Enabling Ethernet Connectivity on Octoclock and Octoclock-G
Revision as of 11:28, 13 January 2020 by SamReiter (Talk | contribs)
AN-800
Date Author Details
2020-01-13 Sam Reiter Initial creation
This application note covers, in detail, the steps required to program an Octoclock or Octoclock-G to allow Ethernet connectivity and communication with UHD. This guide serves as a supplement to the UHD Manual's coverage of the topic. In this guide, we will use Ubuntu 19.10 to program an Octoclock using an ATMEL-ICE programmer.
Verify Current Octoclock Configuration
To get started, we want to make sure that this guide is appropriate for your device(s). Currently shipping Octoclocks will come with the following firmware pre-loaded. You can test which unit you have with a simple ping test:
    1. Connect the 6V DC power supply to the Octoclock
    2. Connect your Octoclock's RJ-45 port to a host PC via an Ethernet cable
    3. Configure your host's Ethernet port to a static connection with the IPV4 address: 192.168.10.1
    4. Configure your host's Ethernet port with a subnet mast of: 255.255.255.0
    5. Turn your host's Ethernet port off and back on for changes to take effect
    6. In a terminal, issue the command:
   ping 192.168.10.3
A successful ping between devices means that your device is already configured with updated firmware and this guide is *not* necessary. At this time, this guide has not been tested for recovering bricked devices.
Tools Required
    1. Philips head screwdriver
    2. ATMEL-ICE Programmer (or comparable AVR programmer) with SPI/ISP cable
    3. Ethernet cable
ATMEL-ICE Configuration
To utilize the ATMEL-ICE programmer, the avrdude utility must be used. The version of avrdude should be >= 6.1. At the time of this guide, version 6.3 is the default install from the Ubunu PPA and programming issues were observed. This guide will cover a build of avrdude 6.1 from source.
Install the following dependencies:
   sudo apt-get install bison flex libftdi1-dev libftdi-dev
Download the avrdude-6.1.tar.gz release here. From this download location, uncompress the directory:
   tar xvzf avrdude-6.1.tar.gz
Enter the source directory
   cd avrdude-6.1/
Run the configure script
   ./configure
Expected output:
<truncated output>
Configuration summary:
DO HAVE    libelf
DO HAVE    libusb
DO HAVE    libusb_1_0
DO HAVE    libftdi1
DO HAVE    libftdi (but prefer to use libftdi1)
DON'T HAVE libhid
DO HAVE    pthread
DISABLED   doc
ENABLED    parport
DISABLED   linuxgpio
Build
   make
Install
   sudo make install
Test your avrdude installation
avrdude -?
Expected output
<truncated output>
avrdude version 6.1, URL: <http://savannah.nongnu.org/projects/avrdude/>
Download Octoclock Firmware
If UHD is not already installed, install your preferred version with this guide:
[Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, https://kb.ettus.com/Building_and_Installing_the_USRP_Open-Source_Toolchain_(UHD_and_GNU_Radio)_on_Linux]
UHD Warning:
To address this issue, non-privileged (non-root) users need to be given special permission to change the scheduling priority. This can be enabled by creating a group usrp, adding your user to it, and then appending the line @usrp - rtprio 99 to the file /etc/security/limits.conf.
   sudo groupadd usrp
   sudo usermod -aG usrp $USER
Then add the line below to end of the file /etc/security/limits.conf:
   @usrp - rtprio  99
You must log out and log back into the account for the settings to take effect. In most Linux distributions, a list of groups and group members can be found in the /etc/group file.
Adjust Network Buffers
This applies to Ethernet connected USRPs (N2xx, N3xx, X3xx, E320).
N2xx
   sudo sysctl -w net.core.rmem_max=625000000
   sudo sysctl -w net.core.wmem_max=625000000
X3xx/N3xx/E320
   sudo sysctl -w net.core.wmem_max=576000
Adjust Ethernet MTU
For 1 Gigabit connections, the MTU should be set to 1500.
For 10 Gigabit connections, the MTU should be set to 8000.
It is important to set the value and not leave it is automatic
Increasing Ring Buffers
This applies to Ethernet connected USRPs using a 10 Gb interface (X3xx, N3xx, E320).
Increasing the Ring Buffers on the NIC may help prevent flow control errors at higher rates.
DPDK
DPDK is supported on N3xx, X3xx and E320 USRPs. DPDK replaces the traditional Linux networking stack with a low overhead user-land based driver. Additional details of using DPDK can be found in the UHD Manual located at the following link: https://files.ettus.com/manual/page_dpdk.html
Disable Hyper-threading
In some applications which require the highest possible CPU performance per core, disabling hyper-threading can provide roughly a 10% increase in core performance, at the cost of having less core threads. Hyper-threading can be disabled within the BIOs and varies by manufacturer.
Disable KPTI Protections for Spectre/Meltdown
In some cases, disabling the KPTI protections for the Linux Kernel can increase performance by 10-15%. It is important to note the ramification making this modification can have. This modification is only recommended for systems that absolutely require the best performance and are not connected to the internet.
Disabling KPTI protections can be done by adding the lines below to your /etc/default/grub file at GRUB_CMDLINE_LINUX_DEFAULT=""
   pti=off spectre_v2=off l1tf=off nospec_store_bypass_disable no_stf_barrier
After modifying the grub file, run the following command to update your configuration and reboot:
   sudo update-grub
