UHD Device Eraser and Certificates of Volatility
Revision as of 15:24, 22 September 2023 by MichaelDickens (Talk | contribs) (USRPs: add X440 LOV)
Application Note Number and Author
AN-111 by Michael Dickens
This Application Note provides an overview of the UHD Device Eraser utility as well as links to the Certificates of Volatility for all Ettus products.
UHD Device Eraser Utility
The uhd_device_eraser utility overwrites all non-volatile memory from any Ettus device supported by it: most USRPs, OctoClock, and daughterboards.
Note that any volatile memory on the device is cleared simply by removing all power from the device. This utility overwrites information that persist after removing all power, that stored in non-volatile memory.
The utility is provided as source code, and requires UHD (headers and library) to be installed as well as the UHD source code be available on the build computer. It uses CMake to build (just like UHD does) and works with any version of UHD from 3.7.2 through 3.15.
This utility will be provided per your specific request via an email to [email protected] . Ettus support will first require you to note receipt of our standard warnings in a first email, then once noted will provide a tarball of the utility.
NOTE: This utility, because it erases settings used by your USRP for runtime functionality, will render your Ettus device unusable ("bricked"). It is entirely possible to make your Ettus device usable again ("unbrick" it), details of which are provided by Ettus support in emails as well as the top-level README of the utility tarball.
OctoClock
OctoClock
USRPs
B200 / B210
E310 / E312 / E313
E320
N200 / N210
N300 / N310
N320 / N321
X300 / X310
X410
X440
Daughterboards
BasicRX / BasicTX
CBX
LFRX / LFTX
SBX
TwinRX
UBX (40 / 160 / 160-LP)
WBX
End-Of-Life Daughterboards
DBSRX2
TVRX2
