- 1 Author
- 2 Application Note Number
- 3 Abstract
- 4 Introduction
- 5 Overview of the USRP N300 and N310
- 6 Overview of the USRP N320 and N321
- 7 Overview of the USRP X410
- 8 Overview of the 5G System and OAI Stack
- 9 Bill of Materials (BoM)
- 10 Hardware Requirements
- 11 Software Requirements
- 12 Installing and Configuring the UHD Software
- 13 Installing and Configuring the USRP Radio
- 14 Configuring the Ubuntu Linux Operating System
- 15 Configuring the BIOS for gNB and UE Systems
- 16 Installing and Configuring the CN System
- 17 Installing and Configuring the gNB System
- 18 Installing and Configuring the UE System
- 19 Running the System
- 20 Monitoring and Benchmarking the System
- 21 Troubleshooting
- 22 Technical Support
- 23 FAQ
- 24 Resources
Author
Neel Pandeya, Bharat Agarwal
AN-956
This Application Note presents a reference design for using the Eurecom OpenAirInterface (OAI) software stack to implement 5G/NR Stand-Alone (SA) systems on the USRP N300, N310, N320, N321, X410 radio devices. The reference design covers the basestation (gNB), the user equipment (UE), and the Core Network (CN) components of the network. Three types of UE are used: a UE running on a USRP radio; a wireless modem module UE; and a commercial (COTS) handset/phone. The reference design supports operation in Frequency Range 1 (FR1), and support for operation in FR2 will be added at a future date. The various aspects of installing, configuring, and running the hardware and software components of the network are discussed in detail, along with a discussion of expected results, methods to benchmark and monitor the system, and troubleshooting steps.
Introduction
This is example text.
- Three desktop computers, with Intel Core i9 CPU, of 10th, 11th, or 12th Generation, with clock speed of minimum 4.0 GHz, with minimum 10 physical cores, and also with only NVMe disk drives. See further details about this item in the Hardware Requirements section.
- Two 10 Gbps Ethernet networks cards. We recommend the Intel X710-DA2 and the Nvidia/Mellanox MCX4121A-ACAT ConnectX-4 network cards. See further details about this item in the Hardware Requirements section.
- Two USRP devices. The USRP may be any of USRP N300, N310, N320, N321, X410. There will be one USRP for the gNB, and one USRP for the UE. The USRP devices can be mixed (i.e., the gNB could run with a USRP X410, while the UE runs with a USRP N310).
- https://kb.ettus.com/N300/N310
- https://kb.ettus.com/N320/N321
- https://kb.ettus.com/X410
- https://www.ettus.com/all-products/usrp-n300/
- https://www.ettus.com/all-products/usrp-n310/
- https://www.ettus.com/all-products/usrp-n320/
- https://www.ettus.com/all-products/usrp-n321/
- https://www.ettus.com/all-products/usrp-x410/
- One QSFP28-to-SFP28 breakout cable (NVIDIA MCP7F00-A003R26N DAC Splitter Cable Ethernet 100GbE to 4x25GbE 3m). This is only needed when using the USRP X410.
- https://store.mellanox.com/products/nvidia-mcp7f00-a003r26n-passive-copper-splitter-cable-ethernet-100gbe-to-4x25gbe-qsfp28-to-4xsfp28-3m-colored-26awg-ca-n.html
- https://store.mellanox.com/products/nvidia-mcp7f00-a003r30l-passive-copper-splitter-cable-ethernet-100gbe-to-4x25gbe-qsfp28-to-4xsfp28-3m-colored-30awg-ca-l.html
- One OctoClock-G. This is needed to synchronize the gNB USRP and the UE USRP. Ensure that device used is the "-G" model, which contains an internal GPSDO module. This is only needed when the UE is implemented on a USRP device.
- Four 10 Gbps Ethernet cables with SFP+ terminations. These cables are available in 0.5, 1.0, and 3.0 meter lengths. These cables are needed when using the USRP N300, N310, N320, N321, but not when using the USRP X410.
- Four VERT900 antennas and/or four VERT2450 antennas. You can use either of these antennas based on the bands in use. There are also many third-party vendors selling a wide variety of antennas, such as omnidirectional antennas. As long as the antenna has an 50-ohm impedance and has SMA connectors, then it can be used with the USRP radio.
- One Quectel RM500Q-GL 5G wireless modem module. See further details about this item in the Hardware Requirements section.
- One Google Pixel 5A 5G handset (phone). Be sure that the handset is unlocked.
- Two 5G SIM cards and one USB UICC/SIM card reader/writer.
- One Mini-Circuits 4-way DC-Pass, SMA, Power Splitter, 250 to 6000 MHz, 50Ω (ZN4PD1-63HP-S+).
- Two Mini-Circuits, 2-way, DC-Pass SMA, Power Splitter, 500 to 5000 MHz, 50Ω (ZN2PD2-50-S+).
- Four Mini-Circuits, VAT-10+, 10 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Four Mini-Circuits, VAT-20+, 20 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Four Mini-Circuits, VAT-30+, 30 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Fourteen Coax SMA Cables, Mini-Circuits, SMA, Hand-Flex Interconnect, 18.0 GHz, 36 inches length (086-36SM+).
- One NETGEAR GS108 8-Port Gigabit Ethernet Unmanaged Switch. See further details about this item in the Hardware Requirements section.
- Three adapters from USB 3.0 to 1 Gbps Ethernet. Any major reputable brand will work. Use either USB-A or USB-C connector as per the ports available on your host computer.
Host Computers
CPU
We recommend using an Intel Core i9 CPU, 10th, 11th, or 12th Generation, with minimum clock speed of 4.0 GHz, and with minimum 10 physical cores. Do not use an Intel Xeon CPU. Examples of such a CPU would be the Intel i9-10940X CPU, which has 14 physical cores, 4.60 GHz clock speed, and is 10th generation, and the Intel i9-12900K CPU, which has 16 physical cores, 5.20 GHz clock speed, and is 12th generation. Be sure that the CPU has at least 40 PCIe lanes, or at least enough lanes to support any GPU and 10 Gbps Ethernet card that are being used. The system should ideally support PCIe Gen 4.
Disk
Memory
GPU
10 Gbps Ethernet network card
Example Systems
USRP Devices
OctoClock-G
Operating System
It is expected that sometime in early 2023, Ubuntu 22.04 will also be officially supported.
- https://releases.ubuntu.com/20.04/
- https://xubuntu.org/download/
- https://kubuntu.org/getkubuntu/
- https://en.wikipedia.org/wiki/Ubuntu
- https://en.wikipedia.org/wiki/Xubuntu
- https://en.wikipedia.org/wiki/Kubuntu
DPDK
The current version of the reference design does not use DPDK, but it is expected that DPDK will be required in the next release of the reference design.
- https://www.dpdk.org/
- https://github.com/DPDK/dpdk
- https://en.wikipedia.org/wiki/Data_Plane_Development_Kit
The USRP N300, N310, N320, N321, X410 may all be used as either the gNB or the UE.
For the USRP N300 and N310
For the USRP N320 and N321
For the USRP X410
On the gNB system, and on the UE system, if the UE being used is a USRP radio, there are several specific settings that need to be made. The hyperthreading, CPU frequency control, C-states, P-states, and any other power management should all be disabled. Each BIOS will have a different way to do this. The two screenshots below show where in the BIOS menu to disable C-states and to disable Hyperthreading.
There are three scenarios for the UE implementation: the USRP radio; the wireless modem module; and the COTS handset.
For the USRP as the UE
For the Wireless Modem Module as the UE
For the COTS Handset as the UE
Running the System
Invoking the CN System
Invoking the gNB System
Invoking the USRP UE System
Invoking the 5G Wireless Modem Module UE
Invoking the COTS Handset UE
Troubleshooting
Technical Support
Mailing Lists
There are two mailing lists that provide help.
USRP Mailing List
OAI Mailing List
Technical support can be requested via email at [email protected] .
Paid Support Contract
FAQ
5G/NR FAQ List
OAI FAQ List
USRP & UHD FAQ List
Resources
Acronyms
The table below contains a list of acronyms used in this document, and their definitions.
| Acronym | Definition |
| 3GPP | 3rd Generation Partnership Project |
Related Documentation
5G Band Allocations
Training Resources
Recommended Books
Recommended Blogs and Online Materials
Recommended IEEE Papers
