X410
Revision as of 08:03, 22 April 2022 by DylanCaswell (Talk | contribs) (→‎100 Gigabit Ethernet)
Notice
When you receive a brand-new device, it is strongly recommended that you download the most recent filesystem image from the Ettus Research website and write it to the NI Ettus USRP X410. Instructions on downloading the latest filesystem image and writing it to the X410 is described in the https://kb.ettus.com/USRP_X410_Getting_Started_Guide.
Note that if you are operating the device in Network Mode, then the versions of UHD running on the host computer and on the NI Ettus USRP X410 device must match.
The NI Ettus USRP X410 is a high-performance, multi-channel software defined radio. The SDR is designed for frequencies from 1 MHz to 7.2 GHz, tunable up to 8 GHz and features a two-stage superheterodyne architecture with 4 independent TX and RX channels capable of 400 MHz of instantaneous bandwidth each. Digital interfaces for data offload and control include two QSFP28 interfaces capable of 100 GbE[1], a PCIe Gen3 x8 [3] interface, as well standard command, control, and debug interfaces: USB-C JTAG, USB-C console, Ethernet 10/100/1000. The USRP X410 is an all-in-one device built on the Xilinx Zynq Ultrascale+ ZU28DR RF System on Chip (RFSoC) with built-in digital up and down conversion and onboard Soft-Decision Forward Error Correction (SD-FEC) IP.
X410
  • High channel density
  • 12 bit ADC, 14 bit DAC
  • Onboard SD-FEC, DDC, DUC
  • RJ45 (1 GbE) [1]
  • 10 MHz Clock reference
  • PPS time reference
  • Trig In/Out Interface
  • Built-in GPSDO
  • 1 Type C USB host port
  • Watchdog timer
  • OpenEmbedded Linux
Hardware Specifications
https://www.ni.com/pdf/manuals/378493a.pdf
X410
  • Current Hardware Revision: Module revision E and Motherboard revision G
  • Minimum version of UHD required: 4.1.0.5
https://github.com/EttusResearch/uhd/releases/tag/v4.1.0.5
CAD/STP Models
If you want any CAD / STP models beyond those found here, please send an email to Ettus Support at [email protected] noting your request and your use case for any such model. We will determine on a case-by-case basis whether we have any such requested model and, if so, whether to release it -- possibly requiring an NDA for any such release. Note that we do not have models on all USRPs and daughterboards, and requesting any model does not guarantee that either Ettus Research or NI will honor any such request.
GPSDO
  • Support GPSDO NMEA Strings
Sensors
Specifications
Module Specifications
1 PPS Timing Accuracy from GPS receiver <8ns to UTC RMS (1-Sigma) GPS Locked
Holdover Stability (1 week with GPS) <±50us over 3 Hour Period @+25°C (No Motion, No Airflow)
1 PPS Output 3.3VDC CMOS
Serial Port TTL Level, GPS NMEA Output with 1Hz or 5Hz update rate, Integrated into UHD
GPS Frequency L1, C/A 1574MHz
GPS Antenna Active (3V compatible) or Passive (0dB to +30dB gain)
GPS Receiver 65 Channels, QZSS, SBAS WAAS, EGNOS, MSAS capable
Supports Position and Hold over-determined clock mode
Sensitivity Acquisition -148dBm, Tracking -165dBm
TTFF Cold Start: <32 sec, Warm Start: 1 sec, Hot Start: 1 sec
ADEV 10s: <7E-011
10Ks: <2E-012 (GPS Locked, 25°C, no motion, no airflow)
Warm Up Time / Stabilization Time <10 min at +25C to 1E-09 Accuracy
Supply Voltage (Vdd) 3.3V Single-Supply, +0.2V/-0.15V
Power Consumption <0.16W
Operating Temperature -10°C to +70°C
Storage Temperature -45C to 85C
Oscillator Specifications (internal)
Frequency Output of low Phase Noise crystal 20MHz CMOS 3Vpp
20MHz Retrace ±2E-08 After 1 Hour @ +25°C without GPS
RF Output Amplitude 3Vpp CMOS
20MHz Phase Jitter (100Hz to 10MHz) <0.135ps rms
Frequency Stability Over Temperature (0°C to +60°C) ±0.1ppm (internal TCXO without GPS)
Warm Up Time < 1 min at +25C
Phase Noise at 20MHz 1Hz -65 dBc/Hz
10Hz -97 dBc/Hz
100Hz -116 dBc/Hz
1kHz -136 dBc/Hz
10kHz <-148 dBc/Hz
100 kHz <-155 dBc/Hz
Datasheet
FPGA
FPGA User Modifications
The Verilog code for the FPGA in the NI Ettus USRP X410 is open-source, and users are free to modify and customize it for their needs. However, certain modifications may result in either bricking the device, or even in physical damage to the unit. Specifically, changing the I/O interface of the FPGA in any way, or modifying the pin and timing constraint files, could result in physical damage to other components on the motherboard, external to the FPGA, and doing this will void the warranty. Also, even if the PCIe interface is not being used, you cannot remove or reassign these pins in the constraint file. The constraint files should not be modified. Please note that modifications to the FPGA are made at the risk of the user, and may not be covered by the warranty of the device.
Interfaces and Connectivity
Front Panel
Rear Panel
Ref Clock - 10 MHz
Using an external 10 MHz reference clock, a square wave will offer the best phase noise performance, but a sinusoid is acceptable.
PPS - Pulse Per Second
Using a PPS signal for timestamp synchronization requires a square wave signal (a typical PPS signal has a 20%-25% duty cycle) with a 5Vpp amplitude.
Front Panel GPIO
Power on state
Accessories
  • Dual 100 Gigabit Ethernet PCIe Interface Kit For Ettus USRP X4xx
    • Part Number: 788216-01
  • QSFP28 To 4xSFP28 Breakout Cable, 1M
    • Part Number: 788214-01
  • QSFP28 Twinaxial Cable, 3M
    • Part Number: 788215-03
  • USRP X4xx 19" Rack Mount Accessory, 1U, 2 USRP X4xx Devices, Shoulder to Shoulder
    • Part Number: 788147-01
  • USRP X4xx Desktop Stack Accessory, Single USRP X4xx Device Fastened Buildup
    • Part Number: 788148-01
  • USRP X4xx 19" Rack Mount Accessory, 1U, 1 USRP X4xx Device, w/Surrogate Extension
    • Part Number: 788149-01
  • GPIO Communication Cable
    • SHH19-H19-AUX Shielded Single-Ended Cable, 1M
      • Part Number: 152629-01
    • SHH19-H19-AUX Shielded Single-Ended Cable, 2M
      • Part Number: 152629-02
  • SCB-19 Noise Rejecting, Shielded Aux I/O Connector
    • Part Number: 782444-01
  • Fan Replacement Cartridges
    • USRP X4xx Fan Cartridge Accessory, Exhaust
      • Part Number: 788164-01
    • USRP X4xx Fan Cartridge Accessory, Intake
      • Part Number: 788165-01
China RoHS
Chinese Customers
Certificate of Volatility
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
10 Gigabit Ethernet
Recommended 100 Gigabit Ethernet Cards
Recommended 100 Gigabit Ethernet Cables
Recommended Host PC
  • At least 15 CPU Cores
  • At least 32 GB RAM
  • Ubuntu 20.04 (5.4.0-89-generic kernel)
Validated Hardware and Software Configuration Examples
  • Ubuntu 20.04 (5.4.0-89-generic kernel), DPDK 19.11, with Intel(R) Core(TM) i9-10920X CPU @ 3.50GHz - 24 CPU - 4.8 GHz Max CPU freq - 64 GB RAM. Mellanox/NVIDIA ConnectX-5 EX 100 GbE NIC (MCX516A-CCAT (PCIe Gen3 x16)). Mellanox/NVIDIA 3m QSFP28 MCP1600-C003E26N cables.
  • Ubuntu 20.04 (5.4.0-89-generic kernel), DPDK 20.11, with AMD Ryzen Threadripper 3960X 24-Core Processor - 48 CPU - 3.6 GHz CPU freq - 64 GB RAM. Mellanox/NVIDIA ConnectX-5 EX 100 GbE NIC (MCX516A-CDAT (PCIe Gen4 x16)). Mellanox/NVIDIA 3m QSFP28 MCP1600-C003E26N cables.
Data Throughput Rates
Testing was completed with the following conditions
Executing benchmark_rate over multiple iterations as well as over an extended continuous time period (>12 Hours) without data loss resulted in the following maximum rates and channel counts
  • Usage of the --priority argument set to high in benchmark_rate which requires benchmark rate to be executed with root privileges via sudo
  • Usage of single versus multiple threads in the benchmark_rate utility - controlled by using the --multi_streamer argument. Specifying this argument assigns one thread per channel being streamed.
  • Utilizing the CG_400 bitfile which does not include DUC/DDC resampling thus supports only rates of 491.52 MS/s and 500 MS/s
  • Dual Port DPDK
    • 4 Rx + 4 Tx @ 491.52 MS/s
    • 4 Rx @ 491.52 MS/s
    • 4 Tx @ 491.52 MS/s
  • Single Port DPDK
    • 2 Rx + 2 Tx @ 491.52 MS/s
    • 3 Tx @ 491.52 MS/s
  • Dual Port Non-DPDK
    • 1 Rx + 1 Tx @ 491.52 MS/s
    • 2 Tx @ 491.52 MS/s
  • Single Port Non-DPDK
    • 3 Rx @ 491.52 MS/s
Guidance on SFP+ Adapters for Fiber Connectivity on NI Ettus USRP X410
Ettus Research currently offers direct-connect, copper cabling accessories for the NI Ettus USRP X410. However, it is also possible to use multi-mode fiber instead of copper connections for these devices. In this section, we will provide general guidance on the types of fiber adapters and cables that can be used with these products.
The NI Ettus USRP X410 is compatible with most brands of SFP+ fiber adapters. In some cases, other equipment in the systems such as 1/10/100 Gigabit Ethernet switches are only compatible with specific brands of SFP+ adapters and cables. As a general rule, we recommend checking compatibility with the switches and network cards in your system before purchasing an adapter.
Ettus Research does test the NI Ettus USRP X410 devices with our TBD. Here are is a list of known-good cables and adapters.
