USRP X Series Quick Start (Daughterboard Installation)
Revision as of 14:48, 28 April 2020 by JoseLoera (Talk | contribs) (→‎UHD FFT)
AN-904
Date Author Details
2016-05-01 Neel Pandeya
Nate Temple
Initial creation
2020-Apr-27 Jose Loera Added link to video on installing UBX board in a USRP X Series device to the Additional Resources section. Link here as well
This application note is a detailed step-by-step guide to install a daughterboard into the USRP X300/X310.
This Quick Start is meant to show you how to put together your new X300/310. We will start at the point when you have yet to unpack the boxes and go all the way to being able to ping the device, performing a quick software probe to verify hardware components and finally running a simple FFT demo. This Quick Start does not cover the installation of software on the host computer. If you have not installed UHD/Gnuradio on your system, please reference the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. You may also use the Live SDR Environment to perform the verification steps for your USRP. Detailed information on the Live SDR Environment is available at the Live SDR Environment Getting Started Guides page.
Tools Required
  • Philips Screwdriver
  • 5/16” wrench
Pre-installed Software
  • UHD Latest
  • GNU Radio
Box Contents
USRP Box
  • 1 x USRP X300/X310
  • 1 x SFP Adapter for 1 GigE
  • 1 x Power Supply and US Cord
  • 1 x USB 2.0 JTAG Debug Cable
  • 1 x Gigabit Ethernet Cable
  • 4 x SMA-Bulkhead Cables
  • 16 x Daughterboard Screws
Daughterboard Boxes
  • 2 x SBX Daughterboards
Antenna Boxes
  • One or more Antennas
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP™ is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP™ can easily cause the device to become non-functional. Ettus Research recommends you perform the installation with no power to the USRP and using ESD equipment. Listed below are some examples of actions which can prevent damage to the unit:
Installation Process
Step 1
Unscrew the 2 screws on the top of the USRP and remove cover. (Lift up about 15 degrees and wiggle back as there is a flange on the front part of the cover)
Step 2
Line up the 8 screw holes on the Daughterboard with the USRP Motherboard standoffs (they only go one way).
Step 3
Step 4
Put 8 of the screws provided in the daughterboard
Step 5
Repeat steps 2- 4 for the second Daughterboard
Step 6
It is recommended to connect the bulkhead cables one at a time to avoid confusion. The Daughterboards and front panel of the X300/310 are clearly labeled as to which cable goes where.
Step 7
Repeat step 6 for the other bulkhead cables
Step 8
Step 9
Connect the SFP 1 GigE adapter into USRP SFP port 0
Step 10
Connect the Gigabit Ethernet cable and power cord provided
Step 11
Step 12
Step 13
Power on the USRP (button on the front right of the USRP)
Step 14
   $ ping 192.168.10.2
Step 15
Assuming you have properly installed the UHD driver you can now run this command in a terminal/command window:
   $ uhd_usrp_probe
This will tell you about the hardware inside of your USRP. The output will look like the following:
   $ uhd_usrp_probe
   linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-202-g9e0861e1
   -- X300 initialization sequence...
   -- Determining maximum frame size... 1472 bytes.
   -- Setup basic communication...
   -- Loading values from EEPROM...
   -- Setup RF frontend clocking...
   -- Radio 1x clock:200
   -- Detecting internal GPSDO.... No GPSDO found
   -- Initialize Radio0 control...
   -- Performing register loopback test... pass
   -- Initialize Radio1 control...
   |       Device: X-Series Device
   |   |       Mboard: X300
   |   |   revision: 7
   |   |   revision_compat: 7
   |   |   product: 30518
   |   |   mac-addr0: ff:ff:ff:ff:ff:ff
   |   |   mac-addr1: ff:ff:ff:ff:ff:ff
   |   |   gateway: 255.255.255.255
   |   |   ip-addr0: 255.255.255.255
   |   |   subnet0: 255.255.255.255
   |   |   ip-addr1: 255.255.255.255
   |   |   subnet1: 255.255.255.255
   |   |   ip-addr2: 255.255.255.255
   |   |   subnet2: 255.255.255.255
   |   |   ip-addr3: 255.255.255.255
   |   |   subnet3: 255.255.255.255
   |   |   serial: FFFFFFF
   |   |   FW Version: 4.0
   |   |   FPGA Version: 20.0
   |   |   Time sources: internal, external, gpsdo
   |   |   Clock sources: internal, external, gpsdo
   |   |   Sensors: ref_locked
   |   |   |       RX DSP: 0
   |   |   |   Freq range: -100.000 to 100.000 MHz
   |   |   |       RX DSP: 1
   |   |   |       RX Dboard: A
   |   |   |   Serial: FFFFFF
   |   |   |   |   Antennas: TX/RX, RX2, CAL
   |   |   |   |   Sensors: lo_locked
   |   |   |   |   Freq range: 400.000 to 4400.000 MHz
   |   |   |   |   Gain range PGA0: 0.0 to 31.5 step 0.5 dB
   |   |   |   |   Bandwidth range: 40000000.0 to 40000000.0 step 0.0 Hz
   |   |   |   |   Gain range digital: 0.0 to 6.0 step 0.5 dB
   |   |   |       RX Dboard: B
   |   |   |   Serial: FFFFFF
   |   |   |   |   Sensors: lo_locked
   |   |   |       TX DSP: 0
   |   |   |       TX DSP: 1
   |   |   |       TX Dboard: A
   |   |   |   Serial: FFFFFF
   |   |   |   |   Antennas: TX/RX, CAL
   |   |   |   |   Sensors: lo_locked
   |   |   |   |   Connection Type: QI
   |   |   |       TX Dboard: B
   |   |   |   Serial: FFFFFF
   |   |   |   |   Sensors: lo_locked
   |   |   |   |   Connection Type: QI
UBX daughterboard Installation Video
The following link is a video of the steps to install the UBX daughterboard. The procedure is similar to what is outlined above.
UBX Installation into a USRP X-series device.
UHD FFT
1. Connect one antenna to RX2 on the left Daughterboard (Daughterboard A)
   $ uhd_fft --ant RX2
Success
Congratulations! You have successfully setup and verified your new USRP X300/X310. A more detailed verification guide is at the Verifying the Operation of the USRP Using UHD and GNU Radio application note. For additional step-by-step guides to using your USRP X300/X310, see the Application Notes section of the Ettus Research Knowledge Base.
