Running UHD and GNU Radio on NI USRP-RIO
Revision as of 13:47, 15 April 2021 by MichaelDickens (Talk | contribs) (whitespace)
AN-638 by Neel Pandeya, Nate Temple, and Michael Dickens
This AN explains the process to updating your NI USRP-RIO to run UHD and GNU Radio.
This application note will cover the details of converting your NI USRP-RIO into an equivalent Ettus Research X310 USRP. Once it is converted into a X310, you will be able to use the UHD API, GNU Radio and RFNoC as you would a proper X310.
Warning
Opening the chassis and changing the daughterboards will void your NI warranty. NI will not be able to provide support for UHD, GNU Radio, or RFNoC. Support questions should be directed to the usrp-users and discuss-gnuradio mailing lists or to [email protected].
Prerequisites
This guide assumes that your USRP-RIO already has a valid IP address, and that you can ping the device.
Installing UHD
You will need to install UHD on to your host system. For more information on installing UHD, please see the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes.
Downloading FPGA Images
After UHD is installed, run the following command to download the corresponding FPGA images.
   sudo uhd_images_downloader
Flashing FPGA Image
Once the FPGA images are downloaded, you are ready to flash the FPGA image with the following command. Note, you will need to update the IP address of the USRP-RIO and the path to the FPGA image in the following command. Ensure power to the USRP-RIO and host computer is not interrupted during the flashing process. You will need to update the IP Address and FPGA Path in the following command.
If you are loading it via Ethernet:
   Automatic FPGA path, detect image type:
   uhd_image_loader --args="type=x300,addr=<IP address>"
If you are using PCI Express, then:
   uhd_image_loader --args="type=x300,resource=<NI-RIO resource>"
Further information regarding the way to load FPGA images into the X3X0 device can be found in our manual page
Once the FPGA burner utility is completed, power cycle the USRP-RIO.
Testing
After you power cycle the USRP-RIO, test it with the following command.
   uhd_usrp_probe
Installing GNU Radio
For details instructions on installing GNU Radio, please reference the GNU Radio section of the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux and OS X Application Notes.
Testing GNU Radio
Once GNU Radio is installed, you can test the operation of the USRP-RIO with the following utility.
   uhd_fft
For a more detailed and through testing procedure, please see the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
RFNoC
For detailed instructions on setting up RFNoC, please see the RFNoC Getting Started Guides page.
