Revision as of 05:47, 2 December 2022 by NeelPandeya (Talk | contribs) (CPU)
Author
Neel Pandeya, Bharat Agarwal
AN-956
This Application Note presents a reference design for using the Eurecom OpenAirInterface (OAI) software stack to implement 5G/NR Stand-Alone (SA) systems on the USRP N300, N310, N320, N321, X410 radio devices. The reference design covers the basestation (gNB), the user equipment (UE), and the Core Network (CN) components of the network. Three types of UE are used: a UE running on a USRP radio; a wireless modem module UE; and a commercial (COTS) handset/phone. The reference design supports operation in Frequency Range 1 (FR1), and support for operation in FR2 will be added at a future date. The various aspects of installing, configuring, and running the hardware and software components of the network are discussed in detail, along with a discussion of expected results, methods to benchmark and monitor the system, and troubleshooting steps.
The N300 features:
  • Xilinx Zynq-7035 FPGA SoC
  • RX, TX filter bank
  • 16 bit ADC, 14 bit DAC
  • RJ45 (1 GbE)
  • 10 MHz clock reference
  • PPS time reference
  • Built-in GPSDO
  • 1 Type A USB host port
  • Watchdog timer
  • OpenEmbedded Linux
  • High channel density
  • Stand-alone operation
The N310 features:
  • Xilinx Zynq-7100 FPGA SoC
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
The USRP N320 features:
  • 14 bit ADC, 16 bit DAC
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
The USRP N321 features:
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
Overview of the USRP X410
The USRP X410 features:
  • 12 bit ADC, 14 bit DAC
  • Onboard SD-FEC, DDC, DUC
  • RJ45 (1 GbE) [1]
  • 10 MHz Clock reference
  • Trig In/Out Interface
  • Built-in GPSDO
  • 1 Type C USB host port
  • Watchdog timer
Overview of the 5G System and OAI Stack
Bill of Materials (BoM)
Host Computers
CPU
Disk
Memory
GPU
10 Gbps Ethernet network card
Example Systems
USRP Devices
OctoClock-G
Software Requirements
Operating System
It is expected that sometime in early 2023, Ubuntu 22.04 will also be officially supported.
DPDK
The current version of the reference design does not use DPDK, but it is expected that DPDK will be required in the next release of the reference design.
   cd $HOME/git
   mkdir $HOME/git
   cd $HOME/git
   cd uhd/host
   mkdir build
   cd build
   git checkout v4.2.0.0
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
   uhd_config_info --print-all
   uhd_find_devices
For the USRP N300 and N310
For the USRP N320 and N321
For the USRP X410
See the article USRP Host Performance Tuning Tips and Tricks for information about specific settings and configuration procedures needed to enable optimal system performance. Specifically, it is necessary to set the CPU governors, enable the thread priority scheduling, set the socket buffer sizes, set the Ethernet MTU values, and set the network card ring buffer sizes. At the time of this writing, do not install or use DPDK, as it should be necessary to use with OAI.
This is example text.
The commands listed below build and install the gNB software from source code using the OAI Git repository. The
   cd openairintergace5g
   git checkout develop
   source oaienv
   cd cmake_targets
Edit the "build_oai" script, and comment out the lines listed below.
     #echo_info "installing packages for USRP support"
     #fi
   fi
For the very fisrt time that you build the gNB software, use the command listed below, which includes the "-I" option, which installs the package dependencies for the gNB software.
   ./build_oai --I --w USRP
   ./build_oai --gNB --w USRP
Specifying the AMF IP address
Specifying the gNB IP address
There are three scenarios for the UE implementation: the USRP radio; the wireless modem module; and the COTS handset.
For the USRP as the UE
For the Wireless Modem Module as the UE
For the COTS Handset as the UE
Running the System
Invoking the CN System
Invoking the gNB System
Invoking the USRP UE System
Invoking the 5G Wireless Modem Module UE
Invoking the COTS Handset UE
Monitoring and Benchmarking the System
Troubleshooting
Technical Support
Mailing Lists
There are two mailing lists that provide help.
USRP Mailing List
OAI Mailing List
Email
Technical support can be requested via email at [email protected] .
FAQ
5G/NR FAQ List
OAI FAQ List
USRP & UHD FAQ List
Resources
Acronyms
The table below contains a list of acronyms used in this document, and their definitions.
Table 999. List Acronyms and Definitions
Acronym Definition
3GPP 3rd Generation Partnership Project
Related Documentation
5G Band Allocations
Training Resources
Recommended Books
Recommended Blogs and Online Materials
Recommended IEEE Papers
