AN-TC
| Date | Author | Details |
| 2020-02-10 | Sam Reiter | Initial creation |
- A
- B
- C
- D
- E
- F
- G
- H
- I
- J
- k
- Data
- Flow Control
- Command
- Command Response
VITA Time
The next topic to cover is the VITA time. This time value (denoted as vita_time) is a 64-bit counter driven by the USRP's FPGA base clock. vita_time is used as an absolute time reference for the radio and is local to the Radio Core of the USRP's FPGA. We'll discuss more about the Radio Core below.
