to update the file system:
root@ni-e320-serial:~# mender -rootfs /home/root/usrp_e320_fs.mender
Example Output:
root@ni-e320-316E375:~# mender -rootfs /home/root/usrp_e320_fs.mender INFO[0000] Start updating from local image file: [/home/root/usrp_e320_fs.mender] module=rootfs Installing update from the artifact of size 399640064 INFO[0000] opening device /dev/mmcblk0p3 for writing module=block_device INFO[0000] partition /dev/mmcblk0p3 size: 2046820352 module=block_device ................................ 0% 1024 KiB ................................ 0% 2048 KiB ................................ 0% 3072 KiB [truncated for readability] ................................ 99% 389120 KiB ................................ 99% 390144 KiB ................................ 100% 390273 KiB INFO[0740] wrote 2046820352/2046820352 bytes of update to device /dev/mmcblk0p3 module=device INFO[0744] Enabling partition with new image installed to be a boot candidate: 3 module=device
$ mender -rootfs <http://server.name/path/to/latest.mender>
$ reboot
$ mender -commit
To identify the currently installed Mender artifact from the command line, the following file can be queried on the E320:
If you are running a hosted Mender server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and you can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is a simple way to update groups of rack-mounted USRPs with custom file systems.
For more information on updating the file-system, refer to the UHD Manual at http://uhd.ettus.com.
Updating the files system by writing the disk image
The microSD card is accessible directly on the Board-only version of the E320 USRP. The E320 Full Enclosure versions must be opened with the included Torx wrench.
NOTE: This will overwrite all data saved on the microSD card, including any data saved to the /data parition.
$ sudo uhd_images_downloader -t sdimg -t e320
Example Output:
$ sudo uhd_images_downloader -t sdimg -t e320 [INFO] Images destination: /usr/local/share/uhd/images [INFO] No inventory file found at /usr/local/share/uhd/images/inventory.json. Creating an empty one. 795674 kB / 795674 kB (100%) e3xx_e320_sdimg_default-v3.13.1.0.zip [INFO] Images download complete.
Example Output:
Install prefix: /usr/local
Example Output:
/usr/local/share/uhd/images/usrp_e320_fs.sdimg
dmesg | tail
[21265.575488] usb-storage 1-2:1.0: USB Mass Storage device detected [21266.586983] scsi 0:0:0:0: Direct-Access Generic Mass-Storage 1.11 PQ: 0 ANSI: 2 [21266.588024] sd 0:0:0:0: Attached scsi generic sg0 type 0 [21267.299812] sd 0:0:0:0: [sdb] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB) [21267.302687] sdb: sdb1 sdb2 sdb3 sdb4
Example Output:
$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sdb 8:16 1 14.9G 0 disk ├─sdb1 8:17 1 16M 0 part /media/user/boot ├─sdb2 8:18 1 1.9G 0 part /media/user/primary ├─sdb3 8:19 1 1.9G 0 part /media/user/secondary └─sdb4 8:20 1 11G 0 part /media/user/data
$ sudo umount /media/user/data $ sudo umount /media/user/primary $ sudo umount /media/user/secondary $ sudo umount /media/user/boot
Example Output:
$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sdb 8:16 1 14.9G 0 disk ├─sdb1 8:17 1 16M 0 part ├─sdb2 8:18 1 1.9G 0 part ├─sdb3 8:19 1 1.9G 0 part └─sdb4 8:20 1 11G 0 part
Writing the SD Card Image
Using dd to write the disk image
NOTE: You must use a 16GB or larger SD card.
The <SD_CARD_DEV_NAME> device node depends on your operating system and which other devices are plugged in. Typical values are sdb or mmcblk0.
In the example above:
<IMAGE>=/usr/local/share/uhd/images/usrp_e320_fs.sdimg <SD_CARD_DEV_NAME>=/dev/sdb
This step of writing the disk image to the SD card can take several minutes to complete.
Example Output:
$ sudo dd if=/usr/local/share/uhd/images/usrp_e320_fs.sdimg of=/dev/sdb bs=1M 15160+0 records in 15160+0 records out 15896412160 bytes (16 GB, 15 GiB) copied, 1160.93 s, 13.7 MB/s
$ sync
You can now remove the microSD card from your host computer and insert it into the USRP E320.
Using bmaptool to write the disk image
The Linux utility bmaptool can be used in place of the utility dd, and will generally write the SD card image faster, however it is not a standard Linux utility and must be installed on your host system.
$ sudo bmaptool copy <IMAGE> <SD_CARD_DEV_NAME> --bmap <IMAGE BMAP (*.sdimg.bmap)>
$ sudo bmaptool copy /usr/local/share/uhd/images/usrp_e320_fs.sdimg /dev/sdb --bmap /usr/local/share/uhd/images/usrp_e320_fs.sdimg.bmap bmaptool: info: block map format version 2.0 bmaptool: info: 3875840 blocks of size 4096 (14.8 GiB), mapped 596649 blocks (2.3 GiB or 15.4%) bmaptool: info: copying image ‘/usr/local/share/uhd/images/usrp_e320_fs.sdimg' to block device '/dev/sdb' using bmap file '/usr/local/share/uhd/images/usrp_e320_fs.sdimg.bmap' bmaptool: info: 100% copied bmaptool: info: synchronizing '/dev/sdb' bmaptool: info: copying time: 4m 10.3s, copying speed 9.3 MiB/sec
The USRP E320 systemd network configuration files are located at: /etc/systemd/network/
# ls /etc/systemd/network/ eth0.network sfp0.network
eth0 (DHCP):
[Match]
Name=eth0
[Network]
DHCP=v4
[DHCPv4]
UseHostname=false
sfp0 (static):
[Match]
Name=sfp0
[Network]
Address=192.168.10.2/24
[Link]
MTUBytes=8000
- Care needs to be taken when editing these files on the device, since
vi/vimsometimes generates undo files (e.g./etc/systemd/network/sfp0.network~), thatsystemd-networkdmight accidentally pick up. - Temporarily setting the IP addresses or MTU sizes via
ifconfigor other command line tools will only change the value until the next reboot or reload of the FPGA image. - If the MTU of the device and host computers differ, streaming issues can occur.
- Streaming via SFP0 at 1 GbE rates requires a MTU of
1500 - Streaming via SFP0 at 10 GbE rates requires a MTU of
8000
For addition details on network configuration here: https://files.ettus.com/manual/page_usrp_e320.html#e320_network_configuration
Host Mode FPGA Image Update
The FPGA image should match the version of UHD installed on the host computer when operated in Host Mode.
Host Mode FPGA image updates must be made through the RJ45 management interface.
To obtain all the FPGA images for your installed version of UHD, run the following command on the host computer with internet access:
$ sudo uhd_images_downloader -t e320 -t fpga
Example Output:
$ uhd_images_downloader -t e320 -t fpga [INFO] Images destination: /usr/local/share/uhd/images [INFO] No inventory file found at /usr/local/share/uhd/images/inventory.json. Creating an empty one. 05920 kB / 05920 kB (100%) e3xx_e320_fpga_default-g494ae8bb.zip [INFO] Images download complete.
There is two versions of the E320 FPGA images shipped with UHD:
- 1G for 1 Gigabit rates on the SFP+ port (default image)
- XG for 10 Gigabit rates on the SFP+ port
In this example, we load the XG variant of the FPGA image.
$ uhd_image_loader --args "type=e3xx,mgmt_addr=<E320_RJ45_IP_ADDR>,fpga=XG"
Example Output:
$ uhd_image_loader --args "mgmt_addr=192.168.1.51,type=e3xx,fpga=XG" [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.13.1.0-1-gd3b7e90a [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.51,type=e3xx,product=e320,serial=316E375,claimed=False,skip_init=1 [INFO] [MPMD] Claimed device without full initialization. [INFO] [MPMD IMAGE LOADER] Starting update. This may take a while. [INFO] [MPM.PeriphManager] Updating component `fpga' [INFO] [MPM.PeriphManager] Updating component `dts' [INFO] [MPM.RPCServer] Resetting peripheral manager. [INFO] [MPM.PeriphManager] Device serial number: 316E375 [INFO] [MPMD IMAGE LOADER] Update component function succeeded. [INFO] [MPM.PeriphManager] Found 1 daughterboard(s).
The FPGA is immediately updated, and this FPGA image will continue to be used. The device does not need to be power cycled to use the new image.
To load a different FPGA image (i.e. 1G), modify the device argument fpga= to a value of fpga=1G.
To specify the path to a custom FPGA image, use the --fpga-path argument.
$ uhd_image_loader --args "type=e3xx,mgmt_addr=<E320_RJ45_IP_ADDR>" --fpga-path=/path/to/custom/fpga.bit
| The Verilog code for the FPGA in the USRP E320 is open-source, and users are free to modify and customize it for their needs. However, certain modifications may result in either bricking the device, or even in physical damage to the unit. Please note that modifications to the FPGA are made at the risk of the user, and may not be covered by the warranty of the device. |
It is possible to update the FPGA image when operated in Embedded mode. Connect to the ARM CPU via Serial Console or SSH as detailed in the section Connecting to the ARM via SSH.
NOTE: The 1 GB RJ45 management interface will require Internet access for this next step.
root@ni-e320-serial:~# python3 /usr/bin/uhd_images_downloader -t e320 -t fpga [INFO] Images destination: /usr/share/uhd/images [INFO] No inventory file found at /usr/share/uhd/images/inventory.json. Creating an empty one. 05920 kB / 05920 kB (100%) e3xx_e320_fpga_default-g494ae8bb.zip [INFO] Images download complete.
NOTE: The default UHD FPGA Images destination within the E320's file-system is /usr/share/uhd/images. The default UHD FPGA Images destination on a typical host installation is /usr/local/share/uhd/images.
Updating the FPGA image from the ARM CPU is the same as detailed above for a Host mode update:
root@ni-e320-serial:~# uhd_image_loader --args "type=e3xx,fpga=1G" [INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106600; UHD_3.13.1.0-0-unknown [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=127.0.0.1,type=e3xx,product=e320,serial=316E375,claimed=False,skip_init=1 [INFO] [MPM.PeriphManager.UDP] No CHDR interfaces found! [INFO] [MPM.PeriphManager.UDP] No CHDR interfaces found! [INFO] [MPMD] Claimed device without full initialization. [INFO] [MPMD IMAGE LOADER] Starting update. This may take a while. [INFO] [MPM.PeriphManager] Updating component `fpga' [INFO] [MPM.PeriphManager] Updating component `dts' [INFO] [MPM.RPCServer] Resetting peripheral manager. [INFO] [MPM.PeriphManager] Device serial number: 316E375 [INFO] [MPMD IMAGE LOADER] Update component function succeeded. [INFO] [MPM.PeriphManager] Found 1 daughterboard(s).
For more information on updating the FPGA image, refer to the UHD Manual at http://uhd.ettus.com.
The device supports multiple high-speed, low-latency interfaces on the SFP+ port for streaming samples to the host computer.
1Gb Streaming via SFP+ Port
Complete the steps below to set up a streaming connection over the 1 Gigabit Ethernet interface on the SFP+ Port.
When streaming via SFP Port at 1 Gb speeds, it is important that the connection is direct between the Host and USRP. Placing a switch or other network gear between the Host and USRP can reduce throughput of the transport link. It is also generally recommended to avoid using USB to Ethernet Adapters for the high-speed streaming interface, as they may limit performance or cause periodic flow control errors.
NOTE: The 1G FPGA image must be loaded for the SFP+ Port to operate at 1Gb speeds. If the XG image is loaded, the port will be unresponsive at 1Gb speeds.
1. Configure your Host's 1Gb Ethernet interface as shown below. This interface should be separate from the 1Gb NIC/network which is connected to the 1Gb RJ45 management interface.
IP Address: 192.168.10.1 Subnet Mask: 255.255.255.0 Gateway: 0.0.0.0 MTU: 1500
NOTE: When operating the SFP Port at 1Gb speeds, it is important to set a MTU of 1500 and not a value of automatic. Mismatched MTU values on either the Host or E320 may cause flow control errors. Your computer may need to be restarted for the MTU value to take effect.
2. Insert the RJ45-to-SFP+ adapter into the SFP Port.
3. Connect the SFP+ adapter on the device to an Ethernet port on the host computer using a standard Ethernet cable.
The Green LED above the SFP Port should illuminate.
4. To test the connection, ping the device at address 192.168.10.2 from the host, as shown below:
$ ping 192.168.10.2 PING 192.168.10.2 (192.168.10.2) 56(84) bytes of data. 64 bytes from 192.168.10.2: icmp_seq=1 ttl=64 time=1.06 ms ^C --- 192.168.10.2 ping statistics --- 1 packets transmitted, 1 received, 0% packet loss, time 0ms rtt min/avg/max/mdev = 1.065/1.065/1.065/0.000 ms
5. Verify your MTU is set correctly for 1 Gb speeds on the E320. See the section Updating the Network Configurations for additional details.
Proceed to the next section Verifying Device Operation.
10Gb Streaming via SFP+ Port
Load the XG FPGA image for 10 Gb streaming as detailed in the section Updating the FPGA Image. You will need to use a 10 GigE cable that can be plugged in directly to the SFP+ connector on the board.
When streaming via SFP+ Port at 10 Gb speeds, it is important that the connection is direct between the Host and USRP. Placing a switch or other network gear between the Host and USRP can reduce throughput of the transport link or cause periodic flow control errors.
NOTE: The XG FPGA image must be loaded for the SFP+ Port to operate at 10Gb speeds. If the 1G image is loaded, the port will be unresponsive at 10Gb speeds. Mismatched MTU values on either the Host or E320 may cause flow control errors.
1. Configure your Host's 10Gb Ethernet interface as shown below.
IP Address: 192.168.10.1 Subnet Mask: 255.255.255.0 Gateway: 0.0.0.0 MTU: 8000
NOTE: When operating the SFP Port at 10Gb speeds, it is important to set a MTU of 8000 and not a value of automatic. Mismatched MTU values on either the Host or E320 may cause flow control errors. Your computer may need to be restarted for the MTU value to take effect.
2. Connect the SFP+ port on the device to an Ethernet port on the host computer using a 10Gb SFP+ copper or fiber cable.
The Green LED above the SFP+ Port should illuminate.
4. To test the connection, ping the device at address 192.168.2v0.2 from the host, as shown below:
5. Verify your MTU is set correctly for 10 Gb speeds on the E320. See the section Updating the Network Configurations for additional details.
The USRP E320 contains 2 channels, each represented on the front panel as RF A and RF B. Below is the subdev mapping of RF Ports.
E320
- RF A = A:0
- RF B = A:1
Supported Sample Rates
The USRP E320 supports master clock rate from 200 kHz to 61.44 MHz and can be changed by adding master_clock_rate= <rate> to the default UHD args. The default master clock rate is 16 MHz.
Probe the USRP E320
$ uhd_usrp_probe --args "addr=192.168.10.2" [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.13.1.0-1-gd3b7e90a [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.10.2,type=e3xx,product=e320,serial=316E375,claimed=False,addr=192.168.10.2 [INFO] [MPM.PeriphManager] init() called with device args `product=e320,mgmt_addr=192.168.10.2'. [INFO] [0/DmaFIFO_0] Initializing block control (NOC ID: 0xF1F0D00000000000) [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1343 MB/s) [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1335 MB/s) [INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000003320) [INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000000) [INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000002) [INFO] [0/Radio_0] Performing CODEC loopback test... [INFO] [0/Radio_0] CODEC loopback test passed [INFO] [0/Radio_0] Performing CODEC loopback test... [INFO] [0/Radio_0] CODEC loopback test passed _____________________________________________________ / | Device: E300-Series Device | _____________________________________________________ | / | | Mboard: ni-e320-316E375 | | eeprom_version: 2 | | mpm_version: 3.13.1.0-gd3b7e90a | | pid: 58144 | | product: e320 | | rev: 2 | | rpc_connection: remote | | serial: 316E375 | | type: e3xx | | MPM Version: 1.2 | | FPGA Version: 3.0 | | RFNoC capable: Yes | | | | Time sources: internal, external, gpsdo | | Clock sources: external, internal, gpsdo | | Sensors: gps_locked, temp_main_power, ref_locked, temp_rf_channelA, temp_fpga, gps_sky, temp_rf_channelB, fan, temp_internal, gps_tpv, gps_time | | _____________________________________________________ | | / | | | RX Dboard: A | | | _____________________________________________________ | | | / | | | | RX Frontend: 0 | | | | Name: Neon | | | | Antennas: RX2, TX/RX | | | | Sensors: lo_locked, ad9361_temperature, rssi, lo_lock | | | | Freq range: 70.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 20000000.0 to 40000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: 1 | | | | Name: Neon | | | | Antennas: RX2, TX/RX | | | | Sensors: lo_locked, ad9361_temperature, rssi, lo_lock | | | | Freq range: 70.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 20000000.0 to 40000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: AD9361 Dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX Dboard: A | | | _____________________________________________________ | | | / | | | | TX Frontend: 0 | | | | Name: Neon | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9361_temperature | | | | Freq range: 47.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 20000000.0 to 40000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: 1 | | | | Name: Neon | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9361_temperature | | | | Freq range: 47.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 20000000.0 to 40000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: AD9361 Dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * DDC_0 | | | * DUC_0
ASCII Art Example
You can quickly verify the operation of your USRP E320 by running the rx_ascii_art_dft UHD example program.
The rx_ascii_art_dft utility is a simple console based, real-time FFT display tool. It is not graphical in nature, so it can be easily run over an SSH connection within a terminal window, and does not need any graphical capability, such as X Windows, to be installed. It can also be run over a serial console connection, although this is not recommended, as the formatting may not render correctly.
You can run a simple test of the E320 USRP by connecting an antenna and observing the spectrum of a commercial FM radio station in real-time, following the steps below:
1. Attach an antenna to the RF A / RX2 antenna port of the E320.
$ /usr/local/lib/uhd/examples/rx_ascii_art_dft \ --args "addr=192.168.10.2" \ --freq 98.5e6 \ --rate 2e6 \ --gain 40 \ --ref-lvl="-30" \ --dyn-rng 90 \ --ant "RX2" \ --subdev "A:0"
NOTE: Modify the commandline argument freq above to specify a tuning frequency for a strong local FM radio station. You will also need to update the IP Address to match your device IP.
3. You should see a real-time FFT display of 2 MHz of spectrum, centered at the specified tuning frequency.
4. Type "Q" to stop the program and to return to the Linux command line.
5. You can run with the --help argument to see a description of all available command-line options.
Example Output:
$ ./rx_ascii_art_dft --args "addr=192.168.10.2" --freq 98.5e6 --rate 2e6 --gain 40 --ref-lvl="-30" --dyn-rng 90 --ant "RX2" --subdev "A:0"
Creating the usrp device with: addr=192.168.10.2...
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1334 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1325 MB/s)
Using Device: Single USRP:
Mboard 0: ni-e320-316E375
RX Channel: 0
RX DSP: 0
RX Dboard: A
RX Subdev: Neon
TX Channel: 0
TX DSP: 0
TX Dboard: A
TX Subdev: Neon
TX Channel: 1
TX DSP: 1
TX Dboard: A
TX Subdev: Neon
Setting RX Rate: 2.000000 Msps...
Actual RX Rate: 2.000000 Msps...
Setting RX Gain: 40.000000 dB...
Actual RX Gain: 40.000000 dB...
Done!
Benchmarking your system
1 Gb Interface
NOTE: This example requires the 1G FPGA image to be loaded.
This example will test one full-duplex stream using "RFA/A:0", at a rate of 2 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "addr=192.168.10.2" \ --duration 60 \ --channels "0" \ --rx_rate 2e6 \ --rx_subdev "A:0" \ --tx_rate 2e6 \ --tx_subdev "A:0"
This example will test two full-duplex streams at 2 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "addr=192.168.10.2" \ --duration 60 \ --channels "0,1" \ --rx_rate 2e6 \ --rx_subdev "A:0 A:1" \ --tx_rate 2e6 \ --tx_subdev "A:0 A:1"
This example will test two full-duplex streams at 12.5 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "addr=192.168.10.2,master_clock_rate=25e6" \ --duration 60 \ --channels "0,1" \ --rx_rate 12.5e6 \ --rx_subdev "A:0 A:1" \ --tx_rate 12.5e6 \ --tx_subdev "A:0 A:1"
10 Gb Interface
NOTE: This example will work with either the XG FPGA image.
This example will test one full-duplex stream using "RFA/A:0", at a rate of 61.44 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "addr=192.168.10.2,master_clock_rate=61.44e6" \ --duration 60 \ --channels "0" \ --rx_rate 61.44e6 \ --rx_subdev "A:0" \ --tx_rate 61.44e6 \ --tx_subdev "A:0"
This example will test two full-duplex stream, at a rate of 30.72 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "addr=192.168.10.2,master_clock_rate=61.44e6" \ --duration 60 \ --channels "0,1" \ --rx_rate 30.72e6 \ --rx_subdev "A:0 A:1" \ --tx_rate 30.72e6 \ --tx_subdev "A:0 A:1"
Turning the Device Off/On
shutdown -h now
Enable Auto Booting
Auto booting of the N310 when power is applied can be configured by enabling the flag on the device's EEPROM with the following command:
eeprom-set-flags 0x1
Default Password
Example Output:
root@ni-e320-serial:~# passwd Changing password for root New password: Re-enter new password: passwd: password changed.
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact [email protected]. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discuss-gnuradio mailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbts-discuss mailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at https://www.ettus.com/support. The Knowledge Base is located at https://kb.ettus.com.
- NOTE: This USRP product is a piece of test equipment.
If you have any non-technical questions related to your order, then please contact us by email at [email protected], or by phone at +14086106399 (Monday-Friday, 8 AM - 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
