SBX
[hide]- 1 Device Overview
- 2 Key Features
- 4 RF Specifications
- 5 Hardware Specifications
- 7 USRP Compatibility
- 8 Phase Synchronization
- 9 Schematics
- 10 Key Component Datasheets
- 11 Drawings
- 12 RF Connectors
- 13 Certifications
- 15 Downloads
The SBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
Features
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
- Note: The user may set the receive antenna to be TX/RX or RX2. However, when using an SBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
- Transmit Gains: PGA0, Range: 0-31.5dB
Bandwidths
- SBX: 40 MHz, RX & TX
- SBX-120: 120 MHz, RX & TX
Sensors
LEDs
- All LEDs flash when daughterboard control is initialized
- TX LD: Transmit Synthesizer Lock Detect
- TX/RX: Receiver on TX/RX antenna port (No TX)
- RX LD: Receive Synthesizer Lock Detect
- RX1/RX2: Receiver on RX2 antenna port
Freq Range
- 400MHz - 4.4GHz
Noise Figure
- 4 - 5 dB @ (400MHz ~ 1.5GHz)
- 5 - 7 dB @ (1.5GHz ~ 3GHz)
- 7 - 12dB @ (3GHz ~ 4.4GHz)
RX IIP3 (Max)
- 16 ~ 22 dBm
RX IQ Imbalance
- -20 dBc @ (400MHz ~ 600MHz)
- -30dBc @ (600MHz ~ 4.4GHz)
TX Power (Max)
- 20 dBm @ (400MHz ~ 3.5GHz)
- 18 - 20dBm @ (3.5GHz ~ 4.4GHz)
TX OIP3
- 26 - 30dBm @ (400MHz ~ 1.5GHz)
- 30 dBm @ (1.5GHz ~ 4.4GHz)
TX IQ Imbalance
Input/Output Impedance
- All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
- The maximum input power for the SBX is -15 dBm.
SBX
- Current Hardware Revision: 5.1
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
The SBX daughterboard is capable of phase-synchronous operation, and is recommended for phase-coherent applications. The UBX and TwinRX daughterboards are also recommended for phase-coherent applications.
SBX
MGA82563 | Amplifier | U1, U5, U4 (1) |
AS225-313LF | SPDT Switch | U3, U6 (1) |
HMC624LP4E | ATTENUATOR | U2, U7 (1) |
LFCN-5850+ | Low Pass Filter | FL1 (1) |
PHA-1+ | Amplifier | U8 (1) |
GVA-84+ | Amplifier | U9 (1) |
ADL5380ACPZ | Quadrature Demodulator | U11 (2) |
ADA4927-2YCPZ | Differential ADC Driver | U10 (2) |
AD8591ARTZ-REEL | Amplifiers | U31 (2) |
ADF4350BCPZ | Synthesizer with Integrated VCO | U23 (3); U24 (6) |
SKY13267 | Diversity Switch | U12 (3); U25 (6) |
LFCN-1200+ | Low Pass Filter | FL13 (3); FL12 (6) |
TC1-1-43A+ | RF Transformer | T3 (2); T2, T5 (3); T4, T6 (6) |
LP3878MR-ADJ | Voltage Regulator | U13, U14 (4); U19, U20 (5) |
NC7WZ04P6X | Dual Inverter | U15, U16 (4); U21 (5); U27 (6); U26 (3) |
24LC024 | EEPROM | U17 (4); U22 (5) |
ADL5375 | Quadrature Modulator | U18 (5) |
Drawings
RF Connectors
China RoHS
Chinese Customers
