GPSDO Kit
Product Compatibility
Specifications
Module Specifications
1 PPS Accuracy
±50ns to UTC RMS (1-Sigma) GPS Locked
Holdover Stability
<±11μs over 3 hour period at +25C
1 PPS Output (OCXO Flywheel Generated)
3.3VDC CMOS
RS-232 Control
NMEA & SCPI-99 Control Commands, Integrated into UHD
GPS Frequency
L1, C/A 1574MHz
GPS Antenna
Active (3V compatible) or Passive
GPS Receiver
50 Channels, Mobile, WAAS, EGNOS, MSAS capable
Sensitivity
Acquisition -144dBm, Tracking -160dBm
TTFF
Cold Start: <45 sec, Warm Start: 1 sec, Hot Start: 1 sec
ADEV
1E-11 at 1s
Warm Up Time / Stabilization Time
<5 min at +25C to 1E-08 Accuracy
Supply Voltage (Vdd)
6VDC
Power Consumption
<1.8W Max, 1.35W Typical
Operating Temperature
0C to +60C
Storage Temperature
-45C to 85C
Oscillator Specifications
Frequency Output
10MHz
10MHz Retrace
±2E-08 after 1 hour at 25C
Frequency Stability Over Temperature (Unlock Condition)
±2.5E-08
Warm Up Time
< 1 min at +25C
Phase Noise at 10MHz
1Hz
-80dBc/Hz
10Hz
-110dBc/Hz
100Hz
-135dBc/Hz
1kHz
-145dBc/Hz
10kHz
<-145dBc/Hz
Installation Guide
Media:gpsdo-kit 4.pdf
GPSDO (OCXO)
Specifications
1 PPS Accuracy
Holdover Stability
<±20μs over 3 hour period at +25C
3.3VDC CMOS
RS-232 Control
GPS Frequency
L1, C/A 1574MHz
GPS Antenna
Active (5V compatible) or Passive
GPS Receiver
Sensitivity
Acquisition -142dBm, Tracking -168dBm
TTFF
ADEV
1E-11 at 1s
3.3/5VDC
Power Consumption
0.7W Max
0C to +60C
Storage Temperature
-45C to 85C
Frequency Output
10MHz
10MHz Retrace
±2.5E-08
Warm Up Time
< 1 min at +25C
1Hz
-75dBc/Hz
10Hz
-110dBc/Hz
100Hz
-132dBc/Hz
1kHz
-142dBc/Hz
10kHz
<-145dBc/Hz
Certificate of Volatility
GPSDO (TCXO)
Specifications
1 PPS Accuracy
3.3VDC CMOS
RS-232 Control
GPS Frequency
L1, C/A 1574MHz
GPS Antenna
GPS Receiver
Sensitivity
TTFF
ADEV
1E-11 at 1s
3.3V
Power Consumption
0.5W Max
0C to +60C
Storage Temperature
-45C to 85C
Frequency Output
10MHz
10MHz Retrace
±7.5E-08
Warm Up Time
< 1 min at +25C
1Hz
-65dBc/Hz
10Hz
-102dBc/Hz
100Hz
-132dBc/Hz
10kHz
<-152dBc/Hz
Manufacturer Samtec
PN: BBL-115-G-E
