Enabling Ethernet Connectivity on Octoclock and Octoclock-G
- 1 Application Note Number
- 2 Revision History
- 3 Overview
- 4 Verify Current Octoclock Configuration
- 5 Tools Required
- 6 ATMEL-ICE Configuration
- 7 Download Octoclock Firmware
- 8 Connect Programmer to Octoclock
- 9 Program the Octoclock
- 10 Uploading Firmware via Ethernet
- 11 Updating the Octoclock's EEPROM
- 12 Additional Resources
- 13 Troubleshooting
AN-800
Date | Author | Details |
2020-01-13 | Sam Reiter | Initial creation |
This application note covers, in detail, the steps required to program an Octoclock or Octoclock-G to allow Ethernet connectivity and communication with UHD. This guide serves as a supplement to the UHD Manual's coverage of the topic. In this guide, we will use Ubuntu 19.10 to program an Octoclock using an ATMEL-ICE programmer.
To get started, we want to make sure that this guide is appropriate for your device(s). Currently shipping Octoclocks will come with the following firmware pre-loaded. You can test which unit you have with a simple ping test:
- Connect the 6V DC power supply to the Octoclock
- Connect your Octoclock's RJ-45 port to a host PC via an Ethernet cable
- Configure your host's Ethernet port to a static connection with the IPV4 address:
192.168.10.1
- Configure your host's Ethernet port with a subnet mast of:
255.255.255.0
- Turn your host's Ethernet port off and back on for changes to take effect
- In a terminal, issue the command:
ping 192.168.10.3
A successful ping between devices means that your device is already configured with updated firmware and this guide is *not* necessary. At this time, this guide has not been tested for recovering bricked devices.
Tools Required
- Philips head screwdriver
- ATMEL-ICE Programmer (or comparable AVR programmer) with SPI/ISP cable
- Ethernet cable
To utilize the ATMEL-ICE programmer, the avrdude
utility must be used. The version of avrdude
should be >= 6.1. At the time of this guide, version 6.3 is the default install from the Ubunu PPA and programming issues were observed. This guide will cover a build of avrdude 6.1 from source.
Install the following dependencies:
sudo apt-get install bison flex libftdi1-dev libftdi-dev
Download the avrdude-6.1.tar.gz
release here. From this download location, uncompress the directory:
tar xvzf avrdude-6.1.tar.gz
Enter the source directory
cd avrdude-6.1/
Run the configure script
./configure
Expected output:
<truncated output> Configuration summary: ---------------------- DO HAVE libelf DO HAVE libusb DO HAVE libusb_1_0 DO HAVE libftdi1 DO HAVE libftdi (but prefer to use libftdi1) DON'T HAVE libhid DO HAVE pthread DISABLED doc ENABLED parport DISABLED linuxgpio
Build
make
Install
sudo make install
Test your avrdude
installation
avrdude -?
Expected output
<truncated output> avrdude version 6.1, URL: <http://savannah.nongnu.org/projects/avrdude/>
If UHD is not already installed, install your preferred version with this guide: Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux
Download images for UHD:
sudo uhd_images_downloader
Verify that you have ```octoclock_bootloader.hex``` and octoclock_r4_fw.hex
ls -l /usr/local/share/uhd/images | grep octoclock
Expected output
-rw-r--r-- 1 root root 17332 Jun 6 2019 octoclock_bootloader.hex -rw-r--r-- 1 root root 22845 Jun 6 2019 octoclock_r4_fw.hex
Change to this directory:
cd /usr/local/share/uhd/images
Begin this guide with the Octoclock unplugged. First, you'll need to remove the top plate from the Octoclock, exposing the PCB. There are 12 screws securing the top plate.
With the top plate removed, locate the 6-pin header (male) for SPI communication with the ATmega128.
Connect the ATMEL-ICE's 6-pin header (female) to the SPI header of the Octoclock as shown below. The tab of the header should be facing the ATmega128 chip.
Note: If you plug the header in backwards, avrdude
is expected to return a "please check your connections" message after a programming failure.
If not already done, connect the other end of the SPI cable to the ATMEL-ICE's AVR squid connector, and connect the ATMEL-ICE to the host computer using the micro-usb port. There should be a single LED lit on the programmer.
Supply power to the Octoclock with the 6V power brick. You should see the Octoclock's Power LED come on and 1 additional green LED on the ATMEL-ICE programmer illuminate.
With the terminal that is open in the same directory as the .hex images, run the following command
sudo avrdude -p atmega128 -c atmelice_isp -P usb -U efuse:w:0xFF:m -U hfuse:w:0x80:m -U lfuse:w:0xEF:m -U flash:w:octoclock_bootloader.hex:i
If you are using a programmer other than the ATMEL-ICE, you will need to change the -c parameter to match your programmer. Valid programmers for your version of avrdude can be found by running:
avrdude -c help
The expected output from a successful run of avrdude
is as follows:
avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.02s avrdude: Device signature = 0x1e9702 avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "0xFF" avrdude: writing efuse (1 bytes): Writing | ################################################## | 100% 0.09s avrdude: 1 bytes of efuse written avrdude: verifying efuse memory against 0xFF: avrdude: load data efuse data from input file 0xFF: avrdude: input file 0xFF contains 1 bytes avrdude: reading on-chip efuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of efuse verified avrdude: reading input file "0x80" avrdude: writing hfuse (1 bytes): Writing | ################################################## | 100% 0.09s avrdude: 1 bytes of hfuse written avrdude: verifying hfuse memory against 0x80: avrdude: load data hfuse data from input file 0x80: avrdude: input file 0x80 contains 1 bytes avrdude: reading on-chip hfuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of hfuse verified avrdude: reading input file "0xEF" avrdude: writing lfuse (1 bytes): Writing | ################################################## | 100% 0.09s avrdude: 1 bytes of lfuse written avrdude: verifying lfuse memory against 0xEF: avrdude: load data lfuse data from input file 0xEF: avrdude: input file 0xEF contains 1 bytes avrdude: reading on-chip lfuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: 1 bytes of lfuse verified avrdude: reading input file "octoclock_bootloader.hex" avrdude: can't open input file octoclock_bootloader.hex: No such file or directory avrdude: read from file 'octoclock_bootloader.hex' failed avrdude: safemode: Fuses OK (E:FF, H:80, L:EF) avrdude done. Thank you.
Upon successful burning of a bootloader, you will now need to upload firmware. Connect the USRP to your host via Ethernet and configure your host's IP as noted in the "Verify Current Octoclock Configuration" section. Next, run
uhd_find_devices
Expected output:
uhd_find_Devices -------------------------------------------------- -- UHD Device 0 -------------------------------------------------- Device Address: addr: 192.168.10.3 type: octoclock-bootloader
This means that UHD successfully recognizes your device's bootloader and can download the firmware image. Run the following command:
uhd_image_loader --args="type=octoclock,addr=192.168.10.3"
Once this completes, your OctoClock will load its firmware. Powercycle the device, then run the uhd_find_devices
utility again, and the output should be similar to the following:
-------------------------------------------------- -- UHD Device 0 -------------------------------------------------- Device Address: addr: 192.168.10.3 type: octoclock name: serial:
Note that the Octoclock will enter its bootloader once it first receives power. It will take ~10s to boot and be recognized as an octoclock as seen in the above output.
As a final step, the device's EEPROM will need to be updated. On the back of your device, you will see a label sticker with a serial number (labeled S/N) and a MAC address (labeled MAC). For later use, the MAC address will have to be used in a different format than is on the label. As an example, if the label lists the MAC address as 00802F112233
, you will need to format it as 00:80:2F:11:22:33
Update the Octoclock's EEPROM witht he following command:
<UHD INSTALL DIRECTORY>/lib/uhd/utils/octoclock_burn_eeprom --args="addr=192.168.10.3" --values="mac-addr=<FORMATTED MAC HERE>,ip-addr=192.168.10.3,netmask=255.255.255.0,gateway=192.168.10.1,serial=<SERIAL HERE>,revision=4"
Troubleshooting
This process has been run and confirmed in Ubuntu 19.10. Other versions of Linux may require different versions of dependencies to be installed.
You can use -v flags with avrdude
to make the output verbose, if running into issues. Here is the ouput of avrdude
with verbose flags set:
sudo avrdude -v -v -p atmega128 -c atmelice_isp -P usb -U efuse:w:0xFF:m -U hfuse:w:0x80:m -U lfuse:w:0xEF:m -U flash:w:octoclock_bootloader.hex:i
Output when SPI plug is plugged into the header backwards:
avrdude: Version 6.1, compiled on Jan 10 2020 at 15:41:02 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "/usr/local/etc/avrdude.conf" User configuration file is "/root/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : usb Using Programmer : atmelice_isp avrdude: stk500v2_jtag3_open() avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J42700007132 avrdude: Found CMSIS-DAP compliant device, using EDBG protocol avrdude: jtag3_edbg_prepare(): connection status 0x01 avrdude: Sending sign-on command: 0x80 (509 bytes msg) AVR Part : ATmega128 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 4 12 64 0 no 4096 8 0 9000 9000 0xff 0xff flash 33 6 128 0 yes 131072 256 512 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : JTAG3_ISP Description : Atmel-ICE (ARM/AVR) in ISP mode avrdude: jtag3_getparm() avrdude: Sending get parameter (scope 0x01, section 1, parm 0) command: 0x84 (509 bytes msg) Vtarget : 2.7 V SCK period : 125.00 us avrdude: jtag3_setparm() avrdude: Sending set parameter (scope 0x12, section 0, parm 0) command: 0x80 (509 bytes msg) avrdude: jtag3_setparm() avrdude: Sending set parameter (scope 0x12, section 0, parm 1) command: 0x80 (509 bytes msg) avrdude: jtag3_setparm() avrdude: Sending set parameter (scope 0x12, section 1, parm 0) command: 0x80 (509 bytes msg) avrdude: stk500v2_command(): command failed avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude: stk500v2_jtag3_close() avrdude: jtag3_close() avrdude: Sending AVR sign-off command: 0x80 (509 bytes msg) avrdude: Sending sign-off command: 0x80 (509 bytes msg) avrdude done. Thank you.
