AN-TC
| Date | Author | Details |
| 2020-02-10 | Sam Reiter | Initial creation |
- A
- B
- C
- D
- E
- F
- G
- H
- I
- J
- Data
- Flow Control
- Command
- Command Response
Command Queue
The command queue is a FIFO for all commands that are sent to an RFNoC block. The command queue FIFO is not to be confused with the data FIFOs used to buffer data between blocks (pictured in Figure **###**). Every command queue maintains a sense of time. The mechanism for acquiring this sense of time is different between the Radio Core and other RFNoC blocks and will be explored later in this Application Note. When commands enter the command queue, their timestamp is compared against the queue's sense of time and the commands are executed when Queue Time >= Command Time. Commands without timestamps are executed immediately when they're at the front of the queue. Command queues in RFNoC do not support on the fly reordering, meaning a command at the front of the queue will block subsequent commands from executing even if their timestamp has passed. An overflow of the command queue will result in a system halt and often requires a physical reset of the FPGA.
Every RFNoC block, including the Radio Core, includes 1 command queue per port (there's generally 1 port per data stream). The depth of this command queue varies from device-to device is determined at FPGA compilation time based on user settings and available resources.
PPS (Pulse Per Second)
- 1Hz
- TTL Signal Levels
- 25% duity cycle
A PPS trigger is used to coordinate time alignment events across multiple devices. For example, the USRPs internal sense of time (the vita_time counter) can be synchronously set/reset across multiple USRPs via UHD API calls such as
set_time_next_pps
set_time_unknown_pps
Radio Core Block Timing
In addition to the functionality listed above, the Radio Core is also responsible for maintaining the USRP's sense of absolute time. This absolute time value is stored as a 64-bit counter called the "VITA time" or vita_time in UHD. The vita_time counter is incremented off of the FPGA's base clock and local to the Radio Core USRP, meaning that other RFNoC blocks can not reference this counter value directly.
