N300/N310 Getting Started Guides
- 1 Kit Contents
- 3 You Will Need
- 4 Proper Care and Handling
- 6 Connecting the Device
- 7 Updating the Linux File System
- 8 Updating the Network Configurations
- 9 Updating the FPGA Image
- 10 Setting Up a Streaming Connection
- 11 Verifying Device Operation
- 12 USRP N300/N310 Device Specific Operations
- 13 Technical Support and Community Knowledge Base
- 14 Legal Considerations
- 15 Sales and Ordering Support
- 16 Terms and Conditions of Sale
Kit Contents
N300/N310
- USRP N300/N310
- DC Power Supply (12V, 7A)
- 1 RJ45 – SFP+ Adapter
- 1 Gigabit Ethernet Cat-5e Cable (3m)
- USB-A to Micro USB-B Cable (1m)
- Getting Started Guide
- Ettus Research Sticker
Ensure that your kit contains all the items listed above. If any items are missing, please contact [email protected] immediately.
You Will Need
- microSD Card Writer
- For Network Mode: A host computer with an available 1 or 10 Gigabit Ethernet interface for sample streaming. In addition to the Ethernet interface used for sampling streaming, your host computer will require a separate 1 Gigabit Ethernet interface for command and control streaming.
- For Stand-Alone Embedded Mode: A host computer with an available 1 Gigabit Ethernet port or a USB 2.0 port to remotely access the embedded Linux operating system running on ARM CPU.
- Never allow any water or condensing moisture to come into contact with the device.
| Never apply more than -15 dBm of power into any RF input. | |
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes.
It is strongly recommended to use the latest stable version of UHD. It is generally recommended to use the maintenance branch of the latest stable version, for example UHD-3.13.
To find the latest release of UHD, see the UHD repository at https://github.com/ettusresearch/uhd.
The USRP N310 requires UHD version 3.11.0.0 or later.
The USRP N300 requires UHD version 3.12.0.0 or later.
White Rabbit Ethernet-Based Synchronization of the N3xx USRP requires UHD version 3.12.0.0 or later. For additional details on White Rabbit Ethernet-Based Synchronization, please see the application note, Using Ethernet-Based Synchronization on the USRP™ N3xx Devices.
NOTE: Before operating the device, it is strongly recommended to update to the latest version of the Embedded Linux file system. If you are operating the device in Network Mode, the version of UHD running on the host machine and N3xx USRP must match.
Interfaces Overview
Listed below are the interfaces to connect to the USRP N300/N310. Each interface has specific functionality, limitations and purpose.
Serial Console
The Serial Console provides a low level interface to the device typically used for debugging.
1 Gigabit RJ45 Connection
The 1 Gigabit RJ45 Connection interfaces with the on-board ARM CPU. When operated in "Host mode", this interface can optionally be used for UHD management traffic. Regardless of the operation mode (Host vs Embedded) this interface can be used to connect to the ARM via SSH. By default, the 1Gb RJ45 connection is configured to use a DHCP assigned IP address.
Dual SFP+ Connections
The Dual SFP+ Connections support multiple configurations for streaming high-speed, low-latency data, depending upon the FPGA image which is loaded.
It is possible to gain shell access to the device using a serial terminal emulator via the Serial Console port. Most Linux, OSX, or other Unix based operating systems have a tool called screen which can be used for this purpose.
If you do not have screen installed, it can be installed via your package manager. For Ubuntu/Debian based operating systems it can be installed with apt such as:
sudo apt install screen
$ ls /dev/serial/by-id usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0 usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0 usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to the ARM CPU, whereas the second connects to the STM32 Microcontroller.
If you have multiple N3XX Serial Consoles connected to a single host, you may have to empirically test nodes.
Upon starting the USRP N300/N310, boot messages will appear and rapidly update. Once the boot process successfully completes, a login prompt like the following should appear:
OpenEmbedded test ni-n3xx-313ABDA ttyPS0 ni-n3xx-313ABDA login:
Enter the username: root
root@ni-n3xx-<motherboard serial #>:~#
Using the default configuration, the serial console will show all kernel log messages (which are not available when using SSH), and give access to the boot loader (U-boot prompt). This can be used to debug kernel or boot-loader issues more efficiently than when logged in via SSH.
Using the Serial Console interface, it is possible to connect to the STM32 microcontroller with the command below. The STM32 controls the power sequencing and several other low level device operations.
Connecting to the ARM via SSH
By default, the RJ45 1Gb management interface is configured to be assigned a DHCP IP address.
If you have access to a network which provides a DHCP server (such as a common router's LAN), attach the RJ45 1Gb port to this network. Details vary by vendor, however, most router management interfaces will provide a list of attached devices to the LAN including their IP address.
Example Output:
# ip a
4: sfp1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 8000 qdisc pfifo_fast qlen 1000
$ sudo dnsmasq -i <ETHERNET_ADAPTER_NAME> --dhcp-range=192.168.1.151,192.168.1.254 --except-interface=lo --bind-dynamic --no-daemon
After the device has obtained an IP address, you can remotely log into it from a Linux or macOS system with SSH, as shown below:
$ ssh [email protected]
NOTE: The root password default password is empty/blank.
On Microsoft Windows, the SSH connection can be established using the third-party program Putty.
After logging in, you should be presented with a shell like the following:
There is two ways to update the file system for the N3xx USRP:
1. Mender
File System Partition Layout
The SD Card is divided into four partitions. There is two root file system partitions, a boot partition and a data partition.
Any data you would like to preserve through Mender updates should be saved to the data partition, which is mounted at /data.
Updating the file system with Mender
Mender is third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website https://mender.io). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Users can host their own local Mender server, or use servers hosted by Mender as a paid service; contact Mender for more information.
Mender Update Process
$ sudo uhd_images_downloader -t mender -t n3xx --yes
Example Output:
[INFO] Images destination: /usr/local/share/uhd/images 451639 kB / 451639 kB (100%) n3xx_common_mender_default-v3.14.0.0.zip [INFO] Images download complete.
Next, you will need to copy this Mender file system image to the USRP N3xx. This can be done with the Linux utility scp.
$ scp /usr/local/share/uhd/images/usrp_n3xx_fs.mender [email protected]:~/.
Note: The path and IP may different for your configuration, the command above assumes you're using the default installation path of /usr/local and that the N3xx's IP is 192.168.1.51.
After copying the Mender file system image to the N3xx, connect to the N3xx using either the Serial Console, or via SSH to gain shell access.
On the N3xx, run mender -rootfs /path/to/latest.mender to update the file system:
root@ni-n3xx-serial:~# mender -rootfs /home/root/usrp_n3xx_fs.mender
Example Output:
root@ni-n3xx-serial:~# mender -rootfs /home/root/usrp_n3xx_fs.mender INFO[0000] Configuration file does not exist: /var/lib/mender/mender.conf module=config INFO[0000] Loaded configuration file: /etc/mender/mender.conf module=config INFO[0000] Mender running on partition: /dev/mmcblk0p2 module=main INFO[0000] Start updating from local image file: [/home/root/usrp_n3xx_fs.mender] module=rootfs Installing update from the artifact of size 460989952 INFO[0000] no public key was provided for authenticating the artifact module=installer INFO[0000] opening device /dev/mmcblk0p3 for writing module=block_device INFO[0000] partition /dev/mmcblk0p3 size: 7851737088 module=block_device ................................ 0% 1024 KiB ................................ 0% 2048 KiB ................................ 0% 3072 KiB [truncated for readability] ................................ 99% 448512 KiB ................................ 99% 449536 KiB ................................ 100% 450185 KiB INFO[3004] wrote 7851737088/7851737088 bytes of update to device /dev/mmcblk0p3 module=device INFO[3009] Enabling partition with new image installed to be a boot candidate: 3 module=device
$ mender -rootfs <http://server.name/path/to/latest.mender>
$ reboot
$ mender -commit
To identify the currently installed Mender artifact from the command line, the following file can be queried on the N3xx:
If you are using a Mender server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and you can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is a simple way to update groups of rack-mounted USRPs with custom file systems.
For more information on updating the file-system, refer to the UHD Manual at https://uhd.ettus.com.
Updating the files system by writing the disk image
Please see the separate application note, Writing the USRP File System Disk Image to a SD Card, for step-by-step instructions on writing the file system image to the SD card.
The USRP N300/N310 systemd network configuration files are located at: /etc/systemd/network/
# ls /etc/systemd/network/ eth0.network sfp0.network sfp1.network
eth0 (DHCP):
[Match]
Name=eth0
[Network]
DHCP=v4
[DHCPv4]
UseHostname=false
sfp0 (static):
[Match]
Name=sfp0
[Network]
Address=192.168.10.2/24
[Link]
MTUBytes=8000
sfp1 (static):
[Match]
Name=sfp1
[Network]
Address=192.168.20.2/24
[Link]
MTUBytes=8000
- Care needs to be taken when editing these files on the device, since
vi/vimsometimes generates undo files (e.g./etc/systemd/network/sfp0.network~), thatsystemd-networkdmight accidentally pick up. - Temporarily setting the IP addresses or MTU sizes via
ifconfigor other command line tools will only change the value until the next reboot or reload of the FPGA image. - If the MTU of the device and host computers differ, streaming issues can occur.
For addition details on network configuration here: https://files.ettus.com/manual/page_usrp_n3xx.html#n3xx_network_configuration
Host Mode FPGA Image Update
The FPGA image should match the version of UHD installed on the host computer, when operated in Host mode. Connect the device to the host computer using either the RJ45 or SFP+ port, refer to the section above for detailed instructions.
To obtain all the FPGA images for a specific version of UHD, run the following command on the host computer with internet access:
$ sudo uhd_images_downloader -v
Example Output:
$ sudo uhd_images_downloader -v [INFO] Images destination: /usr/local/share/uhd/images 00006 kB / 00006 kB (100%) usrp1_b100_fw_default-g6bea23d.zip 11698 kB / 11698 kB (100%) n3xx_n310_fpga_default-g61cdf981.zip 02757 kB / 02757 kB (100%) usrp2_n210_fpga_default-g6bea23d.zip 02076 kB / 02076 kB (100%) n230_n230_fpga_default-g61cdf981.zip 00522 kB / 00522 kB (100%) usrp1_b100_fpga_default-g6bea23d.zip 00465 kB / 00465 kB (100%) b2xx_b200_fpga_default-g1c568e6.zip 02415 kB / 02415 kB (100%) usrp2_n200_fpga_default-g6bea23d.zip 29462 kB / 29462 kB (100%) x3xx_x310_fpga_default-g61cdf981.zip 00517 kB / 00517 kB (100%) b2xx_b205mini_fpga_default-g1c568e6.zip 28343 kB / 28343 kB (100%) x3xx_x300_fpga_default-g61cdf981.zip 00017 kB / 00017 kB (100%) octoclock_octoclock_fw_default-g14000041.zip 04839 kB / 04839 kB (100%) usb_common_windrv_default-g14000041.zip 00007 kB / 00007 kB (100%) usrp2_usrp2_fw_default-g6bea23d.zip 00009 kB / 00009 kB (100%) usrp2_n200_fw_default-g6bea23d.zip 00450 kB / 00450 kB (100%) usrp2_usrp2_fpga_default-g6bea23d.zip 00144 kB / 00144 kB (100%) b2xx_common_fw_default-g14000041.zip 00473 kB / 00473 kB (100%) b2xx_b200mini_fpga_default-g1c568e6.zip 00319 kB / 00319 kB (100%) usrp1_usrp1_fpga_default-g6bea23d.zip 00009 kB / 00009 kB (100%) usrp2_n210_fw_default-g6bea23d.zip 08058 kB / 08058 kB (100%) n3xx_n300_fpga_default-g61cdf981.zip 04442 kB / 04442 kB (100%) e3xx_e310_fpga_default-g61cdf981.zip 00859 kB / 00859 kB (100%) b2xx_b210_fpga_default-g1c568e6.zip [INFO] Images download complete.
NOTE: In the above example output, the Images Destination folder is printed:
To list the N310 FPGA images with a full path, run the command:
$ ls -w 1 /usr/local/share/uhd/images/usrp_n31*.bit /usr/local/share/uhd/images/usrp_n310_fpga_HG.bit /usr/local/share/uhd/images/usrp_n310_fpga_XG.bit
To update the default HG variant of FPGA image, run the command:
$ uhd_image_loader --args "type=n3xx,addr=<N310_IP_ADDR>,fpga=HG"
Example Output:
uhd_image_loader --args "type=n3xx,addr=192.168.1.151,fpga=HG" [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.11.1.HEAD-0-gad6b0935 [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1 [INFO] [MPM.main] Launching USRP/MPM, version: 3.11.1.0-gunknown [INFO] [MPM.main] Spawning RPC process... [INFO] [MPM.PeriphManager] Device serial number: 313ABDA [INFO] [MPM.PeriphManager] Found 2 daughterboard(s). [INFO] [MPM.PeriphManager.UDP] No CHDR interfaces found! [INFO] [MPM.PeriphManager.UDP] No CHDR interfaces found! [INFO] [MPM.RPCServer] RPC server ready! [INFO] [MPM.RPCServer] Spawning watchdog task... [INFO] [MPM.PeriphManager.UDP] No CHDR interfaces found! [INFO] [MPMD] Claimed device without full initialization. [INFO] [MPMD IMAGE LOADER] Starting update. This may take a while. [INFO] [MPM.PeriphManager] Updating component `fpga' [INFO] [MPM.PeriphManager] Updating component `dts' [INFO] [MPM.RPCServer] Resetting peripheral manager. [INFO] [MPM.PeriphManager] Device serial number: 313ABDA [INFO] [MPM.PeriphManager] Found 2 daughterboard(s). [INFO] [MPMD IMAGE LOADER] Update component function succeeded.
To load a different default FPGA image (i.e. XG, WG), modify the device argument fpga= to a value of fpga=XG or fpga=WG.
To specify the path to a custom FPGA image, use the --fpga-path argument.
$ uhd_image_loader --args "type=n3xx,addr=<N310_IP_ADDR>" --fpga-path=/path/to/custom/fpga.bit
The Verilog code for the FPGA in the USRP N300/N310 is open-source, and users are free to modify and customize it for their needs. However, certain modifications may result in either bricking the device, or even in physical damage to the unit. Please note that modifications to the FPGA are made at the risk of the user, and may not be covered by the warranty of the device.
It is possible to update the FPGA image when operated in Embedded mode. Connect to the ARM CPU via Serial Console or SSH as detailed in the section above.
NOTE: The 1 GB RJ45 management interface will require Internet access for the next step.
# uhd_images_downloader [INFO] Images destination: /usr/share/uhd/images [INFO] No inventory file found at /usr/share/uhd/images/inventory.json. Creating an empty one. 00006 kB / 00006 kB (100%) usrp1_b100_fw_default-g6bea23d.zip 11698 kB / 11698 kB (100%) n3xx_n310_fpga_default-g61cdf981.zip 02757 kB / 02757 kB (100%) usrp2_n210_fpga_default-g6bea23d.zip 02076 kB / 02076 kB (100%) n230_n230_fpga_default-g61cdf981.zip 00522 kB / 00522 kB (100%) usrp1_b100_fpga_default-g6bea23d.zip 00465 kB / 00465 kB (100%) b2xx_b200_fpga_default-g1c568e6.zip 02415 kB / 02415 kB (100%) usrp2_n200_fpga_default-g6bea23d.zip 29462 kB / 29462 kB (100%) x3xx_x310_fpga_default-g61cdf981.zip 00517 kB / 00517 kB (100%) b2xx_b205mini_fpga_default-g1c568e6.zip 28343 kB / 28343 kB (100%) x3xx_x300_fpga_default-g61cdf981.zip 00017 kB / 00017 kB (100%) octoclock_octoclock_fw_default-g14000041.zip 04839 kB / 04839 kB (100%) usb_common_windrv_default-g14000041.zip 00007 kB / 00007 kB (100%) usrp2_usrp2_fw_default-g6bea23d.zip 00009 kB / 00009 kB (100%) usrp2_n200_fw_default-g6bea23d.zip 00450 kB / 00450 kB (100%) usrp2_usrp2_fpga_default-g6bea23d.zip 00144 kB / 00144 kB (100%) b2xx_common_fw_default-g14000041.zip 00473 kB / 00473 kB (100%) b2xx_b200mini_fpga_default-g1c568e6.zip 00319 kB / 00319 kB (100%) usrp1_usrp1_fpga_default-g6bea23d.zip 00009 kB / 00009 kB (100%) usrp2_n210_fw_default-g6bea23d.zip 08058 kB / 08058 kB (100%) n3xx_n300_fpga_default-g61cdf981.zip 04442 kB / 04442 kB (100%) e3xx_e310_fpga_default-g61cdf981.zip 00859 kB / 00859 kB (100%) b2xx_b210_fpga_default-g1c568e6.zip [INFO] Images download complete.
NOTE: The default UHD FPGA Images destination within the N300/N310's file-system is /usr/share/uhd/images. The default UHD FPGA Images destination on a typical host installation is /usr/local/share/uhd/images.
Updating the FPGA image from the ARM CPU is the same as detailed above for a Host mode update:
root@ni-n3xx-313ABDA:~# uhd_image_loader --args "type=n3xx,fpga=HG" [INFO] [UHD] linux; GNU C++ version 7.2.0; Boost_106400; UHD_3.11.1.0-0-unknown [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=127.0.0.1,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1 [INFO] [MPMD] Claimed device without full initialization. [INFO] [MPMD IMAGE LOADER] Starting update. This may take a while. [INFO] [MPM.PeriphManager] Updating component `fpga' [INFO] [MPM.PeriphManager] Updating component `dts' [INFO] [MPM.RPCServer] Resetting peripheral manager. [INFO] [MPM.PeriphManager] Device serial number: 313ABDA [INFO] [MPM.PeriphManager] Found 2 daughterboard(s). [INFO] [MPMD IMAGE LOADER] Update component function succeeded.
For more information on updating the FPGA image, refer to the UHD Manual at http://uhd.ettus.com .
The device supports multiple, high-speed, low-latency interfaces on the SFP+ ports for streaming samples to the host computer.
1Gb Streaming SFP Port 0
Complete the steps below to set up a streaming connection over the 1 Gigabit Ethernet interface on SFP Port 0.
When streaming via SFP Port 0 at 1 Gb speeds, it is important that the connection is direct between the Host and USRP. Placing a switch or other network gear between the Host and USRP can reduce throughput of the transport link. It is also generally recommended to avoid using USB to Ethernet Adapters for the high speed streaming interface, as they may limit performance or cause periodic flow control errors.
NOTE: The HG FPGA image must be loaded for SFP Port 0 to operate at 1Gb speeds. If the XG image is loaded, the port will be unresponsive at 1Gb speeds.
1. Configure your Host's Ethernet adapter as shown below. This interface should be separate from the 1Gb NIC/network which is connected to the 1Gb RJ45 management interface.
IP Address: 192.168.10.1 Subnet Mask: 255.255.255.0 Gateway: 0.0.0.0 MTU: 8000
NOTE: When operating SFP Port 0 at 1Gb speeds, it is important to set a MTU of 8000 and not a value of automatic.
2. Insert the RJ45 – SFP+ adapter into SFP Port 0 .
3. Connect the adapter to a host computer using the Ethernet cable to SFP0.
The Green LED above SFP Port 0 should illuminate.
4. To test the connection, ping the device at address 192.168.10.2 from the host, as shown
below:
$ ping 192.168.10.2 PING 192.168.10.2 (192.168.10.2) 56(84) bytes of data. 64 bytes from 192.168.10.2: icmp_seq=1 ttl=64 time=1.06 ms ^C --- 192.168.10.2 ping statistics --- 1 packets transmitted, 1 received, 0% packet loss, time 0ms rtt min/avg/max/mdev = 1.065/1.065/1.065/0.000 ms
Proceed to the next section "Verifying Device Operation".
10Gb Streaming SFP Port 1
Complete the steps below to set up a streaming connection over the 10 Gigabit Ethernet interface on SFP Port 1.
NOTE: Both the HG and XG FPGA images support 10Gb speeds over SFP Port 1.
1. Configure your Host's 10Gb Ethernet adapter as shown below.
IP Address: 192.168.20.1 Subnet Mask: 255.255.255.0 Gateway: 0.0.0.0 MTU: 8000
NOTE: When operating at 10Gb speeds, it is important to set a MTU of 8000 and not a value of automatic.
2. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cable to SFP Port 1.
The Green LED above SFP Port 1 should illuminate.
3. To test the connection, ping the device at address 192.168.20.2 from the host, as shown
below:
$ ping 192.168.20.2
Dual 10Gb Streaming SFP Ports 0/1
Complete the steps below to set up a streaming connections over the Dual 10 Gigabit Ethernet interface on SFP Ports 0/1.
NOTE: The XG FPGA image must be loaded for SFP Port 0 to operate at 10 Gb speeds. If the HG image is loaded, the port will be unresponsive at 10 Gb speeds.
1. Configure your Host's #1 10Gb Ethernet adapter as shown below.
2. Configure your Host's #2 10Gb Ethernet adapter as shown below.
3. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cables to SFP Ports 0/1.
The Green LEDs above SFP Ports 0/1 should illuminate.
4. To test the SFP Port 0 connection, ping the device at address 192.168.10.2 from the host, as shown below:
$ ping 192.168.10.2
5. To test the SFP Port 1 connection, ping the device at address 192.168.20.2 from the host, as shown below:
$ ping 192.168.20.2
For more details on Network Setup and Configuration, please see the “Interfaces and Connectivity” section on the N300/N310 hardware resources page located within the Ettus Research Knowledge Base at https://kb.ettus.com/N300/N310 .
N300
The USRP N300 contains 2 channels, each represented on the front panel as RF0-1. Below is the subdev mapping of RF Ports.
- RF0 = A:0
- RF1 = A:1
N310
The USRP N310 contains 4 channels, each represented on the front panel as RF0-3. Below is the subdev mapping of RF Ports.
UHD 3.11.x.x - 3.12.x.x
- RF0 = A:0
- RF1 = B:0
- RF2 = C:0
- RF3 = D:0
UHD 3.13.x.x+
- RF0 = A:0
- RF1 = A:1
- RF2 = B:0
- RF3 = B:1
Supported Sample Rates
The USRP N300/N310 supports the three fixed Master Clock Rates listed below.
- 122.88 MHz
- 125.00 MHz
- 153.60 MHz
Example Sample Rates
Listed below are common sample rates for the given master clock rates. This is not a complete listing of the supported sample rates.
| Master Clock Rate | Decimation / Interpolation Rate Host Sample Rate [Msps] | |||||||||||||||||||
| 1 | 2 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 | 30 | 32 | 64 | 100 | 128 | 200 | 256 | 512 | 1024 | |
| 122.88e6 | 61.44e6 | 30.72e6 | 20.48e6 | 15.36e6 | 12.288e6 | 10.24e6 | 8.7771e6 | 7.68e6 | 6.8267e6 | 6.144e6 | 4.096e6 | 3.84e6 | 1.92e6 | 1.2288e6 | 960e3 | 614.4e3 | 480e3 | 240e3 | 120e3 | |
| 125e6 | 62.5e6 | 31.25e6 | 20.833e6 | 15.625e6 | 12.5e6 | 10.417e6 | 8.9286e6 | 7.8125e6 | 6.9444e6 | 6.25e6 | 4.1667e6 | 3.90625e6 | 1.953125e6 | 1.25e6 | 976.5625e3 | 625e3 | 488.28125e3 | 244.14e3 | 122.07e3 | |
| 153.6e6 | 76.8e6 | 38.4e6 | 25.6e6 | 19.2e6 | 15.36e6 | 12.8e6 | 10.971e6 | 9.6e6 | 8.5333e6 | 7.68e6 | 5.12e6 | 4.8e6 | 2.4e6 | 1.536e6 | 1.2e6 | 768e3 | 600e3 | 300e3 | 150e3 | |
Probe the USRP N300/N310
$ uhd_usrp_probe [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.13.1.HEAD-0-ga0a71d10 [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.10.2,type=n3xx,product=n310,serial=313ABDA,claimed=False,addr=192.168.10.2 [INFO] [MPM.main] Launching USRP/MPM, version: 3.13.1.0-gd3b7e90a [INFO] [MPM.main] Spawning RPC process... [INFO] [MPM.PeriphManager] Device serial number: 313ABDA [INFO] [MPM.PeriphManager] Initialized 2 daughterboard(s). [INFO] [MPM.PeriphManager] init() called with device args `time_source=internal,clock_source=internal'. [INFO] [MPM.RPCServer] RPC server ready! [INFO] [MPM.RPCServer] Spawning watchdog task... [INFO] [0/DmaFIFO_0] Initializing block control (NOC ID: 0xF1F0D00000000004) [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1355 MB/s) [INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.10.2,clock_source=internal,time_source=internal,product=n310'. [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1358 MB/s) [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1355 MB/s) [INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1345 MB/s) [INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000011312) [INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000011312) [INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000000) [INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000000) [INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000002) [INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000002) _____________________________________________________ / | Device: N300-Series Device | _____________________________________________________ | / | | Mboard: ni-n3xx-313ABDA | | eeprom_version: 1 | | mpm_version: 3.13.1.0-gd3b7e90a | | pid: 16962 | | product: n310 | | rev: 3 | | rpc_connection: remote | | serial: 313ABDA | | type: n3xx | | MPM Version: 1.2 | | FPGA Version: 5.2 | | RFNoC capable: Yes | | | | Time sources: internal, external, gpsdo, sfp0 | | Clock sources: external, internal, gpsdo | | Sensors: gps_tpv, ref_locked, gps_time, gps_locked, temp, gps_sky, fan | | _____________________________________________________ | | / | | | RX Dboard: A | | | _____________________________________________________ | | | / | | | | RX Frontend: 0 | | | | Name: Magnesium | | | | Antennas: TX/RX, RX2, CAL, LOCAL | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 75.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: 1 | | | | Name: Magnesium | | | | Antennas: TX/RX, RX2, CAL, LOCAL | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 75.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: AD9371 Dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RX Dboard: B | | | _____________________________________________________ | | | / | | | | RX Frontend: 0 | | | | Name: Magnesium | | | | Antennas: TX/RX, RX2, CAL, LOCAL | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 75.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: 1 | | | | Name: Magnesium | | | | Antennas: TX/RX, RX2, CAL, LOCAL | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 75.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: B | | | | Name: AD9371 Dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX Dboard: A | | | _____________________________________________________ | | | / | | | | TX Frontend: 0 | | | | Name: Magnesium | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 65.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: 1 | | | | Name: Magnesium | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 65.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: AD9371 Dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX Dboard: B | | | _____________________________________________________ | | | / | | | | TX Frontend: 0 | | | | Name: Magnesium | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 65.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: 1 | | | | Name: Magnesium | | | | Antennas: TX/RX | | | | Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked | | | | Freq range: 1.000 to 6000.000 MHz | | | | Gain range all: 0.0 to 65.0 step 0.5 dB | | | | Gain range rfic: 0.0 to 0.0 step 0.0 dB | | | | Gain range dsa: 0.0 to 0.0 step 0.0 dB | | | | Gain range amp: 0.0 to 0.0 step 0.0 dB | | | | Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: B | | | | Name: AD9371 Dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * DmaFIFO_0 | | | * Radio_0 | | | * Radio_1 | | | * DDC_0 | | | * DDC_1 | | | * DUC_0 | | | * DUC_1
If you see warnings such as:
[WARNING] [UDP] The recv buffer could not be resized sufficiently.
You need to resize the socket buffers for your network interface card:
sudo sysctl -w net.core.rmem_max=288000 sudo sysctl -w net.core.wmem_max=288000 sudo sysctl -w net.core.rmem_max=33554432
ASCII Art Example
You can quickly verify the operation of your USRP N300/N310 by running the rx_ascii_art_dft UHD example program.
The rx_ascii_art_dft utility is a simple console based, real-time FFT display tool. It is not graphical in nature, so it can be easily run over an SSH connection within a terminal window, and does not need any graphical capability, such as X Windows, to be installed. It can also be run over a serial console connection, although this is not recommended, as the formatting may not render correctly.
You can run a simple test of the N300/N310 USRP by connecting an antenna and observing the spectrum of a commercial FM radio station in real-time, following the steps below:
1. Attach an antenna to the Ch0/RX2 antenna port of the N310.
$ /usr/local/lib/uhd/examples/rx_ascii_art_dft --args "master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2" --freq 98.5e6 --rate 2.5e6 --gain 50 --ref-lvl="-50" --dyn-rng 90 --ant "RX2" --subdev "A:0"
NOTE: Modify the command line argument freq above to specify a tuning frequency for a strong local FM radio station. You will also need to update the IP Address to match your device IP.
3. You should see a real-time FFT display of 2.5 MHz of spectrum, centered at the specified tuning frequency.
4. Type "Q" or Ctrl-C to stop the program and to return to the Linux command line.
5. You can run with the --help argument to see a description of all available command-line options.
Example Output:
Creating the usrp device with: master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2...
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,master_clock_rate=125e6,addr=192.168.10.2
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.1.151,product=n310,master_clock_rate=125e6'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1336 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1338 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1346 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1350 MB/s)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_2] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_3] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_2] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_3] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_2] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_3] Initializing block control (NOC ID: 0xD0C0000000000000)
Using Device: Single USRP:
Mboard 0: ni-n3xx-313ABDA
RX Channel: 0
RX DSP: 0
RX Dboard: A
RX Subdev: Magnesium
TX Channel: 0
TX DSP: 0
TX Dboard: A
TX Subdev: Magnesium
TX Channel: 1
TX DSP: 0
TX Dboard: B
TX Channel: 2
TX DSP: 0
TX Dboard: C
TX Channel: 3
TX DSP: 0
TX Dboard: D
Setting RX Rate: 2.500000 Msps...
Actual RX Rate: 2.500000 Msps...
Setting RX Gain: 50.000000 dB...
Actual RX Gain: 50.000000 dB...
Done!
Benchmarking your system
1 Gb Interface
NOTE: This example requires the HG FPGA image to be loaded.
This example will test one full-duplex stream using "RF0/A:0", at a rate of 3.84 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=122.88e6" \ --duration 60 \ --channels "0" \ --rx_rate 3.84e6 \ --rx_subdev "A:0" \ --tx_rate 3.84e6 \ --tx_subdev "A:0"
This example will test four full-duplex streams at 1.25 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=125e6" \ --duration 60 \ --channels "0,1,2,3" \ --rx_rate 1.25e6 \ --rx_subdev "A:0 A:1 B:0 B:1" \ --tx_rate 1.25e6 \ --tx_subdev "A:0 A:1 B:0 B:1"
10 Gb Interface SFP 1
NOTE: This example will work with either the HG or XG FPGA image.
This example will test one full-duplex stream using "RF0/A:0", at a rate of 31.25 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=125e6" \ --duration 60 \ --channels "0" \ --rx_rate 31.25e6 \ --rx_subdev "A:0" \ --tx_rate 31.25e6 \ --tx_subdev "A:0"
This example will test four full-duplex streams at 30.72 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=122.88e6" \ --duration 60 \ --channels "0,1,2,3" \ --rx_rate 30.72e6 \ --rx_subdev "A:0 A:1 B:0 B:1" \ --tx_rate 30.72e6 \ --tx_subdev "A:0 A:1 B:0 B:1"
Dual 10 Gb Interface
NOTE: This example requires the XG FPGA image to be loaded.
This example will test four full-duplex streams at 62.5 MS/s, for 60 seconds:
/usr/local/lib/uhd/examples/benchmark_rate \ --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,second_addr=192.168.20.2,master_clock_rate=125e6" \ --duration 60 \ --channels "0,1,2,3" \ --rx_rate 62.5e6 \ --rx_subdev "A:0 A:1 B:0 B:1" \ --tx_rate 62.5e6 \ --tx_subdev "A:0 A:1 B:0 B:1"
Turning the Device Off/On
shutdown -h now
Enable Auto Booting
Auto booting of the N310 when power is applied can be configured by enabling the flag on the device's EEPROM with the following command:
eeprom-set-flags 0x1
Default Password
Example Output:
root@ni-n3xx-serial:~# passwd Changing password for root New password: Re-enter new password: passwd: password changed.
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact [email protected]. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discuss-gnuradio mailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbts-discuss mailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at https://www.ettus.com/support. The Knowledge Base is located at https://kb.ettus.com.
- NOTE: This USRP product is a piece of test equipment.
If you have any non-technical questions related to your order, then please contact us by email at [email protected], or by phone at +14086106399 (Monday-Friday, 8 AM - 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
