GPSDO Kit
Product Compatibility
Specifications
| Module Specifications
| 1 PPS Accuracy
±50ns to UTC RMS (1-Sigma) GPS Locked
| Holdover Stability
<±11μs over 3 hour period at +25C
| 1 PPS Output (OCXO Flywheel Generated)
3.3VDC CMOS
| RS-232 Control
NMEA & SCPI-99 Control Commands, Integrated into UHD
| GPS Frequency
L1, C/A 1574MHz
| GPS Antenna
Active (3V compatible) or Passive
| GPS Receiver
50 Channels, Mobile, WAAS, EGNOS, MSAS capable
| Sensitivity
Acquisition -144dBm, Tracking -160dBm
| TTFF
Cold Start: <45 sec, Warm Start: 1 sec, Hot Start: 1 sec
| ADEV
1E-11 at 1s
| Warm Up Time / Stabilization Time
<5 min at +25C to 1E-08 Accuracy
| Supply Voltage (Vdd)
6VDC
| Power Consumption
<1.8W Max, 1.35W Typical
| Operating Temperature
0C to +60C
| Storage Temperature
-45C to 85C
| Oscillator Specifications
| Frequency Output
10MHz
| 10MHz Retrace
±2E-08 after 1 hour at 25C
| Frequency Stability Over Temperature (Unlock Condition)
±2.5E-08
| Warm Up Time
< 1 min at +25C
| Phase Noise at 10MHz
1Hz
-80dBc/Hz
| 10Hz
-110dBc/Hz
| 100Hz
-135dBc/Hz
| 1kHz
-145dBc/Hz
| 10kHz
<-145dBc/Hz
Installation Guide
Media:gpsdo-kit 4.pdf
GPSDO (OCXO)
Specifications
| 1 PPS Accuracy
| Holdover Stability
<±20μs over 3 hour period at +25C
3.3VDC CMOS
| RS-232 Control
| GPS Frequency
L1, C/A 1574MHz
| GPS Antenna
Active (5V compatible) or Passive
| GPS Receiver
| Sensitivity
Acquisition -142dBm, Tracking -168dBm
| TTFF
| ADEV
1E-11 at 1s
3.3/5VDC
| Power Consumption
0.7W Max
0C to +60C
| Storage Temperature
-45C to 85C
| Frequency Output
10MHz
| 10MHz Retrace
±2.5E-08
| Warm Up Time
< 1 min at +25C
1Hz
-75dBc/Hz
| 10Hz
-110dBc/Hz
| 100Hz
-132dBc/Hz
| 1kHz
-142dBc/Hz
| 10kHz
<-145dBc/Hz
Certificate of Volatility
GPSDO (TCXO)
Specifications
| 1 PPS Accuracy
3.3VDC CMOS
| RS-232 Control
| GPS Frequency
L1, C/A 1574MHz
| GPS Antenna
| GPS Receiver
| Sensitivity
| TTFF
| ADEV
1E-11 at 1s
3.3V
| Power Consumption
0.5W Max
0C to +60C
| Storage Temperature
-45C to 85C
| Frequency Output
10MHz
| 10MHz Retrace
±7.5E-08
| Warm Up Time
< 1 min at +25C
1Hz
-65dBc/Hz
| 10Hz
-102dBc/Hz
| 100Hz
-132dBc/Hz
| 10kHz
<-152dBc/Hz
Manufacturer: Samtec
PN: BBL-115-G-E
