USRP Host Performance Tuning Tips and Tricks
Revision as of 14:20, 21 November 2023 by MichaelDickens (Talk | contribs) (Disable Hyper-threading: update with modern language)
AN-088
This application note provides various tips and tricks for tuning your host computer for best performance when working with USRP devices.
CPU Governor
Ensure your CPU governor is set to performance. This can be done with the Linux utility cpufrequtils.
Install cpufrequtils with the command below:
   sudo apt install cpufrequtils
You can then set the CPU governor to performance per core by issuing the command:
   sudo cpufreq-set -c $core_number -g performance
To set the CPU governor to performance for all cores:
   for ((i=0;i<$(nproc --all);i++)); do sudo cpufreq-set -c $i -r -g performance; done
You can then verify that the CPU governor has been set by running the command:
   cpufreq-info
Thread Priority Scheduling
UHD Warning:
To address this issue, non-privileged (non-root) users need to be given special permission to change the scheduling priority. This can be enabled by creating a group usrp, adding your user to it, and then appending the line @usrp - rtprio 99 to the file /etc/security/limits.conf.
   sudo groupadd usrp
   sudo usermod -aG usrp $USER
Then add the line below to end of the file /etc/security/limits.conf:
   @usrp - rtprio  99
You must log out and log back into the account for the settings to take effect. In most Linux distributions, a list of groups and group members can be found in the /etc/group file.
Adjust Network Buffers
This applies to USRP devices connected via Ethernet, such as the N200, N210, N300, N310, N320, N321, X300, X310, E320.
Note that these settings will not persist across a reboot.
   sudo sysctl -w net.core.wmem_max=33554432
   sudo sysctl -w net.core.wmem_default=33554432
   sudo sysctl -w net.core.rmem_default=33554432
Adjust Ethernet MTU
This applies to Ethernet connected USRPs (N2xx, N3xx, X3xx, E320).
For 1 Gigabit connections, the MTU should be set to 1500.
For 10 Gigabit connections, the MTU should be set to 9000.
It is important to set the value and not leave it is automatic
Increasing Ring Buffers
This applies to Ethernet connected USRPs using a 10 Gb interface (X3xx, N3xx, E320).
Increasing the Ring Buffers on the NIC may help prevent flow control errors at higher rates.
DPDK
DPDK is supported on N3xx, X3xx and E320 USRPs. DPDK replaces the traditional Linux networking stack with a low overhead user-land based driver. Additional details of using DPDK can be found in the UHD Manual located at the following link: https://files.ettus.com/manual/page_dpdk.html
Disable KPTI Protections for Spectre/Meltdown
In some cases, disabling the KPTI protections for the Linux Kernel can increase performance by 10-15%. It is important to note the ramification making this modification can have. This modification is only recommended for systems that absolutely require the best performance and are not connected to the internet.
Disabling KPTI protections can be done by adding the lines below to your /etc/default/grub file at GRUB_CMDLINE_LINUX_DEFAULT=""
   pti=off spectre_v2=off l1tf=off nospec_store_bypass_disable no_stf_barrier
After modifying the grub file, run the following command to update your configuration and reboot:
   sudo update-grub
