LFTX/LFRX
Revision as of 07:20, 8 April 2020 by MichaelDickens (Talk | contribs) (add in Certificate of Volatility)
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz. The LFTX/LFRX daughterboards are supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
  • DC-30Mhz coverage
Daughterboard Specifications
Frontends
LFRX
The LFRX has 4 frontends:
  • Frontend A: real signal on antenna RXA
  • Frontend B: real signal on antenna RXB
  • Frontend AB: quadrature frontend using both antennas (IQ)
  • Frontend BA: quadrature frontend using both antennas (QI)
LFTX
The LFTX has 4 frontends:
  • Frontend A: real signal on antenna TXA
  • Frontend B: real signal on antenna TXB
Gains
LFRX
  • The LFRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
LFTX
  • The LFTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
LFRX
  • For Real-Mode (A or B frontend): 33 MHz
  • For Complex (AB or BA frontend): 66 MHz
LFTX
Input/Output Impedance
  • All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
  • The maximum input power for the LFRX is +10 dBm.
Hardware Specifications
LFRX
  • Minimum version of UHD required: 3.8.0
LFTX
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
LFRX
  • N or X Series
LFTX
  • N or X Series
LFRX
LFRX Schematics
LFTX
LFTX Schematics
Key Component Datasheets
AD813x Differential ADC Driver U2, U3 (1)
LT3462 DC/DC Converter U3 (1)
24LC025B EEPROM U1 (1)
RF Connectors
  • The LFTX / LFRX daughterboard features female SMA connectors for both the TX and RX connectors.
China RoHS
Chinese Customers
LFRX / LFTX Letter of Volatility
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
