UBX
- 1 Device Overview
- 2 Key Features
- 4 RF Specifications
- 5 RF Performance Data
- 6 Hardware Specifications
- 8 USRP Compatibility
- 9 Phase Synchronization
- 10 Schematics
- 11 Key Component Datasheets
- 12 Mechanical Information
- 13 RF Connectors
- 14 Certifications
- 15 Certificate of Volatility
- 16 Important Notes
- 17 Downloads
The UBX daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 6 GHz. Coherent and phase-aligned operation across multiple UBX daughterboards on USRP X Series motherboards enables users to explore MIMO and direction finding applications. The UBX daughterboard is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The UBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications, on the X Series. Additionally this capability is only available on the X Series devices.
Features
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
- Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a UBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
- Transmit Gains: PGA0, Range: 0-31.5dB
Bandwidths
- UBX: 40 MHz, RX & TX
- UBX-160: 160 MHz, RX & TX
Sensors
LEDs
- LOCK: Synthesizer Lock Detect
- TX/RX TXD: Transmitting on TX/RX antenna port
- TX/RX RXD: Receiving on TX/RX antenna port
- RX2 RXD: Receiving on RX2 antenna port
Freq Range
- 10MHz - 6GHz
Noise Figure
- 10 MHz - 500 MHz: 3 - 4 dB
- 500 MHz - 1.5 GHz: 2 - 3 dB
- 1.5GHz - 6GHz: 4 - 10 dB
RX IIP3 (Max)
- 10 MHz - 6 GHz: 8 - 9 dBm
RX IQ Imbalance
- 10 MHz - 6 GHz: < -30dBc
TX Power (Max)
- 10 MHz - 3 GHz: 20 dBm
- 3 - 6 GHz: 8 - 20 dBm
TX OIP3
- 10 - 500 MHz: 41 dBm
- 0.5 - 3 GHz: 36 dBm
- 3 - 6 GHz: 26 dBm - 36 dBm
TX IQ Imbalance
- 10 MHz - 6 GHz: < -30 dBc
Note: The UBX 160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Input/Output Impedance
- All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
- The maximum input power for the UBX is -15 dBm.
RF Performance Data
UBX-40
- Current Hardware Revision: 2
- Minimum version of UHD required for UBX rev-1: 3.8.2
- Minimum version of UHD required for UBX rev-2: 3.9.5
UBX-160
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
UBX-40
- N or X Series
UBX-160
- X Series only
The UBX daughterboard is capable of phase-synchronous operation, and is recommended for phase-coherent applications. The SBX and TwinRX daughterboards are also recommended for phase-coherent applications.
If you are operating the UBX at frequencies below 1 GHz and need phase synchronization, then it is necessary to select a 20 MHz daughterboard clock rate, instead of using the default 50 MHz rate. Note that this is only required for phase synchronization below 1 GHz. The UBX can still operate below 1 GHz without setting this lower daughterboard clock rate, but it will operate without any phase synchronization capability.
If you're using a UHD program, then you can specify the lower daughterboard clock rate on the command line of the program, with --args="dboard_clock_rate=20e6"
If you're using the UHD API from a C++ program, then you can include "dboard_clock_rate=20e6"
in the device arguments parameter when first invoking multi_usrp::make()
If you're using GNU Radio, then you can add "dboard_clock_rate=20e6"
to the "Device Arguments"
field of the properties for the UHD Sink and UHD Source blocks.
UBX
MAX2871 | Fractional/Integer-N Synthesizer/VCO | U3 (3); U9 (5); U19 (7); U23 (9) |
ADL5375-05 | Quadrature Modulator | U22 (8) |
LFCN-2250+ | Low Pass Filter | F1 (3); F24 (7); F34, F35 (10) |
LTC5510 | Active Mixer | U15 (6) |
LFCN-490+ | Low Pass Filter | F12 (5); F15 (6); F26 (7); F31 (9); F33, F36 (10) |
HMC624LP4E | ATTENUATOR | U16 (6) |
NBB-400 | Amplifier | U13 (6); U30 (11) |
PHA-1+ | Amplifier | U31 (11) |
ADA4927-2 | Differential ADC Driver | U6 (4) |
ADL5380 | Quadrature Demodulator | U8 (4) |
MGA-62563 | Low Noise Amplifier | U36 (11) |
LFCN-1700+ | Low Pass Filter | F41 (11) |
VMMK-3603 | Low Noise Amplifier | U34 (11) |
LFCN-2600+ | Low Pass Filter | F14, F17 (6) |
855916 | SAW Filter | F16 (6) |
LTC5510 | Active Mixer | U15 (6); U28 (10) |
LFCN-2600+ | Low Pass Filter | F14, F17 (10) |
TCM1-63AX+ | RF Transformer | T1 (3); T2, T3 (4); T7 (8) |
AD8591 | Operational Amplifiers | U7 (4) |
ZXTC2062E6 | TRANSISTORS | Q1 (6) |
HMC624ALP4E | ATTENUATOR | U16 (6); U29 (10) |
LFCN-800+ | Low Pass Filter | F2 (3); F25 (7) |
ADP7104-3.3 | CMOS LDO | U4, U5 (3); U10, U11 (5); U20, U21 (7); U24, U25 (9); U48 (13) |
LTC5510 | Active Mixer | U28 (10) |
24LC024 | EEPROM | U38, U39 (12) |
ADP7104-5.0 | CMOS LDO | U41, U42, U43, U44, U45, U46, U47 (13) |
ZXTC2062E6 | TRANSISTORS | Q2, Q3, Q4, Q5 (13) |
Drawings
RF Connectors
- The UBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
UBX-40/UBX-160
Important Notes
- A larger 24W (6V, 4A) power supply is required when using a UBX-40 daughterboard and integrated GPS Disciplined Oscillator accessory together in a USRP2, USRP N200, or USRP N210 device.
- The UBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
