USRP-2974 Getting Started Guide
Revision as of 07:15, 4 June 2019 by NeelPandeya (Talk | contribs) (Note on USRP-2974 Rev A Hardware)
Kit Contents
  • NI USRP-2974
  • 30 dB SMA Attenuator
  • SMA-male to SMA-male Cable
  • Power Supply
  • Getting Started Guide
Make sure that your kit contains all the items listed above. If any items are missing, please contact your sales agent.
Unpacking the Kit
1. To prevent electrostatic discharge (ESD) from damaging the device, ground yourself using a grounding strap or by holding a grounded object, such as your computer chassis.
2. Remove the device from the package and inspect the device for loose components or any other sign of damage.
3. Never touch the exposed pins of connectors.
4. Unpack any other items and documentation from the kit.
NOTE: Do not install a device if it appears damaged in any way. Store the device in the antistatic package when the device is not in use.
Proper Care and Handling
All NI products are individually tested before shipment. The USRP™ is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP™ can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
  • Always handle the USRP with proper anti-static methods.
  • Never allow the USRP to directly or indirectly come into contact with any voltage spikes.
  • Never allow any water, or condensing moisture, to come into contact with the USRP.
Never apply more than +10 dBm of power into RF ports RF0 and RF1.
Never apply more than +15 dBm of power into the REF IN input.
Never apply more than -15 dBm of power into the GPS ANT input.
Install and Setup the Software Tools on the onboard computer (SoM-System on Module)
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on the SoM. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on the Linux Application Note. Release 3.15.0 or later of the USRP Hardware Driver, UHD, is needed.
Basic Connectivity
This USRP-2974 host supports multiple, high-speed, low-latency interface options to the FPGA. To setup the device, follow these basic instructions:
  • Configure the host ethernet adapter (enp1s0f0) to use an IP address of 192.168.40.1 and a subnet mask of 255.255.255.0
  • Configure the host ethernet adapter (enp1s0f1) to use an IP address of 192.168.30.1 and a subnet mask of 255.255.255.0 (loopback with SFP+ cable needed)
  • To test communications, ping the USRP FPGA at address "192.168.40.2" or “192.168.30.2”
For more details on network setup, including PCIe connectivity, please see the section Interfaces and Connectivity of the NI USRP-2974 Hardware Resources page.
Test and Verify the Operation of the USRP
Once the software tools are installed on the onboard computer, verify the correct operation of the USRP by running the utility programs on the onboard computer. More information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Enabling PXE Boot
Legacy PXE Boot
  • When rebooting the USRP-2974 open BIOS with DEL and go to Boot tab
  • Enable PXE Network Boot with Legacy option, restart the system
  • Go into the BIOS’ Boot tab and set IBA CL Slot 00FE v0105 as first boot option, restart the system
UEFI PXE Boot
  • Enable PXE Network Boot with UEFI option, restart the system
  • Go into the BIOS’ Boot tab and set IPv4 as first boot option, restart the system
NI USRP RIO PCIe Support
If you are connecting the USRP-2974 through the PCIe interface, then complete this section.
If you are connecting the USRP-2974 through the 1G or 10G Ethernet connection then do NOT complete this section.
  1. Installer and commands taken from https://files.ettus.com/manual/page_ni_rio_kernel.html
  2. Extract the installer and install as described (note the _ instead of – in the folder name)
  3. Enable or disable the PCIe link
    1. $ sudo /usr/local/bin/niusrprio_pcie start
    2. $ sudo /usr/local/bin/niusrprio_pcie stop
  4. Check the status
    1. $ sudo /usr/local/bin/niusrprio_pcie status
  5. see the connection over PCIe with
    1. $ uhd_find_devices
To find out if you have a "Rev A" hardware version of the USRP-2974 check the last character of the part number on the USRP-2974. E.g. "146873A"
To fully support Rev A with UHD software, install UHD as explained and run the following command:
   $ /usr/local/lib/uhd/utils/usrp_burn_mb_eeprom --args="addr=192.168.40.2" --value="product=31131"
After a reboot run:
   $ uhd_find_devices</code>
Under the product category section you will see the following:
   NI-2974
Legal Considerations
Sales and Ordering Support
If you have any non­-technical questions related to your order, then please contact us by email at [email protected]​. Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
Additional Resources
