Writing the USRP File System Disk Image to a SD Card
AN-630
Date | Author | Details |
2018-12-12 | Nate Temple | Initial creation |
This application note will provide step-by-step instructions on writing a file system disk image to a SD card using Linux, Windows and OSX.
Required Tools
- Computer with USB2/3 Interface
- UHD Installation
- microSD card to USB Adapter
Downloading the File System Image
To obtain the file system SD card image for your USRP device, run the command in the next step on the host computer with UHD installed and Internet access.
N300/N310
$ sudo uhd_images_downloader -t sdimg -t n3xx
Example Output:
$ sudo uhd_images_downloader -t sdimg -t n3xx [INFO] Images destination: /usr/local/share/uhd/images [INFO] No inventory file found at /usr/local/share/uhd/images/inventory.json. Creating an empty one. 845962 kB / 845962 kB (100%) n3xx_common_sdimg_default-v3.11.1.0.zip [INFO] Images download complete.
E320
$ sudo uhd_images_downloader -t sdimg -t e320
Example Output:
$ sudo uhd_images_downloader -t sdimg -t e320 [INFO] Images destination: /usr/local/share/uhd/images [INFO] No inventory file found at /usr/local/share/uhd/images/inventory.json. Creating an empty one. 795674 kB / 795674 kB (100%) e3xx_e320_sdimg_default-v3.13.1.0.zip [INFO] Images download complete.
In the output of the uhd_images_downloader
command above, the folder destination where the images are saved is printed out.
Example Output:
Install prefix: /usr/local
Writing the File System Image with Linux
dmesg | tail
[21265.575488] usb-storage 1-2:1.0: USB Mass Storage device detected [21266.586983] scsi 0:0:0:0: Direct-Access Generic Mass-Storage 1.11 PQ: 0 ANSI: 2 [21266.588024] sd 0:0:0:0: Attached scsi generic sg0 type 0 [21267.299812] sd 0:0:0:0: [sdb] 31116288 512-byte logical blocks: (15.9 Gb/14.8 GiB) [21267.302687] sdb: sdb1 sdb2 sdb3 sdb4
NOTE: In this specific example configuration, the SD card has been attached to sdb
Another method to finding the device node the disk is attached at is to use the Linux utility lsblk
Example Output:
$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sdb 8:16 1 14.9G 0 disk ├─sdb1 8:17 1 16M 0 part /media/user/boot ├─sdb2 8:18 1 1.9G 0 part /media/user/primary ├─sdb3 8:19 1 1.9G 0 part /media/user/secondary └─sdb4 8:20 1 11G 0 part /media/user/data
Some operating systems by default will auto-mount the partitions on a block device when it is attached. Before writing a new disk image to the SD card, you should first unmount any mounted partitions. This can be done with the Linux utility umount
as shown below:
$ sudo umount /media/user/data $ sudo umount /media/user/primary $ sudo umount /media/user/secondary $ sudo umount /media/user/boot
Running the command lsblk
again will show these partitions have been unmounted:
Example Output:
$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sdb 8:16 1 14.9G 0 disk ├─sdb1 8:17 1 16M 0 part ├─sdb2 8:18 1 1.9G 0 part ├─sdb3 8:19 1 1.9G 0 part └─sdb4 8:20 1 11G 0 part
Writing the SD Card Image
Using dd to write the disk image
WARNING: The Linux utility dd
can cause unrecoverable data loss if the incorrect disk is selected, or if the parameters are input incorrectly. Ensure you have selected the correct input and output parameters for your system configuration.
NOTE: You must use a 16 Gb or larger SD card for the N3xx and E320 file system images.
The <SD_CARD_DEV_NAME>
device node depends on your operating system and which other devices are plugged in. Typical values are sdb
or mmcblk0
The <IMAGE>
value will depend upon which file system image you're writing. Examples for the N300/N310 and E320 are listed below:
N300/N310
<IMAGE>=/usr/local/share/uhd/images/usrp_n3xx_fs.sdimg
E320
<IMAGE>=/usr/local/share/uhd/images/usrp_e320_fs.sdimg
This step of writing the disk image to the SD card can take several minutes to complete.
Example Output:
$ sudo dd if=/usr/local/share/uhd/images/usrp_<deivce>_fs.sdimg of=/dev/sdb bs=1M 15160+0 records in 15160+0 records out 15896412160 bytes (16 Gb, 15 GiB) copied, 1160.93 s, 13.7 MB/s
To ensure the disk is synchronized, run the sync
command:
$ sync
You can now remove the microSD card from your host computer and insert it into the USRP.
Using bmaptool to write the disk image
The Linux utility bmaptool
can be used in place of the utility dd
, and will generally write the SD card image faster, however it is not a standard Linux utility and must be installed on your host system.
$ sudo bmaptool copy <IMAGE> <SD_CARD_DEV_NAME> --bmap <IMAGE BMAP (*.sdimg.bmap)>
$ sudo bmaptool copy /usr/local/share/uhd/images/usrp_<deivce>_fs.sdimg /dev/sdb --bmap /usr/local/share/uhd/images/usrp_<device>_fs.sdimg.bmap bmaptool: info: block map format version 2.0 bmaptool: info: 3875840 blocks of size 4096 (14.8 GiB), mapped 596649 blocks (2.3 GiB or 15.4%) bmaptool: info: copying image ‘/usr/local/share/uhd/images/usrp_<device>_fs.sdimg' to block device '/dev/sdb' using bmap file '/usr/local/share/uhd/images/usrp_<device>_fs.sdimg.bmap' bmaptool: info: 100% copied bmaptool: info: synchronizing '/dev/sdb' bmaptool: info: copying time: 4m 10.3s, copying speed 9.3 MiB/sec
