OctoClock CDA-2990
Revision as of 11:04, 10 January 2023 by MichaelDickens (Talk | contribs) (FA Q: fix title & add links to UHD repo and schematics)
The OctoClock CDA-2990 is an affordable solution for high-accuracy time and frequency reference distribution. The OctoClock accepts 10 MHz and PPS signals from an external source, and distributed each signal 8 ways. The OctoClock is a useful accessory for users that would like to build multi-channel systems that are synchronized to a common timing source.
The OctoClock-G CDA-2990 provides the same functionality as the OctoClock CDA-2990, but includes a GPSDO that can be used to produce internal 10 MHz and PPS signals, as well as a front-panel switch to select between internal and external sources for the signals. Note that both signals must come from the same chosen source: either both are generated internally from the GPSDO, or both are provided from the external inputs.
Note: Both of the CDA-2990 devices are functionally identical to the previous generation OctoClock, which contained an Ettus Research logo.
  • 8-Way Time and Frequency Distribution (1 PPS and 10 MHz)
  • Convenient Solution for Multi-Channel Synchronization
  • Use with MIMO Capable N-Series Devices for Coherent System
  • External 10 MHz/1 PPS Source Required
  • 19" Rackmount – 1U
Signal Levels
10 MHz output
1.25 Vpp at 50 ohms, 3.3Vpp at 1M ohms
1 PPS output
20% duty cycle square wave with amplitude 5 V
10 MHz input
0-20 dBm
1 PPS input
2.5-5 V
Physical Specifications
Dimension (1U Rackmount)
4 x 17.187x 1.75 inches
Weight
2.6 lbs
Drawings
CAD/STP Models
OctoClock CDA-2990
OctoClock CDA-2990
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
Input/Output Impedance
All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Ethernet Port
The Ethernet port on the OctoClock and OctoClock-G allows the device to be connected to the network. When connected, the uhd_find_devices utility can find any OctoClock devices on the network, and the device's firmware may be updated over Ethernet using the octoclock_burn_eeprom utility. In addition, with the OctoClock-G, NMEA strings may be obtained from the internal GPSDO via the UHD API. Note that there is no host CPU in the OctoClock, so it is not possible to SSH into the device.
OctoClock
OctoClock Schematics
Key Component Datasheets
ENC28J60−DIG Ethernet Controller U103 (1)
ATmega128 Microcontroller U102 (1)
LC_XO Spec Sheet Manual Jackson Labs LC_XO (OCXO) U206 (2)
SN74AUP1T57 VOLTAGE-LEVEL TRANSLATOR U204, U203 (2)
CDCE18005−PWR Output Clock Programmable Buffer U205 (2)
74HC4020 Binary Ripple Counter U207 (2)
LMZ12001 Power Module U101 (1)
China RoHS
Chinese Customers
Certificate of Volatility
OctoClock
Firmware
The OctoClock's firmware is divided into two image files: octoclock_bootloader.hex and octoclock_r4_fw.hex. All image files can be found here, in version-specific ZIP files. Download the version corresponding to the version of UHD that you're running. You must use at least version 3.9.2.
Downloads
OctoClock Spec Sheet
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
FAQ
  • What is the OctoClock
The OctoClock is a USRP-compatible accessory that allows you to easily synchronize up to 8 USRP radios. Multiple OctoClock devices can be combined for synchronization of larger numbers of USRP radios.
  • When would I used the OctoClock
The OctoClock is useful for synchronizing multiple USRP devices for high channel count systems.
The following applications can benefit from OctoClock clock distribution:
  • Direction Finding
  • Beamforming
  • Adaptive Beamforming
  • Multiple-In-Multiple-Out (MIMO) Prototyping
  • Geolocation Systems that Use Time-Difference-of-Arrival (TDOA)
  • Multi-Channel, Multi-Static, and Passive RADAR
  • Multi-Band GPS Record and Playback
  • Multi-Band Cellular Monitoring
Essentially, anything that requires from synchronization or the distribution of timing information would benefit from the use of the OctoClock.
  • How does the OctoClock work
The OctoClock accepts 10 MHz and PPS signals from an external source. Active circuits are used to amplify and split the signals 8-ways. Matched-length traces minimize phase differences between all 10 MHz and 1 PPS outputs
The OctoClock-G includes an internal GPSDO (GPS Disciplined Oscillator) which provides an internal source for 10 MHz and PPS from an OCXO high precision oscillator. Add a GPS antenna (optional) with a clear view of the sky for GPS Disciplining of the OCXO that futher enhances frequency accuracy of the OCXO and global time synchronization.
  • Where can I find user manuals for the OctoClock and USRP
Here is helpful document. Sync. and MIMO w/ the USRP
Also, here is some documentation on how to use UHD to interact with multi-USRP systems.
  • What USRP model do you recommend for MIMO systems
The USRP N200 + N210, N310, N320 + N321, X300 / X310 are recommended for building high channel count and MIMO systems. These models provide external PPS and 10 MHz reference inputs. The USRP N200 and N210 support the USRP MIMO cable.
The USRP B100, B200, B210, E100, E110, and E310 can be synchronized with 10 MHz/PPS but are not phase coherent MIMO capable devices. The USRP1 cannot be synchronized with 10 MHz/PPS.
  • How does the automatic switchover functionality work
When using the OctoClock-G, the Internal/External switch on the front panel allows the user to choose between the internal GPSDO and external source 10 MHz/PPS source. If the selected source is unavailable, the device will automatically switch over to the backup frequency source. When switchover is active the corresponding LED indicator will illuminate.
If neither source is present, the internal, external and status LEDs will not be illuminated and the user will not received valid 10 MHz/PPS outputs.
  • What do the LED indications mean
The following list describes the behavior when each of the 6 LED status indicators is illuminated:
  • Internal - internal GPSDO is selected and present.
  • External - external source is selected and present
  • Status - Either the internal GPSDO or external source is selected. If neither source is present this LED will turn off (no signals are output).
  • PPS - selected PPS pulse high.
  • GPS Locked - GPS is receiving signals and has valid time/position lock.
  • Power - Power is applied.
  • What are the input and output specifications
  • 10 MHz Input – 0-10 dBm
  • 10 MHz Outputs - ~1.4 Vpp Square Wave, Impedance 50 ohm nominal
  • 1 PPS Input - Logic-level pulse, 2.5 V - 5 V
  • 1 PPS Outputs - Logic-level pulse, 2.5 V - 5 V
  • What is the input voltage rating
The OctoClock can be powered at any voltage between 6 and 15 Vdc.
  • Are the design files open source
As with all of our products, the driver code is free & open source, and can be found in our UHD repository. The schematics are also available.
