Modifying an X310 Chassis for External LO Sharing
Revision as of 12:07, 2 October 2019 by SamReiter (Talk | contribs) (→‎Steps)
AN-123 Note: This AN is currently in progress and is incomplete. Please contact support@ettus if the information that you expect to be in this KB is relevant to your usecase.
Date Author Details
2019-09-06 Sam Reiter Initial creation
This document describes how to modify an X310 chassis to wire the LO to the backplane. Doing this will allow the user to export and import an LO signal as desired when using a compatible daughterboard such as the TwinRX. Tools and cables are not available for purchase from Ettus Research, but product recommendations are made. All modifications are performed at the user's own risk.
Product Compatibility
This guide is only for devices with following Part Numbers:
  • 156485C-09L
  • 156485C-10L
  • 156485F-09L
  • 156485F-10L
  • 156485G-09L
  • 156485G-10L
Cable Recommendation
Cable type: SMA (F) to Right-angle MMCX (M) Cable Assembly Cable Length: 25cm
Example Manufacturer: Cinch Connectivity Solutions Johnson Example Part Number: 415-0073-MM250
Steps
  1. Remove the top cover of the X310
    • There are two Phillips head screws to remove
    • Use the notch in the case to lift up and slide back the cover
    X310 Cover Screws and Notch
  2. Remove the back plate of the X310
    • There are four Torx t5 screws to remove
    • There are 5 nuts around the PPS I/O, REF I/O, and GPS SMA connectors
    • Slide the back plate directly out from the rear of the device to remove.
  3. Cut holes in the backplate sticker as appropriate
    • There are 6 holes pre-drilled in the backplate, no need for any drilling or modifying of the aluminium case.
    • Note, if you don't have these pre-drilled holes, ensure your chassis P/N matches those in the "Product Compatibility" section.
    • NI-Branded USRPs with TwinRX boards such as the NI-2945 and NI-2955 use these holes with a product specific sticker. A picture of this is included below, for reference.
  4. Replace the back plate of the X310
    • This process is the opposite of removal
  5. Add the new SMA cables to the holes in the chassis
    • Unscrew the nut from each SMA, push it through the back of the device, and replace the nut + lock washer.
  6. Connect the MMCX connectors to the TwinRX boards
    • See the guide below for I/O connections
  7. Additional Notes
    • Unfortunately, there is currently no replacement sticker available to add to an ettus-branded X310. Labels will need to be DIY, if desired.
    • Performing this change to an X310 with a part number listed in the "Product Compatibility" section will not void its warranty.
    • If you have an X310 that is not listed in the "Product Compatibility" section and want to perform this modification, contact [email protected] for measurements and appropriate disclaimers.
Configuration Options
8 Channel RX, Star Configuration, External LO
  • Green and blue cables are external connections and components
8 Channel RX, Daisy-Chain Configuration
  • Make sure to measure power
Additional Notes
ToDo
