Software Development on the E3xx USRP - Building RFNoC UHD / GNU Radio / gr-ettus from Source
AN-315
Date | Author | Details |
2017-09-28 | Nate Temple | Initial creation |
2019-08-01 | Nate Temple | Update instructions for Ubuntu 18.x and mainline UHD
This application note is one of a multi-part series which will cover the software development process on the USRP E310, E312 and E313. It will cover building UHD, GNU Radio and gr-ettus from source for the host machine, and cross-compiling UHD, GNU Radio and gr-ettus for the E3xx USRP with RFNoC enabled. It will then cover building a custom RFNoC FPGA image and running an example application RFNoC Fosphor.
Note: Linux only. This application note has been tested using Ubuntu 18.04.
Note: This application note is used with the release-4
E31x file system.
This application note has four sections:
1. Building UHD / GNU Radio / gr-ettus for the Host machine
2. Cross-compiling UHD / GNU Radio / gr-ettus for the E3xx USRP
3. Building a custom RFNoC FPGA image
4. Running an example application, RFNoC Fosphor
Installing UHD / GNU Radio / gr-ettus on the Host
This step is required in order to run the RFNoC Fosphor example. It is possible to operate the E3xx USRP with a RFNoC flowgraph without connecting it to a host machine. All of the processing is performed on the E3xx FPGA, the host is only used to display the FFT/Waterfall.
A more detailed guide to installing UHD / GNU Radio on Linux can be found at the following application note, which can be helpful for reference. https://kb.ettus.com/Building_and_Installing_the_USRP_Open-Source_Toolchain_(UHD_and_GNU_Radio)_on_Linux
This application note is using a vanilla Ubuntu 18.04 installation for the host operating system. If you are using another operating system, please refer to the above application note for specifics on dependency requirements. If you already have UHD and GNU Radio installed, you should first remove them before proceeding with this application note.
System Update
$ sudo apt update $ sudo apt upgrade
Reconfigure Default Shell
Switch your default shell on the host computer from Dash
to Bash
. In some Linux distributions (e.g. Ubuntu) Dash
is set as default shell, which may cause some issues. It is recommended to set the shell to Bash
by running the following commands in the terminal. Choose No
when prompted by the first command and the second command will validate the that Bash
will be used.
$ sudo dpkg-reconfigure dash
Verify Bash is the default shell.
$ ll /bin/sh
Expected Output:
lrwxrwxrwx 1 root root 4 Apr 2 22:00 /bin/sh -> bash*
Install Dependencies
$ sudo apt -y install git swig cmake doxygen build-essential libboost-all-dev libtool libusb-1.0-0 libusb-1.0-0-dev libudev-dev libncurses5-dev libfftw3-bin libfftw3-dev libfftw3-doc libcppunit-1.14-0 libcppunit-dev libcppunit-doc ncurses-bin cpufrequtils python-numpy python-numpy-doc python-numpy-dbg python-scipy python-docutils qt4-bin-dbg qt4-default qt4-doc libqt4-dev libqt4-dev-bin python-qt4 python-qt4-dbg python-qt4-dev python-qt4-doc python-qt4-doc libqwt6abi1 libfftw3-bin libfftw3-dev libfftw3-doc ncurses-bin libncurses5 libncurses5-dev libncurses5-dbg libfontconfig1-dev libxrender-dev libpulse-dev swig g++ automake autoconf libtool python-dev libfftw3-dev libcppunit-dev libboost-all-dev libusb-dev libusb-1.0-0-dev fort77 libsdl1.2-dev python-wxgtk3.0 git libqt4-dev python-numpy ccache python-opengl libgsl-dev python-cheetah python-mako python-lxml doxygen qt4-default qt4-dev-tools libusb-1.0-0-dev libqwtplot3d-qt5-dev pyqt4-dev-tools python-qwt5-qt4 cmake git wget libxi-dev gtk2-engines-pixbuf r-base-dev python-tk liborc-0.4-0 liborc-0.4-dev libasound2-dev python-gtk2 libzmq3-dev libzmq5 python-requests python-sphinx libcomedi-dev python-zmq libqwt-dev libqwt6abi1 python-six libgps-dev libgps23 gpsd gpsd-clients python-gps python-setuptools python3-pyqt5 dnsmasq sshfs
Create Working Directory
These folders will be used as a work area for cloning the sources and building.
$ mkdir -p ~/rfnoc $ mkdir -p ~/rfnoc/src $ mkdir -p ~/rfnoc/oe $ mkdir -p ~/rfnoc/e300
Building UHD
$ cd ~/rfnoc/src $ git clone --recursive https://github.com/EttusResearch/uhd $ cd uhd $ git checkout v3.14.1.0 $ git submodule update --init --recursive $ cd host $ mkdir build-host $ cd build-host $ cmake -DENABLE_E300=ON -DENABLE_GPSD=ON -DENABLE_RFNOC=ON .. $ make -j4 $ sudo make install $ sudo ldconfig
Download UHD FPGA Images
$ sudo uhd_images_downloader
Building GNU Radio
$ cd ~/rfnoc/src $ git clone --recursive https://github.com/gnuradio/gnuradio $ cd gnuradio/ $ git checkout maint-3.7 $ git submodule update --init --recursive $ mkdir build-host $ cd build-host $ cmake .. $ make -j4 $ sudo make install $ sudo ldconfig
Building gr-ettus
$ cd ~/rfnoc/src $ git clone https://github.com/EttusResearch/gr-ettus.git $ cd gr-ettus $ mkdir build-host $ cd build-host $ cmake .. $ make -j4 $ sudo make install $ sudo ldconfig
Verify Installation
Run the following command to verify UHD was installed properly.
$ uhd_usrp_probe --version
Expected Output:
3.14.1.HEAD-0-gbfb9c1c7
Run the following command to verify GNU Radio was installed properly.
$ gnuradio-config-info --version
Expected Output:
3.7.13.5
Cross-Compiling UHD / GNU Radio / gr-ettus for the E3xx USRP
SDK Setup
Download the OE SDK for the E31x release into the ~/rfnoc/src/
directory:
$ cd ~/rfnoc/src $ wget http://files.ettus.com/e3xx_images/e3xx-release-4/oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
Next, install the SDK to the ~/rfnoc/oe
directory. Enter ~/rfnoc/oe
for the installation directory when prompted.
$ bash oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
Expected Output:
Enter target directory for SDK (default: /usr/local/oecore-x86_64): ~/rfnoc/oe You are about to install the SDK to "/home/user/rfnoc/oe". Proceed[Y/n]?y Extracting SDK...done Setting it up...done SDK has been successfully set up and is ready to be used.
Your ~/rfnoc/oe
directory should have a structure such as below:
$ ls ~/rfnoc/oe environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi version-armv7ahf-vfp-neon-oe-linux-gnueabi site-config-armv7ahf-vfp-neon-oe-linux-gnueabi sysroots
Source the OE SDK environment setup file:
$ cd ~/rfnoc/oe $ source ./environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi
Verify the environment has been setup correctly.
$ echo $CC
Expected Output:
arm-oe-linux-gnueabi-gcc -march=armv7-a -mfloat-abi=hard -mfpu=neon --sysroot=/home/user/rfnoc/oe/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi
- Note: If you open a new terminal at any point, you will need to re-run the source command above to initialize the environment. The compiling environment setup is only needed for terminals that are cross-compiling the sources for the E31x. The terminals used later in this application note which are using SSH to connect to other devices do not need to have the compiling environment initialized.
Cross-Compiling UHD
$ cd ~/rfnoc/src/uhd/host $ mkdir build-arm $ cd build-arm $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr -DENABLE_E300=ON -DENABLE_GPSD=ON -DENABLE_RFNOC=ON .. $ make -j4 $ make install DESTDIR=~/rfnoc/e300 $ make install DESTDIR=~/rfnoc/oe/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
Create Environment Setup File
Next, we will create an environment setup file that will set the correct system variables to point to our new installation when ran on the E31x.
$ cd ~/rfnoc/e300 $ touch setup.env $ nano setup.env
Add the following lines to setup.env
LOCALPREFIX=~/newinstall/usr export PATH=$LOCALPREFIX/bin:$PATH export LD_LOAD_LIBRARY=$LOCALPREFIX/lib:$LD_LOAD_LIBRARY export LD_LIBRARY_PATH=$LOCALPREFIX/lib:$LD_LIBRARY_PATH export PYTHONPATH=$LOCALPREFIX/lib/python2.7/site-packages:$PYTHONPATH export PKG_CONFIG_PATH=$LOCALPREFIX/lib/pkgconfig:$PKG_CONFIG_PATH export GRC_BLOCKS_PATH=$LOCALPREFIX/share/gnuradio/grc/blocks:$GRC_BLOCKS_PATH export UHD_RFNOC_DIR=$LOCALPREFIX/share/uhd/rfnoc/ export UHD_IMAGES_DIR=$LOCALPREFIX/share/uhd/images
Copy default FPGA images
$ mkdir -p ~/rfnoc/e300/usr/share/uhd/images $ cd ~/rfnoc/e300/usr/share/uhd/images $ cp -Rv /usr/local/share/uhd/images/usrp_e310_fpga* . $ cp -Rv /usr/local/share/uhd/images/usrp_e3xx_fpga_idle* .
Mount and test the UHD build
Next, we will mount the ~/rfnoc/e300
folder using SSHFS in order to test our new installation.
- Note: This application note assumes you're using a static IP address of
192.168.10.2
for your E31x device, and that your host has the IP address of192.168.10.1
. If you're using different IP addresses, the commands below will need to be updated to reflect the correct IPs.
Open a new terminal and verify that you can ping the E31x:
$ ping 192.168.10.2
Next, SSH into the E31x.
$ ssh root@192.168.10.2
For this next step, your host computer will need to have OpenSSH Server installed.
Open a third terminal window on the host and run:
$ sudo apt-get install openssh-server
Returning to the terminal which you're connected to the E31x via SSH, mount the ~/rfnoc/e300
folder onto the E31x.
First create a directory to mount the remote folder to with (running these commands on the E31x):
# mkdir -p ~/newinstall # sshfs username@192.168.10.1:/home/user/rfnoc/e300 newinstall/
- Note: The "username" in the above command needs to be updated to reflect your user on the host machine.
When prompted, enter the password of your user to complete the mounting of the remote file system.
Verify the mount was successful, your directory structure should match ~/rfnoc/e300
$ ls ~/newinstall/
Expected output:
setup_env.sh usr
Next, we will need to setup the system environment on the E31x to use the newly compiled version of UHD.
Verify that the E31x is using the existing UHD installation, using the which
command:
# which uhd_usrp_probe
Expected output:
/usr/bin/uhd_usrp_probe
Next, source the setup.env<code> file:
# cd ~/newinstall # source ./setup.env
Verify that the newly compiled UHD is being used, again using the <code>which command:
Expected output:
/home/root/newinstall/usr/bin/uhd_usrp_probe
Next, run uhd_usrp_probe
# uhd_usrp_probe
Expect output:
# uhd_usrp_probe [INFO] [UHD] linux; GNU C++ version 4.9.2; Boost_105700; UHD_3.14.1.HEAD-0-gbfb9c1c7 [INFO] [E300] Loading FPGA image: /home/root/newinstall/usr/share/uhd/images/usrp_e310_fpga_sg3.bit... [INFO] [E300] FPGA image loaded [INFO] [E300] Detecting internal GPS.... [INFO] [E300] GPSDO found [INFO] [E300] Initializing core control (global registers)... [INFO] [E300] Performing register loopback test... [INFO] [E300] Register loopback test passed [INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000000) [INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000000) [INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000002) _____________________________________________________ / | Device: E-Series Device | _____________________________________________________ | / | | Mboard: E3XX SG3 | | product: 30675 | | revision: 6 | | serial: xxxxxxx | | mac-addr: 00:80:2f:25:82:bb | | FPGA Version: 255.0 | | FPGA git hash: e39334f | | RFNoC capable: Yes | | | | Time sources: none, internal, external, gpsdo | | Clock sources: internal | | Sensors: temp, ref_locked, gps_locked, gps_time, gps_position, gps_gpgga, gps_gprmc | | _____________________________________________________ | | / | | | RX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxxx | | | _____________________________________________________ | | | / | | | | RX Frontend: A | | | | Name: FE-RX2 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: B | | | | Name: FE-RX1 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: E3x0 RX dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxxxx | | | _____________________________________________________ | | | / | | | | TX Frontend: A | | | | Name: FE-TX2 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: B | | | | Name: FE-TX1 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: E3x0 TX dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * Radio_0 | | | * DDC_0 | | | * DUC_0 [INFO] [E300] Loading FPGA image: /home/root/newinstall/usr/share/uhd/images/usrp_e3xx_fpga_idle_sg3.bit... [INFO] [E300] FPGA image loaded
At this point, it's possible to run the included UHD example programs with the newly compiled UHD.
# cd ~/newinstall/usr/lib/uhd/examples/ # ./rx_samples_to_file --freq 100e6 --gain 0 --ant TX/RX --rate 1e6 --duration 10 --null
Install python-six dependency to the OE SDK
GNU Radio versions that are newer than 3.7.10.2 require python-six
, which is not included within the release-4
SDK. In this step python-six
will be installed into the OE sysroot.
Return to the terminal which is being used to cross-compile, or open a new terminal and source the OE SDK environemnt setup file before proceeding.
$ cd ~/rfnoc/src $ wget https://files.pythonhosted.org/packages/16/d8/bc6316cf98419719bd59c91742194c111b6f2e85abac88e496adefaf7afe/six-1.11.0.tar.gz $ tar -zxvf six-1.11.0.tar.gz $ cd six-1.11.0 $ python setup.py install --prefix=~/rfnoc/oe/sysroots/x86_64-oesdk-linux/usr
Cross-Compiling GNU Radio
Next, clone and cross-compile GNU Radio for the E31x. On the host machine:
$ cd ~/rfnoc/src/gnuradio $ mkdir build-arm $ cd build-arm $ cmake -Wno-dev -DCMAKE_TOOLCHAIN_FILE=~/rfnoc/src/gnuradio/cmake/Toolchains/oe-sdk_cross.cmake -DENABLE_GR_WXGUI=OFF -DENABLE_GR_VOCODER=OFF -DENABLE_GR_DTV=OFF -DENABLE_GR_ATSC=OFF -DENABLE_DOXYGEN=OFF -DCMAKE_INSTALL_PREFIX=/usr ../ $ make -j4 $ make install DESTDIR=~/rfnoc/e300/ $ make install DESTDIR=~/rfnoc/oe/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
Next, verify your GNU Radio installation was successful. On the E31x terminal, run the command:
Expected output:
3.7.13.5
Cross-Compiling gr-ettus
Next, clone and cross-compile gr-ettus
$ cd ~/rfnoc/src/gr-ettus $ mkdir build-arm $ cd build-arm $ cmake -DCMAKE_TOOLCHAIN_FILE=~/rfnoc/src/gnuradio/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. $ make -j4 $ make install DESTDIR=~/rfnoc/e300/ $ make install DESTDIR=~/rfnoc/oe/sysroots/armv7ahf-vfp-neon-oe-linux-gnueabi/
At this point you should have a fully functional UHD RFNoC, GNU Radio and gr-ettus installation. However being that the compiled sources are not located on the E31x (and only temporarily mounted via SSHFS) they will need to copied to the E31x's file system.
On the E31x navigate to your home directory and create a folder, localinstall
# mkdir -p ~/localinstall
Next, copy the etc/
, setup.env
and usr/
folder from the remotely mounted folder:
# cd ~/localinstall
# cp -v ~/newinstall/setup.env . # cp -Rv ~/newinstall/etc . # cp -Rv ~/newinstall/usr .
Verify the folder contents:
# ls ~/localinstall
Expected Output:
etc/ setup_env.sh usr/
Next, we will need to update the setup.env
file that is located within the ~/localinstall/
folder.
Verify your directory location with the pwd
command:
$ pwd
Expected Output:
/home/root/localinstall
Edit the setup.env
file to update the PATH
variable to point to your new installation location (/home/root/localinstall
$ sed -i 's/newinstall/localinstall/g' setup.env
Verify your edit was successful with the command cat
$ cat setup.env
Expected Output:
LOCALPREFIX=~/localinstall/usr export PATH=$LOCALPREFIX/bin:$PATH export LD_LOAD_LIBRARY=$LOCALPREFIX/lib:$LD_LOAD_LIBRARY export LD_LIBRARY_PATH=$LOCALPREFIX/lib:$LD_LIBRARY_PATH export PYTHONPATH=$LOCALPREFIX/lib/python2.7/site-packages:$PYTHONPATH export PKG_CONFIG_PATH=$LOCALPREFIX/lib/pkgconfig:$PKG_CONFIG_PATH export GRC_BLOCKS_PATH=$LOCALPREFIX/share/gnuradio/grc/blocks:$GRC_BLOCKS_PATH export UHD_RFNOC_DIR=$LOCALPREFIX/share/uhd/rfnoc/ export UHD_IMAGES_DIR=$LOCALPREFIX/share/uhd/images
Note, the LOCALPREFIX
variable has been updated to the new location.
This setup.env
file needs to be source in order to utilize the new ~/localinstall
location.
$ source ./setup.env
Verify that the environment is setup correctly:
$ which uhd_usrp_probe
Expected Output:
/home/root/localinstall/usr/bin/uhd_usrp_probe
We can now dismount the remotely connected SSHFS folder. On the E31x, run the commands:
# cd ~/ # umount ~/newinstall # rm -rf ~/newinstall
Building a custom RFNoC FPGA Image
The default FPGA image shipped with UHD releases only contains the Radio
, DDC
, and DUC
blocks. In order to explore the additional RFNoC blocks, a custom FPGA image will need to be built.
To build a FPGA image for the USRP E31x, the Xilinx Vivado toolchain must be installed. A future application note will cover a step-by-step install guide for Vivado. The E31x FPGA is a Zynq 7020 and can be built using the free Vivado WebPACK tools. Vivado System and Design Edition will also work.
Note: UHD 3.14.x.x requires Vivado 2017.4.
UHD provides several tools for building FPGA images. The step below assume you have a working installation of Xilinx Vivado WebPACK.
The first step is to source the environment setup file for the Vivado toolchain.
In a new terminal, run:
$ source ~/rfnoc/src/uhd/fpga-src/usrp3/top/e300/setupenv.sh
Next, you can use either the uhd_image_builder_gui.py
utility or the command line version uhd_image_builder.py
to build the FPGA image.
In this step we will build a FPGA image with the following blocks:
- 1x FFT - 1x Window - 1x Fosphor - 2x FIFO
Note: Depending upon your host machine performance, it can take a few hours to build a FPGA image.
Building a FPGA image with uhd_image_builder.py
$ ./uhd_image_builder.py fft window fosphor -t E310_RFNOC_sg3 -d E310 -m 5 --fill-with-fifos
Building an FPGA image with uhd_image_builder_gui.py
Note: uhd_image_builder_gui.py
requires Python3.
$ cd ~/rfnoc/src/uhd/fpga-src/usrp3/tools/scripts $ python3 uhd_image_builder_gui.py
- Select the E310_RFNOC_SG3
as the build target
- Select the FFT, Window, and Fosphor block by highlighting them and clicking >>
to add them to the design
- Click the Fill with FIFOs
checkbox
- Then click Generate .bit file
Copy FPGA Image to E31x and verify
Once the FPGA image has completed in the previous step, it will need to be copied to to the E31x.
$ scp /path/to/e300.bit root@192.168.10.2:~/localinstall/.
Note: The location of the generate bit file is printed at the end of the building process.
Example location:
/home/user/rfnoc/src/uhd/fpga-src/usrp3/top/e300/build-E310_RFNOC_sg3/e300.bit
Next, SSH into the E31x and run `uhd_usrp_probe`, using this FPGA new custom FPGA image. The custom FPGA image path should be passed as a device argument to the UHD application.
# source ./localinstall/setup.env # uhd_usrp_probe --args"fpga=/home/root/localinstall/e300.bit"
Expected Output:
# uhd_usrp_probe --args "fpga=/home/root/localinstall/e300.bit" [INFO] [UHD] linux; GNU C++ version 4.9.2; Boost_105700; UHD_3.14.1.HEAD-0-gbfb9c1c7 [INFO] [E300] Loading FPGA image: /home/root/localinstall/e300.bit... [INFO] [E300] FPGA image loaded [INFO] [E300] Detecting internal GPS.... [INFO] [E300] GPSDO found [INFO] [E300] Initializing core control (global registers)... [INFO] [E300] Performing register loopback test... [INFO] [E300] Register loopback test passed [INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000000) [WARNING] [RFNOC] Can't find a block controller for key FFT, using default block controller! [INFO] [0/FFT_0] Initializing block control (NOC ID: 0xFF70000000000000) [INFO] [0/Window_0] Initializing block control (NOC ID: 0xD053000000000000) [WARNING] [RFNOC] Can't find a block controller for key fosphor, using default block controller! [INFO] [0/fosphor_0] Initializing block control (NOC ID: 0x666F000000000000) [INFO] [0/FIFO_0] Initializing block control (NOC ID: 0xF1F0000000000000) [INFO] [0/FIFO_1] Initializing block control (NOC ID: 0xF1F0000000000000) _____________________________________________________ / | Device: E-Series Device | _____________________________________________________ | / | | Mboard: E3XX SG3 | | product: 30675 | | revision: 6 | | serial: xxxxxxx | | mac-addr: 00:80:2f:25:82:bb | | FPGA Version: 255.0 | | FPGA git hash: e39334f-dirty | | RFNoC capable: Yes | | | | Time sources: none, internal, external, gpsdo | | Clock sources: internal | | Sensors: temp, ref_locked, gps_locked, gps_time, gps_position, gps_gpgga, gps_gprmc | | _____________________________________________________ | | / | | | RX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | RX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxxx | | | _____________________________________________________ | | | / | | | | RX Frontend: A | | | | Name: FE-RX2 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Frontend: B | | | | Name: FE-RX1 | | | | Antennas: TX/RX, RX2 | | | | Sensors: temp, rssi, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 76.0 step 1.0 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | RX Codec: A | | | | Name: E3x0 RX dual ADC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | TX DSP: 0 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX DSP: 1 | | | | | | Freq range: 0.000 to 0.000 MHz | | _____________________________________________________ | | / | | | TX Dboard: A | | | ID: E310 MIMO XCVR (0x0110) | | | Serial: xxxxxxx | | | _____________________________________________________ | | | / | | | | TX Frontend: A | | | | Name: FE-TX2 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Frontend: B | | | | Name: FE-TX1 | | | | Antennas: TX/RX | | | | Sensors: temp, lo_locked | | | | Freq range: 50.000 to 6000.000 MHz | | | | Gain range PGA: 0.0 to 89.8 step 0.2 dB | | | | Bandwidth range: 200000.0 to 56000000.0 step 0.0 Hz | | | | Connection Type: IQ | | | | Uses LO offset: No | | | _____________________________________________________ | | | / | | | | TX Codec: A | | | | Name: E3x0 TX dual DAC | | | | Gain Elements: None | | _____________________________________________________ | | / | | | RFNoC blocks on this device: | | | | | | * Radio_0 | | | * FFT_0 | | | * Window_0 | | | * fosphor_0 | | | * FIFO_0 | | | * FIFO_1 [INFO] [E300] Loading FPGA image: /home/root/localinstall/usr/share/uhd/images/usrp_e3xx_fpga_idle_sg3.bit... [INFO] [E300] FPGA image loaded
Note: At the end of the uhd_usrp_probe
output is a list of blocks within this custom FPGA image.
Running RFNoC Fosphor
In order to run RFNoC Fosphor, we will first need to generate the Python file to be ran on the E3xx USRP.
On the Host machine, in a new terminal, open GNU Radio:
$ gnuradio-companion
Within GNU Radio, open the following files:
/home/user/rfnoc/src/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_host.grc /home/user/rfnoc/src/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_usrp.grc
Select the rfnoc_fosphor_network_usrp.grc
flowgraph.
Modify the Variable ip_addr
and set the value to match the Host's address: 192.168.10.1
Modify the device3
block to set the master_clock_rate
to be 56e6
and FPGA path argument.
Example:
master_clock_rate=56e6,fpga=/home/root/localinstall/e300.bit
Modify the variable fft_size
to be 512
Modify the variable spp
under the USRP UHD Source
block to be 512
Next, click the Generate the flow graph
button. Note the file path in the console where it is generating the rfnoc_fosphor_network_usrp.py
is created.
Copy the generated Python file, rfnoc_fosphor_network_usrp.py
to the E3xx using the scp
utility.
$ scp /home/user/rfnoc/src/gr-ettus/examples/rfnoc/rfnoc_fosphor_network_usrp.py root@192.168.10.2:~/.
You will now need to SSH to the USRP E3xx.
Verify that the rfnoc_fosphor_network_usrp.py
file was copied to your E3xx.
# ls -al rfnoc_fosphor_network_usrp.py
Expected Output:
root@ettus-e3xx-sg3:~# ls -al rfnoc_fosphor_network_usrp.py -rwxr-xr-- 1 root root 8980 Jan 15 04:43 rfnoc_fosphor_network_usrp.py
Source the Environment Setup file, setup.env
Next, run rfnoc_fosphor_network_usrp.py
. Leave this window open in the background.
# python rfnoc_fosphor_network_usrp.py
Return to gnuradio-companion
, select the rfnoc_fosphor_network_host.grc
flowgraph, and click the Execute the flow graph
button.
Maximize the GUI window that has started. RFNoC Fosphor should be running now on the E3xx and be displayed on your host computer. Adjust the Frequency to a strong set of signals, and adjust the Gain slider as needed to produce the best signal to noise ratio for your RF environment.
