Revision as of 16:51, 4 February 2020 by SamReiter (Talk | contribs) (CHDR Packet Types and Structure)
AN-TC
Date Author Details
2020-02-10 Sam Reiter Initial creation
  • A
  • B
  • C
  • D
  • E
  • F
  • G
  • Data
  • Flow Control
  • Command
  • Command Response
CHDR Packet Structure
VITA Time
PPS (Pulse Per Second)
Radio Core Block Timing
General RFNoC block Timing
Command Queue
Summary
USRP Time Sources
Internal PPS
External PPS
GPSDO
UHD API for Timed Commands
Overview of Relevant Methods
Timed Commands vs. Stream Commands with time_spec (remove this?)
Commands that can be timed
Time Resolution of Timed Commands
Example: Using Timed Commands to Phase Align Channels
Example: Using Timed Commands to Control GPIO
