- 1 Authors
- 2 Application Note Number
- 3 Abstract
- 4 Overview of the USRP N300 and N310
- 5 Overview of the USRP N320 and N321
- 6 Overview of the USRP X410
- 7 Overview of the OpenAirInterface (OAI) Software Stack
- 8 Overview of the Reference Architecture
- 9 Bill of Materials (BoM)
- 10 Hardware Requirements
- 11 Software Requirements
- 12 Installing and Configuring the UHD Software
- 13 Installing and Configuring the USRP Radio
- 14 Configuring the Ubuntu Linux Operating System
- 15 Configuring the BIOS for gNB and UE Systems
- 16 Installing, Configuring, and Running the CN System
- 16.1 Prerequisites for the Scenario 1 Minimalist Deployment
- 16.2 Pull Base Images
- 16.3 Pulling the images from Docker Hub
- 16.4 Synchronizing the installed images
- 16.5 Configure the Containers
- 16.6 Deploy the containers
- 16.7 Installing docker-compose and Wireshark
- 16.8 Invoking the Core Network
- 16.9 Stopping the Core Network
- 17 Installing, Configuring, and Running the gNB System
- 17.1 Building and installing the gNB software
- 17.2 Editing the gNB configuration file
- 17.3 Specifying the AMF IP address
- 17.4 Specifying the gNB IP address
- 17.5 Specifying the USRP IP address
- 17.6 Adding a static route to the CN system
- 17.7 Invoking the gNB
- 17.8 Interfaces Between gNB and Core Network
- 17.9 Testing Connectivity Between gNB and CN
- 18 Installing, Configuring, and Running the UE System
- 19 Technical Support
Authors
Neel Pandeya, Bharat Agarwal
AN-956
This Application Note presents a reference design for using the Eurecom OpenAirInterface (OAI) software stack to implement 5G NR Stand-Alone (SA) systems on the USRP N300, N310, N320, N321, X410 radio devices. The reference design covers the base station (gNB), the user equipment (UE), and the Core Network (CN) components of the network. Three types of UE are used: a UE running on a USRP radio; a wireless modem module UE; and a commercial (COTS) handset/phone. The reference design supports operation in Frequency Range 1 (FR1), and support for operation in FR2 will be added at a future date. The various aspects of installing, configuring, and running the hardware and software components of the network are discussed in detail, along with a discussion of expected results, methods to benchmark and monitor the system, and troubleshooting steps.
You can learn more about other solutions for 5G and 6G Wireless Research and Prototyping at the website here.
The N300 features:
The N310 features:
For more detailed technical information about the USRP N300 and N310, please reference the N300/N310 Hardware Resource Page. For more information about getting started with the USRP N300 and N310, please reference the Getting Started Guide. |
The USRP N320 features:
The USRP N321 features:
For more detailed technical information about the USRP N320 and N321, please reference the N320/N321 Hardware Resource Page. For more information about getting started with the USRP N320 and N321, please reference the Getting Started Guide. |
The USRP X410 features:
For more detailed technical information about the USRP X410, please reference the X410 Hardware Resource Page. For more information about getting started with the USRP X410, please reference the X410 Getting Started Guide. |
- Three desktop computers, with Intel Core i9 CPU, of 10th, 11th, or 12th Generation, with clock speed of minimum 4.0 GHz, with minimum 10 physical cores, and also with only NVMe disk drives. See further details about this item in the Hardware Requirements section.
- Two 10 Gbps Ethernet networks cards. We recommend the Intel X710-DA2 and the Nvidia/Mellanox MCX4121A-ACAT ConnectX-4 network cards. See further details about this item in the Hardware Requirements section.
- Two USRP devices. The USRP may be any of USRP N300, N310, N320, N321, X410. There will be one USRP for the gNB, and one USRP for the UE. The USRP devices can be mixed (i.e., the gNB could run with a USRP X410, while the UE runs with a USRP N310).
- https://kb.ettus.com/N300/N310
- https://kb.ettus.com/N320/N321
- https://kb.ettus.com/X410
- https://www.ettus.com/all-products/usrp-n300/
- https://www.ettus.com/all-products/usrp-n310/
- https://www.ettus.com/all-products/usrp-n320/
- https://www.ettus.com/all-products/usrp-n321/
- https://www.ettus.com/all-products/usrp-x410/
- One QSFP28-to-SFP28 breakout cable (NVIDIA MCP7F00-A003R26N DAC Splitter Cable Ethernet 100GbE to 4x25GbE 3m). This is only needed when using the USRP X410.
- https://store.mellanox.com/products/nvidia-mcp7f00-a003r26n-passive-copper-splitter-cable-ethernet-100gbe-to-4x25gbe-qsfp28-to-4xsfp28-3m-colored-26awg-ca-n.html
- https://store.mellanox.com/products/nvidia-mcp7f00-a003r30l-passive-copper-splitter-cable-ethernet-100gbe-to-4x25gbe-qsfp28-to-4xsfp28-3m-colored-30awg-ca-l.html
- One OctoClock-G. This is needed to synchronize the gNB USRP and the UE USRP. Ensure that device used is the "-G" model, which contains an internal GPSDO module. This is only needed when the UE is implemented on a USRP device.
- Four 10 Gbps Ethernet cables with SFP+ terminations. These cables are available in 0.5, 1.0, and 3.0 meter lengths. These cables are needed when using the USRP N300, N310, N320, N321, but not when using the USRP X410.
- Four VERT900 antennas and/or four VERT2450 antennas. You can use either of these antennas based on the bands in use. There are also many third-party vendors selling a wide variety of antennas, such as omnidirectional antennas. As long as the antenna has an 50-ohm impedance and has SMA connectors, then it can be used with the USRP radio.
- One Quectel RM500Q-GL 5G wireless modem module. See further details about this item in the Hardware Requirements section.
- One Google Pixel 5A 5G handset (phone). Be sure that the handset is unlocked.
- Two 5G SIM cards and one USB UICC/SIM card reader/writer.
- One Mini-Circuits 4-way DC-Pass, SMA, Power Splitter, 250 to 6000 MHz, 50Ω (ZN4PD1-63HP-S+).
- Two Mini-Circuits, 2-way, DC-Pass SMA, Power Splitter, 500 to 5000 MHz, 50Ω (ZN2PD2-50-S+).
- Four Mini-Circuits, VAT-10+, 10 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Four Mini-Circuits, VAT-20+, 20 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Four Mini-Circuits, VAT-30+, 30 dB Fixed Attenuator, DC to 6000 MHz, 50Ω, SMA.
- Fourteen Coax SMA Cables, Mini-Circuits, SMA, Hand-Flex Interconnect, 18.0 GHz, 36 inches length (086-36SM+).
- One NETGEAR GS108 8-Port Gigabit Ethernet Unmanaged Switch. See further details about this item in the Hardware Requirements section.
- Three adapters from USB 3.0 to 1 Gbps Ethernet. Any major reputable brand will work. Use either USB-A or USB-C connector as per the ports available on your host computer.
Host Computers
CPU
Disk
Memory
GPU
10 Gbps Ethernet network card
Example Systems
USRP Devices
OctoClock-G
Operating System
- https://releases.ubuntu.com/20.04/
- https://xubuntu.org/download/
- https://kubuntu.org/getkubuntu/
- https://en.wikipedia.org/wiki/Ubuntu
- https://en.wikipedia.org/wiki/Xubuntu
- https://en.wikipedia.org/wiki/Kubuntu
DPDK
- https://www.dpdk.org/
- https://github.com/DPDK/dpdk
- https://en.wikipedia.org/wiki/Data_Plane_Development_Kit
cd $HOME/git mkdir $HOME/git
cd $HOME/git git clone http://github.com/EttusResearch/uhd.git
cd uhd/host mkdir build cd build git checkout v4.3.0.0
cmake ../ make -j4 sudo make install sudo ldconfig
export PYTHONPATH=/usr/local/lib/python3/dist-packages:/usr/local/lib/python3.7/site-packages:/usr/local/lib/python3/dist-packages:$PYTHONPATH export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
uhd_config_info --print-all uhd_find_devices uhd_usrp_probe
For the USRP N300 and N310
For the USRP N320 and N321
For the USRP X410
- Using docker-compose, perform a minimalist deployment
- Using docker-compose, perform a basic deployment
- Using docker-compose, perform a basic-vpp deployment with VPP implementation of UPF
- Using docker-compose, perform a basic deployment with static UE IP address allocation
- Using Helm Chart, perform a basic deployment
- Using docker-compose, doing network slicing
- Scenario 1: AMF, SMF, UPF (SPGWU), NRF, MYSQL
- Scenario 2: AMF, SMF, UPF (SPGWU), MYSQL
The diagram below shows the layout and architecture of the various Docker containers running on the CN machine, along with the IP address of each container.
dpkg --list | grep docker
python3 --version
Pull Base Images
docker login docker pull ubuntu:bionic docker pull mysql:5.7 docker logout
sudo sysctl net.ipv4.conf.all.forwarding=1 sudo iptables -P FORWARD ACCEPT
docker login
Pull the images listed below.
docker pull rdefosseoai/oai-amf:latest docker pull rdefosseoai/oai-nrf:latest docker pull rdefosseoai/oai-spgwu-tiny:latest docker pull rdefosseoai/oai-smf:latest docker pull rdefosseoai/oai-udr:latest docker pull rdefosseoai/oai-udm:latest docker pull rdefosseoai/oai-ausf:latest docker pull rdefosseoai/oai-upf-vpp:latest docker pull rdefosseoai/oai-nssf:latest
docker image tag rdefosseoai/oai-amf:latest oai-amf:latest docker image tag rdefosseoai/oai-nrf:latest oai-nrf:latest docker image tag rdefosseoai/oai-smf:latest oai-smf:latest docker image tag rdefosseoai/oai-spgwu-tiny:latest oai-spgwu-tiny:latest docker image tag rdefosseoai/oai-udr:latest oai-udr:latest docker image tag rdefosseoai/oai-udm:latest oai-udm:latest docker image tag rdefosseoai/oai-ausf:latest oai-ausf:latest docker image tag rdefosseoai/oai-upf-vpp:latest oai-upf-vpp:latest docker image tag rdefosseoai/oai-nssf:latest oai-nssf:latest
docker logout
git clone https://gitlab.eurecom.fr/oai/cn5g/oai-cn5g-fed.git git checkout v1.3.0
cd oai-cn5g-fed
./scripts/syncComponents.sh
--------------------------------------------------------- OAI-NRF component branch : master OAI-AMF component branch : master OAI-SMF component branch : master OAI-SPGW-U component branch : master OAI-AUSF component branch : master OAI-UDM component branch : master OAI-UDR component branch : master OAI-UPF-VPP component branch : master OAI-NSSF component branch : master ---------------------------------------------------------
git submodule deinit --all --force git submodule init git submodule update
INSERT INTO users VALUES
sudo add-apt-repository ppa:wireshark-dev/stable sudo apt update sudo apt install wireshark
wireshark --version
cd oai-cn5g-fed/docker-compose sudo python3 ./core-network.py --type start-mini --fqdn no --scenario 1
root:DEBUG: Starting 5gcn components... Please wait....
Creating oai-nrf ... done
Creating mysql ... done
Creating oai-amf ... done
Creating oai-smf ... done
Creating oai-spgwu ... done
Creating oai-ext-dn ... done
[2021-09-14 16:44:10,098] root:DEBUG: OAI 5G Core network started, checking the health status of the containers... takes few secs....
[2021-09-14 16:44:47,025] root:DEBUG: All components are healthy, please see below for more details....
Name Command State Ports
mysql docker-entrypoint.sh mysqld Up (healthy) 3306/tcp, 33060/tcp
oai-amf /bin/bash /openair-amf/bin ... Up (healthy) 38412/sctp, 80/tcp, 9090/tcp
oai-ext-dn /bin/bash -c apt update; ... Up
oai-nrf /bin/bash /openair-nrf/bin ... Up (healthy) 80/tcp, 9090/tcp
oai-smf /bin/bash /openair-smf/bin ... Up (healthy) 80/tcp, 8805/udp, 9090/tcp
oai-spgwu /openair-spgwu-tiny/bin/en ... Up (healthy) 2152/udp, 8805/udp
[2021-09-14 16:44:47,025] root:DEBUG: Checking if the containers are configured....
[2021-09-14 16:44:47,025] root:DEBUG: Checking if SMF and UPF registered with nrf core network....
[2021-09-14 16:44:47,059] root:DEBUG: For example: oai-smf Registration with oai-nrf can be checked on this url /nnrf-nfm/v1/nf-instances?nf-type="SMF" {"_links":{"item":[{"href":"192.168.70.133"}],"self":""}}....
[2021-09-14 16:44:47,059] root:DEBUG: SMF and UPF are registered to NRF....
[2021-09-14 16:44:47,059] root:DEBUG: Checking if SMF is able to connect with UPF....
[2021-09-14 16:44:47,176] root:DEBUG: UPF receiving heathbeats from SMF....
[2021-09-14 16:44:47,176] root:DEBUG: OAI 5G Core network is configured and healthy....
sudo wireshark
networks:
public_net:
external:
# public_net:
# driver: bridge
# name: demo-oai-public-net
# ipam:
# config:
# - subnet: 192.168.70.128/26
# driver_opts:
# com.docker.network.bridge.name: "demo-oai"
--driver=bridge \
--subnet=192.168.70.128/26 \
demo-oai-public-net
demo-oai: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.70.129 netmask 255.255.255.192 broadcast 192.168.70.191
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
NETWORK ID NAME DRIVER SCOPE
d2d34e05bb2d bridge bridge local
455631b3749c demo-oai-public-net bridge local
networks:
# public_net:
# external:
public_net:
driver: bridge
ipam:
config:
driver_opts:
Showing the SMF request to NRF for subscribing UPF registration/deregistration events:
Showing the SMF registration with NRF for the PUT request:
Showing the UPF registration with NRF for the PUT request:
Showing the NRF notification to SMF for UPF registration for the POST request:
Showing the SMF-to-UPF PFCP association setup request-and-response:
cd oai-cn5g-fed/docker-compose sudo python3 ./core-network.py --type stop-mini --fqdn no --scenario 1
The commands listed below build and install the gNB software from source code using the OAI Git repository.
git clone https://gitlab.eurecom.fr/oai/openairinterface5g.git cd openairinterface5g git checkout 2022.w33 source oaienv cd cmake_targets
git status
if [ "$HW" == "OAI_USRP" ] ; then
#if [ ! "$DISABLE_HARDWARE_DEPENDENCY" == "True" ]; then
# install_usrp_uhd_driver $UHD_IMAGES_DIR
#fi
fi
./build_oai -I --w USRP
./build_oai --gNB --w USRP
The mgmt_addr, addr, and second_addr should be defined according to the configuration of your USRP device. For the clock_source and the time source, the values can be internal, external, or gpsdo. In this reference architecture, an OctoClock-G is connected to the USRP, so we use the value of external for both the clocking source and the timing source.
Invoking the gNB
Once both the gNB and the CN machines are up-and-running, test the connectivity between the two systems by pinging the AMF in the CN machine from the gNB machine. On the gNB machine, run the command listed below.
ping 192.168.70.132
If the ping fails, then it may be due to the firewall settings. On the CN machine, run the commands listed below to configure the firewall.
After running these commands on the CN machine, run this command on the gNB machine to add a route from the gNB machine to the CN machine. You will likely need to replace the Ethernet interface name eno1 with the correct interface name on your gNB machine.
sudo ip route add 192.168.70.128/26 via 10.89.14.6 dev eno1
The IP address 192.168.70.128/26 is for the demo-oai interface, and 10.89.14.6 is the IP address of the CN machine, and eno1 is the Ethernet interface name on the gNB machine.
There are three scenarios for the UE implementation: the USRP radio; the 5G wireless modem module; and the COTS handset.
UE Scenario 1: USRP
Before installing and configuring the UE system, be sure that you first have configured the system BIOS, implemented the Linux performance tuning settings, and installed UHD.
Building and installing the OAI softmodem software
Note that the procedure for building and configuring the UE software is very similar to the procedure for building and installing the gNB software.
The commands listed below build and install the UE software from source code using the OAI Git repository.
git status
#fi
fi
Editing the UE Configuration File
Once we build and install the UE software, we need to modify the UE configuration file. Only one UE configuration file is available in the folder openairinterface5g/targets/PROJECTS/GENERIC-NR-5GC/CONF. The UE configuration file used in this reference architecture is ue.conf. The default contents of the file is shown below.
uicc0 = {
imsi = "2089900007487";
key = "fec86ba6eb707ed08905757b1bb44b8f";
opc= "C42449363BBAD02B66D16BC975D77CC1";
dnn= "oai";
nssai_sst=1;
nssai_sd=1;
Edit the fields imsi, key, opc, dnn, nssai_sst, nssai_sd per the values for the CN. Earlier, when configuring the Docker containers for the CN system, we entered several parameters in the oai_db1.sql file. The imsi, key, opc fields there should match the values here in the UE configuration file. The dnn value should be same as listed in the docker-compose-mini-nrf.yaml<code> file. The <code>nssai_sst and nssai_sd values should be same as listed in the gNB configuration file and the docker-compose-mini-nrf.yaml file.
Invoking the OAI UE softmodem
Run the command listed below to invoke the OAI UE softmodem.
openairinterface5g/cmake_targets/ran_build/build sudo ./nr-uesoftmodem --usrp-args "addr=192.168.10.2, clock_source=external,time_source=external" -r 106 --numerology 1 --band 78 -C 3319680000 --sa --nokrnmod 1 -O ../../../targets/PROJECTS/GENERIC-NR-5GC/CONF/ue.conf
The command-line option --usrp-args specifies the USRP device arguments, which are passed to the UHD driver. Here we specify the IP address of the USRP, along with clocking source and the timing source, which are set to external, to indicate the use of the connection to the OctoClock-G device.
The command-line option -r 106 specifies the PRBS being used. Based on the PRBS, we can calculate the operational channel bandwidth being used (i.e., 40 MHz).
The command-line option --numerology 1 specifies the SCS being used (i.e., 30 KHz).
The command-line option --band 78 specifies the 3GPP frequency band being used.
The command-line option -C 3319680000 specifies the CF we are operating (i.e., 3.319 GHz).
The command-line option --nokrnmod 1 forces the use of the tunnel interface.
Once the UE is attached to the CN, verify that the oaitun_ue1 network interface has been created, and that is has been assigned an IP address of 10.x.x.x, using the command listed below.
ifconfig
The call attach process between the UE and the gNB is illustrated in the sequence diagram shown below.
The relevant lines in the OAI UE softmodem log file show information about the call attach process.
Launch Wireshark to view the packets exchanged between the UE and gNB for this call attach process.
Verify that the UE was connected to the gNB
To verify that UE has successfully attached to the gNB, check the OAI-AMF logs on the CN machine using the command listed below. Check the output to confirm that UE has been registered by the Core Network.
sudo docker logs oai-amf
Run ifconfig on the UE machine to check the IP address assigned to the UE. Verify that the oaitun_ue1 network interface has been created, and that is has been assigned an IP address of 10.x.x.x. You can also check the OAI-SMF logs using the command listed below.
sudo docker oai-smf logs
The UE can be implemented using a 5G wireless modem module. Currently, this reference architecture is focused on the use of a Quectel RM500Q-GL 5G wireless modem module. This device is a 5G NR sub-6GHz M.2 module which meets the 3GPP Release 15 specification, and is optimized for industrial and commercial IoT and eMBB applications. It supports both standalone (SA) and non-standalone (NSA) modes. Other wireless modem modules can certainly be used as well. Detailed documentation for the Sierra Wireless EM9191 module will be added in the near future.
Configuring the SIM Card
When using a 5G wireless modem module or a COTS handset, a SIM card will be required. If a USRP is being used as the UE, running the OAI UE softmodem, then a SIM card is not required.
The SIM card used in this reference architecture is provided by Open-Cells, and is shown below. Note that the ADM code is printed directly on the SIM card itself.
Insert the nano SIM card into the SIM card reder/writer, and plug it into the USB slot on the UE computer.
To read and program the SIM card, we use the program program_uicc from Open-Cells (here).
We first read the existing data on the SIM by running the command below.
sudo ./program_uicc --adm 1
We then write the key and the OPC in the UICC file in the SIM card. The ADM value enables this. Run the command below to perform this operation, where ADM_VALUE_FROM_SIM is the ADB value printed directly on the SIM card itself.
sudo ./program_uicc --adm <ADM_VALUE_FROM_SIM> --key 0C0A34601D4F07677303652C0462535B --opc 63bfa50ee6523365ff14c1f45f88737d --authenticate --noreadafter
Configuring the Wireless Modem Module
The The The
UE Scenario 3: COTS Handset
The UE can be implemented using the commercial (COTS) handset. This reference architecture will feature the use of the Google Pixel 5A handset. Detailed documentation about this will be added in the near future.
Technical Support
USRP Mailing List
OAI Mailing List
Emailing NI
You can contact National Instruments directly via email about the reference architecture at [email protected].
