Enabling Ethernet Connectivity on Octoclock and Octoclock-G
- 1 Application Note Number
- 2 Revision History
- 3 Overview
- 4 Verify Current Octoclock Configuration
- 5 Tools Required
- 6 ATMEL-ICE Configuration
- 7 Download Octoclock Bootloader and Firmware
- 8 Connect Programmer to Octoclock
- 9 Program the Octoclock Bootloader
- 10 Uploading Octoclock Firmware via Ethernet
- 11 Updating the Octoclock's EEPROM
- 12 Additional Resources
- 13 Troubleshooting
AN-800
| Date | Author | Details |
| 2020-01-13 | Sam Reiter | Initial creation |
This application note covers, in detail, the steps required to program an Octoclock or Octoclock-G to allow Ethernet connectivity and communication with UHD. This guide serves as a supplement to the UHD Manual's coverage of the topic. In this guide, we will use Ubuntu 19.10 to program an Octoclock using an ATMEL-ICE programmer.
This guide applies to Octoclock, Octoclock-G, and CDA-2990 devices. Any of these names is interchangeable with "Octoclock" in this document.
To get started, we want to make sure that this guide is appropriate for your device(s). Currently shipping Octoclocks will come with the new firmware pre-loaded and do not require the update in this guide. You can test which firmware / bootloader you have with a simple ping test:
- Connect the 6V DC power supply to the Octoclock
- Connect your Octoclock's RJ-45 port to a host PC via an Ethernet cable
- Configure your host's Ethernet port to a static connection with the IPV4 address:
192.168.10.1 - Configure your host's Ethernet port with a subnet mast of:
255.255.255.0 - Turn your host's Ethernet port off and back on for changes to take effect
- In a terminal, issue the command:
ping 192.168.10.3
A device with the old bootloader will not respond to a ping. In this case, proceed to the next section. A successful ping between devices means that your device is already configured with updated firmware and this guide is not necessary. At this time, this guide has not been tested for recovering bricked devices.
Tools Required
- Philips head screwdriver
- ATMEL-ICE Programmer (or comparable AVR programmer) with SPI/ISP cable
- Ethernet cable
To use the ATMEL-ICE programmer, the avrdude utility must be installed. The version of avrdude should be >= 6.1. At the time of this guide, version 7.0 has been released but not tested here; possible usable versions are 6.1 through 6.4. This guide will cover a build of avrdude 6.1 from source as it is known to work; version 6.3 is also provided by apt and PPA, and might also work.
Install the following dependencies:
sudo apt-get install bison flex libftdi1-dev libftdi-dev
Download the avrdude-6.1.tar.gz release here, for example via the following command:
wget https://download.savannah.gnu.org/releases/avrdude/avrdude-6.1.tar.gz
Uncompress the tarball:
tar xf avrdude-6.1.tar.gz
Enter the source directory:
cd avrdude-6.1
Run the configure script:
./configure
Expected output:
<truncated output> Configuration summary: ---------------------- DO HAVE libelf DO HAVE libusb DO HAVE libusb_1_0 DO HAVE libftdi1 DO HAVE libftdi (but prefer to use libftdi1) DON'T HAVE libhid DO HAVE pthread DISABLED doc ENABLED parport DISABLED linuxgpio
Build the code:
make
Install the executable:
sudo make install
Update Linux dynamic library cache:
sudo ldconfig
Test your avrdude installation
avrdude -?
Expected output:
<truncated output> avrdude version 6.1, URL: <http://savannah.nongnu.org/projects/avrdude/>
If UHD is not already installed, install your preferred version with this guide: Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux
Download images for UHD:
sudo uhd_images_downloader
Verify that you have octoclock_bootloader.hex and octoclock_r4_fw.hex
ls -l /usr/local/share/uhd/images | grep octoclock
Expected output
-rw-r--r-- 1 root root 17332 Jun 6 2019 octoclock_bootloader.hex -rw-r--r-- 1 root root 22845 Jun 6 2019 octoclock_r4_fw.hex
Change to your images directory:
cd /usr/local/share/uhd/images
Leave this terminal open for future steps.
Begin this section with the Octoclock completely unplugged.
First, you'll need to remove the top plate from the Octoclock, exposing the PCB. There are 12 screws securing the top plate.
With the top plate removed, locate the 6-pin header (J108, male) for SPI communication with the ATmega128.
Connect the ATMEL-ICE's 6-pin header (female) to the SPI header of the Octoclock as shown below. The tab of the header must be facing the ATmega128 chip.
Note: If you plug the header in backwards, avrdude is expected to return a please check your connections message after a programming failure. See the section "Troubleshooting" at the bottom of this document for more detail.
Disconnect the Octoclock from power, then hook up the AMTEL-ICE connections: Connect the other end of the SPI cable to the ATMEL-ICE's AVR squid connector, and connect the ATMEL-ICE to the host computer using the micro-usb port. The connections will be Host --> Micro USB Cable --> ATMEL-ICE --> Squid to SPI Cable --> Octoclock SPI header. There should be a single LED lit -- the middle one (red) -- on the programmer:
Supply power to the Octoclock with the 6V power brick. You should see the Octoclock's Power LED come on and the left LED (green) on the ATMEL-ICE programmer illuminate, such that the left 2 LEDs are lit. The overall setup should look something like this:
With the terminal that is open in the same directory as the .hex images, run the following command:
sudo avrdude -p atmega128 -c atmelice_isp -P usb -U efuse:w:0xFF:m -U hfuse:w:0x80:m -U lfuse:w:0xEF:m -U flash:w:octoclock_bootloader.hex:i
NOTE that this command must be executed with sudo, otherwise avrdude will error out trying to open the USB interface, for example:
avrdude: usb_open(): cannot read serial number "error sending control message: Operation not permitted" avrdude: usb_open(): cannot read product name "error sending control message: Operation not permitted" avrdude: usbdev_open(): WARNING: failed to set configuration 1: could not set config 1: Operation not permitted avrdude: usbdev_open(): error claiming interface 0: could not claim interface 0: Operation not permitted avrdude: usbdev_open(): error claiming interface 1: could not claim interface 1: Operation not permitted avrdude: usbdev_open(): no usable interface found avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2141
If you are using a programmer other than the ATMEL-ICE, you will need to change the -c parameter to match your programmer. Valid programmers for your version of avrdude can be found by running:
avrdude -c help
The expected output from a successful run of avrdude is as follows:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9702 (probably m128)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "0xFF"
avrdude: writing efuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFF:
avrdude: load data efuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0x80"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0x80:
avrdude: load data hfuse data from input file 0x80:
avrdude: input file 0x80 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xEF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xEF:
avrdude: load data lfuse data from input file 0xEF:
avrdude: input file 0xEF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "octoclock_bootloader.hex"
avrdude: writing flash (129012 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 129012 bytes of flash written
avrdude: verifying flash memory against octoclock_bootloader.hex:
avrdude: load data flash data from input file octoclock_bootloader.hex:
avrdude: input file octoclock_bootloader.hex contains 129012 bytes
avrdude: reading on-chip flash data:
avrdude: 129012 bytes of flash verified
avrdude: safemode: Fuses OK (E:FF, H:80, L:EF)
avrdude done. Thank you.
Upon successful burning of a bootloader, you will now need to upload firmware. Connect the USRP to your host via Ethernet and configure your host's IP as noted in the "Verify Current Octoclock Configuration" section. Next, run
uhd_find_devices
Expected output:
uhd_find_Devices
-- UHD Device 0
Device Address:
addr: 192.168.10.3
type: octoclock-bootloader
This means that UHD successfully recognizes your device's bootloader and can download the firmware image. If you get a "No Devices Found" return from UHD, something went wrong during the bootloader burn. In this case you should rerun the avrdude command with verbose output enabled - see Troubleshooting for more detail.
If UHD successfully recognized the Octoclock's bootloader, run the following command:
uhd_image_loader --args="type=octoclock,addr=192.168.10.3"
Once this completes, your OctoClock will load its firmware. Powercycle the device, then run the uhd_find_devices utility again, and the output should be similar to the following:
-- UHD Device 0
Device Address:
addr: 192.168.10.3
type: octoclock
name:
serial:
Note that the Octoclock will enter its bootloader once it first receives power. It will take ~10s to boot and be recognized as an octoclock as seen in the above output.
As a final step, the device's EEPROM will need to be updated. On the back of your device, you will see a label sticker with a serial number (labeled S/N) and a MAC address (labeled MAC). For later use, the MAC address will have to be used in a different format than is on the label. As an example, if the label lists the MAC address as 00802F112233, you will need to format it as 00:80:2F:11:22:33.
Update the Octoclock's EEPROM witht he following command:
/usr/local/lib/uhd/utils/octoclock_burn_eeprom --args="addr=192.168.10.3" --values="mac-addr=<FORMATTED MAC HERE>,ip-addr=192.168.10.3,netmask=255.255.255.0,gateway=192.168.10.1,serial=<SERIAL HERE>,revision=4"
Verify everything with
/usr/local/lib/uhd/utils/octoclock_burn_eeprom --args="addr=192.168.10.3" --read-all
Expected output:
Creating OctoClock device from args: addr=192.168.10.3
[INFO] [UHD] linux; GNU C++ version 9.2.1 20191008; Boost_106700; UHD_3.15.0.HEAD-0-gaea0e2de
[INFO] [OCTOCLOCK] Opening an OctoClock device...
[INFO] [OCTOCLOCK] Detecting internal GPSDO...
[INFO] [GPS] Found an internal GPSDO: LC_XO, Firmware Rev 0.929a
[INFO] [OCTOCLOCK] Detecting external reference...false
[INFO] [OCTOCLOCK] Detecting switch position...Prefer internal
Fetching current settings from EEPROM...
EEPROM ["mac-addr"] is "<MAC ADDR>"
EEPROM ["ip-addr"] is "192.168.10.3"
EEPROM ["gateway"] is "192.168.10.1"
EEPROM ["netmask"] is "255.255.255.0"
Device is using internal reference
EEPROM ["serial"] is "<SERIAL NUMBER>"
EEPROM ["name"] is ""
EEPROM ["revision"] is "4"
Power-cycle your device to allow any changes to take effect.
Power cycle your device and your octoclock has been updated!
Troubleshooting
This process has been run and confirmed in Ubuntu 19.10. Other versions of Linux may require different versions of dependencies to be installed. avrdude also runs natively on Windows.
You can use -v flags with avrdude to make the output verbose, if running into issues. Here is the ouput of avrdude with verbose flags set:
sudo avrdude -v -v -p atmega128 -c atmelice_isp -P usb -U efuse:w:0xFF:m -U hfuse:w:0x80:m -U lfuse:w:0xEF:m -U flash:w:octoclock_bootloader.hex:i
Output when SPI plug is plugged into the header backwards:
avrdude: Version 6.1, compiled on Jan 10 2020 at 15:41:02
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/usr/local/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : atmelice_isp
avrdude: stk500v2_jtag3_open()
avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J42700007132
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
avrdude: jtag3_edbg_prepare(): connection status 0x01
avrdude: Sending sign-on command: 0x80 (509 bytes msg)
AVR Part : ATmega128
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 12 64 0 no 4096 8 0 9000 9000 0xff 0xff
flash 33 6 128 0 yes 131072 256 512 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : JTAG3_ISP
Description : Atmel-ICE (ARM/AVR) in ISP mode
avrdude: jtag3_getparm()
avrdude: Sending get parameter (scope 0x01, section 1, parm 0) command: 0x84 (509 bytes msg)
Vtarget : 2.7 V
SCK period : 125.00 us
avrdude: jtag3_setparm()
avrdude: Sending set parameter (scope 0x12, section 0, parm 0) command: 0x80 (509 bytes msg)
avrdude: Sending set parameter (scope 0x12, section 0, parm 1) command: 0x80 (509 bytes msg)
avrdude: Sending set parameter (scope 0x12, section 1, parm 0) command: 0x80 (509 bytes msg)
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_jtag3_close()
avrdude: jtag3_close()
avrdude: Sending AVR sign-off command: 0x80 (509 bytes msg)
avrdude: Sending sign-off command: 0x80 (509 bytes msg)
