LFTX/LFRX
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The boards accept real-mode only signals. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz. The LFTX/LFRX daughterboards are supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
Daughterboard Specifications
Frontends
LFRX
The LFRX has 4 frontends:
- Frontend A: real signal on antenna RXA
- Frontend B: real signal on antenna RXB
- Frontend AB: quadrature frontend using both antennas (IQ)
- Frontend BA: quadrature frontend using both antennas (QI)
LFTX
The LFTX has 4 frontends:
- Frontend A: real signal on antenna TXA
- Frontend B: real signal on antenna TXB
Gains
LFRX
- The LFRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
LFTX
- The LFTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
LFRX
- For Real-Mode (A or B frontend): 33 MHz
- For Complex (AB or BA frontend): 66 MHz
LFTX
Input/Output Impedance
- All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
- The maximum input power for the LFRX is +10 dBm.
Hardware Specifications
LFRX
LFTX
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
LFRX
- N or X Series
LFTX
- N or X Series
LFRX
LFTX
Key Component Datasheets
AD813x | Differential ADC Driver | U2, U3 (1) |
LT3462 | DC/DC Converter | U3 (1) |
24LC025B | EEPROM | U1 (1) |
RF Connectors
- The LFTX / LFRX daughterboard features female SMA connectors for both the TX and RX connectors.
China RoHS
Chinese Customers
Certificate of Volatility
LFRX / LFTX Letter of Volatility
