AN-TC
| Date | Author | Details |
| 2020-02-10 | Sam Reiter | Initial creation |
- A
- B
- C
- D
- E
- F
- G
- H
- I
- J
- k
- Data
- Flow Control
- Command
- Command Response
VITA Time
The next topic to cover is the VITA time. This time value (denoted as vita_time) is a 64-bit counter driven by the USRP's FPGA base clock. vita_time is used as an absolute time reference for the radio and is local to the Radio Core of the USRP's FPGA. We'll discuss more about the Radio Core below.
PPS (Pulse Per Second)
PPS is a signal used by USRPs for time synchronization. Within the context of a USRP, a PPS signal is expected to have the following properties:
- 1Hz
- TTL Signal Levels
- 25% duity cycle
A PPS trigger is used to coordinate time alignment events across multiple devices. For example, the USRPs internal sense of time (the vita_time) can be synchronously set/reset across multiple USRPs via UHD API calls such as
set_time_next_pps
set_time_unknown_pps
For further information on PPS and other common reference signals, see the UHD Manual: Device Synchronization.
Radio Core Block Timing
