WBX
Revision as of 18:05, 26 March 2020 by SamReiter (Talk | contribs) (→‎Gains)
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently. The WBX daughterboard is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The WBX provides phase coherent operation, although with a 180-degree ambiguity, which must be calibrated out in the application. For phase-coherent applications, Ettus Research recommends the SBX with the N200/N210 or the SBX or UBX with the X300/X310.
  • Frequency Range: 50MHz - 2.2GHz
  • Versions: 40MHz / 120MHz
  • Power Output: 100mW
  • Noise Figure: 5dB
Daughterboard Specifications
Features
  • 2 quadrature frontends (1 transmit, 1 receive)
    • Defaults to direct conversion
    • Can be used in low IF mode through lo_offset with uhd::tune_request_t
  • Independent receive and transmit LO's and synthesizers
    • Allows for full-duplex operation on different transmit and receive frequencies
    • Can be set to use Integer-N tuning for better spur performance with uhd::tune_request_t
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
  • Frontend 0: Complex baseband signal for selected antenna
  • Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a WBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
  • Transmit Gains: PGA0, Range: 0-31.5dB
  • Receive Gains: PGA0, Range: 0-31.5dB
Bandwidths
  • WBX: 40 MHz, RX & TX
  • WBX-120: 120 MHz, RX & TX
Sensors
  • lo_locked: boolean for LO lock state
Freq Range
  • 50MHz - 2.2GHz
Noise Figure
  • 2 - 4 dB @ (50MHz ~ 1.2GHz)
  • 4 - 8 dB @ (1.2GHz ~ 2.2GHz)
RX IIP3 (Max)
  • 10 - 18 dBm
RX IQ Imbalance
  • -30 dBc
TX Power (Max)
  • 18 - 20 dBm @ (50MHz ~ 1.4 GHz)
  • 12 - 18dBm @ (1.4GHz ~ 2.2 GHz)
TX OIP3
  • 30 - 32 dBm @ (50MHz ~ 800MHz)
  • 25 - 30 dBm @ (800MHz ~ 2.2GHz)
TX IQ Imbalance
  • -30 dBc @ (50MHz ~ 1.9GHz)
  • - 24 dBc @ (1.9GHz ~ 2.2GHz)
Input/Output Impedance
  • All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
  • The maximum input power for the WBX is -15 dBm.
RF Performance Data
Hardware Specifications
WBX-40
  • Minimum version of UHD required: 3.8.0
WBX-120
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
WBX-40
  • N or X Series
WBX-120
  • X Series only
Phase Synchronization
The WBX daughterboard is capable of phase-synchronous operation, but with a with a 180-degree ambiguity, which must be calibrated out in the user application. The SBX, UBX, TwinRX daughterboards are recommended for phase-coherent applications.
WBX
WBX Schematics
WBX FE Schematics
Key Component Datasheets
ADA4937 Ultralow Distortion Differential ADC Driver U304 (2)
ADP3336 High Accuracy Ultralow IQ, 500 mA anyCAP® Adjustable Low Dropout Regulator U306, U308 (2); U503, U505 (4)
ADL5387 50 MHz to 2 GHz Quadrature Demodulator U307 (2)
ADL5385 50 MHz to 2200 MHz Quadrature Modulator U501 (4,5)
ADF4350 / ADF4351 Wideband Synthesizer with Integrated VCO U201 (3); U401 (5)
HMC472LP4 Attenuator U302 (2); U504 (4,5)
MGA82563 Amplifier U313 (2)
24LC024 EEPROM U202 (3); U403 (5)
GVA−84+ Amplifier U502 (4)
Mechanical Information
Drawings
RF Connectors
  • The WBX daughterboard features female MCX connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
Certificate of Volatility
WBX-40/WBX-120
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
