DBSRX2
Revision as of 18:20, 3 December 2018 by Ettus (Talk | contribs)
The DBSRX2 is a configurable receiver that can operate from 0.8-2.3 GHz. The DBSRX2 has a programmable 1-60 MHz channel filter that allows users to serve a wide variety of applications while providing the appropriate level of selectivity in the analog path. The DBSRX2 is MIMO capable, and can also power an external LNA or active antenna. Example applications include 902-928 MHz ISM, cellular and PCS, hydrogen and hydroxyl astronomy bands, and DECT.
Note: The maximum operating frequency specification has been reduced from 2.4 to 2.3 GHz.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The DBSRX2 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the DBSRX2 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
