Revision as of 20:43, 16 February 2023 by NeelPandeya (Talk | contribs) (Serial Connection to the Module via Minicom)
Authors
Neel Pandeya, Bharat Agarwal
AN-956
This Application Note presents a reference design for using the Eurecom OpenAirInterface (OAI) software stack to implement 5G NR Stand-Alone (SA) systems on the USRP N300, N310, N320, N321, X410 radio devices. The reference design covers the base station (gNB), the user equipment (UE), and the Core Network (CN) components of the network. Three types of UE are used: a UE running on a USRP radio; a wireless modem module UE; and a commercial (COTS) handset/phone. The reference design supports operation in Frequency Range 1 (FR1), and support for operation in FR2 will be added at a future date. The various aspects of installing, configuring, and running the hardware and software components of the network are discussed in detail, along with a discussion of expected results, methods to benchmark and monitor the system, and troubleshooting steps.
You can learn more about other solutions for 5G and 6G Wireless Research and Prototyping at the website here.
The N300 features:
  • Xilinx Zynq-7035 FPGA SoC
  • RX, TX filter bank
  • 16 bit ADC, 14 bit DAC
  • RJ45 (1 GbE)
  • 10 MHz clock reference
  • PPS time reference
  • Built-in GPSDO
  • 1 Type A USB host port
  • Watchdog timer
  • OpenEmbedded Linux
  • High channel density
  • Stand-alone operation
The N310 features:
  • Xilinx Zynq-7100 FPGA SoC
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
The USRP N320 features:
  • 14 bit ADC, 16 bit DAC
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
The USRP N321 features:
  • RJ45 (1 GbE)
  • Built-in GPSDO
  • Watchdog timer
Overview of the USRP X410
The USRP X410 features:
  • 12 bit ADC, 14 bit DAC
  • Onboard SD-FEC, DDC, DUC
  • RJ45 (1 GbE) [1]
  • 10 MHz Clock reference
  • Trig In/Out Interface
  • Built-in GPSDO
  • 1 Type C USB host port
  • Watchdog timer
Bill of Materials (BoM)
Host Computers
CPU
Disk
Memory
GPU
10 Gbps Ethernet network card
Example Systems
USRP Devices
OctoClock-G
Software Requirements
Operating System
DPDK
   cd $HOME/git
   mkdir $HOME/git
   cd $HOME/git
   cd uhd/host
   mkdir build
   cd build
   git checkout v4.3.0.0
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
   uhd_config_info --print-all
   uhd_find_devices
   uhd_usrp_probe
For the USRP N300 and N310
For the USRP N320 and N321
For the USRP X410
The diagram below shows the layout and architecture of the various Docker containers running on the CN machine, along with the IP address of each container.
   dpkg --list | grep docker
   python3 --version
Pull Base Images
   docker login
   docker pull ubuntu:bionic
   docker pull mysql:5.7
   docker logout
   docker login
Pull the images listed below.
  docker logout
   git checkout v1.3.0
   cd oai-cn5g-fed
   ./scripts/syncComponents.sh
   git submodule init
   git submodule update
Configure the Containers
   INSERT INTO users VALUES
Deploy the containers
   sudo apt update
   sudo apt install wireshark
   wireshark --version
Invoking the Core Network
   Creating oai-nrf ... done
   Creating mysql   ... done
   Creating oai-amf ... done
   Creating oai-smf ... done
   Creating oai-spgwu ... done
   Creating oai-ext-dn ... done
   sudo wireshark
   networks:
       public_net:
           external:
       # public_net:
       #     driver: bridge
       #     ipam:
       #         config:
       #     driver_opts:
     --driver=bridge \
     --subnet=192.168.70.128/26 \
     demo-oai-public-net
           RX packets 0  bytes 0 (0.0 B)
           TX packets 0  bytes 0 (0.0 B)
   networks:
       # public_net:
       #     external:
         public_net:
             driver: bridge
             ipam:
                 config:
             driver_opts:
Stopping the Core Network
The commands listed below build and install the gNB software from source code using the OAI Git repository.
   cd openairinterface5g
   git checkout 2022.w33
   source oaienv
   cd cmake_targets
   git status
     #fi
   fi
   ./build_oai -I --w USRP
   ./build_oai --gNB --w USRP
Specifying the AMF IP address
Specifying the gNB IP address
The mgmt_addr, addr, and second_addr should be defined according to the configuration of your USRP device. For the clock_source and the time source, the values can be internal, external, or gpsdo. In this reference architecture, an OctoClock-G is connected to the USRP, so we use the value of external for both the clocking source and the timing source.
Invoking the gNB
Interfaces Between gNB and Core Network
Testing Connectivity Between gNB and CN
Once both the gNB and the CN machines are up-and-running, test the connectivity between the two systems by pinging the AMF in the CN machine from the gNB machine. On the gNB machine, run the command listed below.
   ping 192.168.70.132
If the ping fails, then it may be due to the firewall settings. On the CN machine, run the commands listed below to configure the firewall.
After running these commands on the CN machine, run this command on the gNB machine to add a route from the gNB machine to the CN machine. You will likely need to replace the Ethernet interface name eno1 with the correct interface name on your gNB machine.
   sudo ip route add 192.168.70.128/26 via 10.89.14.6 dev eno1
The IP address 192.168.70.128/26 is for the demo-oai interface, and 10.89.14.6 is the IP address of the CN machine, and eno1 is the Ethernet interface name on the gNB machine.
Installing, Configuring, and Running the UE System
There are three scenarios for the UE implementation: the USRP radio; the 5G wireless modem module; and the COTS handset.
UE Scenario 1: USRP
Before installing and configuring the UE system, be sure that you first have configured the system BIOS, implemented the Linux performance tuning settings, and installed UHD.
Building and installing the OAI softmodem software
Note that the procedure for building and configuring the UE software is very similar to the procedure for building and installing the gNB software.
The commands listed below build and install the UE software from source code using the OAI Git repository.
   source oaienv
   cd cmake_targets
   git status
     #fi
   fi
Editing the UE Configuration File
Once we build and install the UE software, we need to modify the UE configuration file. Only one UE configuration file is available in the folder openairinterface5g/targets/PROJECTS/GENERIC-NR-5GC/CONF. The UE configuration file used in this reference architecture is ue.conf. The default contents of the file is shown below.
   uicc0 = {
   imsi = "2089900007487";
   key = "fec86ba6eb707ed08905757b1bb44b8f";
   opc= "C42449363BBAD02B66D16BC975D77CC1";
   dnn= "oai";
   nssai_sst=1;
   nssai_sd=1;
Edit the fields imsi, key, opc, dnn, nssai_sst, nssai_sd per the values for the CN. Earlier, when configuring the Docker containers for the CN system, we entered several parameters in the oai_db1.sql file. The imsi, key, opc fields there should match the values here in the UE configuration file. The dnn value should be same as listed in the docker-compose-mini-nrf.yaml<code> file. The <code>nssai_sst and nssai_sd values should be same as listed in the gNB configuration file and the docker-compose-mini-nrf.yaml file.
Invoking the OAI UE softmodem
Run the command listed below to invoke the OAI UE softmodem.
   openairinterface5g/cmake_targets/ran_build/build sudo ./nr-uesoftmodem --usrp-args "addr=192.168.10.2, clock_source=external,time_source=external" -r 106 --numerology 1 --band 78 -C 3319680000 --sa --nokrnmod 1 -O ../../../targets/PROJECTS/GENERIC-NR-5GC/CONF/ue.conf
The command-line option --usrp-args specifies the USRP device arguments, which are passed to the UHD driver. Here we specify the IP address of the USRP, along with clocking source and the timing source, which are set to external, to indicate the use of the connection to the OctoClock-G device.
The command-line option -r 106 specifies the PRBS being used. Based on the PRBS, we can calculate the operational channel bandwidth being used (i.e., 40 MHz).
The command-line option --numerology 1 specifies the SCS being used (i.e., 30 KHz).
The command-line option --band 78 specifies the 3GPP frequency band being used.
The command-line option -C 3319680000 specifies the CF we are operating (i.e., 3.319 GHz).
The command-line option --nokrnmod 1 forces the use of the tunnel interface.
Once the UE is attached to the CN, verify that the oaitun_ue1 network interface has been created, and that is has been assigned an IP address of 10.x.x.x, using the command listed below.
   ifconfig
The call attach process between the UE and the gNB is illustrated in the sequence diagram shown below.
The relevant lines in the OAI UE softmodem log file show information about the call attach process.
Launch Wireshark to view the packets exchanged between the UE and gNB for this call attach process.
Verify that the UE was connected to the gNB
To verify that UE has successfully attached to the gNB, check the OAI-AMF logs on the CN machine using the command listed below. Check the output to confirm that UE has been registered by the Core Network.
   sudo docker logs oai-amf
Run ifconfig on the UE machine to check the IP address assigned to the UE. Verify that the oaitun_ue1 network interface has been created, and that is has been assigned an IP address of 10.x.x.x. You can also check the OAI-SMF logs using the command listed below.
   sudo docker oai-smf logs
The UE can be implemented using a 5G wireless modem module. Currently, this reference architecture is focused on the use of a Quectel RM500Q-GL 5G wireless modem module. This device is a 5G NR sub-6GHz M.2 module which meets the 3GPP Release 15 specification, and is optimized for industrial and commercial IoT and eMBB applications. It supports both standalone (SA) and non-standalone (NSA) modes. Other wireless modem modules can certainly be used as well. Detailed documentation for the Sierra Wireless EM9191 module will be added in the near future.
Configuring the SIM Card
When using a 5G wireless modem module or a COTS handset, a SIM card will be required. If a USRP is being used as the UE, running the OAI UE softmodem, then a SIM card is not required.
The SIM card used in this reference architecture is provided by Open-Cells, and is shown below. Note that the ADM code is printed directly on the SIM card itself.
Insert the nano SIM card into the SIM card reder/writer, and plug it into the USB slot on the UE computer.
To read and program the SIM card, we use the program program_uicc from Open-Cells (here).
We first read the existing data on the SIM by running the command below.
   sudo ./program_uicc --adm 1
We then write the key and the OPC in the UICC file in the SIM card. The ADM value enables this. Run the command below to perform this operation, where ADM_VALUE_FROM_SIM is the ADM value printed directly on the SIM card itself.
   sudo ./program_uicc --adm <ADM_VALUE_FROM_SIM> --key 0C0A34601D4F07677303652C0462535B --opc 63bfa50ee6523365ff14c1f45f88737d --authenticate --noreadafter
Ensure that the values being programmed into the SIM card match the corresponding values entered in the SQL database on the CN machine. The values of primary importance are listed in the table below.
Primary Configuration Parameters for UE, gNB, CN
Parameter UE gNB CN
IMSI 208920100001101 MCC: 208, MNC: 92 208920100001101
MSISDN 00000101 00000101
IMEI 863305040549338 863305040549338
Key 0C0A34601D4F07677303652C0462535B 0C0A34601D4F07677303652C0462535B
OPC 63bfa50ee6523365ff14c1f45f88737d 63bfa50ee6523365ff14c1f45f88737d
The The The
Attach all four antennas to the Quectel wireless modem module. Then, mount the Quectel module into the M.2 connector slot on the carrier board. Then, connect the carrier board to the UE computer via a USB 3.0 port.
We will use Minicom to communicate with the Quectel module over a USB serial connection. Run which minicom to verify that Minicom is already installed. If not, then run the command listed below to install it.
   sudo apt-get install minicom
Once the Quectel module is plugged in, the Linux operating system should create several USB serial devices which can be used to communicate with the module. The default device should be /dev/ttyUSB0. Run the command listed below to start a Minicom serial console session with the Quectel device.
   sudo minicom /dev/ttyUSB0
Note that in order to exit Minicom, type Ctrl-A, then "X".
AT Commands for the Module
The The The
Configuring the Wireless Modem Module
The The The
Verifying the Operation with Wireshark
The The The
UE Scenario 3: COTS Handset
The UE can be implemented using the commercial (COTS) handset. This reference architecture will feature the use of the Google Pixel 5A handset. Detailed documentation about this will be added in the near future.
End-to-End Verification
The The The
Technical Support
USRP Mailing List
OAI Mailing List
Email
You can contact the authors about the reference architecture directly via email at [email protected].
