The UHD logging facility
Application Note Information
AN-001 by Michael Dickens
This application note describes the UHD logging facility: compile-time options, runtime options, application usage, and default values ... and how all of these interact.
Code
UHD has 3 primary files associated with logging: log.hpp, log.cpp, and UHDLog.cmake. There are secondary logging files providing an interface to C and Python.
Concepts
There are 7 logging levels; the name and number can be used interchangeably for any logging variable.
| trace | debug | info | warning | error | fatal | off |
| 0 | 1 | 2 | 3 | 4 | 5 | 6 |
There are 2 distinct times where logging can be controlled: during compilation per CMake settings, and during runtime via shell environment variables.
CMake Logging Settings
There are 10 CMake variables that control logging:
- 6 are boolean:
UHD_LOG_FASTPATH_DISABLE,UHD_LOG_CONSOLE_DISABLE,UHD_LOG_CONSOLE_COLOR,UHD_LOG_CONSOLE_TIME,UHD_LOG_CONSOLE_THREAD, andUHD_LOG_CONSOLE_SRC; - 3 set log levels:
UHD_LOG_MIN_LEVEL,UHD_LOG_FILE_LEVEL, andUHD_LOG_CONSOLE_LEVEL; - 1 sets the default log file:
UHD_LOG_FILE.
Each of these variables can be set independently via the CMake commandline or other methods, and override each's default value as set in the UHD CMake scripts. The default values for 2 of these variables depends on whether the CMAKE_BUILD_TYPE is Debug or not, as follows:
| Default Value | ||
| Variable | non-Debug
Debug
UHD_LOG_FILE_LEVEL
info
trace
info
debug
Here is a description of the 10 CMake variables the influence logging:
- The variable
UHD_LOG_CONSOLE_DISABLEsets whether to disable (ifON) or enable (ifOFF) console-based logging; the default isOFFsuch that console logging is enabled. When set toON, console-based logging is not compiled into UHD at all, and so anyCONSOLElog setting will have no effect.
- The variable
UHD_LOG_FASTPATH_DISABLEsets whether to disable (ifON) or enable (ifOFF) fastpath logging; the default isOFFsuch that fastpath logging is enabled. Fastpath logging is used for Extra-fast logging macro for when speed matters; no metadata is tracked, and only the message is displayed. This logging is used for printing theUOSDLcharacters during streaming to show underrun, overflow, and other situations.
- The variable
UHD_LOG_CONSOLE_COLORsets whether to disable (ifOFF) or enable (ifON) colorization of logging text via special terminal character sequences. By default on Microsoft Windows or Cygwin, colorization is disabled; otherwise it is enabled.
- The variable
UHD_LOG_CONSOLE_TIMEsets whether to disable (ifOFF) or enable (ifONthe current timestamp as part of the log message. By default this variable is not set, which means it isOFF. This variable must be set toON(or the equivalent) for this logging to be enabled.
- The variable
UHD_LOG_CONSOLE_THREADsets whether to disable (ifOFF) or enable (ifONthe thread ID displaying the log as part of the log message. By default this variable is not set, which means it isOFF. This variable must be set toON(or the equivalent) for this logging to be enabled.
- The variable
UHD_LOG_CONSOLE_SRCsets whether to disable (ifOFF) or enable (ifONthe source code filename and line displaying the log as part of the log message. By default this variable is not set, which means it isOFF. This variable must be set toON(or the equivalent) for this logging to be enabled.
- The variable
UHD_LOG_MIN_LEVELsets the minimum logging level for any logging functionality. For example, when this variable is set todebug(the default), thentracelevel debugging will not be available for any logging; onlydebugand higher (up tofatal) will be available. Setting this variable tooffwill disable runtime logging, but all enabled logging will still be compiled as part of UHD.
- The variable
UHD_LOG_FILE_LEVELsets the default value for file-based logging. This value can be changed for runtime to any valueUHD_LOG_MIN_LEVELor higher.
- The variable
UHD_LOG_CONSOLE_LEVELsets the default value for console-based logging. This value can be changed for runtime to any valueUHD_LOG_MIN_LEVELor higher.
- The variable
UHD_LOG_FILEsets the default file to use for file-based logging. By default this variable is not set, which means that there is no default file to write file-based logging into. If not set during compile-time, then to enable file-based logging the eponymous runtime variable must be set, as noted below.
Runtime Logging Settings
There are 5 runtime environment variables that control logging. Each of these variables can be set independently via a shell environment, on the commandline, or other methods, and override each's default value as set by the aforementioned CMake variables.
- The variable
UHD_LOG_LEVELsets the minimum logging level for any logging functionality. For example, when this variable is set todebug(the default), thentracelevel debugging will not be available for any logging; onlydebugand higher (up tofatal) will be available.
- The variable
- The variable
UHD_LOG_FILEsets the file to use for file-based logging. If no log file is set at compile-time or runtime, then no file logging will take place. Any file specified for logging must be able to be opened for writing to (but not necessarily reading from by the UHD process); any existing file will be appended to.
- The variable
- The variable
UHD_LOG_FASTPATH_DISABLEsets whether to disable fastpath logging, if it was not disabled at compile-time.
