Revision as of 08:16, 7 November 2022 by NeelPandeya (Talk | contribs) (Installing and Configuring the USRP Radio)
Author
Neel Pandeya, Bharat Agarwal
AN-956
This Application Note presents a reference design for using the Eurecom OpenAirInterface (OAI) software stack to implement 5G/NR Stand-Alone (SA) systems on the USRP N300, N310, N320, N321, X410 radio devices. The reference design covers the basestation (gNB), the user equipment (UE), and the Core Network (CN) components of the network. Three types of UE are used: a UE running on a USRP radio; a wireless modem module UE; and a commercial (COTS) handset/phone. The reference design supports operation in Frequency Range 1 (FR1), and support for operation in FR2 will be added at a future date. The various aspects of installing, configuring, and running the hardware and software components of the network are discussed in detail, along with a discussion of expected results, methods to benchmark and monitor the system, and troubleshooting steps.
This is example text.
Overview of the USRP X410
Overview of the 5G System and OAI Stack
Bill of Materials (BoM)
Host Computers
CPU
We recommend using an Intel Core i9 CPU, 10th, 11th, or 12th Generation, with minimum clock speed of 4.0 GHz, and with minimum 10 physical cores. Do not use an Intel Xeon CPU. Examples of such a CPU would be the Intel i9-10940X CPU, which has 14 physical cores, 4.60 GHz clock speed, and is 10th generation, and the Intel i9-12900K CPU, which has 16 physical cores, 5.20 GHz clock speed, and is 12th generation. Be sure that the CPU has at least 40 PCIe lanes, or at least enough lanes to support any GPU and 10 Gbps Ethernet card that are being used. The system should ideally support PCIe Gen 4.
Disk
Memory
GPU
10 Gbps Ethernet network card
Example Systems
USRP Devices
OctoClock-G
Software Requirements
Operating System
It is expected that sometime in early 2023, Ubuntu 22.04 will also be officially supported.
DPDK
The current version of the reference design does not use DPDK, but it is expected that DPDK will be required in the next release of the reference design.
   cd $HOME/git
   mkdir $HOME/git
   cd $HOME/git
   cd uhd/host
   mkdir build
   cd build
   git checkout v4.2.0.0
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
   uhd_config_info --print-all
   uhd_find_devices
For the USRP N300 and N310
For the USRP N320 and N321
For the USRP X410
There are three scenarios for the UE implementation: the USRP radio; the wireless modem module; and the COTS handset.
For the USRP as the UE
For the Wireless Modem Module as the UE
For the COTS Handset as the UE
Running the System
Invoking the CN System
Invoking the gNB System
Invoking the USRP UE System
Invoking the 5G Wireless Modem Module UE
Invoking the COTS Handset UE
Monitoring and Benchmarking the System
Troubleshooting
Technical Support
Mailing Lists
There are two mailing lists that provide help.
USRP Mailing List
OAI Mailing List
Email
Technical support can be requested via email at [email protected] .
FAQ
5G/NR FAQ List
OAI FAQ List
USRP & UHD FAQ List
Resources
Acronyms
The table below contains a list of acronyms used in this document, and their definitions.
Table 999. List Acronyms and Definitions
Acronym Definition
3GPP 3rd Generation Partnership Project
Related Documentation
5G Band Allocations
Training Resources
Recommended Books
Recommended Blogs and Online Materials
Recommended IEEE Papers
